13 Tiguan LED Bulbs
Kram769
C?ID=376956
Hi my bulbs started burning out so I replaced all the rear bulbs with Sylvania LEDs (Brake, Turn Signals, Parking, Tail, Back-up and Plate).
I was able to find on Byte 17 to disable Licence Plate Lights Pulse Width Modulation
However I am still getting bulb out for the others. I saw a few posts similar on other models and they all say to go to Byte 18 to turn off Cold Diagnosis. When I go to Byte 18 on mine all it shows is NAR, however I noticed if I go to LCode no.2 Byte 18 looks similar to screenshots of others but there is no text next to the Bits.
So my question is there a way to turn on text in LCode no.2 if not, are these options the Cold Diagnosis toggles?
Wednesday,07,August,2019,21:22:25:57042
VIN: WVGAV3AX6DW626993   License Plate:
Mileage: 118770km-73800mi   Repair Order:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4C 52 53 56 62 72 77
VIN: WVGAV3AX6DW626993   Mileage: 118770km-73800miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 997 027 M    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 06 0396
   Revision: P3H07---    Serial number:
   Coding: 0423010A19070160
   Shop #: WSC 54991 001 1048576
   VCID: 3FDB43858B7051DFF33-806A
   Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
   Component: AQ 250 6F           2253
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 074B9B659320D91F8B3-8052
   Part No SW: 5N0 614 109 BD    HW: 5N0 614 109 BD
   Component: J104   C6 450M VDD6 0011
   Revision: --H07---    Serial number: 00000007016804
   Coding: 0005158
   VCID: 6E85CEC19C9AE857285-803A
   Part No SW: 561 907 426     HW: 561 907 426
   Component: AC Manuell    H02 0101
   Revision: 00001K07
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 58E98819029E86E7D29-800C
   Part No SW: 5K0 937 084 J    HW: 5K0 937 084 J
   Component: BCM PQ35 B    021 0068
   Revision: BG021001
   Coding: 6F180A3B84232EC4008800C1140004444801AD86524D8960648000000040
   Shop #: WSC 33361 790 00999
   VCID: 392F2D9D99547FEFCD7-806C
   Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS 070513 03  32  0010
   Coding: 009795
                    Fault Frequency: 34
                    Reset counter: 254
                    Mileage: 110691 km
                    Date: 2013.07.28
                    Time: 05:34:09
                    Voltage: 12.60 V
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 66
                    Mileage: 37663 km
                    Date: 2016.06.17
                    Time: 00:00:04
                        Term 15 Off
                    Voltage: 12.60 V
01501 - Bulb for Blinkers; Rear Left (M6)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 214
                    Mileage: 118451 km
                    Date: 2013.12.16
                    Time: 08:12:13
                        Term 15 Off
                    Voltage: 12.65 V
                    Fault Frequency: 20
                    Reset counter: 214
                    Mileage: 118451 km
                    Date: 2013.12.16
                    Time: 08:30:06
                        Term 15 Off
                    Voltage: 12.55 V
                    Reset counter: 201
                    Mileage: 118451 km
                    Date: 2013.12.16
                    Time: 08:20:45
                    Voltage: 12.40 V
01800 - Light Switch (E1)
                    Fault Frequency: 12
                    Reset counter: 234
                    Mileage: 115810 km
                    Date: 2013.11.08
                    Time: 10:18:08
                    Voltage: 14.15 V
   Part No SW: 5N0 959 655 AD    HW: 5N0 959 655 AD
   Component: J234__207 VW10 HI   2318
   Revision: 27019000    Serial number: 003N4P9FBZQM
   Coding: 0012343
   VCID: 7F5B0385CBF091DFB33-802A
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 0000000000DJLF
   Subsystem 3 - Serial number: 0014.02.130000300000640031ÿ†63
   Subsystem 4 - Serial number: 640031ÿ†6332MTS6456511732ÿ†63
   Subsystem 5 - Serial number: 511732ÿ†6342MTS6658011732ÿ†63
   Subsystem 6 - Serial number: 011732ÿ†6351HTS67L0IRBKJ3ÿ†63
   Subsystem 7 - Serial number: IRBKJ3ÿ†6361HTS691JNRBKJAÿ†63
   Subsystem 8 - Serial number: NRBKJAÿ†63727TS6MT6ORBKR$ÿ†63
   Subsystem 9 - Serial number: ORBKR$ÿ†63827TS68IDORBKJEÿ
   Subsystem 10 - Serial number: ORBKJEÿ
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 110672 km
                    Date: 2013.07.28
                    Time: 02:11:57
   Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
   Revision: FF010042    Serial number: 20130511300686
   Coding: 198A140000
   VCID: 7CA1F489D6668AC7961-8028
   Component: E221__MFL-TAS  H31 0033
   Coding: 820000
147462 - Terminal 15
          B1148 12 [008] - Short to Plus
                    Reset counter: 254
                    Mileage: 72166 km
                    Date: 2017.08.15
                    Time: 14:08:58
   Part No SW: 5N0 920 973 B    HW: 5N0 920 973 B
   Component: KOMBI         H06 0705
   Coding: 211F01
   VCID: 33331FB5BBB885BF07B-8066
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 060513F1002413
   Coding: 356002
   VCID: 74B1DCA9FEB6C287DE1-8020
   Component: IMMO          H06 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC2D1ACF2047774D-803E
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0006953596
   Coding: 0004B4
   VCID: 38292899A2DE66E7329-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1504
   Serial number: 00000007886615
   Coding: 000490
   Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.285 1202
   Revision: 1BH04839    Serial number: 00131190153901
   Coding: 0000258
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0006966167
   Coding: 0004B4
   VCID: 392F2D9D99D47FEFCD7-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1504
   Serial number: 00000007883667
   Coding: 000490
   Revision:   H19       Serial number: 00000001006217
   Coding: 0026156
   VCID: 363526A1A44A9097205-8062
   Part No SW: 5N0 035 164 D    HW: 5N0 035 164 D
   Component: LOW NAR Tig   H02 0006
   Revision: -----06S    Serial number: VWZ4Z6N3557739
   Coding: 0500040004000C
   VCID: 2A0D02D16CF2C477B4D-807E
03138 - Input AUX IN
                    Reset counter: 31
                    Mileage: 17002 km
                    Date: 2015.03.14
                    Time: 21:10:24
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007664772905
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2D32919CD274F7C4D-806E
End----------(Elapsed Time: 01:13, VBatt start/end: 12.5V/12.5V)-----------
Saturday,10,August,2019,20:13:21:57042
Mileage: 119010km-73949mi   Repair Order:
VIN: WVGAV3AX6DW626993   Mileage: 119010km-73949miles
   Coding: 0000840
   Component: J104   C6 450M VDDB 0011
   Coding: 0005158
   Revision: 00001K07
   Coding: 0010001002
   Revision: BG021001
   Coding: 6F180A3B84232EC4008800C1140004444881AD86524D8920648000000040
   Coding: 009795
                    Fault Status: 01101000
                    Fault Frequency: 35
                    Reset counter: 217
                    Mileage: 110691 km
                    Date: 2013.07.28
                    Time: 05:34:09
                    Voltage: 12.60 V
                    Reset counter: 66
                    Mileage: 37663 km
                    Date: 2016.06.17
                    Time: 00:00:04
                        Term 15 Off
                    Voltage: 12.60 V
                    Fault Frequency: 14
                    Reset counter: 219
                    Mileage: 118451 km
                    Date: 2013.12.16
                    Time: 08:12:13
                        Term 15 Off
                    Voltage: 12.65 V
                    Fault Status: 00101010
                    Fault Frequency: 24
                    Reset counter: 4
                    Mileage: 118451 km
                    Date: 2013.12.16
                    Time: 08:30:06
                        Term 15 Off
                    Voltage: 12.55 V
                    Reset counter: 201
                    Mileage: 118451 km
                    Date: 2013.12.16
                    Time: 08:20:45
                    Voltage: 12.40 V
                    Fault Frequency: 12
                    Reset counter: 234
                    Mileage: 115810 km
                    Date: 2013.11.08
                    Time: 10:18:08
                    Voltage: 14.15 V
   Coding: 0012343
                    Mileage: 110672 km
                    Date: 2013.07.28
                    Time: 02:11:57
   Coding: 198A140000
   Coding: 820000
                    Reset counter: 4
                    Mileage: 72166 km
                    Date: 2017.08.15
                    Time: 14:08:58
   Coding: 211F01
   Coding: 356002
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
                    Reset counter: 31
                    Mileage: 17002 km
                    Date: 2015.03.14
                    Time: 21:10:24
End----------(Elapsed Time: 01:13, VBatt start/end: 12.6V/12.6V)-----------
Mari
C?ID=150535
Don't play around with byte 18 if you don't know what you are doing! Lots of people messed things up by changing byte 18.
Start with fixing Ignition switch...
MasterTommy
Amsterdam
C?ID=295586
This ^
And do all bulbs serve a dedicated function, or does (for example) some tail light bulbs double as brake light? In that case, PWM is the only way to realize that function, and you might want to have a second person in the car operate the lights while you visually observe if everything functions as it should, especially brightness difference between tail lights and brake lights.
Kram769
C?ID=376956
This ^
All the bulbs functions just fine, they are dimmer for tail lights and brighter for brake/turn.
I am just trying to turn off the Cold Diagnostics so that I can stop the bulbs flickering when starting the car and get rid of all the annoying messages on the dash.
m87a
Bosnia and Herzegovina
C?ID=156900
this can be done with vcp (reading and modifying eeprom values directly), not with vcds, trying different values for byte 18, experimenting, can brick your bcm...
