MY2017 Golf 1.4 TSI 92kW BMT Sport "R-Line" Hatchback 3-doors
darkchina811
ITALY
C?ID=333184
I realized I never published an autoscan of my car here. I retrofitted so much stuff that I will probably forget something :)
admaps can be found here:
https://www.dropbox.com/s/3u8au3o7kkgj2qx/dBGolf_logs.zip
unfortunately I do not have a backup of when the car was stock. well, I have it, but it's incomplete and it would end up in the Hall of Shame anyway :banghead:
everything is working fine, as you can see there are no errors in the autoscan.
I hope this will help other retrofitters :)
LIST OF OEM RETROFITS:
- spare tyre with jack and tools;
- GTI front bumper with LED fog lights;
- leather/cloth seats with ergoActive function for the driver's;
- heated seats;
- Webasto parking heater with remote control (this, together with heated seats, required replacing the Climatronic panel);
- heated windshield with bracket for A5 camera;
- auto dimming internal mirror;
- shark fin antenna for GSM and Webasto (also GPS, but not in use currently);
- illuminated door sills;
- adaptive cruise control (ACC) + front assist (this required replacing the steering wheel buttons and the front bumper carrier bar);
- active TPMS;
- doors entry LED lights;
- park assist (PLA) 3.0 (this required replacing the rear wheels ABS sensors);
- multifunction camera A5 (MFK) for lane assist, high beam assist and traffic sign recognition;
- blind spot detection (BSD), although the indicator LEDs are not the OEM;
- GTE LED headlights (this required removing the manual headlight height level and installing the 55 module for automatic level);
- cluster illumination dimmer;
- washer fluid level sensor;
- heated washer jets;
- Comfort telephone interface with antenna baseplate inside the center console armrest;
- 8" display for the infotainment, Golf 7.5 "facelift" version;
- USB hub;
- headlight switch with "AUTO" position;
- rain, light and humidity sensor (RLFS);
- alarm sensor + alarm siren + steel cage for the ECU;
- ESP deactivation button;
- parking camera "low" inside the rear VW emblem;
- BCM and Gateway HIGH
- telematics buttons on the roof (these were custom modified to open my gate and garage, I don't have the telematics module)
LIST OF NON-OEM RETROFITS/INSTALLATIONS:
- illumination of the front storage compartment in the center console;
- LED bulbs for the dash drawer and the trunk (these were the only halogen interior bulbs);
- S&S deactivation module (this is a true blessing);
- anti-glare exterior mirrors;
- 70Ah/720A battery (stock was 59Ah/320A);
- HELIX/MATCH PP62DSP amplifier for the sound system;
- Coral MT25 tweeters instead of the horrible OEM loud-hailers;
- I painted red the front brake calipers;
- illuminated gearshift knob;
- Yi Mini dashcam;
modules 01 and 5F had the SW updated to the most recent version;
LIST OF FUTURE PLANNED RETROFITS:
- dynamic chassis control (DCC), I already started sourcing parts;
- I know it's easier to retrofit bigger front brake discs by just replacing the caliper bracket, so I will do that when it's time to replace the brake pads;
- I would like to paint red the rear brake calipers as well, but I am a little afraid of removing them because of the electronic parking brake;
- I might as well replace the reverse gear bulb, which is the only halogen exterior light. I just always forget :banghead:
Thursday,01,August,2019,17:21:07:06888
Dealer/Shop Name: dB
Workshop Code: 031 33097 006209
VIN: WVWZZZAUZHW0xxxxx   License Plate:
Mileage: 35451km-22028mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 18 19 3C 42 44 52 55 5F 65 A5
VIN: WVWZZZAUZHW0xxxxx   Mileage: 35451km-22028miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 4418
   Revision: R7H25---
   Coding: 0119003A23441D082000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001006
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B833BBF03045EDF0FB-803E
   CAN Converter 01:
   Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
   Component: ESC           H62 0637
   Revision: 00000000    Serial number: 91596000011507
   Coding: 01FA6AA1242219704779060841C62980562498E26082947314205008408903
   Shop #: WSC 33097 031 06209
   VCID: 74B120C35E3A8127DE1-8020
   Part No SW: 5G0 907 044 BM    HW: 5G0 907 044 BM
   Component: Climatronic   H04 1601
   Revision: 00001K08
   Coding: 00020004104411011105004200101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 73B323DF5B34861FC7B-8026
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Air quality sensor:
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Serial number: 01061633700891
   Coding: 00000966C20102F90B244080B11407281400000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 045170030E9AB1A7EE1-8050
   Component: WWS    160522  043 0551
   Serial number:         160601172917
   Coding: 0E4DFD
   Component: RLFS  024 0042
   Serial number: Y13M05D10H00M20S03S4
   Coding: 06A8DD
   Serial number: 000000000ZY15028208R
   Serial number: 00000000000030139763
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417617145
   Coding: 0271165041
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50F98C538A629D071A9-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
   Component: ACC3          H08 0390
   Serial number: 19021303030627
   Coding: 00000700FE030B
   ASAM Dataset: EV_ACCBoschMQB 001021
   ROD: EV_ACCBoschMQB_VW37.rod
   VCID: 3FDBBFEF27FC127FF33-806A
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Component: AirbagVW20    015 0388
   Serial number: 003F6R1V1W4Y
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 41DFB9175108648F857-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 35767000000432B44C1Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 358670000008B4C4DB17
   Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
   Serial number: 3516502BB205729313D3
   Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
   Serial number: 3526502AF2076340F201
   Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
   Serial number: 35565029B21160C1025X
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 13061608490829
   Coding: 0400
   VCID: 0D4755275DD0F0EFB1F-8058
   Part No SW: 5G1 920 750 B    HW: 5G1 920 750 B
   Component: KOMBI         303 8311
   Coding: 03A501806E8C000D02882B0F1401000000000000
   VCID: 26150A8BD866A3B7905-8072
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
   Component: STH-MQB       006 0069
   Coding: 1309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   VCID: 3537DDC715C0D82F29F-8060
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000180382
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0004271482
   Coding: 030100043F085700FB000258080F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CA108E3766AC967961-8028
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0038
   Serial number: 29140002632800044485
   Coding: 2C0000
   Serial number: 8442320304
   Component: HRE_Master    H11 0071
   Serial number: 0392234969
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C21C8E336EA0967D61-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H11 0071
   Serial number: 0381249049
   Coding: 020111
   Serial number: 300516EEU02971
   Coding: 003F0220D000040100001000
   VCID: 43D3B31F4B14769F97B-8016
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2DCEFB3CDE3757C4D-806E
   Serial number: 280516EER24731
   Coding: 003F0020DE00040100801000
   VCID: 42DDB61B540E7F979CD-8016
   Coding: 029A000001000000
   Shop #: WSC 00028 028 00068
   VCID: 75B71DC75540982FE9F-8020
   Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
   Component: MU-S--ER      710 0757
   Coding: 02730000AA0000005111000100080A031F0206D40120010003
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2C01F8A3C68A99E7461-8078
   Subsystem 1 - Part No SW: 5G6 919 605     HW: 5G6 919 605
   Component: ABT_Std-2  H50 8120
   Serial number: VWZ6ZHT1541317
   Serial number: 40000000018766
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E0C31EBAC1271E1-8060
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0060
   Serial number: 10000049677
   Coding: 0101010001020300010500010100000100
   ROD: EV_MFKBoschAU370.rod
End----------(Elapsed Time: 01:41, VBatt start/end: 12.3V/12.3V)-----------
Qassem
Kuwait
C?ID=325382
Great work and efforts, well done 👍🏻 enjoy it man
GeorgeWSR
Romania
Hello mate! I saw on your profile that you have done the retrofit from halogen headlights to gte 5ge941036 led headlights. Could you please tell if needs some coding after replacement or just the wiring? I kindly ask you to help me with a wiring diagram for the new 14 pins plug and please sorry that I reply on this thread but on that one, the reply is off or I can’t do that...please help me with these informations. Thank you very much in advice!
darkchina811
ITALY
C?ID=333184
well, you'll forgive me if I cut it short, but there's a reason if you cannot answer in the other thread. you need to prove you own a genuine VCDS cable.
of course there is a little coding involved and all adaptations for front lights in module 09 need to be adjusted. for the wiring diagrams, we all paid the price. buy one hour on erwin and print-to-PDF all schematics for your VIN. there will be a huge file called BASIC EQUIPMENT, this will have wiring for both halogens and GTE lights, then you can compare.
module 55 needs to be installed, together with the height sensor on the rear left suspension link.
Carolco
Spain
Hi.
Do you have manual or information for the retrofit of ergoactive seats?
darkchina811
ITALY
C?ID=333184
the ergoActive driver seat only requires power from fuse C45. if your regular seats are already heated you only need to add one wire from fuse C45 to pin 1 of the 10-pin seat connector. if the connector is 17-pin then power goes to pin 15.
if your seats are not heated you need to install the whole wiring loom, follow the guides for heated seats.
darkchina811
ITALY
C?ID=333184
UPDATE AS OF 06/19/2020
- spare tire with jack and tools;
- GTI front bumper with LED fog lights, GTD upper grille;
- leather/cloth ergoActive heated seats (this required the BCM to be upgraded to a MID+ version at least, I installed the HIGH);
- shark fin antenna for GSM and Webasto (also GPS, not in use);
- active TPMS (this required the Gateway to be upgraded to HIGH);
- park assist PLA 3.0 (this required replacing the rear wheels ABS sensors);
- multifunction camera A5 (MFK) for lane assist, high beam assist and traffic sign recognition (this required replacing the windshield, I chose the heated version. sun sensor on the dashboard was replaced as well);
- USB hub;
- rain, light and humidity sensor (RLFS, which allows closing windows when it rains);
- parking camera LOW inside the rear VW emblem;
- telematics buttons on the roof (these were custom modified to open my gate and garage, I don't have the telematics module);
- 312mm front braked discs instead of 288mm (this required replacing the caliper carriers);
- dfreeeze app control for the Webasto heater.
- whole DCC system has been retrofitted (this required replacing the front wheel bearings, including the housings with the lower swivel joints. some bolts/nuts need replacing too); it's 95% as OEM, it lacks only the Comfort entry in the Driving Profile Selection menu;
- wireless QI charger with antenna baseplate, incorporated in the OEM center console compartment; the whole thing is replaced. this sacrificed the AUX audio input, which I never used anyway. the antenna baseplate in the armrest has been disconnected but the USB port still works. actually now both USB ports work for sticks and CarPlay;
- illumination of the front storage compartment in the center console (I moved this from Terminal 15 to Terminal 58 so it stays off during the day);
- Yi Mini dashcam;
modules 01 and 5F had the SW updated to the most recent version.
- will soon upgrade the rear camera to the HIGH version with dynamic guide lines;
- I might as well replace the reverse gear bulb, which is the only halogen exterior light. I just always forget.
CURRENT ADMAPS:
https://www.dropbox.com/s/3qwgmfctw5y5nv3/dBGolf06192020.rar
CURRENT AUTOSCAN:
Friday,19,June,2020,21:55:20:06888
VCDS Version: 20.4.1.0  HEX-V2 CB: 0.4513.4
Workshop Code: 011 33097 006209
VIN: WVWZZZAUZHW0xxxxx   License Plate: DCCOK
Mileage: 38182km-23725mi   Repair Order:
Scan: 01 03 08 09 10 13 14 15 16 17 18 19 3C 42 44 52 55 5F 65 A5
   Revision: R7H25---
   VCID: 6B833BBF03045ED3969-803E
   CAN Converter 01:
   Coding: 01FA6AA1342219704779060841C62980562C98E26082947314205088408903
   VCID: 74B120C35E3A812B473-8020
   Revision: 00001K08
   VCID: 73B323DF5B3486135E9-8026
   Air quality sensor:
   VCID: 045170030E9AB1AB773-8050
   Coding: 0E4DFD
   Coding: 06A8DD
   Coding: 0271165041
   VCID: 50F98C538A629D0B83B-8004
   VCID: 3FDBBFEF27FC12736A1-806A
   Serial number: 13011641350610
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3829D4F302D2254BABB-806C
   VCID: 41DFB917510864831C5-8014
   Coding: 0400
   VCID: 0D4755275DD0F0E328D-8058
   Coding: 03A501807E8C000D02882B0F1401000000000000
   VCID: 26150A8BD866A3BB097-8072
   Coding: 1309
   VCID: 3537DDC715C0D823B0D-8060
   Coding: 030100043F085700FB000258880F00010001050000000000000000000000
   Shop #: WSC 33097 011 06209
   VCID: 7CA108E3766AC96B0F3-8028
   Coding: 2C0000
   Coding: 02011103
   VCID: 3C21C8E336EA096B4F3-8068
   Coding: 020111
   VCID: 43D3B31F4B1476930E9-8016
   Coding: 9307
   VCID: 3A2DCEFB3CDE375B5DF-806E
   VCID: 42DDB61B540E7F9B05F-8016
   Coding: 0292000001000000
   VCID: 75B71DC75540982370D-8020
   Coding: 02730000000000004111000100080A239F0206D40120010003
   VCID: 2C01F8A3C68A99EBDF3-8078
   VCID: 3431E0C31EBAC12B873-8060
End----------(Elapsed Time: 01:43, VBatt start/end: 12.6V/12.6V)-----------
CURRENT AUTOSCAN:
All those retrofits and not a single fault code in your scan. :thumbs:
darkchina811
ITALY
C?ID=333184
sounds like I kick ass :D I take it as a compliment :D
darkchina811
ITALY
C?ID=333184
updated autoscan after rear camera upgrade from LOW to HIGH :)
Wednesday,22,July,2020,23:15:51:06888
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4513.4
Mileage: 39890km-24786mi   Repair Order:
Scan: 01 03 08 09 10 13 14 15 16 17 18 19 3C 42 44 52 55 5F 65 6C
          A5
VIN: WVWZZZAUZHW0xxxxx   Mileage: 39890km-24786miles
   Revision: R7H25---
   CAN Converter 01:
Address 03: ABS Brakes (J104)       Labels:. User\5Q0-614-517-CC.lbl
   Revision: 00001K08
   Air quality sensor:
   Coding: 0E4DFD
   Coding: 06A8DD
   Coding: 0271565841
   Coding: 0400
   Coding: 1309
   Coding: 2C0000
   Coding: 02011103
   Coding: 020111
   Coding: 003F0220D000040100001001
   Coding: 9307
   Coding: 003F0020DE00040100801001
   Coding: 02730000000000004111000100080A239F0206C40120010003
   Part No SW: 5Q0 980 568 A    HW: 5Q0 980 568 B
   Component: RVC Compact+  H09 0180
   Coding: 01844201C2002013000040
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
   ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW37.rod
   VCID: 3B23CBFF33E40E53469-806E
End----------(Elapsed Time: 01:45, VBatt start/end: 12.1V/12.1V)-----------
darkchina811
ITALY
C?ID=333184
updated autoscan after DC/AC power inverter retrofit :)
Sunday,02,August,2020,21:20:41:06888
Scan: 01 03 08 09 10 13 14 15 16 17 18 19 3C 42 44 52 55 5F 65 6C A5
VIN: WVWZZZAUZHW0xxxxx   Mileage: 40654km-25261miles
   Revision: R7H25---
   CAN Converter 01:
Readiness: 1110 0001
   Revision: 00001K08
   Air quality sensor:
   Coding: 0E4DFD
   Coding: 06A8DD
   Coding: 0271565841
   Coding: 0400
   Coding: 1309
   Coding: 0B0100043F085701FB000258880F00010001050000000000000000000000
   Coding: 2C0000
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 F    HW: 5Q0 907 155 F
   Component: U13DCAC  H27 0810
   Serial number: 6072417
   Coding: 02011103
   Coding: 020111
   Coding: 9307
End----------(Elapsed Time: 01:47, VBatt start/end: 12.2V/12.1V)-----------
darkchina811
ITALY
C?ID=333184
updated autoscan after Discover Media navigation unit retrofit :)
actual admaps are here:
https://www.dropbox.com/s/xfs2foalv7xgthv/dBGolf_15MAY2021.zip
Saturday,15,May,2021,15:03:24:06888
          A5
VIN: WVWZZZAUZHW0xxxxx   Mileage: 62047km-38554miles
   Revision: R7H25---
   VCID: 6B833BBF03045ED34A1-803E
   ROD: EV_Brake1UDSContiMK100IPB_035.rod
   VCID: 74B120C35E3A812B9BB-8020
   Revision: 00001K08
   VCID: 73B323DF5B348613821-8026
   Air quality sensor:
   VCID: 045170030E9AB1ABABB-8050
   Coding: 0E4DFD
   Coding: 06A8DD
   Coding: 0271565841
   VCID: 50F98C538A629D0B5F3-8004
   VCID: 3FDBBFEF27FC1273B69-806A
   VCID: 3829D4F302D2254B773-806C
   VCID: 41DFB91751086483C0D-8014
   Coding: 0400
   VCID: 0D4755275DD0F0E3F45-8058
   Coding: 03A501807E8C000D02806F0F1401000000000000
   VCID: 26150A8BD866A3BBD5F-8072
   Coding: 1309
   VCID: 3537DDC715C0D8236C5-8060
   Auxiliary heating remote control:
   VCID: 7CA108E3766AC96BD3B-8028
   Generator:
   Coding: 2C0000
   Inverter for electrical outlet:
   Coding: 02011103
   VCID: 3C21C8E336EA096B93B-8068
   Coding: 020111
   VCID: 43D3B31F4B147693D21-8016
   Coding: 9307
   VCID: 3A2DCEFB3CDE375B817-806E
   VCID: 42DDB61B540E7F9BD97-8016
   VCID: 75B71DC755409823AC5-8020
   Part No SW: 3Q0 035 846 A    HW: 3Q0 035 846 A
   Component: MU-S-N-ER     840 0764
   Coding: 02730001000000004111000100080A231F0206C401200100C7
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2F3BEFAFF79CE2F3269-807A
   Subsystem 2 - Part No SW: 5NA 919 866 BG    HW: -----------
   Component: ECE AS 2021  --- 1520
   VCID: 3431E0C31EBAC12B5BB-8060
   VCID: 3B23CBFF33E40E539A1-806E
   Coding: 0101010001020306020500010100000100
End----(Elapsed Time: 01:52, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
