Audi A5 8T Reverse Camera Calibration/Coding
MAJones89
C?ID=373177
Hi,
First time user of VCDS here, i've just registered it but not sure how i go about linking it to this account?
I had a reversing camera installed a couple of weeks ago by a professional retrofitting company here in the UK. Despite specifically checking that they will calibrate the camera, my first auto scan shows it as not calibrated :banghead:
Now I've got my own VCDS and a print off of the calibration board I've decided to give it a go myself.
The coding i've tried to enter for module 6C is 1032006 which gave me an 'error 31 - request out of range'. Is this because the company i used have kindly installed a Q5 camera module into my A5? As the coding 1032010 was accepted. (last 2 digits are 06 for A5 & 10 for Q5)
After the above coding was accepted i changed the various adaptation numbers as required and the calibration was successful.
My question is what difference it makes with the 6C coding being wrong for my car? Do the last 2 digits (which relate to the car model) just affect the adaptation default values?
Scan after calibration below
Saturday,10,August,2019,15:23:33:33426
VIN: WAUZZZ8T2FA048289   License Plate:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F 62 69
          6C 72
VIN: WAUZZZ8T2FA048289   Mileage: 68920km-42824miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 KL    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Coding: 0A254012243601080000
   Shop #: WSC 24483 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018KL 003009
   ROD: EV_ECM20TDI01103L906018KK.rod
   VCID: 7EA5FED3D07F5CD7B85-802A
   Part No SW: 8K9 927 156 S    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H03 0005
   Revision: --H03---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 4DC7691F2D59374F71F-8018
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 359DCC01
   VCID: 094F9D0F99316B6F9D7-805C
   Part No SW: 8K0 907 064 KE    HW: 8K0 907 064 KE
   Component: BCM2 2.0      H15 0711
   Coding: 01B44040000000000000
   VCID: 7DA7F9DFDDF947CFA1F-8028
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0515000015944001
   Serial number: 3215000026633001
   Part No SW: 8K2 820 043 BB    HW: 8K2 820 043 BB
   Revision: D1000000    Serial number: 01160220152780
   Coding: 342402E000
   VCID: 6A8DC283BC77C07774D-803E
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00001004059602
   Coding: 260000108034AFE00781408300001D0D009D634827090201000008004400030100000034000000
   Shop #: WSC 01211 210 01254
   VCID: 78A9E8CBF2DB62E7F29-802C
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 090215  H13 0080
   Serial number: SWF15022095188
   Coding: 00FD31
   Serial number: 20129513
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001102150507
   Serial number: E4B88397000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC5WB1Q
   Coding: 30533938363030303030554A305238543053
   VCID: 48C9580BC23BD267429-801C
   Serial number: 6334MSME4E192A63M
   Serial number: 6344MSME4E3D7104K
   Serial number: 6352QSME764D1B66V
   Serial number: 6362QSME2E501264C
   Serial number: 63732SME7F4D21468
   Serial number: 63832SME7F4D20604
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862OBD0002D
   Coding: 000036
   VCID: 48C9580BC2BBD267429-801C
   Part No SW: 8T0 920 984 K    HW: 8T0 920 984 K
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 5L+3APA2G
   Coding: 33A7310003012600010400
   VCID: 47CB5B37CFA5DD1F4B3-8012
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y152100C45
   Coding: 80CF07FF00
   VCID: 4ACD6203DCB7207754D-801E
   Serial number: 5458155803
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 15040000605021200410
   Part No SW: 8T0 959 793 Q    HW: 8T0 959 793 F
   Component: TSG FA        H10 0305
   Coding: 011002624001450005
   VCID: 57EB8B771F054D9FDB3-8002
   Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0011502315
   Coding: 100000010001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3E253ED390FF9CD7F85-806A
   Revision: 00002001    Serial number: 0360423804
   Coding: 013B0622A0B900008320043680000047
   Revision: 00005001    Serial number: 94813040423706
   VCID: 2D07099F4D19174F51F-8078
   Part No SW: 8T0 959 792 Q    HW: 8T0 959 792 H
   Component: TSG BF        H09 0305
   Coding: 011002224001450005
   VCID: 56F58673180F7497C05-8002
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 30000000333833
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D32C38CD7B0F7C4D-806E
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109BK0F8010341
   Coding: 010103010000000001
   VCID: 2B030787730D197F4FB-807E
   Part No SW: 8R2 035 666 H    HW: 8R2 035 666 H
   Component: H-BN-EU       H48 0897
   Revision: --------    Serial number: 515BS0F7512306
   Coding: 130101040006A1EF0580AB5E00000403E40000020000000000
   VCID: 3E253ED3907F9CD7F85-806A
   Subsystem 1 - Part No: 8R0 060 884 GA
   Component: EUR 2019  2802
   Component: DU7 High  H42 0104
   Serial number: A130BT0F3261668
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000002127159
   Component: CD-Database  5950
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H08 0305
   Coding: 010002224001450005
   VCID: 59EF8D4F69115BEFED7-800C
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H12 0100
   Revision: 1A001001    Serial number: 00000360403068
   Coding: 010D000000000000
   Shop #: WSC 25381 000 00000
   VCID: 363526F3B84F5497205-8062
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H08---    Serial number: 525PA8-J3940QN
   Coding: 1032010
   VCID: 34311CFBA23346871E1-8060
   Component: TSG HR        H08 0305
End----(Elapsed Time: 01:46, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
Matt
Done, Verified. Moving to Retrofits.
