GOLF 7.5 change halogen headlights to Led, Leuchte changed error
energy22
Spain
Hi, I need urgent help
I have changed my halogen headlights of golf 7.5 for a full LED with DLA (although I do not have a windshield camera) that I have achieved second hand, and I have coding problems do not go as expected:
Lighthouse 5G1941081 and 82.
BCM M + 5q0937084CP
4B. 3Q090733C
Existing Gateway High
The wiring change has been made according to the manufacturer's scheme, and all units have been coded.
The problem is that the high beam comes on steady without hitting the steering wheel controls, that said I deactivate BCM leuchte 8 and 9 and the low beam lights go out, so I have the high beams on Leuchte 6 and 7, I have a crossing of Leuchte, what may it be due to
a cable crossed in the wiring, or inside the headlight if it was manipulated, could it be?
I got a temporary solution that is activating the lichfunktion A8 and A9 by putting Fernlicht Links and Rechts (instead of Abblendlich links and rechts) and now I have no errors in BCM, in the FIS there are no mistakes either and in the 4B the only mistake is that no He lets me make the basic adjustment, although when I flurry, I turn off the lights for 1 second and turn them on again, and I still need the turning lights and coming home, but those must be activated in 4B.
Someone with experience can guide me please !!!
thank you.
siLc
Tallinn, Estonia
C?ID=330192
Also admap of the BCM because that holds the real important info in this case.
energy22
Spain
This afternoon I realized that one of the cables was changed since the original scheme allows 2 options according to the equalization, of Pin 11 of the right headlight was set at 39 instead of 2 (Socket B), and I removed the existing X-shaped junction, but that has not solved the problem and the lights remain the same. And now they are crossed inside the same headlamp
Now it's like that.
Leuchte 6 and 7 activate high beams (backwards)
Leuchte 8 and 9 activate low beams. (Reversed)
Say that for the current wiring to Led we take advantage of the existing halogen.
I can attach the schemes if necessary ..
Tomorrow I pass you the Admap !!!
energy22
Spain
Modulo 9
Fecha: 2019-08-13 17:44
    Numero de bastidor: WVWZZZAUZJP008993
    Coche: Volkswagen Golf
    Año: 2018
    Tipo de carrocería: 5-dr hatchback
    Motor: DADA 110 kW (150 HP) 1.5 l
    Kilometraje: 11157 KM
Copia de seguridad
    Unidad de Control: 09 Centralita electrónica
    Descripción del sistema: BCM MQBAB M+
    Número de software: 5Q0937084CP
    Versión de software: 0253
    Número de hardware: 5Q0937084CF
    Versión de Hardware: H36
    Número de serie: 01001716100946
    Nombre ODX: EV_BCMMQB
    Versión ODX: 018001
    Nombre de copia de seguridad: modulo09 130819
    Codificación extendida:
        000000000000000000000000000000000000000000000000000000000000
    Sub sistemas:
        Sub sistema: WWS    170508
        Codificación extendida: 0E4DDD
        Sub sistema: RLHS
        Codificación extendida: 00A8DD
    Adaptaciones:
        Leuchte 0 BLK VL B36:
            Lasttyp 0:
                inactivo
            Lampendefektbit Position 0:
            Fehlerort mittleres Byte DTC-DFCC 0:
            Lichtfunktion A 0:
                nicht aktiv
            Lichtfunktion B 0:
                nicht aktiv
            Dimmwert AB 0:
            Lichtansteuerung HD AB 0:
                always
            Lichtfunktion C 0:
                nicht aktiv
            Lichtfunktion D 0:
                nicht aktiv
            Dimmwert CD 0:
            Dimming Direction CD 0:
                maximize
            Lichtfunktion E 0:
                nicht aktiv
            Lichtfunktion F 0:
                nicht aktiv
            Dimmwert EF 0:
            Dimming Direction EF 0:
                maximize
            Lichtfunktion H 0:
                nicht aktiv
            Dimmwert GH 0:
            Dimming Direction GH 0:
                maximize
            Lichtfunktion G 0:
                nicht aktiv
        Leuchte1BLK VRB20:
            Lasttyp 1:
                inactivo
            Lampendefektbitposition 1:
            Fehlerort mittleres Byte DTC-DFCC 1:
            Lichtfunktion A 1:
                nicht aktiv
            Lichtfunktion B 1:
                nicht aktiv
            Dimmwert AB 1:
            Lichtansteuerung HD AB 1:
                always
            Lichtfunktion C 1:
                nicht aktiv
            Lichtfunktion D 1:
                nicht aktiv
            Dimmwert CD 1:
            Dimming Direction CD 1:
                maximize
            Lichtfunktion E 1:
                nicht aktiv
            Lichtfunktion F 1:
                nicht aktiv
            Dimmwert EF 1:
            Dimming Direction EF 1:
                maximize
            Lichtfunktion G 1:
                nicht aktiv
            Lichtfunktion H 1:
                nicht aktiv
            Dimmwert GH 1:
            Dimming Direction GH 1:
                maximize
        Leuchte2SL VLB10:
            Lasttyp 2:
                inactivo
            Lampendefektbitposition 2:
            Fehlerort mittleres Byte DTC-DFCC 2:
            Lichtfunktion A 2:
                nicht aktiv
            Lichtfunktion B 2:
                nicht aktiv
            Dimmwert AB 2:
            Lichtansteuerung HD AB 2:
                always
            Lichtfunktion C 2:
                nicht aktiv
            Lichtfunktion D 2:
                nicht aktiv
            Dimmwert CD 2:
            Dimming Direction CD 2:
                maximize
            Lichtfunktion E 2:
                nicht aktiv
            Lichtfunktion F 2:
                nicht aktiv
            Dimmwert EF 2:
            Dimming Direction EF 2:
                maximize
            Lichtfunktion G 2:
                nicht aktiv
            Lichtfunktion H 2:
                nicht aktiv
            Dimmwert GH 2:
            Dimming Direction GH 2:
                maximize
        Leuchte3SL VRB21:
            Lasttyp 3:
                inactivo
            Lampendefektbitposition 3:
            Fehlerort mittleres Byte DTC-DFCC 3:
            Lichtfunktion A 3:
                nicht aktiv
            Lichtfunktion B 3:
                nicht aktiv
            Dimmwert AB 3:
            Lichtansteuerung HD AB 3:
                always
            Lichtfunktion C 3:
                nicht aktiv
            Lichtfunktion D 3:
                nicht aktiv
            Dimmwert CD 3:
            Dimming Direction CD 3:
                maximize
            Lichtfunktion E 3:
                nicht aktiv
            Lichtfunktion F 3:
                nicht aktiv
            Dimmwert EF 3:
            Dimming Direction EF 3:
                maximize
            Lichtfunktion G 3:
                nicht aktiv
            Lichtfunktion H 3:
                nicht aktiv
            Dimmwert GH 3:
            Dimming Direction GH 3:
                maximize
        Leuchte4TFL LB4:
            Lasttyp 4:
                inactivo
            Lampendefektbitposition 4:
            Fehlerort mittleres Byte DTC-DFCC 4:
            Lichtfunktion A 4:
                nicht aktiv
            Lichtfunktion B 4:
                nicht aktiv
            Dimmwert AB 4:
            Lichtansteuerung HD AB 4:
                always
            Lichtfunktion C 4:
                nicht aktiv
            Lichtfunktion D 4:
                nicht aktiv
            Dimmwert CD 4:
            Dimming Direction CD 4:
                maximize
            Lichtfunktion E 4:
                nicht aktiv
            Lichtfunktion F 4:
                nicht aktiv
            Dimmwert EF 4:
            Dimming Direction EF 4:
                maximize
            Lichtfunktion G 4:
                nicht aktiv
            Lichtfunktion H 4:
                nicht aktiv
            Dimmwert GH 4:
            Dimming Direction GH 4:
                maximize
        Leuchte5 TFL RB32:
            Lasttyp 5:
                inactivo
            Lampendefektbitposition 5:
            Fehlerort mittleres Byte DTC-DFCC 5:
            Lichtfunktion A 5:
                nicht aktiv
            Lichtfunktion B 5:
                nicht aktiv
            Dimmwert AB 5:
            Lichtansteuerung HD AB 5:
                always
            Lichtfunktion C 5:
                nicht aktiv
            Lichtfunktion D 5:
                nicht aktiv
            Dimmwert CD 5:
            Dimming Direction CD 5:
                maximize
            Lichtfunktion E 5:
                nicht aktiv
            Lichtfunktion F 5:
                nicht aktiv
            Dimmwert EF 5:
            Dimming Direction EF 5:
                maximize
            Lichtfunktion G 5:
                nicht aktiv
            Lichtfunktion H 5:
                nicht aktiv
            Dimmwert GH 5:
            Dimming Direction GH 5:
                maximize
        Leuchte6ABL LC5:
            Lasttyp 6:
                5 - LED Abblendlicht
            Lampendefektbitposition 6:
                36
            Fehlerort mittleres Byte DTC-DFCC 6:
                1a
            Lichtfunktion A 6:
                Fernlicht links
            Lichtfunktion B 6:
                Lichthupe generell
            Dimmwert AB 6:
                127
            Lichtansteuerung HD AB 6:
                always
            Lichtfunktion C 6:
                Coming Home oder Leaving Home aktiv
            Lichtfunktion D 6:
                nicht aktiv
            Dimmwert CD 6:
                127
            Dimming Direction CD 6:
                maximize
            Lichtfunktion E 6:
                nicht aktiv
            Lichtfunktion F 6:
                nicht aktiv
            Dimmwert EF 6:
            Dimming Direction EF 6:
                maximize
            Lichtfunktion G 6:
                nicht aktiv
            Lichtfunktion H 6:
                nicht aktiv
            Dimmwert GH 6:
            Dimming Direction GH 6:
                maximize
        Leuchte7ABL RB1:
            Lasttyp 7:
            Lampendefektbitposition 7:
                40
            Fehlerort mittleres Byte DTC-DFCC 7:
                1b
            Lichtfunktion A 7:
                Fernlicht rechts
            Lichtfunktion B 7:
                Lichthupe generell
            Dimmwert AB 7:
                127
            Lichtansteuerung HD AB 7:
                always
            Lichtfunktion C 7:
            Lichtfunktion D 7:
                nicht aktiv
            Dimmwert CD 7:
                127
            Dimming Direction CD 7:
                maximize
            Lichtfunktion E 7:
                nicht aktiv
            Lichtfunktion F 7:
                nicht aktiv
            Dimmwert EF 7:
            Dimming Direction EF 7:
                maximize
            Lichtfunktion G 7:
                nicht aktiv
            Lichtfunktion H 7:
                nicht aktiv
            Dimmwert GH 7:
            Dimming Direction GH 7:
                maximize
        Leuchte8FL LB39:
            Lasttyp 8:
            Lampendefektbitposition 8:
                44
            Fehlerort mittleres Byte DTC-DFCC 8:
                4b
            Lichtfunktion A 8:
                Versorgungsbedarf der LCM Module
            Lichtfunktion B 8:
                nicht aktiv
            Dimmwert AB 8:
                127
            Lichtansteuerung HD AB 8:
                always
            Lichtfunktion C 8:
                nicht aktiv
            Lichtfunktion D 8:
                Parklicht rechts
            Dimmwert CD 8:
                127
            Dimming Direction CD 8:
                maximize
            Lichtfunktion E 8:
                nicht aktiv
            Lichtfunktion F 8:
                nicht aktiv
            Dimmwert EF 8:
            Dimming Direction EF 8:
                maximize
            Lichtfunktion G 8:
                nicht aktiv
            Lichtfunktion H 8:
                nicht aktiv
            Dimmwert GH 8:
            Dimming Direction GH 8:
                maximize
        Leuchte9FL RB2:
            Lasttyp 9:
            Lampendefektbitposition 9:
                3a
            Fehlerort mittleres Byte DTC-DFCC 9:
                49
            Lichtfunktion A 9:
            Lichtfunktion B 9:
                nicht aktiv
            Dimmwert AB 9:
                127
            Lichtansteuerung HD AB 9:
                always
            Lichtfunktion C 9:
                nicht aktiv
            Lichtfunktion D 9:
                Parklicht rechts
            Dimmwert CD 9:
                127
            Dimming Direction CD 9:
                maximize
            Lichtfunktion E 9:
                nicht aktiv
            Lichtfunktion F 9:
                nicht aktiv
            Dimmwert EF 9:
            Dimming Direction EF 9:
                maximize
            Lichtfunktion G 9:
                nicht aktiv
            Lichtfunktion H 9:
                nicht aktiv
            Dimmwert GH 9:
            Dimming Direction GH 9:
                maximize
        Leuchte10SHUTTER LB23:
            Lasttyp 10:
                inactivo
            Lampendefektbitposition 10:
            Fehlerort mittleres Byte DTC-DFCC 10:
            Lichtfunktion A 10:
                nicht aktiv
            Lichtfunktion B 10:
                nicht aktiv
            Dimmwert AB 10:
            Lichtansteuerung HD AB 10:
                always
            Lichtfunktion C 10:
                nicht aktiv
            Lichtfunktion D 10:
                nicht aktiv
            Dimmwert CD 10:
            Dimming Direction CD 10:
                maximize
            Lichtfunktion E 10:
                nicht aktiv
            Lichtfunktion F 10:
                nicht aktiv
            Dimmwert EF 10:
            Dimming Direction EF 10:
                maximize
            Lichtfunktion G 10:
                nicht aktiv
            Lichtfunktion H 10:
                nicht aktiv
            Dimmwert GH 10:
            Dimming Direction GH 10:
                maximize
        Leuchte11SHUTTER RB22:
            Lasttyp 11:
                inactivo
            Lampendefektbitposition 11:
            Fehlerort mittleres Byte DTC-DFCC 11:
            Lichtfunktion A 11:
                nicht aktiv
            Lichtfunktion B 11:
                nicht aktiv
            Dimmwert AB 11:
            Lichtansteuerung HD AB 11:
                always
            Lichtfunktion C 11:
                nicht aktiv
            Lichtfunktion D 11:
                nicht aktiv
            Dimmwert CD 11:
            Dimming Direction CD 11:
                maximize
            Lichtfunktion E 11:
                nicht aktiv
            Lichtfunktion F 11:
                nicht aktiv
            Dimmwert EF 11:
            Dimming Direction EF 11:
                maximize
            Lichtfunktion G 11:
                nicht aktiv
            Lichtfunktion H 11:
                nicht aktiv
            Dimmwert GH 11:
            Dimming Direction GH 11:
                maximize
        Leuchte12NL LB45:
            Lasttyp 12:
                10 - allgemeine Scheinwerfer
            Lampendefektbitposition 12:
                38
            Fehlerort mittleres Byte DTC-DFCC 12:
                22
            Lichtfunktion A 12:
                Nebellicht links
            Lichtfunktion B 12:
                nicht aktiv
            Dimmwert AB 12:
                100
            Lichtansteuerung HD AB 12:
                always
            Lichtfunktion C 12:
                nicht aktiv
            Lichtfunktion D 12:
                nicht aktiv
            Dimmwert CD 12:
            Dimming Direction CD 12:
                maximize
            Lichtfunktion E 12:
                nicht aktiv
            Lichtfunktion F 12:
                nicht aktiv
            Dimmwert EF 12:
            Dimming Direction EF 12:
                maximize
            Lichtfunktion G 12:
                nicht aktiv
            Lichtfunktion H 12:
                nicht aktiv
            Dimmwert GH 12:
            Dimming Direction GH 12:
                maximize
        Leuchte13NL RB5:
            Lasttyp 13:
            Lampendefektbitposition 13:
                42
            Fehlerort mittleres Byte DTC-DFCC 13:
                23
            Lichtfunktion A 13:
                Nebellicht rechts
            Lichtfunktion B 13:
                nicht aktiv
            Dimmwert AB 13:
                100
            Lichtansteuerung HD AB 13:
                always
            Lichtfunktion C 13:
                nicht aktiv
            Lichtfunktion D 13:
                nicht aktiv
            Dimmwert CD 13:
            Dimming Direction CD 13:
                maximize
            Lichtfunktion E 13:
                nicht aktiv
            Lichtfunktion F 13:
                nicht aktiv
            Dimmwert EF 13:
            Dimming Direction EF 13:
                maximize
            Lichtfunktion G 13:
                nicht aktiv
            Lichtfunktion H 13:
                nicht aktiv
            Dimmwert GH 13:
            Dimming Direction GH 13:
                maximize
        Leuchte 35 LED Warnblinktaster C48:
            Lasttyp 15:
                41 - LED Kleinleistung
            Lampendefektbitposition 15:
            Fehlerort mittleres Byte DTC-DFCC 15:
                63
            Lichtfunktion A 15:
                nicht_definiert_4C
            Lichtfunktion B 15:
                nicht aktiv
            Dimmwert AB 15:
                100
            Lichtansteuerung HD AB 15:
                always
            Lichtfunktion C 15:
                nicht aktiv
            Lichtfunktion D 15:
                nicht aktiv
            Dimmwert CD 15:
            Dimming Direction CD 15:
                maximize
            Lichtfunktion E 15:
                nicht aktiv
            Lichtfunktion F 15:
                nicht aktiv
            Dimmwert EF 15:
            Dimming Direction EF 15:
                maximize
            Lichtfunktion G 15:
                nicht aktiv
            Lichtfunktion H 15:
                nicht aktiv
            Dimmwert GH 15:
            Dimming Direction GH 15:
                maximize
        Leuchte16BLK SLB35BLK SL KC9:
            Lasttyp 16:
                43 - allgemeine LED
            Lampendefektbitposition 16:
            Fehlerort mittleres Byte DTC-DFCC 16:
                36
            Lichtfunktion A 16:
                Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
            Lichtfunktion B 16:
                Parklicht rechts
            Dimmwert AB 16:
                127
            Lichtansteuerung HD AB 16:
                only_if_closed
            Lichtfunktion C 16:
                nicht aktiv
            Lichtfunktion D 16:
                nicht aktiv
            Dimmwert CD 16:
            Dimming Direction CD 16:
                maximize
            Lichtfunktion E 16:
                nicht aktiv
            Lichtfunktion F 16:
                nicht aktiv
            Dimmwert EF 16:
            Dimming Direction EF 16:
                maximize
            Lichtfunktion G 16:
                nicht aktiv
            Lichtfunktion H 16:
                nicht aktiv
            Dimmwert GH 16:
            Dimming Direction GH 16:
                maximize
        Leuchte17TFL R BLK SRB3TFL R BLK SR KC3:
            Lasttyp 17:
                43 - allgemeine LED
            Lampendefektbitposition 17:
            Fehlerort mittleres Byte DTC-DFCC 17:
                35
            Lichtfunktion A 17:
            Lichtfunktion B 17:
                Parklicht links (beidseitiges Parklicht aktiviert li & re)
            Dimmwert AB 17:
                127
            Lichtansteuerung HD AB 17:
                only_if_closed
            Lichtfunktion C 17:
                nicht aktiv
            Lichtfunktion D 17:
                nicht aktiv
            Dimmwert CD 17:
            Dimming Direction CD 17:
                maximize
            Lichtfunktion E 17:
                nicht aktiv
            Lichtfunktion F 17:
                nicht aktiv
            Dimmwert EF 17:
            Dimming Direction EF 17:
                maximize
            Lichtfunktion G 17:
                nicht aktiv
            Lichtfunktion H 17:
                nicht aktiv
            Dimmwert GH 17:
            Dimming Direction GH 17:
                maximize
        Leuchte18BLK HLA60:
            Lasttyp 18:
                38 - LED Blinkleuchten
            Lampendefektbitposition 18:
                8
            Fehlerort mittleres Byte DTC-DFCC 18:
                16
            Lichtfunktion A 18:
                Blinken links Hellphase
            Lichtfunktion B 18:
                nicht aktiv
            Dimmwert AB 18:
                127
            Lichtansteuerung HD AB 18:
                always
            Lichtfunktion C 18:
                nicht aktiv
            Lichtfunktion D 18:
                nicht aktiv
            Dimmwert CD 18:
            Dimming Direction CD 18:
                maximize
            Lichtfunktion E 18:
                nicht aktiv
            Lichtfunktion F 18:
                nicht aktiv
            Dimmwert EF 18:
            Dimming Direction EF 18:
                maximize
            Lichtfunktion G 18:
                nicht aktiv
            Lichtfunktion H 18:
                nicht aktiv
            Dimmwert GH 18:
            Dimming Direction GH 18:
                maximize
        Leuchte19BLK HRC31:
            Lasttyp 19:
            Lampendefektbitposition 19:
                18
            Fehlerort mittleres Byte DTC-DFCC 19:
                18
            Lichtfunktion A 19:
                Blinken rechts Hellphase
            Lichtfunktion B 19:
                nicht aktiv
            Dimmwert AB 19:
                127
            Lichtansteuerung HD AB 19:
                always
            Lichtfunktion C 19:
                nicht aktiv
            Lichtfunktion D 19:
                nicht aktiv
            Dimmwert CD 19:
            Dimming Direction CD 19:
                maximize
            Lichtfunktion E 19:
                nicht aktiv
            Lichtfunktion F 19:
                nicht aktiv
            Dimmwert EF 19:
            Dimming Direction EF 19:
                maximize
            Lichtfunktion G 19:
                nicht aktiv
            Lichtfunktion H 19:
                nicht aktiv
            Dimmwert GH 19:
            Dimming Direction GH 19:
                maximize
        Leuchte20BR LA71:
            Lasttyp 20:
                43 - allgemeine LED
            Lampendefektbitposition 20:
                9
            Fehlerort mittleres Byte DTC-DFCC 20:
                2b
            Lichtfunktion A 20:
                Bremslicht
            Lichtfunktion B 20:
                nicht aktiv
            Dimmwert AB 20:
                127
            Lichtansteuerung HD AB 20:
                always
            Lichtfunktion C 20:
                nicht aktiv
            Lichtfunktion D 20:
                nicht aktiv
            Dimmwert CD 20:
            Dimming Direction CD 20:
                maximize
            Lichtfunktion E 20:
                nicht aktiv
            Lichtfunktion F 20:
                nicht aktiv
            Dimmwert EF 20:
            Dimming Direction EF 20:
                maximize
            Lichtfunktion G 20:
                nicht aktiv
            Lichtfunktion H 20:
                nicht aktiv
            Dimmwert GH 20:
            Dimming Direction GH 20:
                maximize
        Leuchte21BR RC8:
            Lasttyp 21:
                43 - allgemeine LED
            Lampendefektbitposition 21:
                19
            Fehlerort mittleres Byte DTC-DFCC 21:
                2d
            Lichtfunktion A 21:
                Bremslicht
            Lichtfunktion B 21:
                nicht aktiv
            Dimmwert AB 21:
                127
            Lichtansteuerung HD AB 21:
                always
            Lichtfunktion C 21:
                nicht aktiv
            Lichtfunktion D 21:
                nicht aktiv
            Dimmwert CD 21:
            Dimming Direction CD 21:
                maximize
            Lichtfunktion E 21:
                nicht aktiv
            Lichtfunktion F 21:
                nicht aktiv
            Dimmwert EF 21:
            Dimming Direction EF 21:
                maximize
            Lichtfunktion G 21:
                nicht aktiv
            Lichtfunktion H 21:
                nicht aktiv
            Dimmwert GH 21:
            Dimming Direction GH 21:
                maximize
        Leuchte22BR MA57:
            Lasttyp 22:
                42 - LED dritte Bremsleuchte
            Lampendefektbitposition 22:
                29
            Fehlerort mittleres Byte DTC-DFCC 22:
                2c
            Lichtfunktion A 22:
                Bremslicht
            Lichtfunktion B 22:
                Quittierungsfunktion 1
            Dimmwert AB 22:
                127
            Lichtansteuerung HD AB 22:
                always
            Lichtfunktion C 22:
                nicht aktiv
            Lichtfunktion D 22:
                nicht aktiv
            Dimmwert CD 22:
            Dimming Direction CD 22:
                maximize
            Lichtfunktion E 22:
                nicht aktiv
            Lichtfunktion F 22:
                nicht aktiv
            Dimmwert EF 22:
            Dimming Direction EF 22:
                maximize
            Lichtfunktion G 22:
                nicht aktiv
            Lichtfunktion H 22:
                nicht aktiv
            Dimmwert GH 22:
            Dimming Direction GH 22:
                maximize
        Leuchte23SL HLC10:
            Lasttyp 23:
                43 - allgemeine LED
            Lampendefektbitposition 23:
                a
            Fehlerort mittleres Byte DTC-DFCC 23:
                29
            Lichtfunktion A 23:
            Lichtfunktion B 23:
            Dimmwert AB 23:
                127
            Lichtansteuerung HD AB 23:
                always
            Lichtfunktion C 23:
                nicht aktiv
            Lichtfunktion D 23:
                nicht aktiv
            Dimmwert CD 23:
            Dimming Direction CD 23:
                maximize
            Lichtfunktion E 23:
                nicht aktiv
            Lichtfunktion F 23:
                nicht aktiv
            Dimmwert EF 23:
            Dimming Direction EF 23:
                maximize
            Lichtfunktion G 23:
                nicht aktiv
            Lichtfunktion H 23:
                nicht aktiv
            Dimmwert GH 23:
            Dimming Direction GH 23:
                maximize
        Leuchte24SL HRA65:
            Lasttyp 24:
                43 - allgemeine LED
            Lampendefektbitposition 24:
                1a
            Fehlerort mittleres Byte DTC-DFCC 24:
                2a
            Lichtfunktion A 24:
            Lichtfunktion B 24:
                Parklicht rechts
            Dimmwert AB 24:
                127
            Lichtansteuerung HD AB 24:
                always
            Lichtfunktion C 24:
                nicht aktiv
            Lichtfunktion D 24:
                nicht aktiv
            Dimmwert CD 24:
            Dimming Direction CD 24:
                maximize
            Lichtfunktion E 24:
                nicht aktiv
            Lichtfunktion F 24:
                nicht aktiv
            Dimmwert EF 24:
            Dimming Direction EF 24:
                maximize
            Lichtfunktion G 24:
                nicht aktiv
            Lichtfunktion H 24:
                nicht aktiv
            Dimmwert GH 24:
            Dimming Direction GH 24:
                maximize
        Leuchte25KZL HA59:
            Lasttyp 25:
                25 - allgemeine Glühlampe Innen- oder Außenlicht
            Lampendefektbitposition 25:
                28
            Fehlerort mittleres Byte DTC-DFCC 25:
                30
            Lichtfunktion A 25:
            Lichtfunktion B 25:
                nicht aktiv
            Dimmwert AB 25:
                127
            Lichtansteuerung HD AB 25:
                always
            Lichtfunktion C 25:
                nicht aktiv
            Lichtfunktion D 25:
                nicht aktiv
            Dimmwert CD 25:
            Dimming Direction CD 25:
                maximize
            Lichtfunktion E 25:
                nicht aktiv
            Lichtfunktion F 25:
                nicht aktiv
            Dimmwert EF 25:
            Dimming Direction EF 25:
                maximize
            Lichtfunktion G 25:
                nicht aktiv
            Lichtfunktion H 25:
                nicht aktiv
            Dimmwert GH 25:
            Dimming Direction GH 25:
                maximize
        Leuchte26NSL LA72:
            Lasttyp 26:
                43 - allgemeine LED
            Lampendefektbitposition 26:
                c
            Fehlerort mittleres Byte DTC-DFCC 26:
                2e
            Lichtfunktion A 26:
                Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr
            Lichtfunktion B 26:
                nicht aktiv
            Dimmwert AB 26:
                127
            Lichtansteuerung HD AB 26:
                only_if_closed
            Lichtfunktion C 26:
                nicht aktiv
            Lichtfunktion D 26:
                nicht aktiv
            Dimmwert CD 26:
            Dimming Direction CD 26:
                maximize
            Lichtfunktion E 26:
                nicht aktiv
            Lichtfunktion F 26:
                nicht aktiv
            Dimmwert EF 26:
            Dimming Direction EF 26:
                maximize
            Lichtfunktion G 26:
                nicht aktiv
            Lichtfunktion H 26:
                nicht aktiv
            Dimmwert GH 26:
            Dimming Direction GH 26:
                maximize
        Leuchte27NSL RC6:
            Lasttyp 27:
                inactivo
            Lampendefektbitposition 27:
            Fehlerort mittleres Byte DTC-DFCC 27:
            Lichtfunktion A 27:
                nicht aktiv
            Lichtfunktion B 27:
                nicht aktiv
            Dimmwert AB 27:
            Lichtansteuerung HD AB 27:
                always
            Lichtfunktion C 27:
                nicht aktiv
            Lichtfunktion D 27:
                nicht aktiv
            Dimmwert CD 27:
            Dimming Direction CD 27:
                maximize
            Lichtfunktion E 27:
                nicht aktiv
            Lichtfunktion F 27:
                nicht aktiv
            Dimmwert EF 27:
            Dimming Direction EF 27:
                maximize
            Lichtfunktion G 27:
                nicht aktiv
            Lichtfunktion H 27:
                nicht aktiv
            Dimmwert GH 27:
            Dimming Direction GH 27:
                maximize
        Leuchte28RFL LC11:
            Lasttyp 28:
                43 - allgemeine LED
            Lampendefektbitposition 28:
                b
            Fehlerort mittleres Byte DTC-DFCC 28:
                31
            Lichtfunktion A 28:
                Rueckfahrlicht
            Lichtfunktion B 28:
                nicht aktiv
            Dimmwert AB 28:
                127
            Lichtansteuerung HD AB 28:
                only_if_closed
            Lichtfunktion C 28:
                nicht aktiv
            Lichtfunktion D 28:
                nicht aktiv
            Dimmwert CD 28:
            Dimming Direction CD 28:
                maximize
            Lichtfunktion E 28:
                nicht aktiv
            Lichtfunktion F 28:
                nicht aktiv
            Dimmwert EF 28:
            Dimming Direction EF 28:
                maximize
            Lichtfunktion G 28:
                nicht aktiv
            Lichtfunktion H 28:
                nicht aktiv
            Dimmwert GH 28:
            Dimming Direction GH 28:
                maximize
        Leuchte29RFL RA64:
            Lasttyp 29:
                43 - allgemeine LED
            Lampendefektbitposition 29:
                1b
            Fehlerort mittleres Byte DTC-DFCC 29:
                32
            Lichtfunktion A 29:
                Rueckfahrlicht
            Lichtfunktion B 29:
                nicht aktiv
            Dimmwert AB 29:
                127
            Lichtansteuerung HD AB 29:
                only_if_closed
            Lichtfunktion C 29:
                nicht aktiv
            Lichtfunktion D 29:
                nicht aktiv
            Dimmwert CD 29:
            Dimming Direction CD 29:
                maximize
            Lichtfunktion E 29:
                nicht aktiv
            Lichtfunktion F 29:
                nicht aktiv
            Dimmwert EF 29:
            Dimming Direction EF 29:
                maximize
            Lichtfunktion G 29:
                nicht aktiv
            Lichtfunktion H 29:
                nicht aktiv
            Dimmwert GH 29:
            Dimming Direction GH 29:
                maximize
        Leuchte30FR LC72:
            Lasttyp 30:
                36 - LED Kleinleistung
            Lampendefektbitposition 30:
            Fehlerort mittleres Byte DTC-DFCC 30:
            Lichtfunktion A 30:
                Fussraumlicht
            Lichtfunktion B 30:
                nicht aktiv
            Dimmwert AB 30:
                89
            Lichtansteuerung HD AB 30:
                always
            Lichtfunktion C 30:
                nicht aktiv
            Lichtfunktion D 30:
                nicht aktiv
            Dimmwert CD 30:
            Dimming Direction CD 30:
                maximize
            Lichtfunktion E 30:
                nicht aktiv
            Lichtfunktion F 30:
                nicht aktiv
            Dimmwert EF 30:
            Dimming Direction EF 30:
                maximize
            Lichtfunktion G 30:
                nicht aktiv
            Lichtfunktion H 30:
                nicht aktiv
            Dimmwert GH 30:
            Dimming Direction GH 30:
                maximize
        Leuchte31AMBL 1C61:
            Lasttyp 31:
                inactivo
            Lampendefektbitposition 31:
            Fehlerort mittleres Byte DTC-DFCC 31:
            Lichtfunktion A 31:
                nicht aktiv
            Lichtfunktion B 31:
                nicht aktiv
            Dimmwert AB 31:
            Lichtansteuerung HD AB 31:
                always
            Lichtfunktion C 31:
                nicht aktiv
            Lichtfunktion D 31:
                nicht aktiv
            Dimmwert CD 31:
            Dimming Direction CD 31:
                maximize
            Lichtfunktion E 31:
                nicht aktiv
            Lichtfunktion F 31:
                nicht aktiv
            Dimmwert EF 31:
            Dimming Direction EF 31:
                maximize
            Lichtfunktion G 31:
                nicht aktiv
            Lichtfunktion H 31:
                nicht aktiv
            Dimmwert GH 31:
            Dimming Direction GH 31:
                maximize
        Leuchte32AMBL 2C35:
            Lasttyp 32:
                inactivo
            Lampendefektbitposition 32:
            Fehlerort mittleres Byte DTC-DFCC 32:
            Lichtfunktion A 32:
                nicht aktiv
            Lichtfunktion B 32:
                nicht aktiv
            Dimmwert AB 32:
            Lichtansteuerung HD AB 32:
                always
            Lichtfunktion C 32:
                nicht aktiv
            Lichtfunktion D 32:
                nicht aktiv
            Dimmwert CD 32:
            Dimming Direction CD 32:
                maximize
            Lichtfunktion E 32:
                nicht aktiv
            Lichtfunktion F 32:
                nicht aktiv
            Dimmwert EF 32:
            Dimming Direction EF 32:
                maximize
            Lichtfunktion G 32:
                nicht aktiv
            Lichtfunktion H 32:
                nicht aktiv
            Dimmwert GH 32:
            Dimming Direction GH 32:
                maximize
        Leuchte33AMBL 3C36:
            Lasttyp 33:
                inactivo
            Lampendefektbitposition 33:
            Fehlerort mittleres Byte DTC-DFCC 33:
            Lichtfunktion A 33:
                nicht aktiv
            Lichtfunktion B 33:
                nicht aktiv
            Dimmwert AB 33:
            Lichtansteuerung HD AB 33:
                always
            Lichtfunktion C 33:
                nicht aktiv
            Lichtfunktion D 33:
                nicht aktiv
            Dimmwert CD 33:
            Dimming Direction CD 33:
                maximize
            Lichtfunktion E 33:
                nicht aktiv
            Lichtfunktion F 33:
                nicht aktiv
            Dimmwert EF 33:
            Dimming Direction EF 33:
                maximize
            Lichtfunktion G 33:
                nicht aktiv
            Lichtfunktion H 33:
                nicht aktiv
            Dimmwert GH 33:
            Dimming Direction GH 33:
                maximize
        Leuchte34AMBL 4C37:
            Lasttyp 34:
                inactivo
            Lampendefektbitposition 34:
            Fehlerort mittleres Byte DTC-DFCC 34:
            Lichtfunktion A 34:
                nicht aktiv
            Lichtfunktion B 34:
                nicht aktiv
            Dimmwert AB 34:
            Lichtansteuerung HD AB 34:
                always
            Lichtfunktion C 34:
                nicht aktiv
            Lichtfunktion D 34:
                nicht aktiv
            Dimmwert CD 34:
            Dimming Direction CD 34:
                maximize
            Lichtfunktion E 34:
                nicht aktiv
            Lichtfunktion F 34:
                nicht aktiv
            Dimmwert EF 34:
            Dimming Direction EF 34:
                maximize
            Lichtfunktion G 34:
                nicht aktiv
            Lichtfunktion H 34:
                nicht aktiv
            Dimmwert GH 34:
            Dimming Direction GH 34:
                maximize
        HW_Verbau:
            Aussentemperatursensor:
                montado
            Desgaste de las guarniciones de freno:
                montado
            PTC Zuheizer:
                Sin montar
            Falta líquido de frenos:
                montado
            Falta líquido refrigerante:
                montado
            Falta de agua para lavar:
                Sin montar
            Kontaktschalter_fuer_Motorhaube:
                montado
            Status_Tankdeckelverriegelung:
                inactivo
            Druckklappe:
                Sin montar
            Ladesteckerverriegelung:
                Sin montar
            Signalhorn ohne KL15:
                activado
            Elektrische_Laderaumabdeckung:
                Sin montar
            Elektrische Laderaumabdeckung aktiv:
                inactivo
        Aussenlicht_Front:
            Abblendlicht_Leuchtentyp:
                H7
            Zahl der aktiven Scheinwerfer auf 2 limitieren:
                in Betrieb lassen
            Lichthupe bei Zuendung aus moeglich:
                activado
            Allwetterlicht Einschaltgrenze:
                350 km/h
            Allwetterlicht Ausschaltgrenze:
                350 km/h
            Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht:
                inactivo
            Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich:
                inactivo
            Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge:
                activado
            Standlicht aktiviert zusaetzlich Tagfahrlicht:
                activado
            Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten:
                inactivo
            Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht:
                inactivo
            Tagfahrlichtkontrollleuchte:
                inactivo
            Fahrlicht bei Tag:
                Luz de circulación diurna
            Tagfahrlicht nur in Schalterstellung AUTO:
                inactivo
            Signaturlicht_verbaut:
                Sin montar
            Signaturlicht HMI-default Anzeige im Kombiinstrument:
                inactivo
            TFL_Abschaltung_ueber_Geschwindigkeit:
                inactivo
            Geschwindigkeitsabhaengiges TFL:
                5 km/h
        Aussenlicht_Heck:
            Bremslicht_ist_auch_Blinklicht:
                no
            Schlusslicht mit Bremslichtfunktion:
                inactivo
            Notbremsanzeige NBA:
                activado
            Umgreifende_Heckklappe:
                Sin montar
            Nebelschlusslicht Warngeschwindigkeit:
                0 km/h
        Luz de curva estática:
            bei Rueckwaertsfahrt:
                ambos lados
            Zeitwert Einschaltzeit Abbiegelicht:
                15 min
            Vorschrift:
                ECE R119
            Untere Geschwindigkeitsschwelle:
                0.0 km/h
            Obere Geschwindigkeitsschwelle:
                40.0 km/h
            Ángulo del volante, offset:
                0.3 °
            Unterer Lenkradwinkel:
                80 °
            Oberer Lenkradwinkel:
                120 °
            Abdimmgeschwindigkeit:
                50.0 %/s
            Maximaltemperatur:
                100.0 °C
            obere Grenztemperatur:
                95.0 °C
            untere Grenztemperatur:
                80.0 °C
        Sonderfunktionen:
            Sonderfunktionen 1:
                Sin montar
            Sonderfunktionen:
                no desbloqueado
            Signalprioritaet fuer Blinker:
                SMLS
        Fernlicht_assistent:
            Erweiterte_Fernlichtsteuerung:
                AFS, BCM-Fernlicht
            Menuesteuerung Fernlichtassistent:
                Disponible
            Fernlichtassistent Reset:
                inactivo
            Menuesteuerung Fernlichtassistent Werkseinstellung:
                Disponible
            Assistenzfahrlicht, Empfindlichkeit per BAP einstellbar:
                Disponible
        lwr_ofs_RSw_Ah1S:
            x0:
                -5.00 %
            x1:
                -5.00 %
            x2:
                -5.00 %
            x3:
                -5.00 %
            x4:
                -5.00 %
            y0:
                -5.00
            y1:
                -5.00
            y2:
                -5.00
            y3:
                -5.00
            y4:
                -5.00
        Kennlinie_sLWR_Soll:
            x0:
                100.00 %
            x1:
                100.00 %
            x2:
                100.00 %
            x3:
                100.00 %
            x4:
                83.00 %
            x5:
                67.00 %
            x6:
                50.00 %
            x7:
                33.00
            x8:
                17.00 %
            x9:
                0.00 %
            y0:
                58.5 %
            y1:
                58.5 %
            y2:
                58.5 %
            y3:
                58.5 %
            y4:
                54.5 %
            y5:
                49.5 %
            y6:
                46.5 %
            y7:
                35.5 %
            y8:
                31.5 %
            y9:
                20.0 %
        Funciones de luz de asistencia:
            Regen_Lichtsensor:
                LIN_Regen_Licht_Sensor
            Feuchtesensor:
                montado
            Assistenzfahrlicht bei Regen:
                activado
            Sonnensensor:
                Sin montar
            LS_Error_Ausgabe:
                activado
            Maskierung_Regenfunktion:
                inactivo
            Lichtsensorempfindlichkeit:
                normal
        Sensor de luz:
            Einschaltgrenze_CHO_LHO:
                600 lx
            Daemmerungsgrenze, Hysterese_obergrenze:
                1200 lx
            Daemmerungsgrenze_Hysterese_untergrenze:
                2200 lx
            Helligkeitsgrenze_sehr_hell:
                2000 lx
            Helligkeitsgrenze_Licht__einschalten:
                1200 lx
            Helligkeitsgrenze_Licht_ausschalten:
                2200 lx
            Minimale_Beleuchtungsstaerke:
                0 lx
            Maximale_Beleuchtungsstaerke:
                0 lx
            Minimale_Ausgangsspannung:
                0 mV
            Maximale_Ausgangsspannung:
                0 mV
            Tunnel_einschalt_verzoegerung:
            ECE_Lichteinschaltschwelle:
                0 lx
            Helligkeitsgrenze_Licht_ausschalten_red:
            HMI_Wiper_Comfort_Rain_Sensor_OFF:
                not active
            HMI_Exterior_light_on_highway:
                inactivo
            HMI_Exterior_light_on_rain:
                inactivo
            LS_Error_Ausgabe:
                inactivo
            HMI_exterior_light_sensitivity:
                frueh
        LuB Lichtrouter Kennlinie 1:
            x0:
                0.0 %
            x1:
                5.0 %
            x2:
                50.0 %
            x3:
                75.0 %
            x4:
                110.0
            x5:
                126.5
            y0:
                0.0 %
            y1:
                6.0 %
            y2:
                16.0 %
            y3:
                30.0 %
            y4:
                60.0 %
            y5:
                100.0 %
        Configuración de luces:
                0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000536001A0D0F7F1E007F0000000000000540001B0E0F7F1E007F0000000000000544004B46007F000A7F000000000000053A004946007F000A7F00000000000000000000000000000000000000000000000000000000000000000000000000000A3800221200640000000000000000000A420023130064000000000000000000
        Leuchtenkonfiguration_Aussenlich_Heck:
                2608001602007F0000000000000000002618001804007F0000000000000000002B09002B18007F0000000000000000002B19002D18007F0000000000000000002A29002C18247F0000000000000000002B0A002908097F0000000000000000002B1A002A080A7F0000000000000000001928003008007F0000000000000000002B0C002E1B00FF000000000000000000000000000000000000000000000000002B0B00311900FF0000000000000000002B1B00321900FF000000000000000000
        Leuchtenkonfiguration_Sonstiges:
                2B000036080AFF0000000000000000002B0000350809FF000000000000000000240000022B005900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000290000634C0064000000000000000000
        debug_light_function:
            Adresse:
            Bitmask:
            Offset:
            Divisor:
            Polaritaet:
            Aktivierung:
        Iluminación interior, parámetros:
            p_t_verzoegerung_einstieg_innenlicht:
                0.0 s
            p_t_verzoegerung_ausstieg_innenlicht:
                0.0 s
            p_t_verzoegerung_oeffnen_innenlicht:
                0.0 s
            p_t_verzoegerung_entriegelt_innenlicht:
                0.0 s
            p_t_verzoegerung_schliessen_innenlicht:
                0.0 s
            p_t_verzoegerung_schluessel_ab_innenlicht:
                0.0 s
            p_t_verzoegerung_verriegelt_innenlicht:
                0.0 s
            p_t_verzoegerung_einstieg_tueren:
                0.5 s
            p_t_verzoegerung_ausstieg_tueren:
                0.0 s
            p_t_verzoegerung_oeffnen_tueren:
                0.0 s
            p_t_verzoegerung_entriegelt_tueren:
                0.0 s
            p_t_verzoegerung_schliessen_tueren:
                0.0 s
            p_t_verzoegerung_schluessel_ab_tueren:
                0.0 s
            p_t_verzoegerung_verriegelt_tueren:
                0.0 s
            p_t_verzoegerung_einstieg_fussraum:
                2.0 s
            p_t_verzoegerung_ausstieg_fussraum:
                0.0 s
            p_t_verzoegerung_oeffnen_fussraum:
                0.0 s
            p_t_verzoegerung_entriegelt_fussraum:
                0.0 s
            p_t_verzoegerung_schliessen_fussraum:
                0.0 s
            p_t_verzoegerung_schluessel_ab_fussraum:
                0.0 s
            p_t_verzoegerung_verriegelt_fussraum:
                0.0 s
            p_t_verzoegerung_einstieg_cockpit:
                0.0 s
            p_t_verzoegerung_ausstieg_cockpit:
                0.0 s
            p_t_verzoegerung_oeffnen_cockpit:
                0.0 s
            p_t_verzoegerung_entriegelt_cockpit:
                0.0 s
            p_t_verzoegerung_schliessen_cockpit:
                0.0 s
            p_t_verzoegerung_schluessel_ab_cockpit:
                0.0 s
            p_t_verzoegerung_verriegelt_cockpit:
                0.0 s
            p_t_verzoegerung_einstieg_miko:
                0.0 s
            p_t_verzoegerung_ausstieg_miko:
                0.0 s
            p_t_verzoegerung_oeffnen_miko:
                0.0 s
            p_t_verzoegerung_entriegelt_miko:
                0.0 s
            p_t_verzoegerung_schliessen_miko:
                0.0 s
            p_t_verzoegerung_schluessel_ab_miko:
                0.0 s
            p_t_verzoegerung_verriegelt_miko:
                0.0 s
            p_t_verzoegerung_einstieg_dach:
                0.0 s
            p_t_verzoegerung_ausstieg_dach:
                0.0 s
            p_t_verzoegerung_oeffnen_dach:
                0.0 s
            p_t_verzoegerung_entriegelt_dach:
                0.0 s
            p_t_verzoegerung_schliessen_dach:
                0.0 s
            p_t_verzoegerung_schluessel_ab_dach:
                0.0 s
            p_t_verzoegerung_verriegelt_dach:
                0.0 s
            p_helligkeit_entriegelt_innenlicht:
                100 %
            p_helligkeit_max_innenlicht:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_innenlicht:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_innenlicht:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht:
                0 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht:
                100 %
            p_helligkeit_einausstieg_innenlicht:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht:
                100 %
            p_adaption_kundenwunsch_tuer:
                0.60
            p_helligkeit_entriegelt_tueren:
                0 %
            p_helligkeit_max_tueren:
                96 %
            p_helligkeit_HD_auf_zuendung_ein_tueren:
                126 %
            p_helligkeit_HD_auf_zuendung_aus_tueren:
                127 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_tueren:
                96 %
            p_helligkeit_andereTuer_auf_zuendung_ein_tueren:
                96 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_tueren:
                96 %
            p_helligkeit_andereTuer_auf_zuendung_aus_tueren:
                96 %
            p_helligkeit_einausstieg_tueren:
                96 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren:
                127 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren:
                96 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren:
                96 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren:
                96 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren:
                96 %
            p_adaption_kundenwunsch_fussraum:
                0.20
            p_helligkeit_entriegelt_fussraum:
                0 %
            p_helligkeit_max_fussraum:
                70 %
            p_helligkeit_HD_auf_zuendung_ein_fussraum:
                126 %
            p_helligkeit_HD_auf_zuendung_aus_fussraum:
                127 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum:
                70 %
            p_helligkeit_andereTuer_auf_zuendung_ein_fussraum:
                70 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum:
                70 %
            p_helligkeit_andereTuer_auf_zuendung_aus_fussraum:
                70 %
            p_helligkeit_einausstieg_fussraum:
                70 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum:
                127 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum:
                70 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum:
                70 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum:
                70 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum:
                70 %
            p_adaption_kundenwunsch_lautsprecher:
                1.00
            p_helligkeit_entriegelt_lautsprecher:
                100 %
            p_helligkeit_max_lautsprecher:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_lautsprecher:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_lautsprecher:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher:
                100 %
            p_helligkeit_einausstieg_lautsprecher:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher:
                100 %
            p_adaption_kundenwunsch_itafel:
                1.00
            p_helligkeit_entriegelt_itafel:
                100 %
            p_helligkeit_max_itafel:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_itafel:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_itafel:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_itafel:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_itafel:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_itafel:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_itafel:
                100 %
            p_helligkeit_einausstieg_itafel:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel:
                100 %
            p_adaption_kundenwunsch_cockpit:
                1.00
            p_helligkeit_entriegelt_cockpit:
                100 %
            p_helligkeit_max_cockpit:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_cockpit:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_cockpit:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_cockpit:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_cockpit:
                100 %
            p_helligkeit_einausstieg_cockpit:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit:
                100 %
            p_adaption_kundenwunsch_miko:
                1.00
            p_helligkeit_entriegelt_miko:
                100 %
            p_helligkeit_max_miko:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_miko:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_miko:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_miko:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_miko:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_miko:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_miko:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_miko:
                100 %
            p_helligkeit_einausstieg_miko:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_miko:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_miko:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_miko:
                100 %
            p_adaption_kundenwunsch_dach:
                1.00
            p_helligkeit_entriegelt_dach:
                100 %
            p_helligkeit_max_dach:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_dach:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_dach:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_dach:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_dach:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_dach:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_dach:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_dach:
                100 %
            p_helligkeit_einausstieg_dach:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_dach:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_dach:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_dach:
                100 %
            p_adaption_kundenwunsch_psd:
                1.00
            p_helligkeit_entriegelt_psd:
                100 %
            p_helligkeit_max_psd:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_psd:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_psd:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_psd:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_psd:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_psd:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_psd:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_psd:
                100 %
            p_helligkeit_einausstieg_psd:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_psd:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_psd:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_psd:
                100 %
            p_dimmfaktor_farbwechsel_auf:
            p_dimmfaktor_farbwechsel_ab:
            p_farbwechsel_delay:
            p_farbauswahl_HMI:
            p_ambienteumfang_mehrfarbig_HMI:
            p_ambienteumfang_mehrfarbig_HMI_2:
            p_ambienteumfang_mehrfarbig_HMI_3:
            p_ambienteumfang_mehrfarbig_HMI_4:
            p_ambientelicht_verbauinformation_HMI:
            p_ambientelicht_verbauinformation_HMI_2:
            p_ambientelicht_verbauinformation_HMI_3:
            p_ambientelicht_verbauinformation_HMI_4:
            p_verzoegerung_berechnen:
            p_t_HMI_verzoegerung_helligkeitswerte:
                200 ms
        Ambientelicht Farbliste:
            Rotwert Farbe 1:
            Gruenwert Farbe 1:
            Blauwert Farbe 1:
            Rotwert Farbe 2:
            Gruenwert Farbe 2:
            Blauwert Farbe 2:
            Rotwert Farbe 3:
            Gruenwert Farbe 3:
            Blauwert Farbe 3:
            Rotwert Farbe 4:
            Gruenwert Farbe 4:
            Blauwert Farbe 4:
            Rotwert Farbe 5:
            Gruenwert Farbe 5:
            Blauwert Farbe 5:
            Rotwert Farbe 6:
            Gruenwert Farbe 6:
            Blauwert Farbe 6:
            Rotwert Farbe 7:
            Gruenwert Farbe 7:
            Blauwert Farbe 7:
            Rotwert Farbe 8:
            Gruenwert Farbe 8:
            Blauwert Farbe 8:
            Rotwert Farbe 9:
            Gruenwert Farbe 9:
            Blauwert Farbe 9:
            Rotwert Farbe 10:
            Gruenwert Farbe 10:
            Blauwert Farbe 10:
        ambient_lighting_lin_slaves_modules:
            pa_einzeladresse_slave_1:
            pa_verbauinfo_slave_1:
                Sin montar
            pa_fehlerort_slave_1:
            pa_einzeladresse_slave_2:
            pa_verbauinfo_slave_2:
                Sin montar
            pa_fehlerort_slave_2:
            pa_einzeladresse_slave_3:
            pa_verbauinfo_slave_3:
                Sin montar
            pa_fehlerort_slave_3:
            pa_einzeladresse_slave_4:
            pa_verbauinfo_slave_4:
                Sin montar
            pa_fehlerort_slave_4:
            pa_einzeladresse_slave_5:
            pa_verbauinfo_slave_5:
                Sin montar
            pa_fehlerort_slave_5:
            pa_einzeladresse_slave_6:
            pa_verbauinfo_slave_6:
                Sin montar
            pa_fehlerort_slave_6:
            pa_einzeladresse_slave_7:
            pa_verbauinfo_slave_7:
                Sin montar
            pa_fehlerort_slave_7:
            pa_einzeladresse_slave_8:
            pa_verbauinfo_slave8:
                Sin montar
            pa_fehlerort_slave8:
            pa_einzeladresse_slave_9:
            pa_verbauinfo_slave_9:
                Sin montar
            pa_fehlerort_slave_9:
            pa_einzeladresse_slave_10:
            pa_verbauinfo_slave_10:
                Sin montar
            pa_fehlerort_slave_10:
            pa_einzeladresse_slave_11:
            pa_verbauinfo_slave_11:
                Sin montar
            pa_fehlerort_slave_11:
            pa_einzeladresse_slave_:12:
            pa_verbauinfo_slave_12:
                Sin montar
            pa_fehlerort_slave_12:
            pa_einzeladresse_slave_13:
            pa_verbauinfo_slave_13:
                Sin montar
            pa_fehlerort_slave_13:
            pa_einzeladresse_slave_14:
            pa_verbauinfo_slave_14:
                Sin montar
            pa_fehlerort_slave_14:
            pa_einzeladresse_slave_15:
            pa_verbauinfo_slave_15:
                Sin montar
            pa_fehlerort_slave_15:
            pa_einzeladresse_slave_16:
            pa_verbauinfo_slave_16:
                Sin montar
            pa_fehlerort_slave_16:
            pa_einzeladresse_slave_17:
            pa_verbauinfo_slave_17:
                Sin montar
            pa_fehlerort_slave_17:
            pa_einzeladresse_slave_18:
            pa_verbauinfo_slave_18:
                Sin montar
            pa_fehlerort_slave_18:
            pa_einzeladresse_slave_19:
            pa_verbauinfo_slave_19:
                Sin montar
            pa_fehlerort_slave_19:
            pa_einzeladresse_slave_20:
            pa_verbauinfo_slave_20:
                Sin montar
            pa_fehlerort_slave_20:
        ambient_lighting_lin_slaves_groups:
            pa_verbauinfo_gruppe_1:
                Sin montar
            pa_lichtfunktion_gruppe_1:
                Puerta
            pa_korrekturfaktor_gruppe_1:
                1.00
            pa_verbauinfo_gruppe_2:
                Sin montar
            pa_lichtfunktion_gruppe_2:
                Puerta
            pa_korrekturfaktor_gruppe_2:
                1.00
            pa_verbauinfo_gruppe_3:
                Sin montar
            pa_lichtfunktion_gruppe_3:
                Puerta
            pa_korrekturfaktor_gruppe_3:
                1.00
            pa_verbauinfo_gruppe_4:
                Sin montar
            pa_lichtfunktion_gruppe_4:
                Puerta
            pa_korrekturfaktor_gruppe_4:
                1.00
            pa_verbauinfo_gruppe_5:
                Sin montar
            pa_lichtfunktion_gruppe_5:
                Puerta
            pa_korrekturfaktor_gruppe_5:
                1.00
            pa_verbauinfo_gruppe_6:
                Sin montar
            pa_lichtfunktion_gruppe_6:
                Puerta
            pa_korrekturfaktor_gruppe_6:
                1.00
            pa_verbauinfo_gruppe_7:
                Sin montar
            pa_lichtfunktion_gruppe_7:
                Puerta
            pa_korrekturfaktor_gruppe_7:
                1.00
            pa_verbauinfo_gruppe_8:
                Sin montar
            pa_lichtfunktion_gruppe_8:
                Puerta
            pa_korrekturfaktor_gruppe_8:
                1.00
            pa_verbauinfo_gruppe_9:
                Sin montar
            pa_lichtfunktion_gruppe_9:
                Puerta
            pa_korrekturfaktor_gruppe_9:
                1.00
            pa_verbauinfo_gruppe_10:
                Sin montar
            pa_lichtfunktion_gruppe_10:
                Puerta
            pa_korrekturfaktor_gruppe_10:
                1.00
            pa_verbauinfo_gruppe_11:
                Sin montar
            pa_lichtfunktion_gruppe_11:
                Puerta
            pa_korrekturfaktor_gruppe_11:
                1.00
            pa_verbauinfo_gruppe_12:
                Sin montar
            pa_lichtfunktion_gruppe_12:
                Puerta
            pa_korrekturfaktor_gruppe_12:
                1.00
            pa_verbauinfo_gruppe_13:
                Sin montar
            pa_lichtfunktion_gruppe_13:
                Puerta
            pa_korrekturfaktor_gruppe_13:
                1.00
            pa_verbauinfo_gruppe_14:
                Sin montar
            pa_lichtfunktion_gruppe_14:
                Puerta
            pa_korrekturfaktor_gruppe_14:
                1.00
            pa_verbauinfo_gruppe_15:
                Sin montar
            pa_lichtfunktion_gruppe_15:
                Puerta
            pa_korrekturfaktor_gruppe_15:
                1.00
        Suchbeleuchtung_Tasterdimmung:
            tasterdimmung x0:
                0 ms
            tasterdimmung x1:
                2000 ms
            tasterdimmung x2:
                3000 ms
            tasterdimmung x3:
                4000 ms
            tasterdimmung x4:
                5100 ms
            tasterdimmung y0:
                1.0 %
            tasterdimmung y1:
                5.0
            tasterdimmung y2:
                15.0
            tasterdimmung y3:
                40.0
            tasterdimmung y4:
                100.0
        Suchbeleuchtung_Hochdimmen:
            x0:
                0 ms
            x1:
                200 ms
            x2:
                400 ms
            x3:
                600 ms
            x4:
                800 ms
            x5:
                1000 ms
            x6:
                1200 ms
            x7:
                1400 ms
            x8:
                1600 ms
            x9:
                1800 ms
            x10:
                2000 ms
            y0:
                0.0 %
            y1:
                1.0 %
            y2:
                3.0 %
            y3:
                5.0 %
            y4:
                11.0 %
            y5:
                22.0 %
            y6:
                40.0 %
            y7:
                80.0 %
            y8:
                95.0 %
            y9:
                100.0 %
            y10:
                100.0 %
        Suchbeleuchtung_Abdimmen:
            x0:
                0 ms
            x1:
                200 ms
            x2:
                400 ms
            x3:
                600 ms
            x4:
                800 ms
            x5:
                1000 ms
            x6:
                1200 ms
            x7:
                1400 ms
            x8:
                1600 ms
            x9:
                1800 ms
            x10:
                2000 ms
            y0:
                100.0 %
            y1:
                100.0 %
            y2:
                95.0 %
            y3:
                80.0 %
            y4:
                40.0 %
            y5:
                20.0 %
            y6:
                10.0 %
            y7:
                5.0 %
            y8:
                3.0 %
            y9:
                1.0 %
            y10:
                0.0 %
        Suchbeleuchtung_Fotosensor:
            x0:
            x1:
                50
            x2:
                100
            x3:
                200
            x4:
                253
            x5:
            x6:
            x7:
            x8:
            x9:
            x10:
            y0:
                0 lx
            y1:
                50 lx
            y2:
                100 lx
            y3:
                200
            y4:
                500
            y5:
            y6:
                0 lx
            y7:
                0 lx
            y8:
                0 lx
            y9:
                0 lx
            y10:
                0 lx
        Suchbeleuchtung_KL 58xs min:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                510 lx
            y0:
                6.0
            y1:
                6.0
            y2:
                100.0
            y3:
                100.0
        Suchbeleuchtung_KL 58xs max:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                100.0
            y1:
                100.0
            y2:
                100.0
            y3:
                100.0
        Suchbeleuchtung_KL_58xt min:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                6.0
            y1:
                6.0
            y2:
                100.0
            y3:
                100.0
        Suchbeleuchtung_KL_58xt_max:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                100.0
            y1:
                100.0
            y2:
                100.0
            y3:
                100.0
        Suchbeleuchtung_KL_58xd_min:
            x0:
                0 lx
            x1:
                50 lx
            x2:
                220 lx
            x3:
                300 lx
            x4:
                500 lx
            y0:
                6.0
            y1:
                16.0
            y2:
                25.0
            y3:
                30.0
            y4:
                50.0
        Suchbeleuchtung_KL_58xd_max:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                200 lx
            x3:
                300 lx
            x4:
                500 lx
            y0:
                16.0
            y1:
                16.0
            y2:
                100.0
            y3:
                100.0
            y4:
                100.0
        Suchbeleuchtung_KL_58xd_log_Bus:
            x0:
                0.0 %
            x1:
                6.0 %
            x2:
                16.0 %
            x3:
                30.0 %
            x4:
                60.0 %
            x5:
                100.0 %
            y0:
                10
            y1:
                10
            y2:
                100
            y3:
                150
            y4:
                220
            y5:
                253
        Dimmunt_KL_58xs_PWM:
            x0:
                0.0 %
            x1:
                50.0 %
            x2:
                100.0 %
            y0:
                0.0 %
            y1:
                50.0 %
            y2:
                100.0 %
        Suchbeleuchtung_KL_58xt_PWM:
            x0:
                0.0 %
            x1:
                50.0 %
            x2:
                100.0 %
            y0:
                0.0 %
            y1:
                50.0 %
            y2:
                100.0 %
        Suchbeleuchtung_KL_58xd_PWM:
            x0:
            x1:
                10
            x2:
                50
            x3:
                100
            x4:
                220
            x5:
                253
            y0:
                2.0 %
            y1:
                2.0 %
            y2:
                6.0 %
            y3:
                10.0 %
            y4:
                80.0 %
            y5:
                100.0 %
        Suchbeleuchtung_58_xs_Bus_Kennlinie:
            x0:
                0.0 lx
            x1:
                8.0 lx
            x2:
                50.0 lx
            x3:
                80.0 lx
            x4:
                100.0 lx
            y0:
                6.0
            y1:
                6.0
            y2:
                20.0
            y3:
                50.0
            y4:
                100.0
        Suchbeleuchtung_58xt_Bus_Kennlinie:
            x0:
                0.0 lx
            x1:
                8.0 lx
            x2:
                50.0 lx
            x3:
                80.0 lx
            x4:
                100.0 lx
            y0:
                6.0
            y1:
                6.0
            y2:
                20.0
            y3:
                50.0
            y4:
                100.0
        Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie:
            x0:
                0 lx
            x1:
                10 lx
            x2:
                100 lx
            x3:
                500 lx
            x4:
                800 lx
            x5:
                1020 lx
            y0:
            y1:
                20
            y2:
                80
            y3:
                180
            y4:
                300
            y5:
                500
        ZV allgemein:
            Notschliessfunktion:
                activado
            Funkfrequenz:
                434,42MHz
            Funk bei Klemme 15 ein:
                inactivo
            ZV_ohne_Safe_Funktion:
                Sin montar
            Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster:
                activado
            Entsafen mit autorisierte Klemme 15 Ein:
                activado
            Bewusstes Safe mit 2. Betaetigung der FFB:
                inactivo
            Lock_Unlock_Taster_direkt:
                Sin montar
            Lock_Unlock_Toggle_Taster:
                Sin montar
            ZV Tuerentriegelung:
                Globale Entriegelung
            Menuesteuerung Tuerentriegelung:
                activado
            LS_Taster_Togglefunktion:
                inactivo
            Deaktivierung_Laderaumschliessung_extern:
                inactivo
            Nutzfahrzeug_Schliessung:
                inactivo
            Wiederverriegelung_Laderaum:
                Freigabe_Softtouch
            Tankschloss:
                bidirectional
        ZV Türkonfiguration:
            Viertuerer:
                sí
            Fond_Schloss:
                2-Motorenschloesser
            Schlosstyp_NAR:
                no
            Schiebetueren_Crafter:
                Sin montar
            Schiebetuerschloss_direkt_BCM:
                lado cond.
            Schiebetuer_Kontaktmodul_Fahrerseite:
                Sin montar
            Schiebetuer_Kontaktmodul_Beifahrerseite:
                Sin montar
            Schiebetuer_links:
                no
            Schiebetuer_rechts:
                no
            Schliessung der Schiebetuer bei geoeffneter Tankklappe:
                inactivo
            HFT_Invertierung_Drehfallensignal:
                nicht invertiert
        ZV Heck:
            Tausch_Tank_Hecktreiberausgang:
                no
            ZV_Heck_Schlosstyp:
                1- oder 2-Rasten-Hecksteller
            Heckschloss_mit_Vorraste:
                sí
            Heckschloss_Steuerung:
                Kontaktsteuerung
            Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang:
                inactivo
            Heckdeckelentriegelung_HDF_Innentaster:
                Sin montar
            ZV entriegelt auch Heckdeckel:
                activado
            Direkter Auswurf des Heckdeckels:
                activado
            Heckfreigabe_Ohne_Verzoegerung:
                inactivo
            ZV Heck nur direkt auswerfen:
                inactivo
            Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster:
                inactivo
            Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt:
                inactivo
            Mindestbetaetigung_HDF_Innentaster:
                0.0 s
            Heckoeffnung_ueber_2_Bedienhandlungen:
                inactivo
        Señales de respuesta:
            Aviso óptico al bloquear:
                Decelerar
            Optische Rueckmeldung Komfortschliessen:
                activado
            Optische Rueckmeldung 3.Bremsleuchte:
                inactivo
            Akustische Rueckmeldung global:
                inactivo
            Akustische Rueckmeldung entriegeln:
                inactivo
            Quittierton bei zweitem ZV-AUF-Befehl:
                inactivo
            Akustische Rueckmeldung verriegeln:
                inactivo
            Quittierton bei zweitem ZV-ZU-Befehl:
                inactivo
            Menuesteuerung akustische Rueckmeldung:
                inactivo
            Dauer der Akustischen Rueckmeldung vom Einfachhorn:
                kurz
            Akustische Rueckmeldung Signalhorn:
                inactivo
            ZV-Blinken_Hellzeit:
                200 ms
            ZV-Blinken_Dunkelzeit:
                200 ms
            ZV-Blinken_Abschluss_Dunkelzeit:
                200 ms
        ZV Komfort:
            Freigabenachlauf FH bei Kl 15 aus:
                activado
            Freigabenachlauf FH bei Tueroeffnen abbrechen:
                activado
            Komfortbedienung global:
                activado
            Apertura confort:
                inactivo
            Komfortoeffnen nur FH Fahrertuer:
                inactivo
            Schliesszylinder Komfort oeffnen:
                inactivo
            Funk Komfort oeffnen:
                activado
            Fahrertuerbedienung Fensterheber oeffnen:
                activado
            FH SAD Kl15Aus Freigabezeit:
                600 s
            Cierre de confort:
                activado
            Schliesszylinder Komfort schliessen:
                inactivo
            Funk Komfort schliessen:
                activado
            Fahrertuerbedienung Fensterheber schliessen:
                activado
            Menuesteuerung Komfortbedienung einstellbar:
                adjustable
            Regenschliessen_ein_aus:
                inactivo
            Regenschliessen_art:
                once
            Menuesteuerung Regenschliessen:
                inactivo
            elektrischer_Fensterheber_hinten:
                sí
        ZV Autolock:
            Automatisches Verriegeln bei Geschwindigkeit:
                inactivo
            automatisches Entriegeln:
                activado
            Autounlock NAR:
                inactivo
            Autolock Autounlock wirkt auf Heck:
                activado
            Geschwindigkeitsabhaengige Tankdeckelverriegelung:
                inactivo
            Menuesteuerung ZV Autolock-Unlock:
                adjustable
        Schiebedach:
            SAD Richtung Komfortoeffnen:
                tilting
            SAD Komfort schliessen:
                inactivo
            SAD Komfort oeffnen:
                inactivo
            Schiebedachmodul_MD_1:
                Sin montar
            Schiebedachmodul_MD_3:
                Sin montar
            Schiebedachmodul_MD_Rollo:
                Sin montar
            Verortung Schiebedachmodule:
                LIN
        Spiegelverstellung:
            Spiegelabsenkung bei Rueckwaertsfahrt:
                activado
            Spiegelverstellung Synchron:
                activado
            Menuesteuerung Spiegelabsenkung:
                activado
            Funk Spiegelanklappen:
                activado
            Funk Spiegelanklappung Modus:
                by look command via remote control key
            Menuesteuerung synchrone Spiegelverstellung:
                activado
            Menuesteuerung Funk Spiegel anklappen:
                activado
            Profilfunktion fuer Anklappung der Aussenspiegel:
                activado
            Signalisierung_Spiegelanklappung:
                inactivo
            Spiegelanklappen_bei_Wiederverriegelung:
                activado
        ZV Crash:
            Heckdeckel-Bedienstellen nachCrash temporaer sperren:
                activado
            ZV-Entriegelung nach Seitencrash:
                inactivo
            SAD PreCrash Konturschliessen:
                inactivo
        Postfunc. luz posición:
            Bedingungen zur Beendigung des Standlichtnachlaufs:
                inactivo
            ZV verriegeln bei Klemme 15 Ein:
                activado
            Standlicht-Nachlaufzeit:
                255 min
        Pulsador en consola central:
            Funktion Taster 1:
                Arranque/parada
            Funktion Taster 2:
                Sin codificar / sin montar
            Funktion Taster 3:
                Programa de conducción
            Funktion Taster 4:
            Zusatzcodierung Fahrprofiltaster hat keine LED:
                LED installed
        Curva característica ventilador asiento:
            Level_1_Sitz:
                25 %
            Level_1_Lehne:
                30 %
            Level_2_Sitz:
                25 %
            Level_2_Lehne:
                30 %
            Level_3_Sitz:
                53 %
            Level_3_Lehne:
                58 %
            Level_4_Sitz:
                53 %
            Level_4_Lehne:
                58 %
            Level_5_Sitz:
                80 %
            Level_5_Lehne:
                85 %
            Level_6_Sitz:
                80 %
            Level_6_Lehne:
                85 %
            Sitzlueftung:
                Sin montar
            Sitzlueftung_reduzierbar:
                Sin montar
            Sitzpneumatik:
                Sin montar
        Función de clim./calef. por control remoto:
            Remotestart:
                Sin montar
            Rueckmeldung_bei_Aktivierung:
                activado
            Kombi_Fahrerhinweis_m_Uebernahme_RSt:
                activado
            Abbruch_Hupen_RSt:
                inactivo
            Abbruch_d_Warnblinker_moeglich:
                activado
            Kombi_Fahrerhinweis_m_Akustik:
                activado
            Aktivierung_Drehzahlanzeige:
                activado
        Comportamiento en modo de producción:
            Lavafaros:
                2000 ms
        Modo para banco de pruebas de rodillos, funcional:
                inactivo
        Modo de transporte:
                activado
        Desactivar modo de producción:
                inactivo
        Schlüssellose Zugang- und Startberechtigung:
            Kessy:
                Sin montar
            Elektische_Lenkradverriegelung:
                Sin montar
            Kessy Komfort oeffnen:
                inactivo
            Kessy Komfort schliessen:
                activado
            Oeffnung Heckdeckel bei Wiederentriegelung:
                inactivo
            Kessy Komfortbedienung Reichweitenbegrenzung:
                inactivo
        Leer dirección de parámetros:
            Parámetro dirección:
        Vernetzungs- Diagnosefunktionen:
            can msg 1:
            can msg 2:
            can msg 3:
            can msg 4:
            lin msg 1:
            lin msg 2:
            lin msg 3:
            lin msg 4:
            lin msg 5:
            lin msg 6:
        Activación y desactivación de todos los mensajes de desarrollo:
                inactivo
        Gestión de energía:
            Hybridfahrzeug:
                no
            Recuperation:
                activado
            Energiemanagement Abschaltung:
                activado
            Zweitbatterie:
                Sin montar
            Energy_Management_Adaptation:
                Gestión de energía activada
            Praediktives_Energiemanagement:
                inactivo
            Hochvoltfahrzeug:
                Sin montar
        Verdecksteuergeraet:
            Nachsaven_nach_Verdecklauf:
                inactivo
            Komfortbedienung Verdeck global:
                activado
            Komfortbedienung Verdeck oeffnen:
                activado
            Komfortbedienung Verdeck schliessen:
                activado
            Verdeck oeffnen via Schliesszylinder:
                activado
            Verdeck schliessen via Schliesszylinder:
                activado
            Verdeck oeffnen via Funkfernbedienung:
                activado
            Verdeck schliessen via Funkfernbedienung:
                activado
            Verdeck oeffnen via Kessy:
                activado
            Verdeck schliessen via Kessy:
                activado
            Doppelpuls nur Verdeck:
                activado
            Verdeck mit Schiebedach:
                inactivo
            Heckdeckel sperren bei Verdeckbetrieb:
                inactivo
            Softtouch-Betaetigung senden:
                immer
            Servoheck Schlossansteuerung:
                immer
            Reichweitenbegrenzung fuer Servoheck schliessen:
                inactivo
            Cabrio_Verdeck:
                not_installed
            trunk_lid_conrol_unit:
                Sin montar
            Virtuelles_Pedal_Verbau:
                Sin montar
            Virtuelles_Pedal:
                inactivo
            Virtuelles_Pedal_HMI_einstellba:
                inactivo
            easycloselight_aktiv:
                inactivo
            Kick_and_close:
                Sin montar
        Allwetterlicht_Spoiler:
            tt_spoiler:
                Sin montar
            Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT:
                inactivo
            Spoiler Einfahrunterdrueckung nach manuellem Ausfahren:
                inactivo
        Slave_systems_identification:
            UC para el motor del limpiacristales:
                No disponible
            Sensor de lluvia y de luz:
                No disponible
            Conmutador de las luces:
                No disponible
            Unidad de control para apertura de la puerta del garaje:
                No disponible
            Unidad de mandos para apertura de la puerta del garaje:
                No disponible
            Sensor del sistema de alarma antirrobo:
                No disponible
            Bocina alarma:
                No disponible
            Unidad de control del techo corredizo:
                No disponible
            Unidad de control de la electrónica del techo:
                No disponible
            Unidad de control de la cortinilla del techo:
                No disponible
            Sensor de humedad del aire, interior:
                No disponible
            Calefacción zona cabeza, izq.:
                No disponible
            Calefacción zona cabeza, der.:
                No disponible
            Ventilador 1 para el respaldo del asiento del. izq.:
                No disponible
            Ventilador 1 para el cojín del asiento del. izq.:
                No disponible
            Ventilador 1 para el respaldo del asiento del. der.:
                No disponible
            Ventilador 1 para el cojín del asiento del. der.:
                No disponible
        Vigilancia del habitáculo, alarma antirrobo:
            Sensibilidad:
                100 %
        Alarma antirrobo: sensor inclinación veh.:
            Sensibilidad:
                100 %
        Vigil. hab., alarma antirrobo, set parámetros:
                010A080043530AC801140A0381330C00000001CDD606000F1E00850F39F764234542579B25443F3A6958952D09A3027A0656000F170089102FF7690FE342871B05343F3A6958930809A30344462A000F1C00880E2FE7691E6542771B05243F3A6947930809A304FFF646000F1E00851E32F7440C4220571B05243F3A6958920509A305342619150C12188609263367234542579B25240CFA0A34952D09A3210300020202020202B110232966
        DWA_Interior_Monitoring_Data_Set_Development:
                FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
        RLS_wiper_position_parking:
                15 s
        RLS_close_glazing:
                2.0 s
        RLS_lights_for_autobahn:
            p_v_autobahn_on:
                140 km/h
            p_v_autobahn_off:
                65 km/h
            p_t_autobahn_delay_on:
                10 s
            p_t_autobahn_delay_off:
                120 s
        RLS_Washer_Front:
                15 s
        RLS_LIN_Communication:
                4 s
        RLS_tunel_gateway_recognize:
                5 s
        RLS_Lights_on_at_Rain:
            p_n_regenlichtschwelle_high:
                12
            p_n_regenlichtschwelle_low:
                6
            p_lx_regenlichtschwelle:
                6000 lx
            p_t_regenlicht:
                30 s
        RLS_Night_Sensitivity:
            p_lx_rs_day:
                500 lx
            p_lx_rs_dawn:
                200 lx
        Pos. de giro superior:
                170.494335 °
        Pos. de giro inferior:
                31.494474 °
        Posición en funcionamiento a intervalos:
                31.494474 °
        Posición de aparcamiento alterna 1:
                7.494498 °
        Posición de aparcamiento alterna 2:
                29.494476 °
        Posición de servicio:
                170.494335 °
        Wischgeschwindigkeiten:
            Dauerwischen Stufe_1 Zyklen pro Minute:
                40
            Dauerwischen Stufe_2 Zyklen pro Minute:
                60
            Reduzierte Wischgeschwindigkeit Zyklen pro Minute:
                30
        Front_wash_function:
            factor_washing_delay:
                10
        error_mask:
                0 bit
        erase_error_table:
                550000
        Kopfraumheizung:
            blower_speed:
            temperature:
                -2
        Vernetzung:
            Klimaelektronik:
                montado
            Anhaengeranschlussgeraet:
                Sin montar
            Bremsen_Steuergeraet:
                montado
            Getriebesteuergeraet:
                Sin montar
            Kunden_spezifisches_Funktions_SG:
                Sin montar
            Kopfraumheizung:
                Sin montar
            UGDO:
                Sin montar
        Querschnitts_funktionen:
            Lenkungsanordnung:
                Izq.
            Verkehrsseite:
                Der.
            Marca:
                VW
            Personalisierungsuebernahme:
                not_installed
            Bedien_und_Anzeigeprotokoll:
                activado
            Schnittstelle_TrackingSystem:
                inactivo
            Codierungsabsicherung:
                inactivo
            CAN Wecken bei Softtouchbetaetigung:
                inactivo
            Hardware_Eingang_Drucktankklappenstatus:
                Pin A31
            Klemmenfehler auf CAN ausgeben:
                activado
            Fahrgeschwindigkeit_aus_ESP_21:
                activado
            Hupe:
                Sollspannungsanforderung 13,5V
        Aktivierung_Entwicklungsdiagnose:
            log_dtc_status:
                inactivo
            Reaktion_LOG-DTC:
                First_dtc
            log-dtc_DFCC:
        Aussenlicht_uebergreifend:
            Light_Control_Module:
                montado
            Kontrollleuchte fuer Begrenzungslicht:
                integriert in Suchbeleuchtung
            Standlicht aus:
                activado
            Parklicht ueber LSS aktiviert:
                Un lado
            Standlichtreduzierung mit beidseitigem Parklicht:
                activado
            Menueeinstellung CHO LHO:
                Menuesteuerung Zeit aktivieren
            Faktor fuer Verfuegbarkeitstimer:
                Faktor fuer x5 Minuten
            Umfeldleuchte als Manoevrierleuchte:
                inactivo
            Fahrlichtwarnung_Hinweis_Konfig:
                Hinweis_in_LDS-Stellung_Null_und_SL
            Fahrlicht_Hinweis_mehrfach:
                activado
            Bedingungen zur Standlichtbegrenzung:
                abschaltbar über Energiemanagement
            Standlicht-Verfügbarkeit:
                24 s
            bewusstes Standlicht:
                Aktive Begrenzung
            Bedingungen zur Parklichtbegrenzung:
            Lichtwarnungsverhalten:
                klemmenabhaengig
            Coming Home Verbaustatus:
                manual
            Menuesteuerung Coming Home Werkseinstellung:
                activado
            Coming home Leuchten:
                luz de cruce
            Menueeinstellung Cominghome:
                10 segundos
            Coming-home Einschaltereignis:
                driver door
            Helligkeitsschwelle Infrarot-Messung:
                12 lx
            Leaving-Home Verbausstatus:
                desbloqueado
            Menuesteuerung Leaving-home Freischaltung per BAP:
                activado
            LDS_mit_Nebellicht:
                sí
            Lichtdrehschalter (LDS):
                discrete
            Menueeinstellung Leaving-home Zeit per BAP:
                10 segundos
            Helligkeitsschwelle Forward-Messung:
                46400 lx
            LDS_mit_Nebel_Schlusslicht:
                sí
            LDS_mit_AFL:
                sí
            LDS_mit_Standlichtstellung:
                sí
            HVLM_Ladezustandsanzeige:
                no
            LCM_blinker:
                WAHR
            Allwetterlicht:
                Sin montar
            Abblendlicht:
            Fernlicht_LH:
            Nebellicht:
            Blinker:
        Aussenlicht_Blinker:
            Warnblinken_durch_Fahrerassistenz:
                inactivo
            Komfortblinken Blinkzyklen:
                3
            Abbruch Komfortblinken:
                activado
            Komfortblinken:
                activado
            Blinkkontrolleuchte fuer Anhaenger:
                separte
            Schluessel_Anlern_Blinken:
                activado
            UGDO_ Anlern_Blinken:
                activado
            ZV_Blinken_zu:
                activado
            ZV_Blinken_auf:
                activado
            Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken:
                activado
            DWA_Schaerfungsquittung:
                activado
            DWA_Alarm_Blinken:
                activado
            Taxialarmblinken:
                activado
            Panikblinken:
                activado
            Multi_kollisions_Blinken:
                inactivo
            Emergency_alert_blinken:
                inactivo
            Notwarn_blinken_NBA_Phase_2:
                inactivo
            dynamisch_blinken_10:
                activado
            Richtungs_blinken_rechts:
                activado
            Richtungs_blinken_links:
                activado
            ABBA_Blinken:
                inactivo
            Crashblinken:
                inactivo
            Warnblinken_Zuendung_EIN:
                activado
            Warnblinken_Zuendung_AUS:
                activado
            Dynamische_Blink_Delay:
                50 ms
            Fahrerassistenz_Blinkenfunktionen:
                Warnblinke_zulaessig
            PreCrash_RECAS:
                PreCrash_passiv
        Leuchtweitenregulierung:
            sensor_headlight_range_control_installed:
                Sin montar
            sLWR_verbaut:
                HIM
            1_Sensor_LWR:
                1-Sensor_LWR
            Fahrwerk_Variante:
                Variante_1
            sLWR_bei_Abblendlicht:
                activado
            Quelle_Hoehenwerte:
                BCM
            Aktivierung_LWR_Fehlerlampe:
                inactivo
            Logik_PWM_Signal:
                Negativo
            sLWR_nach_Motorstart:
                inactivo
            Entprellung_Fehlerlampe:
                10.0 s
            Fail_Safe_sLWR:
                0.0 %
            Zyklus_sLWR:
                1.00 s
            sLWR_Touristenlicht:
                -100.0 %
            sLWR_SW_Grad:
                10.0 %/s
            sLWR_Hysterese:
                1.0 %
            diagnose_soll_toleranz:
                15 %
            Ansteuerung_untere_grenze:
                0.0 %
            Ansteuerung_obere_grenze:
                100.0 %
            Delay_DC_Motor_Versorgung:
                -101.5 ms
            Lineare_Abbildung:
                normal
            fac_Pwm_Zu_Hoehe_V_1:
                -8.00 mm/%
            fac_Pwm_Zu_Hoehe_H_1:
                -8.00 mm/%
            fac_Pwm_Zu_Hoehe_V_2:
                -8.00 mm/%
            fac_Pwm_Zu_Hoehe_H_2:
                -8.00 mm/%
            fac_Pwm_Zu_Hoehe_V_3:
                -8.00 mm/%
            fac_Pwm_Zu_Hoehe_H_3:
                -8.00 mm/%
            Achsabstand_des_Fahrzeuges:
                0 mm
            lwr_lFzg_Sw_Abstand:
                0 mm
            lwr_lFzg_Sw_Hoehe:
                0 mm
            pa_fDynFiltStatLwr:
                100 Hz
            fFiltEinf:
                0.00 Hz
            pa_fFiltSwNeigung:
                0.00 Hz
            lwr_pwm_untere_schwelle:
                2.5 %
            lwr_pwm_obere_schwelle:
                95.0 %
            max_v_slwr:
                255 km/h
            lwr_lEinfOffsHFahrw_1:
                0 mm
            lwr_lEinfOffsHFahrw_2:
                0 mm
            lwr_lEinfOffsHFahrw_3:
                0 mm
            lwr_lEinfOffsHFahrw_4:
                0 mm
        Activar conmutación conducción por la izquierda/derecha:
                inactivo
        Luz interior 2.ª generación:
            Aufloesung Dimmzeit:
                0.10 s
            weicher Farbwechsel:
                inactivo
            Tuertafelbeleuchtung mehrfarbig:
                inactivo
            Instrumententafelbeleuchtung mehrfarbig:
                inactivo
            Cockpitbeleuchtung mehrfarbig:
                inactivo
            Lautsprecherbeleuchtung mehrfarbig:
                inactivo
            Mittelkonsolenbeleuchtung mehrfarbig:
                inactivo
            Dachbeleuchtung mehrfarbig:
                inactivo
            Panoramaschiebedachbeleuchtung mehrfarbig:
                inactivo
            Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren:
                inactivo
            BAP Farbwert Farbe 1:
            BAP Farbwert Farbe 2:
                3
            BAP Farbwert Farbe 3:
            Defaultwert Ambienteprofil Mittelkonsole:
                80 %
            Defaultwert Ambienteprofil Dach:
                80 %
            Defaultwert Ambienteprofil Farbe:
            Defaultwert Ambienteprofil Fussraum:
                50 %
            Defaultwert Ambienteprofil Tuer:
                50 %
            Defaultwert Ambienteprofil Vorn:
                50 %
            Ambiente_Farbliste_HMI_mit_Farbtransformation:
                inactivo
            Helligkeit_Tuertafelbeleuchtung_nicht_berechnen:
                inactivo
            Helligkeit Instrumententafelbeleuchtung nicht berechnen:
                activado
            Helligkeit Cockpitbeleuchtung nicht berechnen:
                activado
            Helligkeit Lautsprecherbeleuchtung nicht berechnen:
                activado
            Helligkeit Mittelkonsolenbeleuchtung nicht berechnen:
                activado
            Helligkeit Dachbeleuchtung nicht berechnen:
                activado
            Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen:
                activado
            Farbausgabe Tuertafelbeleuchtung nicht berechnen:
                activado
            Farbausgabe Instrumententafelbeleuchtung nicht berechnen:
                activado
            Farbausgabe Cockpitbeleuchtung nicht berechnen:
                activado
            Farbausgabe Lautsprecherbeleuchtung nicht berechnen:
                activado
            Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen:
                activado
            Farbausgabe Dachbeleuchtung nicht berechnen:
                activado
            Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen:
                activado
            Innenlicht bei offenem Heckdeckel einschalten:
                inactivo
            KL30G ohne PWM:
                inactivo
            Weckfaehigkeit_klemme_30G:
                montado
            LIN-Dachkonsole mit Flaechenlicht:
                Sin montar
            Tuerinnengriffbeleuchtung mit I-Tafel:
                Sin montar
            Tuerinnengriff mit Tuertafel:
                Sin montar
            Ambiente_Farbwahl_FPA_waehlbare_Kopplung:
                inactivo
            Ambiente_Fahrprofil_Individual:
                7
            Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default:
                activado
            Innenlicht:
                Keine_Spannungsanforderung
        Luz interior configuración de luces:
            Ambiente_Applikationsleisten_in_Tuertafel:
                montado
            Ambiente_Lautsprecher:
                Sin montar
            Ambiente_Applikationsleisten_in_Instrumententafel:
                Sin montar
            Cockpitbeleuchtung:
                Sin montar
            Mittelkonsolenbeleuchtung:
                Sin montar
            Dachbeleuchtung:
                Sin montar
            Panoramaschiebedachbeleuchtung:
                Sin montar
            Fussraumbeleuchtung:
                montado
            Farbwahl ueber HMI:
                Sin montar
            Farbwahl ueber Fahrprofil:
                Sin montar
            LIN-Dachkonsole lokal aktivierbar:
                inactivo
            Ambientemenue mit globalem aus:
                inactivo
            Ambientemenue mit alle Zonen:
                inactivo
            Ambient_Farbliste_HMI:
                inactivo
            Frei_Farbwahl_ueber_HMI:
                inactivo
            Ambience_light_colorlist_default:
        Ambience_lightning_color_list_2:
            Rotwert Farbe 11:
            Gruenwert Farbe 11:
            Blauwert Farbe 11:
            Rotwert Farbe 12:
            Gruenwert Farbe 12:
            Blauwert Farbe 12:
            Rotwert Farbe 13:
            Gruenwert Farbe 13:
            Blauwert Farbe 13:
            Rotwert Farbe 14:
            Gruenwert Farbe 14:
            Blauwert Farbe 14:
            Rotwert Farbe 15:
            Gruenwert Farbe 15:
            Blauwert Farbe 15:
            Rotwert Farbe 16:
            Gruenwert Farbe 16:
            Blauwert Farbe 16:
            Rotwert Farbe 17:
            Gruenwert Farbe 17:
            Blauwert Farbe 17:
            Rotwert Farbe 18:
            Gruenwert Farbe 18:
            Blauwert Farbe 18:
            Rotwert Farbe 19:
            Gruenwert Farbe 19:
            Blauwert Farbe 19:
            Rotwert Farbe 20:
            Gruenwert Farbe 20:
            Blauwert Farbe 20:
            Rotwert_Farbe_21:
            Gruenwert_Farbe_21:
            Blauwert_Farbe_21:
            Rotwert_Farbe_22:
            Gruenwert_Farbe_22:
            Blauwert_Farbe_22:
            Rotwert_Farbe_23:
            Gruenwert_Farbe_23:
            Blauwert_Farbe_23:
            Rotwert_Farbe_24:
            Gruenwert_Farbe_24:
            Blauwert_Farbe_24:
            Rotwert_Farbe_25:
            Gruenwert_Farbe_25:
            Blauwert_Farbe_25:
            Rotwert_Farbe_26:
            Gruenwert_Farbe_26:
            Blauwert_Farbe_26:
            Rotwert_Farbe_27:
            Gruenwert_Farbe_27:
            Blauwert_Farbe_27:
            Rotwert_Farbe_28:
            Gruenwert_Farbe_28:
            Blauwert_Farbe_28:
            Rotwert_Farbe_29:
            Gruenwert_Farbe_29:
            Blauwert_Farbe_29:
            Rotwert_Farbe_30:
            Gruenwert_Farbe_30:
            Blauwert_Farbe_30:
        Ambience_lightning_color_list_lin:
            Rotwert_Farbe_1_lin:
            Gruenwert_Farbe_1_lin:
            Blauwert_Farbe_1_lin:
            Rotwert_Farbe_2_lin:
            Gruenwert_Farbe_2_lin:
            Blauwert_Farbe_2_lin:
            Rotwert_Farbe_3_lin:
            Gruenwert_Farbe_3_lin:
            Blauwert_Farbe_3_lin:
            Rotwert_Farbe_4_lin:
            Gruenwert_Farbe_4_lin:
            Blauwert_Farbe_4_lin:
            Rotwert_Farbe_5_lin:
            Gruenwert_Farbe_5_lin:
            Blauwert_Farbe_5_lin:
            Rotwert_Farbe_6_lin:
            Gruenwert_Farbe_6_lin:
            Blauwert_Farbe_6_lin:
            Rotwert_Farbe_7_lin:
            Gruenwert_Farbe_7_lin:
            Blauwert_Farbe_7_lin:
            Rotwert_Farbe_8_lin:
            Gruenwert_Farbe_8_lin:
            Blauwert_Farbe_8_lin:
            Rotwert_Farbe_9_lin:
            Gruenwert_Farbe_9_lin:
            Blauwert_Farbe_9_lin:
            Rotwert_Farbe_10_lin:
            Gruenwert_Farbe_10_lin:
            Blauwert_Farbe_10_lin:
        Ambience_lightning_color_list_lin_2:
            Rotwert_Farbe_11_lin:
            Gruenwert_Farbe_11_lin:
            Blauwert_Farbe_11_lin:
            Rotwert_Farbe_12_lin:
            Gruenwert_Farbe_12_lin:
            Blauwert_Farbe_12_lin:
            Rotwert_Farbe_13_lin:
            Gruenwert_Farbe_13_lin:
            Blauwert_Farbe_13_lin:
            Rotwert_Farbe_14_lin:
            Gruenwert_Farbe_14_lin:
            Blauwert_Farbe_14_lin:
            Rotwert_Farbe_15_lin:
            Gruenwert_Farbe_15_lin:
            Blauwert_Farbe_15_lin:
            Rotwert_Farbe_16_lin:
            Gruenwert_Farbe_16_lin:
            Blauwert_Farbe_16_lin:
            Rotwert_Farbe_17_lin:
            Gruenwert_Farbe_17_lin:
            Blauwert_Farbe_17_lin:
            Rotwert_Farbe_18_lin:
            Gruenwert_Farbe_18_lin:
            Blauwert_Farbe_18_lin:
            Rotwert_Farbe_19_lin:
            Gruenwert_Farbe_19_lin:
            Blauwert_Farbe_19_lin:
            Rotwert_Farbe_20_lin:
            Gruenwert_Farbe_20_lin:
            Blauwert_Farbe_20_lin:
            Rotwert_Farbe_21_lin:
            Gruenwert_Farbe_21_lin:
            Blauwert_Farbe_21_lin:
            Rotwert_Farbe_22_lin:
            Gruenwert_Farbe_22_lin:
            Blauwert_Farbe_22_lin:
            Rotwert_Farbe_23_lin:
            Gruenwert_Farbe_23_lin:
            Blauwert_Farbe_23_lin:
            Rotwert_Farbe_24_lin:
            Gruenwert_Farbe_24_lin:
            Blauwert_Farbe_24_lin:
            Rotwert_Farbe_25_lin:
            Gruenwert_Farbe_25_lin:
            Blauwert_Farbe_25_lin:
            Rotwert_Farbe_26_lin:
            Gruenwert_Farbe_26_lin:
            Blauwert_Farbe_26_lin:
            Rotwert_Farbe_27_lin:
            Gruenwert_Farbe_27_lin:
            Blauwert_Farbe_27_lin:
            Rotwert_Farbe_28_lin:
            Gruenwert_Farbe_28_lin:
            Blauwert_Farbe_28_lin:
            Rotwert_Farbe_29_lin:
            Gruenwert_Farbe_29_lin:
            Blauwert_Farbe_29_lin:
            Rotwert_Farbe_30_lin:
            Gruenwert_Farbe_30_lin:
            Blauwert_Farbe_30_lin:
        Ambientelicht Zuordnung der Farbe zum Fahrprofil:
            Fahrprofil_0:
            Fahrprofil_1:
            Fahrprofil_2:
            Fahrprofil_3:
            Fahrprofil_4:
            Fahrprofil_5:
            Fahrprofil_6:
            Fahrprofil_7:
            Fahrprofil_8:
            Fahrprofil_9:
            Fahrprofil_10:
            Fahrprofil_11:
            Fahrprofil_12:
            Fahrprofil_13:
            Fahrprofil_14:
            Fahrprofil_15:
            Ambiente:
        Suchbeleuchtung_allgemein:
            Warnblinktastersuchbeleuchtung Aktivierung:
                always active
            Eingabemedium_Suchbeleuchtung:
                HMI
            Umgebungs_helligkeit_auswahl:
                Fotosensor_Kombi
            Warnblinktastersuchbeleuchtung Grundwert:
                6.0 %
            Warnblinktastersuchbeleuchtung Faktor:
                0.100
            KL58 Einschalten mit Rampe:
                inactivo
            KL58 Verriegelungsausschalten:
                not_active
            Lichtsensor wirkt auf Suchbeleuchtung:
                activado
            Suchbeleuchtung Festwert:
                100 %
            PWM_Daempfung_Aufdimmen_KL58xs_PWM:
                0.00 s
            Daempfung_Abdimmen_KL_58xs_PWM:
                0.00 s
            Daempfung_Aufdimmen_KL_58xt_PWM:
                0.00 s
            Daempfung_Abdimmen_KL_58xt_PWM:
                0.00 s
            Daempfung_Aufdimmen_KL_58xd_PWM:
                0.00 s
            Daempfung Abdimmen KL 58xd PWM:
                0.00 s
            Helligkeit_RLS_Daempfung_Aufdimmen:
                3.0 s
            Helligkeit_RLS_Daempfung_Abdimmen:
                20.0 s
            pa_Hysterese_RLS:
        Protección antirrobo:
            Alarmsignal:
                frequency modulated
            Verzoegerung Panikalarm:
                2 sekunden verzoegerung
            DWA Alarmverzoegerung:
                inactivo
            DWA Camper Modus:
                inactivo
            Ueberwachung Innenentriegelungshebel:
                inactivo
            Sirenen Alarmzahl:
                10 Alarme
            Akustischer Alarm Signalhorn:
                inactivo
            IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet:
                no
            Diebstahlwarnanlage:
                activado
            Heckscheibenbruchsensor:
                Sin montar
            Deaktivierung_DWA_Sensoren_HMI:
                activ
            DWA_Einfachhorn_oder_Sounder:
                Sounder_verbaut
            tilt_sensor:
                sí
            Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv):
                no
            Sensor_fuer_Innenraumueberwachung:
                sí
            Calefacción independiente:
                Sin montar
            OBD Alarm:
                activ
            Deaktivierung DWA-Sensoren via Doppelklick:
                not_active
            RHF_Panikalarm:
                not_active
        Front_wiper:
            Frontwischertyp:
                LIN
            Frontwischer Referenzlauf:
                activado
            Variable Regensensoraktivierung:
                inactivo
            Wischer stop bei KL15 aus:
                inactivo
            Wischer abparken bei Oeffnen der Motorhaube:
                inactivo
            Regensensor aktivieren:
                desactivar
            Menuesteuerung Frontwischer:
                inactivo
            Frontwischer Notlaufprogramm:
                activado
            Tippwischen mit erhoehter Wischfrequenz:
                activado
            Geschwindigkeitsabhaengige Wischstufenrueckschaltung:
                activado
            Traenenwischen Front Status:
                inactivo
            Washer_Tipwiping_Variant:
                inactivo
            Adaptives Nachwischen bei SRA:
                inactivo
            Wischer Stopp bei Oeffnen der Motorhaube:
                activado
            Frontwischer_Abtauposition:
                inactivo
            Anfahrzeit_servicestellung:
                800 ms
            Mindestwaschzeit_Frontwischer:
                0 ms
            Timer_DWP_SRA_delay:
                300 ms
            Frontwischer Spannungsanforderung_konfig:
        Limpialuneta:
            Heckwischer:
                logikgesteuert
            Komfortwischen Heck:
                activado
            Menuesteuerung Komfortwischen HW:
                activado
            Automatisches Heckwischen:
                inactivo
            Traenenwischen Heck:
                activado
            Heckwischer Weiterlauf:
                inactivo
            Komofortwischen Heck Intervallpausenzeit Stufe Intervall:
                7 s
            Komofortwischen Heck Intervallpausenzeit Stufe Automatik:
                7 s
            Komofortwischen Heck Intervallpausenzeit Stufe 1:
                5 s
            Komofortwischen Heck Intervallpausenzeit Stufe 2:
                3 s
            Einzelansteuerung Heckintervallwischen Zeitintervall 1:
                8 s
            Einzelansteuerung Heckintervallwischen Zeitintervall 2:
                16 s
            Einzelansteuerung Heckintervallwischen:
                inactivo
            Zeit_wasch_min_heck:
                0 ms
            Spannungsanforderung_konfig_Wischer:
        Scheinwerferreinigung:
            Scheinwerferreinigungsanlage:
                Sin montar
            SRA bei Waschwassermangel:
                activado
            Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung:
                10
            SRA Verzoegerungszeit:
                0 ms
            SRA Waschzeit:
                400 ms
            SRA Einweichpausenzeit:
                2000 ms
            SRA Nachwaschzeit:
                400 ms
            SRA Pausenzeit:
                0 ms
            Waschen:
        Asignac. consumo corriente p. niveles calef. asiento:
            Sitzheizung Filterkonstante fuer Waermefluss:
                0 s
            Sitzheizung Regeltemperaturkorrektur bei Waermefluss:
                0.00 °C
            Sitzheizung Stufe 1 untere Schaltschwelle:
                0.00 °C
            Sitzheizung Stufe 1 obere Schaltschwelle:
                0.00 °C
            Sitzheizung Stufe 2 untere Schaltschwelle:
                0.00 °C
            Sitzheizung Stufe 2 obere Schaltschwelle:
                0.00 °C
            Sitzheizung Stufe 3 untere Schaltschwelle:
                0.00 °C
            Sitzheizung Stufe 3 obere Schaltschwelle:
                0.00 °C
            Sitzheizung Stufe 4 untere Schaltschwelle:
                0.00 °C
            Sitzheizung Stufe 4 obere Schaltschwelle:
                0.00 °C
            Sitzheizung Stufe 5 untere Schaltschwelle:
                0.00 °C
            Sitzheizung Stufe 5 obere Schaltschwelle:
                0.00 °C
            Sitzheizung Stufe 6 untere Schaltschwelle:
                0.00 °C
            Sitzheizung Stufe 6 obere Schaltschwelle:
                0.00 °C
            Spannungsoffset SIH_75:
                15.0 V
            Sitzheitzung_CAN:
                not_installed
            Sitzheizungsfreigabe:
                Sin montar
            Sitzheizung.Regelbetrieb LO:
            Sitzheizung.Aufheizphase HI:
        Calefacción de los cristales:
            Heizbare_Frontscheibe:
                Sin montar
            Heizbare Heckscheibe:
                montado
            Waschduesenheizung:
                Sin montar
            Frontscheibenheizung_LED_direkt:
                Sin montar
            Frontscheibenheizungsansteuerung direkt von externem Algorithmus:
                Sin montar
            Temperaturabhaengige Einschaltzeit HSH:
                activado
            Temperaturabhaengige Einschaltzeit FSH:
                activado
            FSH Automatik:
                activado
            Heckscheibenheizung Zeitwert:
                320 s
            Parabrisas térmico, tiempo de ejecución:
                600 s
            Abschalttemperatur fuer Heckscheibenheizung:
                35.0 °C
            Abschalttemperatur fuer Frontscheibenheizung:
                35.0 °C
            Frontscheibenheizung _maximale_Dauer:
                0 s
            window heating front activation time pause:
                240 s
        Modo de producción:
                inactivo
            Heckwischer:
                inactivo
            Innenbeleuchtung:
                inactivo
            Aussenbeleuchtung:
                inactivo
            Zugangskontrolle:
                inactivo
            Virtuel_pedal:
                inactivo
        LIN-Mirrormode:
            mirror_mode_typ:
                inactivo
            Bus de datos LIN 1:
                inactivo
            Bus de datos LIN 2:
                inactivo
            Bus de datos LIN 3:
                inactivo
            Bus de datos LIN 4:
                inactivo
            Bus de datos LIN 5:
                inactivo
            Bus de datos LIN 6:
                inactivo
        Personalisierung:
            Personalisierung_Profilfunkion:
                profiles_active
            Profil_Variante:
                Konto (v. 1.x)
            Personalisierung_aktiv:
                activado
            Aktivierungsoption_im_HMI-Menue_sichtbar:
                activado
            Benutzerkontenverwaltung_in_HMI-Menue_sichtbar:
                activado
            Personalisierungsfunktionen_in_HMI-Menue_sichtbar:
                activado
            Anzahl_Benutzerkonten:
                4
            Automatische_ Schluesselzuordnung:
                inactivo
            PSO_FSG_Setup2_Bit_1:
                activado
            PSO_FSG_Setup2_Bit_2:
                activado
            PSO_FSG_Setup2_Bit_3:
                inactivo
            PSO_FSG_Setup2_Bit_4:
                inactivo
        OCU:
            OCU:
                Sin montar
            DWA_push:
                inactivo
            Remote_Unlock_Lock:
                not_active
            Honk DWA_Ausgabe_Fanfare:
                inactivo
            Remote Lock Unlock Timer s3:
                2000 ms
            Remote Lock Unlock Timer s1:
                80 s
            Remote HuF Abbruch:
                20 km/h
            Remote HuF Hupfrequenz:
                3 Hz
        Lenkstockschalter:
            Verbauort_Lenkstockschalter:
                CAN
            Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel:
                10 km/h
            Zeit_erkennung_fahrt_für_P_plausibel:
                10.0 min
            Anzahl_fehler_P-verriegelt:
                250
            Zeit_t_P-verriegelt_entprellen:
                40 ms
    Kilometraje: 11157 km
    Fecha: 2019-08-13 17:44
energy22
Spain
Modulo 4B
Also admap of the BCM because that holds the real important info in this case.
Fecha: 2019-08-13 17:45
    Numero de bastidor: WVWZZZAUZJP008993
    Coche: Volkswagen Golf
    Año: 2018
    Tipo de carrocería: 5-dr hatchback
    Motor: DADA 110 kW (150 HP) 1.5 l
    Kilometraje: 11157 KM
Copia de seguridad
    Unidad de Control: 4B Módulo multifunción
    Descripción del sistema: FCM MQB Low
    Número de software: 3Q0907338
    Versión de software: 0286
    Número de hardware: 3Q0907338
    Versión de Hardware: 002
    Número de serie: 15101710800434
    Nombre ODX: EV_MultiModulContiVW48X
    Versión ODX: 001010
    Nombre de copia de seguridad: modulo 4b 130819
    Codificación extendida:
        000000050100164A00200300020000000000000000000000000000000000
        Ventil. 1 p. banqueta del asiento tras. der.:
            Sin montar
        lcm_afs_leimo_mounted:
            Control automático de la luz de cruce
        Luz de curva dinámica:
            activado
        Function_activation_AFS:
            Ativado
        Function_activation_seat_backrest_and_cushion_fan_1:
            no activado
        Tipo de vehículo:
            16
        Sensor de lluvia y luz:
            montado
        Conmutación conducción por la izquierda/derecha:
            Circulación por la derecha
        chassis_unit:
            Mehrlenkerhinterachse Frontantrieb
        disable_afs:
            AFS III Abschaltung MFA+
        Arranque/parada:
            auxiliado
        steering_curve:
            normal
        lwr_sensors:
            1_sensor
        Source_height_value:
            BCM
        market:
            ece
        headlamp_coding_word:
        offroad_light:
            no activado
            ECE R119
    Adaptaciones:
                inactivo
        Modo de presentación:
                inactivo
                inactivo
        Ejecución de presentación luz de curva dinámica:
                activado
        Funciones adaptativas de luces:
                activado
        Faros Matrix, atenuación total:
                100 %
        Faros Matrix, función en parada:
                inactivo
        Muestra de bit excitación individual de segmentos, faro izq.:
            LED 1:
                off
            LED 2:
                off
            LED 3:
                off
            LED 4:
                off
            LED 5:
                off
            LED 6:
                off
            LED 7:
                off
            LED 8:
                off
            LED 9:
                off
            LED 10:
                off
            LED 11:
                off
            LED 12:
                off
            LED 13:
                off
            LED 14:
                off
            LED 15:
                off
            LED 16:
                off
            LED 17:
                off
            LED 18:
                off
            LED 19:
                off
            LED 20:
                off
            LED 21:
                off
            LED 22:
                off
            LED 23:
                off
            LED 24:
                off
            LED 25:
                off
            LED 26:
                off
            LED 27:
                off
            LED 28:
                off
            LED 29:
                off
            LED 30:
                off
            LED 31:
                off
            LED 32:
                off
            LED 33:
                off
            LED 34:
                off
            LED 35:
                off
            LED 36:
                off
            LED 37:
                off
            LED 38:
                off
            LED 39:
                off
            LED 40:
                off
            LED 41:
                off
            LED 42:
                off
            LED 43:
                off
            LED 44:
                off
            LED 45:
                off
        Muestra de bit excitación individual de segmentos, faro der.:
            LED 1:
                off
            LED 2:
                off
            LED 3:
                off
            LED 4:
                off
            LED 5:
                off
            LED 6:
                off
            LED 7:
                off
            LED 8:
                off
            LED 9:
                off
            LED 10:
                off
            LED 11:
                off
            LED 12:
                off
            LED 13:
                off
            LED 14:
                off
            LED 15:
                off
            LED 16:
                off
            LED 17:
                off
            LED 18:
                off
            LED 19:
                off
            LED 20:
                off
            LED 21:
                off
            LED 22:
                off
            LED 23:
                off
            LED 24:
                off
            LED 25:
                off
            LED 26:
                off
            LED 27:
                off
            LED 28:
                off
            LED 29:
                off
            LED 30:
                off
            LED 31:
                off
            LED 32:
                off
            LED 33:
                off
            LED 34:
                off
            LED 35:
                off
            LED 36:
                off
            LED 37:
                off
            LED 38:
                off
            LED 39:
                off
            LED 40:
                off
            LED 41:
                off
            LED 42:
                off
            LED 43:
                off
            LED 44:
                off
            LED 45:
                off
        Modo de producción:
            Desactivar conmutación conducción por la izquierda/derecha:
                inactivo
                desactivar
        Reference_Run_Start_Condition:
                Arranque del motor
        Seat_fan_rear_characteristics:
            Level_1_seat_cushion:
                0 %
            Level_1_seat_backrest:
                0 %
            Level_2_seat_cushion:
                0 %
            Level_2_seat_backrest:
                0 %
            Level_3_seat_cushion:
                0 %
            Level_3_seat_backrest:
                0 %
            Level_4_seat_cushion:
                0 %
            Level_4_seat_backrest:
                0 %
            Level_5_seat_cushion:
                0 %
            Level_5_seat_backrest:
                0 %
            Level_6_seat_cushion:
                0 %
            Level_6_seat_backrest:
                0 %
        Reference_Run_Activation_Effect:
            par_Reference_Run_Activation_Effect:
                Activation effect disabled
        Order_Reference_Run_Activation_Effect:
            par_Order_Reference_Run_Activation_Effect:
                No dependency
        Lista de montaje montaje teórico:
            Módulo multifunción:
                sí
            Multifunction_Module_Secondary:
                sí
            Mando de la luz izquierda:
                sí
            Mando de la luz derecha:
                sí
            Mando de la luz izquierda 2:
                sí
            Mando de la luz derecha 2:
                sí
energy22
Spain
Modulo19
    Año: 2018
Copia de seguridad
    Versión ODX: 001010
            Sin montar
            activado
            Ativado
            no activado
        Tipo de vehículo:
            16
            montado
        chassis_unit:
        disable_afs:
        Arranque/parada:
            auxiliado
        steering_curve:
            normal
        lwr_sensors:
            1_sensor
            BCM
        market:
            ece
        offroad_light:
            no activado
            ECE R119
    Adaptaciones:
                inactivo
                inactivo
                inactivo
                activado
                activado
                100 %
                inactivo
            LED 1:
                off
            LED 2:
                off
            LED 3:
                off
            LED 4:
                off
            LED 5:
                off
            LED 6:
                off
            LED 7:
                off
            LED 8:
                off
            LED 9:
                off
            LED 10:
                off
            LED 11:
                off
            LED 12:
                off
            LED 13:
                off
            LED 14:
                off
            LED 15:
                off
            LED 16:
                off
            LED 17:
                off
            LED 18:
                off
            LED 19:
                off
            LED 20:
                off
            LED 21:
                off
            LED 22:
                off
            LED 23:
                off
            LED 24:
                off
            LED 25:
                off
            LED 26:
                off
            LED 27:
                off
            LED 28:
                off
            LED 29:
                off
            LED 30:
                off
            LED 31:
                off
            LED 32:
                off
            LED 33:
                off
            LED 34:
                off
            LED 35:
                off
            LED 36:
                off
            LED 37:
                off
            LED 38:
                off
            LED 39:
                off
            LED 40:
                off
            LED 41:
                off
            LED 42:
                off
            LED 43:
                off
            LED 44:
                off
            LED 45:
                off
            LED 1:
                off
            LED 2:
                off
            LED 3:
                off
            LED 4:
                off
            LED 5:
                off
            LED 6:
                off
            LED 7:
                off
            LED 8:
                off
            LED 9:
                off
            LED 10:
                off
            LED 11:
                off
            LED 12:
                off
            LED 13:
                off
            LED 14:
                off
            LED 15:
                off
            LED 16:
                off
            LED 17:
                off
            LED 18:
                off
            LED 19:
                off
            LED 20:
                off
            LED 21:
                off
            LED 22:
                off
            LED 23:
                off
            LED 24:
                off
            LED 25:
                off
            LED 26:
                off
            LED 27:
                off
            LED 28:
                off
            LED 29:
                off
            LED 30:
                off
            LED 31:
                off
            LED 32:
                off
            LED 33:
                off
            LED 34:
                off
            LED 35:
                off
            LED 36:
                off
            LED 37:
                off
            LED 38:
                off
            LED 39:
                off
            LED 40:
                off
            LED 41:
                off
            LED 42:
                off
            LED 43:
                off
            LED 44:
                off
            LED 45:
                off
        Modo de producción:
                inactivo
                desactivar
                Arranque del motor
                0 %
                0 %
                0 %
                0 %
                0 %
                0 %
                0 %
                0 %
                0 %
                0 %
                0 %
                0 %
                No dependency
                sí
                sí
                sí
                sí
                sí
                sí
energy22
Spain
Modulo17
Fecha: 2019-08-13 18:20
    Año: 2018
Copia de seguridad
    Unidad de Control: 17 Cuadro de instrumentos
    Descripción del sistema: KOMBI
    Número de software: 5G1920790A
    Versión de software: 3193
    Número de hardware: 5G1920790A
    Versión de Hardware: 407
    Nombre ODX: EV_DashBoardVDDMQBAB
    Versión ODX: 009058
    Nombre de copia de seguridad: modulo17 130819
        07A401002F80000801882B211401000080000000
        Advertencia de velocidad:
            off
        Lado del volante del vehículo:
            Veh. con volante a la izq.
        Iluminación diurna (escalas):
            sí
        Two_keys:
            no
        SDS_BAP:
            sí
        Derivado de vehículo:
            Variante 0
        Curva característica del depósito:
            Variante 2
        Diám. rueda:
            Variante 1
        Formato hora:
            24h
        Volumen:
            litros
        Presión:
            bares
        Velocidad:
            Kilómetros por hora
        Dist. rec.:
            kilómetros
        Temperatura:
            grados Celsios
        Consumo gasolina / diésel / LPG (autogas/gas líquido):
            Litros a los 100 km
        fecha:
            dd_mm_jj
        Idioma:
            Inglés
        Pantalla inicial:
            Variante 1
        Aviso para el uso del cinturón de seguridad:
            Variante 1
        Indicador desgaste pastillas freno con testigo p. sist. frenos:
            no
        Caja de cambios:
            Cambio manual
        Consumo CNG (gas natural comprimido):
            kg por 100 km
        Indicación brújula:
            Posición inferior
        reg. int. luz:
            Regulación de intensidad de iluminación, borne 58xd
        Consumo medio prop. eléctrica:
            kWh por 100 km
        Lista de radios:
            Nombre de emisora o frecuencia
        Towing_capacity_mass:
            kg
    Adaptaciones:
        Día:
                13 d
        time_parameter_display:
            tDDWUP:
                0.00
            tDD15_on:
                0.00
            tDD15_off:
                0.15
            hmi_t_Dreiter_ms:
                2.0 s
            hmi_t_dummyMenuTimeout_ms:
                5 s
            hmi_t_UhrTimeout_ms:
                10 s
            hmi_t_MenuTimeout_ms:
                255 s
            hmi_t_TWSAnz_ms:
                3 s
            hmi_t_NextWarning_ms:
                6 s
            hmi_t_NextServiceAnz_ms:
                5 s
            hmi_t_P2Pause_ms:
                900 s
            hmi_t_Quit_ms:
                10 s
            hmi_t_FondGurt:
                35 s
            hmi_t_USZ:
                0.20 s
            hmi_t_FTuerAUF:
                300 ms
            hmi_t_P1Pause_ms:
                20 s
            rollierblockgroesse:
                3
        Dist. rec.:
                11157 km
        Picture_Upload_Download:
                inactivo
        FIJO: Kilometraje desde última rev. en función del kilometraje:
                11100 km
        Fijo: Kilometraje máx. hasta siguiente rev. en función de kil.:
                30000 km
        Offset p. val. de calibr. del depósito:
            Offset transmisor 1:
                -12.8 l
            Offset transmisor 2:
                12.7 l
            Offset transmisor 3:
                12.7 l
            Offset transmisor 4:
                12.7 l
            Depósito calibr. completo:
                -12.8 l
        Advertencia previa de servicio en día:
                30 d
        SIA: valor máx. de tiempo hasta servicio:
                365 d
        Fuente p. sincronización de la hora:
                Reloj interno
        Desactivar advertencia cinturón:
                no
        Hora:
                18 h
        PIM: reiniciar prolong. interv. mant.:
                ninguna advertencia
        Indicación de la temperatura del aceite:
                on
        FIJO: Tiempo máx. hasta siguiente rev. en función del tiempo:
                730 d
        Contador de días:
                772 d
        FIJO: valor reposic. próx inspec en función del tiempo:
                365 d
        Reset MFA3:
            Tecla del indicador multifunción RESET / OK:
                Reset manual, no posible
            Detección de repostaje post. gasolina / gasóleo:
                Reset MFA3
            Detección repostaje post. gas:
                Reset MFA3
            Nachtankerkennung Elektro:
                Reset MFA3
        SIA: valor máx. de trayecto hasta servicio:
                15000 km
        Unidades ajustadas:
            Volumen:
                litros
            Temperatura:
                grados Celsios
                Litros a los 100 km
            Presión:
                bares
            Dist. rec.:
                kilómetros
            Velocidad:
                Kilómetros por hora
            fecha:
                dd_mm_jj
            Hora:
                24h
                kg por 100 km
                kWh por 100 km
                kg
        PIM: valor mínimo de km-prestación kilométrica/revisión:
                15000 km
            send_messages:
                inactivo
        Año:
                2019 a
        Mes:
                8 mes
                inactivo
            Unidad:
                Kilómetros por hora
            Velocidad:
                70
        FIJO: valor reposic. próx inspec en función del kilometraje:
                30000 km
        Imagen en pantalla:
                Variante 1
        outside_temperature:
            p_time_constant_pt1:
                40 s
            p_speed_threshold:
                20 km/h
            p_kmt_at_delta:
                25 °C
            p_blocking_time_after_v_bigger_0:
                15 s
            p_storage_time_engine_off:
                180 min
            p_mileage_after_v_bigger_0:
                5.0 km
            p_ice_warning_exit_temperature:
                6 °C
            p_ice_warning_entry_temperature:
                4 °C
            p_tendency_threshold:
                1.0 °C
            p_time_constant_slow_damping:
                2.0
            p_tendency_damping:
                15 s
        Perfil de marcha para alcance restante:
                6.8 l/100 km
        PIM: tiempo tras inspección:
                136 d
        FIJO: Tiempo desde última revisión en función del tiempo:
                741 d
        PIM: valor máximo de km-prestación kilométrica/revisión:
                30000 km
        Service_Key_Clear_All_Counter:
            clear_all_counter:
                sí
        PIM: valor máximo del tiempo transcurrido entre revisiones:
                730 d
        PIM: carga térmica:
                2300 km
        PIM: Recorrido tras inspección:
                1660 km
        Ajustes llave de servicio:
            p_write_delay_time:
                40 s
            p_write_delay_speed:
                20 km/h
            p_write_distance:
                20 km
            p_forcewrite_qual_time:
                10 s
            p_main_switch_Keyless:
                on
            p_main_switch_Basic:
                on
            p_deactivate_SK_Function:
                on
        PIM: valor mínimo del tiempo transcurrido entre revisiones:
                365 d
        PIM: entrada de hollín:
                0 km
        Corrección del indicador de consumos y alcance:
                100 %
        Configuration of Development CAN-Messages:
            Block 1:
                off
            Block 12:
                off
            Block 2:
                off
            Block 3:
                off
            Block 4:
                off
            Block 5:
                off
            Block 6:
                off
            Block 7:
                off
            Block 8:
                off
            Block 9:
                off
            Block 10:
                off
            Block 11:
                off
            Block 13:
                off
            Block 14:
                off
            Block 15:
                off
            Block 16:
                off
            Block 17:
                off
            Block 18:
                off
            Block 19:
                off
            Block 20:
                off
            Block 21:
                off
            Block 22:
                off
            Block 23:
                off
            Block 24:
                off
            Block 25:
                off
            Block 26:
                off
            Block 27:
                off
            Block 28:
                off
            Block 29:
                off
            Block 30:
                off
            Block 31:
                off
            Block 32:
                off
            Block 33:
                off
            Block 34:
                off
            Block 35:
                off
            Block 36:
                off
            Block 37:
                off
            Block 38:
                off
            Block 39:
                off
        Minuto:
                19 min
        Idioma:
                Español
        PIM: calidad del aceite:
                Buena calidad del aceite
        dimming_characteristic_curve_adjustment_internal_phototransistor:
            X1:
            Y1:
            X2:
            Y2:
                a
            X3:
                32
            Y3:
                32
            X4:
                12c
            Y4:
                96
            X5:
                1f4
            Y5:
                fd
        BAP_Debug_Mode_Release:
            Release:
                not_released
        UC de la interfaz del sistema de localización del vehículo:
                Sin montar
        Encendido activo mensaje, excitador:
                Puerta del conductor
        defuel_threshold:
            defuel_threshold:
                9 l
        init_fuel_algorithm:
            initialisation:
                no
                no activado
        Gas_functionality:
            Gas_functionality:
                inactivo
        total_range_gas:
            state:
                inactivo
            selection_consumption_factor:
                consumption_factor_CAN
            consumption_profile:
                consumption_profile_calculation
            consumption_factor:
                0.000
        Desactivación del cilindro:
                Indicación
        Illumination_algorithm:
            Pointer_illumination_algorithim:
                terminal_58xd_log_bus_parkinglight
            Scale_switching_algorithm:
                parking_light
        dimming_characteristic_curve_adjustment_fpk_middle_display_main_field:
            X1:
            Y1:
                9
            X2:
                a
            Y2:
                9
            X3:
                64
            Y3:
                50
            X4:
                96
            Y4:
                190
            X5:
                dc
            Y5:
                352
            X6:
                fd
            Y6:
                3e8
        dimming_characteristic_curve_adjustment_fpk_indicator_lights:
            X1:
            Y1:
                32
            X2:
                a
            Y2:
                32
            X3:
                32
            Y3:
                78
            X4:
                64
            Y4:
                e6
            X5:
                96
            Y5:
                1f4
            X6:
                fd
            Y6:
                3e8
        Preaviso del Servicio:
                30 d
        Statistic_phev_mileage:
                5 km
        Leaving_warning_delay:
                1.6 s
        Display Farbabgleich:
            Rojo:
            Verde:
            Azul:
                lowbeam_foglight
        Tube_version:
                variant_0
        Display_longitudinal_coordinator:
            Control de crucero adaptativo (ACC):
                inactivo
            GRA:
                inactivo
            Limitador de velocidad:
                inactivo
        Second_digital_speed:
                Indicación
energy22
Spain
Modulo 19 Correct
Now it's correct ..
Fecha: 2019-08-13 18:21
    Año: 2018
Copia de seguridad
    Unidad de Control: 19 Interfaz de diagnóstico de datos
    Descripción del sistema: GW MQB High
    Número de software: 3Q0907530G
    Versión de software: 5304
    Número de hardware: 3Q0907530C
    Versión de Hardware: 518
    Número de serie: 01061710802433
    Nombre ODX: EV_GatewNF
    Versión ODX: 013023
    Nombre de copia de seguridad: modulo19 130819
        030100047F085700FB000258080F00010001070000000000000000000000
        Sollverbau_MFL:
            montado
        EHR_EHRPsd15ProviderVerbaut_CO:
            Sin montar
        MV-EM_Stützung:
            inactivo
        EM_Ref_Spannungsmessung_Inaktiv:
            sí
        HV-EM_Klima_Codierung:
        MKE_Funktion:
            activado
        EM_Batterie_Verbauort:
            8
        EM_Generator_Uebersetzung:
            57
        FPA_Taster_Auswertung:
            Flanco ascendente
        MKE_Variante:
            7
    Sub sistemas:
        Sub sistema: E221__MFL-DC1
        Codificación extendida: 2CFFFF
    Adaptaciones:
            Interfaz de diagnóstico para el bus de datos:
                Codificado
            Node_0x01:
                Sin codificar
            Node_0x02:
                Sin codificar
            Node_0x03:
                Sin codificar
            Node_0x04:
                Sin codificar
            Node_0x05:
                Sin codificar
            Node_0x06:
                Sin codificar
            Node_0x07:
                Sin codificar
            Node_0x08:
                Sin codificar
                Codificado
            aparcamiento asistido:
                Codificado
            Supervisión presión neum.:
                Sin codificar
            el sistema electrónico de la columna de dirección:
                Codificado
            Node_0x0D:
                Sin codificar
            Centralita eléctrica electrónica:
                Codificado
            Electrónica de todas las ruedas:
                Sin codificar
            Node_0x11:
                Sin codificar
            Dirección asistida:
                Codificado
            Electrónica de los frenos:
                Codificado
            Cuadro de instrumentos:
                Codificado
            Airbag:
                Codificado
            Node_0x16:
                Sin codificar
            Node_0x17:
                Sin codificar
            Radio:
                Sin codificar
            Compresor climatizador:
                Sin codificar
            Node_0x1A:
                Sin codificar
            Pantalla elevada:
                Sin codificar
            Actuador para la sonoridad del motor:
                Sin codificar
            Node_0x1D:
                Sin codificar
            Sistema eléctrico de bloqueo:
                Sin codificar
            Node_0x1F:
                Sin codificar
            Node_0x20:
                Sin codificar
            Node_0x21:
                Sin codificar
            Node_0x22:
                Sin codificar
            Sistema electrónico de la puerta del maletero:
                Sin codificar
            Node_0x24:
                Sin codificar
            Node_0x25:
                Sin codificar
            Node_0x26:
                Sin codificar
            Node_0x27:
                Sin codificar
            Node_0x28:
                Sin codificar
            Node_0x29:
                Sin codificar
            Node_0x2A:
                Sin codificar
            Función especial 2:
                Sin codificar
            Función especial:
                Sin codificar
            Accionamiento eléct. techo:
                Sin codificar
            Node_0x2E:
                Sin codificar
            Node_0x2F:
                Sin codificar
            Asistente de luz de carretera:
                Sin codificar
            Bloqueo columna direc.:
                Sin codificar
            Interfaz para sist. acceso y arranque:
                Sin codificar
            Puerta corrediza tras. izq.:
                Sin codificar
            Puerta corrediza tras. der.:
                Sin codificar
            Node_0x35:
                Sin codificar
            Node_0x36:
                Sin codificar
            Node_0x37:
                Sin codificar
            Node_0x38:
                Sin codificar
            Node_0x39:
                Sin codificar
            Node_0x3A:
                Sin codificar
            Servofreno:
                Sin codificar
            Node_0x3C:
                Sin codificar
            Node_0x3D:
                Sin codificar
            Electr. pta. lado conductor detrás:
                Sin codificar
            Electr. pta. lado acomp. detrás:
                Sin codificar
            Node_0x40:
                Sin codificar
            Node_0x41:
                Sin codificar
            Gestión térmica:
                Sin codificar
            Node_0x43:
                Sin codificar
            Cargador de la batería de alto voltaje:
                Sin codificar
            Node_0x45:
                Sin codificar
            Electrónica del aire acondicionado/de la calefacción:
                Codificado
            Función remolque:
                Sin codificar
            Node_0x48:
                Sin codificar
            Node_0x49:
                Sin codificar
            Electrónica pta. conductor:
                Codificado
            Electrónica pta. acomp.:
                Codificado
            Regulación del asiento del lado del conductor:
                Sin codificar
            Regulación del asiento, lado del acompañante:
                Sin codificar
            Sistema de asistencia para cambio de carril:
                Sin codificar
            Sensores frontales de sist de asist al conductor:
                Sin codificar
            Detección de la posición del vehículo:
                Sin codificar
            Node_0x51:
                Sin codificar
            Node_0x52:
                Sin codificar
            Node_0x53:
                Sin codificar
            del alcance de las luces:
                Sin codificar
            Node_0x55:
                Sin codificar
            Node_0x56:
                Sin codificar
            Regulación de la distancia:
                Codificado
            Node_0x58:
                Sin codificar
            Node_0x59:
                Sin codificar
            Node_0x5A:
                Sin codificar
            Node_0x5B:
                Sin codificar
            Node_0x5C:
                Sin codificar
            Node_0x5D:
                Sin codificar
            Node_0x5E:
                Sin codificar
            Node_0x5F:
                Sin codificar
            Node_0x60:
                Sin codificar
            Node_0x61:
                Sin codificar
            Node_0x62:
                Sin codificar
            UC del micrófono:
                Sin codificar
            Actuador para sonido ext.:
                Sin codificar
            Gestión de carga de la batería de alto voltaje:
                Sin codificar
            Node_0x66:
                Sin codificar
            Módulo llamada de emergencia y unidad de comunicación:
                Sin codificar
            Node_0x68:
                Sin codificar
            Sist. cámara marcha atrás:
                Sin codificar
            Calefacción adicional/auxiliar:
                Sin codificar
            Node_0x6B:
                Sin codificar
            Node_0x6C:
                Sin codificar
            Receptor de TV:
                Sin codificar
            Node_0x6E:
                Sin codificar
            Sistema de sonido:
                Sin codificar
            Media Player 1:
                Sin codificar
            Tacógrafo:
                Sin codificar
            Sistema electrónico de amortiguación de las ruedas:
                Sin codificar
            Electrónica de información 1:
                Codificado
            Node_0x74:
                Sin codificar
            Node_0x75:
                Sin codificar
            Electrónica del motor:
                Codificado
            Electrónica del cambio:
                Sin codificar
            Node_0x78:
                Sin codificar
            Node_0x79:
                Sin codificar
            Node_0x7A:
                Sin codificar
            Gestión de batería híbrida:
                Sin codificar
            Tracción eléctrica:
                Sin codificar
            Node_0x7D:
                Sin codificar
            Node_0x7E:
                Sin codificar
            Node_0x7F:
                Sin codificar
            Node_0x80:
                Sin codificar
            Node_0x81:
                Sin codificar
            Node_0x82:
                Sin codificar
            Node_0x83:
                Sin codificar
                Sin codificar
            Alternador motor arranque:
                Sin codificar
            Node_0x86:
                Sin codificar
            Node_0x87:
                Sin codificar
            Node_0x88:
                Sin codificar
            Node_0x89:
                Sin codificar
            Sistema de asistencia de cambio de carril 2:
                Sin codificar
            Node_0x8B:
                Sin codificar
            Node_0x8C:
                Sin codificar
            Node_0x8D:
                Sin codificar
            Node_0x8E:
                Sin codificar
            Node_0x8F:
                Sin codificar
            Node_0x90:
                Sin codificar
            Node_0x91:
                Sin codificar
            Node_0x92:
                Sin codificar
            Node_0x93:
                Sin codificar
            Node_0x94:
                Sin codificar
            Node_0x95:
                Sin codificar
            Node_0x96:
                Sin codificar
            Node_0x97:
                Sin codificar
            Node_0x98:
                Sin codificar
            Node_0x99:
                Sin codificar
            Node_0x9A:
                Sin codificar
            Node_0x9B:
                Sin codificar
            Gestión de batería 2:
                Sin codificar
            Node_0x9D:
                Sin codificar
            Node_0x9E:
                Sin codificar
            Node_0x9F:
                Sin codificar
            Node_0xA0:
                Sin codificar
            Node_0xA1:
                Sin codificar
            Node_0xA2:
                Sin codificar
            Node_0xA3:
                Sin codificar
            Calefacción adicional por aire:
                Sin codificar
            Node_0xA5:
                Sin codificar
            Node_0xA6:
                Sin codificar
            Node_0xA7:
                Sin codificar
            Node_0xA8:
                Sin codificar
                Codificado
            Node_0xAA:
                Sin codificar
            Node_0xAB:
                Sin codificar
            Node_0xAC:
                Sin codificar
            Node_0xAD:
                Sin codificar
            la regulación de la batería:
                Sin codificar
            Node_0xAF:
                Sin codificar
            Node_0xB0:
                Sin codificar
            Node_0xB1:
                Sin codificar
            Node_0xB2:
                Sin codificar
            Node_0xB3:
                Sin codificar
            Node_0xB4:
                Sin codificar
            Node_0xB5:
                Sin codificar
            Node_0xB6:
                Sin codificar
            Node_0xB7:
                Sin codificar
            Node_0xB8:
                Sin codificar
            Node_0xB9:
                Sin codificar
            Node_0xBA:
                Sin codificar
            Node_0xBB:
                Sin codificar
            Node_0xBC:
                Sin codificar
            Node_0xBD:
                Sin codificar
            Node_0xBE:
                Sin codificar
            Node_0xBF:
                Sin codificar
            Node_0xC0:
                Sin codificar
            Node_0xC1:
                Sin codificar
            Node_0xC2:
                Sin codificar
            Node_0xC3:
                Sin codificar
            Node_0xC4:
                Sin codificar
            Node_0xC5:
                Sin codificar
            Node_0xC6:
                Sin codificar
            Node_0xC7:
                Sin codificar
            Node_0xC8:
                Sin codificar
            Node_0xC9:
                Sin codificar
            Node_0xCA:
                Sin codificar
            Node_0xCB:
                Sin codificar
            Node_0xCC:
                Sin codificar
            Node_0xCD:
                Sin codificar
            Node_0xCE:
                Sin codificar
            Node_0xCF:
                Sin codificar
            Node_0xD0:
                Sin codificar
            Node_0xD1:
                Sin codificar
            Node_0xD2:
                Sin codificar
            Node_0xD3:
                Sin codificar
            Node_0xD4:
                Sin codificar
            Node_0xD5:
                Sin codificar
            Node_0xD6:
                Sin codificar
            Node_0xD7:
                Sin codificar
            Node_0xD8:
                Sin codificar
            Node_0xD9:
                Sin codificar
            Node_0xDA:
                Sin codificar
            Node_0xDB:
                Sin codificar
            Node_0xDC:
                Sin codificar
            Node_0xDD:
                Sin codificar
            Node_0xDE:
                Sin codificar
            Node_0xDF:
                Sin codificar
            Node_0xE0:
                Sin codificar
            Node_0xE1:
                Sin codificar
            Node_0xE2:
                Sin codificar
            Node_0xE3:
                Sin codificar
            Node_0xE4:
                Sin codificar
            Node_0xE5:
                Sin codificar
            Node_0xE6:
                Sin codificar
            Node_0xE7:
                Sin codificar
            Node_0xE8:
                Sin codificar
            Node_0xE9:
                Sin codificar
            Node_0xEA:
                Sin codificar
            Node_0xEB:
                Sin codificar
            Node_0xEC:
                Sin codificar
            Node_0xED:
                Sin codificar
            Node_0xEE:
                Sin codificar
            Node_0xEF:
                Sin codificar
            Node_0xF0:
                Sin codificar
            Node_0xF1:
                Sin codificar
            Node_0xF2:
                Sin codificar
            Node_0xF3:
                Sin codificar
            Node_0xF4:
                Sin codificar
            Node_0xF5:
                Sin codificar
            Node_0xF6:
                Sin codificar
            Node_0xF7:
                Sin codificar
            Node_0xF8:
                Sin codificar
            Node_0xF9:
                Sin codificar
            Node_0xFA:
                Sin codificar
            Node_0xFB:
                Sin codificar
            Node_0xFC:
                Sin codificar
            Node_0xFD:
                Sin codificar
            Node_0xFE:
                Sin codificar
            Node_0xFF:
                Sin codificar
I'm not sure what these maps are from. Spanish language ODIS? Doesn't matter.
This is the Ross-Tech forum. It exists to support Ross-Tech's customers. So please post data from VCDS. If you don't have VCDS, then you are seeking help in the wrong place.
^^^hmmm..... they look like OBDeleven back-up files to me in Spanish-in the main. And the last post appears to be a "history" file from the same device
