Central Electrics Gremlins
   #41
Tbez
C?ID=377106
Progress!!
Well Gents, I drove the car around today doing figure-8's and the fault light on the dash went out. I then checked meas blocks for G85 sensor and was able to see the steering angle move in real time. I then went through the calibration procedure and everything came up aces! I drove the car around a bit more just to make sure things stayed error free and then ran another scan. Everything comes up clean except the number plate fault (01504). I've been searching forums for some clue as to what may be causing that but am not finding anything consistent or conclusive. I would greatly appreciate and insight into that fault. Latest Autoscan is below. Thanks!
Wednesday,21,August,2019,18:45:53:23170
VIN: WAULC68E05A114733   License Plate: TONY A4
Mileage: 274950km-170846mi   Repair Order: 8-20-19 Scan 2 after driving and g85 calibration-original BCM
          67 69 75 76 77
VIN: WAULC68E05A114733   Mileage: 274950km-170846miles
Address 01: Engine        Labels: 06B-909-518-AMB.lbl
   Part No SW: 8E0 909 518 BC    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0020
   Revision: 00000000    Serial number: AUZ6Z0D0371349
   Coding: 0016751
   Shop #: WSC 11111 111 45799
   VCID: 72BDDAB038BA89B7CCD-5160
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 8E0 927 156 AA
   Component: AG5 01V 1.8l5VT USA 0505
   Coding: 0001002
   Shop #: WSC 06325 000 00000
   VCID: 6D87C9CC2184564F11F-5160
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      4529
   Coding: 04277
   Shop #: WSC 12345
   VCID: 2615F6E0C1F2A517905-51A8
   Part No: 8E0 820 043 AD
   Component:   A4 Klimaautomat   1424
   Coding: 00000
   Shop #: WSC 06325
   VCID: 6393AFF4F240103FB7B-513C
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  USA 0517
   Coding: 00003
   Shop #: WSC 11111
   VCID: 353721AC0C54DE8F29F-4B00
            57-00 - Electric Circuit Failure
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 K
   Component: Airbag 8.4EP        1001
   Coding: 0010607
   VCID: 3FDB43843B6814DFF33-5184
   Part No: 8E0 953 549 N
   Component: Lenks·ulenmodul     0611
   Coding: 01041
   Shop #: WSC 11111
   VCID: 3E253E8039621DD7F85-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 950 P
   Component: KOMBI+WEGFAHRS. RB4 D42
   Coding: 01231
   Shop #: WSC 03131
   VCID: 363526A01152D597205-5160
   WAULC68E05A114733     AUZ6Z0D0371349
   Part No: 8E0 959 433 BB
   Component: Komfortger·t T7B    1612
   Coding: 11788
   Shop #: WSC 06325
   VCID: 72BDDAB03DBA89B7CCD-4B00
   Subsystem 1 - Part No: 8E1959801
   Component: Tırsteuer.FS BRM 0205
   Subsystem 2 - Part No: 8E1959802E
   Component: Tırsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8E0959801A
   Component: Tırsteuer.HL BRM 0205
   Subsystem 4 - Part No: 8E0959802A
   Component: Tırsteuer.HR BRM 0205
End----------(Elapsed Time: 05:46, VBatt start/end: 12.8V/12.6V)-----------
   #42
   Coding: 00003
   Shop #: WSC 11111
Does the light work? Is the correct type of bulb installed?
Gone But Not Forgotten
Corrosion in bulb socket from water ingress or cracked lens, damaged wire harness at chafe point to deck?
Tbez
C?ID=377106
Hi, the light does not work and I did replace bulbs. I'll poke around in there tomorrow and post update.
   #45
Jef
HQ
J519 - T32b/6 (grey connector station) - grey wire 0.35mm² - tail lights - blue wire 0.35mm² - grounded
Not much there to check.
   #46
Tbez
C?ID=377106
Phhhht...
Well the good news is that I've fixed the license plate issue and just about everything else that I'm capable of fixing. The bad news is that the gremlins still live. The G85 fault is back and I've been unable to clear it. I'm going to get the car into a highly qualified mechanic and get a thorough diagnoses so I can decide if the car is worth keeping. Latest scan is below just for grins.
:banghead:
          67 69 75 76 77
VIN: WAULC68E05A114733   Mileage: 274960km-170852miles
   Coding: 0016751
   Coding: 0001002
   Coding: 04277
   Shop #: WSC 12345
            35-00 - -
   Coding: 00000
   Shop #: WSC 06325
   Coding: 00003
   Shop #: WSC 11111
   Coding: 0010607
   Coding: 01041
   Shop #: WSC 11111
   Coding: 01231
   Shop #: WSC 03131
   Coding: 11788
   Shop #: WSC 06325
End----------(Elapsed Time: 06:17, VBatt start/end: 12.5V/12.5V)-----------
