VW Scirocco 2009MY ABS Coding help
totaltuning
C?ID=255206
Hi, car arrived into the shop for an ABS problem. After an autoscan it's apparent there is no coding stored in the ABS (the customer doesn't know how this happened!). Attached below the autoscan, if anyone can generate long coding it's much appreciated, thanks.
Thursday,08,August,2019,11:42:13:23296
VCDS Version: 19.6.1.0
VIN: WVWZZZ13Z9V027187   License Plate: SCIROCCO
Mileage: 247080km-153528mi   Repair Order: NAIL
Chassis Type: 13 (1K0)
Scan: 01 03 08 09 14 15 16 17 19 25 2E 42 44 46 52 56
VIN: WVWZZZ13Z9V027187   Mileage: 247080km-153528miles
46-Central Conv. -- Status: Cannot be reached 1100
Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 KD    HW: 03L 906 022 G
   Component: R4 2,0L EDC 0000SG  6166
   Revision: 13H01---    Serial number: VWX7Z0I03N8082
   Coding: 0001072
   Shop #: WSC 00864 210 104192
   VCID: 71E9820B68F21AC766-8024
000258 - Mass Air Flow Sensor (G70)
               P0102 - 000 - Signal too Low - Intermittent
                    Voltage: 5.85 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 560.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
000256 - Mass Air Flow Sensor (G70)
               P0100 - 000 - Supply Voltage - Intermittent
                    Mileage: 247041 km
                    Time: 13:55:27
                    Voltage: 5.62 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 640.0 mg/str
000257 - Mass Air Flow Sensor (G70)
               P0101 - 000 - Implausible Signal - Intermittent
                    Mileage: 246833 km
                    Time: 11:57:26
                    Voltage: 5.85 V
                    Load: 100.0 %
                    Load: 100.0 %
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Voltage: 0.00 V
                    Hex Value: 0xFF00
                    Bin. Bits: 00000000
                    Temperature: -90.0°C
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Voltage: 9.12 V
                    Voltage: 9.12 V
                    Voltage: 9.12 V
                    Voltage: 9.12 V
001552 - Engine Control Unit Incorrectly Coded
               P0610 - 000 -  - Intermittent
                    Mileage: 247041 km
                    Voltage: 10.64 V
                    Voltage: 10.64 V
                    Voltage: 10.64 V
                    Voltage: 10.64 V
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 00020 790 00000
   VCID: 74E78B1FD7E02FEF8D-8020
                    Reset counter: 2
                    Count: 4608
                    Count: 195
                    Count: 44288
                    Count: 65280
   Part No SW: 1K0 907 044 CT    HW: 1K0 907 044 CT
   Component: ClimatronicPQ35 133 1213
   Revision: 00133024    Serial number: 00000000000000
   VCID: 7BF5A0233ABE6097CC-802E
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Revision: 00H54000    Serial number: 00000009341371
   Coding: ED880F0300041A0067960E001900000000087F075C400124000000000000
   VCID: 33654803526E68D754-8066
   Subsystem 1 - Part No: 1K8 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 151008 022  0602
   Coding: 00038805
   Shop #: WSC 00020
   Component: RLS     030209 054  0402
   Coding: 00209133
   Shop #: WSC 00020
                    Reset counter: 2
                    Mileage: 247082 km
                    Voltage: 12.10 V
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 28010907670001
   Coding: 000180
   Shop #: WSC 00864 210 104205
   VCID: 275DAC5356B61477F8-8072
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 2
                    Mileage: 247082 km
                    Time: 20:22:51
                    Bin. Bits: 00000000 00001000
00144 - Rear Left Dampening Adjustment Valve (N338)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Reset counter: 2
                    Mileage: 247082 km
                    Time: 20:27:00
                    Bin. Bits: 00000000 00100000
00145 - Rear Right Dampening Adjustment Valve (N339)
                    Reset counter: 2
                    Mileage: 247082 km
                    Time: 20:27:00
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0H AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D00RXW-
   Coding: 0012360
   VCID: 6FED84737EC60C3770-803A
   Subsystem 1 - Serial number: 6332MSME436531531
   Subsystem 2 - Serial number: 6342MSME4364746AG
   Subsystem 3 - Serial number: 6352QSME2501023A0
   Subsystem 4 - Serial number: 6362QSME671F0520E
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           055 0111
   Coding: 0000102
   VCID: 78FFBF2F0B884B8FA1-802C
   Component: E0221           002 0030
   Part No SW: 1K8 920 970 G    HW: 1K8 920 970 G
   Component: KOMBIINSTRUMENT VDD 2444
   Revision: V0005000    Serial number: VWX7Z0I03N8082
   Coding: 0003403
   Shop #: WSC 00864 067 57207
   VCID: 36637117411C7DFF73-8062
                    Reset counter: 2
                    Mileage: 247082 km
                    Time: 20:22:51
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H-- 0210
   Revision:   H--       Serial number:
H00K09131067E
   Coding: E9881F06000212004001
   VCID: 377D7C13461684F768-8062
                    Reset counter: 2
                    Mileage: 247082 km
                    Time: 20:22:55
   Component: IMMO            VDD 2444
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0084
   Revision: A1001003    Serial number: 7667348558
   VCID: 2643A15751BC0D7FC3-8072
   Part No SW: 1Q0 959 701 F    HW: 1Q0 959 701 F
   Component: Tuer-SG         008 2022
   Coding: 0016949
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 178    2501
   Revision: 00H15000
   VCID: 2C57537F8F50372F15-8078
Address 46: Central Conv.
   Part No SW: 1Q0 959 702 F    HW: 1Q0 959 702 F
   Coding: 0016948
   VCID: 387F7F2F4B088B8F61-806C
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3I4215928
   Coding: 0100040004
   VCID: 65C1E65B6C3AC6670A-8030
End-------------------------(Elapsed Time: 02:00)--------------------------
NostraJackAss
Vehicle Identification No.WVWZZZ13Z9V027187
ModelScirocco 2.0
SCI
Date of production18.02.2009
Model year2009
Sales type13726L
Engine CodeCBDB
Transmission CodeKRM
Part No SW: 03L 906 022 KD HW: 03L 906 022 G <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
Coding: 0001072
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
Revision: 00H35001
OP:
Because all I see is you are here is for taking ABS coding I will not help you further.
Anyone else please have at it.........
Coding: 763B00F5092400016E0C00EC902000000000 VIN STRIP RHD DECRYPT
PART NUMBERDESCRIPTIONREMARKMODEL
1K0 907 375 ANControl unit for ABS1K0 614 517 BJ
1K0 907 379 AN
1K0 614 517 BD
1K0 907 379 AD
1K0 907 379 CD
PR-UG0
SCANS OF NET STARTED FOR ABSTRACTS NOT YOUR CODING!
Coding: 763B40F5492500016E0B02E9921C0082300000
Coding: 763B40F5492600FC6E1102E992200082300000
Coding: 763B40F5492500006E0E02E6921D0082300000
[TABLE="class: vinInfoTable, width: 533"]
[TR]
[TH="align: left"]Special editions[/TH]
[TD="class: prCode"]E0A[/TD]
[TD]Without special action equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PE[/TD]
[TD]Wheel bolts with anti-theft protection
(unlockable)[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle class differentiation
units/platform components[/TH]
[TD="class: prCode"]7KB[/TD]
[TD]Vehicle class differentiation -130-[/TD]
[/TR]
[TR]
[TH="align: left"]drive-off assistance[/TH]
[TD="class: prCode"]UG0[/TD]
[TD]Without hill start assist/hill descent
control/comfort driving assist[/TD]
[/TR]
[TR]
[TH="align: left"]Emission standard[/TH]
[TD="class: prCode"]7MG[/TD]
[TD]Emission standard EU5[/TD]
[/TR]
[TR]
[TH="align: left"]Trailer hitch[/TH]
[TD="class: prCode"]1D0[/TD]
[TD]without trailer towing[/TD]
[/TR]
[TR]
[TH="align: left"]airbag[/TH]
[TD="class: prCode"]4UF[/TD]
[TD]Airbag for driver and front passenger
with front passenger airbag
deactivation[/TD]
[/TR]
[TR]
[TH="align: left"]Aktivkohlebehälter / Ottopartikelfilter[/TH]
[TD="class: prCode"]1E0[/TD]
[TD]Without activated charcoal canister[/TD]
[/TR]
[TR]
[TH="align: left"]Aerials[/TH]
[TD="class: prCode"]8ZH[/TD]
[TD]Antenna for AM/FM reception, "diversity"[/TD]
[/TR]
[TR]
[TH="align: left"]Exterior mirror setting[/TH]
[TD="class: prCode"]6XN[/TD]
[TD]Exterior mirrors, power-adjustable/
separately heated[/TD]
[/TR]
[TR]
[TH="align: left"]Left exterior mirror[/TH]
[TD="class: prCode"]5SJ[/TD]
[TD]Left exterior mirror, convex[/TD]
[/TR]
[TR]
[TH="align: left"]Right exterior mirror[/TH]
[TD="class: prCode"]5RV[/TD]
[TD]Right exterior mirror, aspherical[/TD]
[/TR]
[TR]
[TH="align: left"]Drive type[/TH]
[TD="class: prCode"]1X0[/TD]
[TD]Front-wheel drive[/TD]
[/TR]
[TR]
[TH="align: left"]"Multimedia"video/DVD/notebook connection[/TH]
[TD="class: prCode"]9WL[/TD]
[TD]Jack for external audio source[/TD]
[/TR]
[TR]
[TH="align: left"]Equipment levels[/TH]
[TD="class: prCode"]A8F[/TD]
[TD]Sports equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type in rear[/TH]
[TD="class: prCode"]1KD[/TD]
[TD]Disc brakes in rear[/TD]
[/TR]
[TR]
[TH="align: left"]batteries[/TH]
[TD="class: prCode"]J0N[/TD]
[TD]Battery 330 A (61 Ah)[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type, front[/TH]
[TD="class: prCode"]1ZE[/TD]
[TD]Disc brakes in front (Geomet D)[/TD]
[/TR]
[TR]
[TH="align: left"]Battery/alternator capacity[/TH]
[TD="class: prCode"]NY0[/TD]
[TD]Standard battery/alternator capacity[/TD]
[/TR]
[TR]
[TH="align: left"]Component part sets with
country-specific design requirements[/TH]
[TD="class: prCode"]B0N[/TD]
[TD]Component parts set, complying with
vehicle type for Great Britain, various
parts[/TD]
[/TR]
[TR]
[TH="align: left"]vehicle tools and jack[/TH]
[TD="class: prCode"]1S1[/TD]
[TD]vehicle tools and jack[/TD]
[/TR]
[TR]
[TH="align: left"]Brake systems[/TH]
[TD="class: prCode"]1AT[/TD]
[TD]Electronic stability control (ESC)[/TD]
[/TR]
[TR]
[TH="align: left"]Owner's manuals[/TH]
[TD="class: prCode"]0VF[/TD]
[TD]Information kit in English[/TD]
[/TR]
[TR]
[TH="align: left"]brake wear indicator[/TH]
[TD="class: prCode"]9U1[/TD]
[TD]brake wear indicator[/TD]
[/TR]
[TR]
[TH="align: left"]Heated washer nozzles[/TH]
[TD="class: prCode"]9T0[/TD]
[TD]Without heated washer nozzles[/TD]
[/TR]
[TR]
[TH="align: left"]CD ROM/DVD/SD card[/TH]
[TD="class: prCode"]7QA[/TD]
[TD]Without CD/DVD for navigation[/TD]
[/TR]
[TR]
[TH="align: left"]CD changer/CD player[/TH]
[TD="class: prCode"]7A0[/TD]
[TD]Without CD changer/CD player[/TD]
[/TR]
[TR]
[TH="align: left"]"Charism"[/TH]
[TD="class: prCode"]2H1[/TD]
[TD]"drive select"[/TD]
[/TR]
[TR]
[TH="align: left"]General operating permit, alterations[/TH]
[TD="class: prCode"]C03[/TD]
[TD]Operating permit, alteration[/TD]
[/TR]
[TR]
[TH="align: left"]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FA[/TD]
[TD]roof without cut out[/TD]
[/TR]
[TR]
[TH="align: left"]Suspension system in rear[/TH]
[TD="class: prCode"]UB7[/TD]
[TD]Rear shock absorption for sports version[/TD]
[/TR]
[TR]
[TH="align: left"]Suspension system in front[/TH]
[TD="class: prCode"]G03[/TD]
[TD]Shock absorption in front[/TD]
[/TR]
[TR]
[TH="align: left"]Insert for the filling up of unleaded
fuel/fuel type[/TH]
[TD="class: prCode"]2G5[/TD]
[TD]Filler neck module 1 without insert[/TD]
[/TR]
[TR]
[TH="align: left"]Installation differentiation for components[/TH]
[TD="class: prCode"]0EN[/TD]
[TD]Installation differentiation for
transmission MQ 350
-- vehicle components --[/TD]
[/TR]
[TR]
[TH="align: left"]Theft protection system[/TH]
[TD="class: prCode"]7AL[/TD]
[TD]Anti-theft alarm system, interior
monitoring, backup horn and towing
protection[/TD]
[/TR]
[TR]
[TH="align: left"]Park distance control[/TH]
[TD="class: prCode"]7X0[/TD]
[TD]Without park distance control[/TD]
[/TR]
[TR]
[TH="align: left"]Electric interface for external use[/TH]
[TD="class: prCode"]UF6[/TD]
[TD]Electric interface for external use
(MEDIA-IN jack)[/TD]
[/TR]
[TR]
[TH="align: left"]Manufacturing sequence differentiation[/TH]
[TD="class: prCode"]0FA[/TD]
[TD]Standard manufacturing sequence[/TD]
[/TR]
[TR]
[TH="align: left"]window regulator[/TH]
[TD="class: prCode"]4R4[/TD]
[TD]Power windows with comfort operation and
circuit breaker[/TD]
[/TR]
[TR]
[TH="align: left"]fire extinguisher[/TH]
[TD="class: prCode"]6A0[/TD]
[TD]without fire extinguisher[/TD]
[/TR]
[TR]
[TH="align: left"]Pedal cluster[/TH]
[TD="class: prCode"]VF0[/TD]
[TD]Standard pedal cluster[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight activation[/TH]
[TD="class: prCode"]8K3[/TD]
[TD]Daytime headlights with automatic headlight control
and coming home function[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Alternators[/TH]
[TD="class: prCode"]8GU[/TD]
[TD]Alternator 140 A[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category rear axle[/TH]
[TD="class: prCode"]0YA[/TD]
[TD]Weight range 1
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category front axle[/TH]
[TD="class: prCode"]L58[/TD]
[TD]Suspension range 58
[/TR]
[TR]
[TH="align: left"]Base engine[/TH]
[TD="class: prCode"]TU3[/TD]
[TD]4-cylinder diesel engine 2.0 l
unit 03L.H[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage netting/pocket on backrest(s)[/TH]
[TD="class: prCode"]4U0[/TD]
[TD]Without luggage nets/pockets
on backrests[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage compartment cover[/TH]
[TD="class: prCode"]3U1[/TD]
[TD]Folding trunk cover[/TD]
[/TR]
[TR]
[TH="align: left"]cruise control system[/TH]
[TD="class: prCode"]8T0[/TD]
[TD]Without cruise control system (CCS)[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission specifications[/TH]
[TD="class: prCode"]G0K[/TD]
[TD]6-speed manual transmission[/TD]
[/TR]
[TR]
[TH="align: left"]handle for hand brake lever[/TH]
[TD="class: prCode"]6PC[/TD]
[TD]handbrake lever grip (leather)[/TD]
[/TR]
[TR]
[TH="align: left"]Rear window wiper and washer system[/TH]
[TD="class: prCode"]8M1[/TD]
[TD]Rear window wiper washer system with
intermittent wipe[/TD]
[/TR]
[TR]
[TH="align: left"]Rear seats[/TH]
[TD="class: prCode"]3KC[/TD]
[TD]Rear bench seat, not split, split backrest, folding[/TD]
[/TR]
[TR]
[TH="align: left"]Heating and air-conditioning system[/TH]
[TD="class: prCode"]9AK[/TD]
[TD]Climatronic with impact pressure
control, CFC-free[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamps[/TH]
[TD="class: prCode"]8BK[/TD]
[TD]Twin headlamps for driving on the left,
with integrated high beam[/TD]
[/TR]
[TR]
[TH="align: left"]Customized installation[/TH]
[TD="class: prCode"]FC0[/TD]
[TD]Without individual installation[/TD]
[/TR]
[TR]
[TH="align: left"]Interior light in footwell[/TH]
[TD="class: prCode"]6T1[/TD]
[TD]Interior light in footwell[/TD]
[/TR]
[TR]
[TH="align: left"]Instrument clusters[/TH]
[TD="class: prCode"]U5B[/TD]
[TD]Instrument insert, mph speedometer
Great Britain[/TD]
[/TR]
[TR]
[TH="align: left"]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L6[/TD]
[TD]Breakaway interior rearview mirror,
auto-dimming[/TD]
[/TR]
[TR]
[TH="align: left"]Sticker (customized or special edition)[/TH]
[TD="class: prCode"]0KA[/TD]
[TD]Without decals and emblems[/TD]
[/TR]
[TR]
[TH="align: left"]Body style[/TH]
[TD="class: prCode"]K8C[/TD]
[TD]Coupe[/TD]
[/TR]
[TR]
[TH="align: left"]coolbox[/TH]
[TD="class: prCode"]1W2[/TD]
[TD]Glove compartment cooling system[/TD]
[/TR]
[TR]
[TH="align: left"]Climatic zones[/TH]
[TD="class: prCode"]0Y1[/TD]
[TD]Standard climatic zones[/TD]
[/TR]
[TR]
[TH="align: left"]Compass/road sign display[/TH]
[TD="class: prCode"]QR0[/TD]
[TD]Without compass/road sign display/
dynamic road sign display[/TD]
[/TR]
[TR]
[TH="align: left"]Head restraints[/TH]
[TD="class: prCode"]3J1[/TD]
[TD]Hight-adjustable head restraints for
front seats[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel quantity for initial filling[/TH]
[TD="class: prCode"]1Z2[/TD]
[TD]Increase in initial standard fuel
filling[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel systems[/TH]
[TD="class: prCode"]0F5[/TD]
[TD]Fuel system for diesel engine[/TD]
[/TR]
[TR]
[TH="align: left"]Body measures[/TH]
[TD="class: prCode"]5C0[/TD]
[TD]Without special body measures[/TD]
[/TR]
[TR]
[TH="align: left"]Rear license plate bracket[/TH]
[TD="class: prCode"]6P1[/TD]
[TD]Rear license plate carrier (ECE)[/TD]
[/TR]
[TR]
[TH="align: left"]Front license plate bracket[/TH]
[TD="class: prCode"]6W1[/TD]
[TD]Front license plate carrier (large)[/TD]
[/TR]
[TR]
[TH="align: left"]Paint preservative/transit coating[/TH]
[TD="class: prCode"]5K5[/TD]
[TD]Transport protection film with
additional transport protection measures[/TD]
[/TR]
[TR]
[TH="align: left"]Steering system arrangement[/TH]
[TD="class: prCode"]L0R[/TD]
[TD]Right-hand drive[/TD]
[/TR]
[TR]
[TH="align: left"]steering[/TH]
[TD="class: prCode"]1N3[/TD]
[TD]Speed-related variable steering assist
(Servotronic)[/TD]
[/TR]
[TR]
[TH="align: left"]Backrest release[/TH]
[TD="class: prCode"]3H9[/TD]
[TD]Backrest release for front seats with
Easy Entry feature[/TD]
[/TR]
[TR]
[TH="align: left"]Lumbar support[/TH]
[TD="class: prCode"]7P0[/TD]
[TD]Without lumbar support
in seat backrests[/TD]
[/TR]
[TR]
[TH="align: left"]steering wheels[/TH]
[TD="class: prCode"]2FN[/TD]
[TD]Leather-wrapped multi-function steering
wheel with decorative aluminum inserts[/TD]
[/TR]
[TR]
[TH="align: left"]Speaker installation[/TH]
[TD="class: prCode"]8RM[/TD]
[TD]8 speakers (passive)[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight range control[/TH]
[TD="class: prCode"]8Q1[/TD]
[TD]Headlight range control[/TD]
[/TR]
[TR]
[TH="align: left"]Center armrest[/TH]
[TD="class: prCode"]6E3[/TD]
[TD]Center armrest in front[/TD]
[/TR]
[TR]
[TH="align: left"]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q5[/TD]
[TD]Multi-function display with control[/TD]
[/TR]
[TR]
[TH="align: left"]Engine cooling[/TH]
[TD="class: prCode"]8Z5[/TD]
[TD]not hot country[/TD]
[/TR]
[TR]
[TH="align: left"]Engine specifications[/TH]
[TD="class: prCode"]D91[/TD]
[TD]4-cyl. turbo diesel engine 2.0 L/103 KW (4 V)
TDI common rail
TG3/TJ3/TU3/TL4/TP4/TM3/TW3/TR4/TS1/TN5[/TD]
[/TR]
[TR]
[TH="align: left"]Left vanity mirror[/TH]
[TD="class: prCode"]4SD[/TD]
[TD]Vanity mirror, left, illuminated[/TD]
[/TR]
[TR]
[TH="align: left"]Right vanity mirror[/TH]
[TD="class: prCode"]4TD[/TD]
[TD]Vanity mirror, right, illuminated[/TD]
[/TR]
[TR]
[TH="align: left"]Navigation device[/TH]
[TD="class: prCode"]7Q0[/TD]
[TD]without navigation system[/TD]
[/TR]
[TR]
[TH="align: left"]rear fog lamp[/TH]
[TD="class: prCode"]8TD[/TD]
[TD]Rear fog light for driving on the left[/TD]
[/TR]
[TR]
[TH="align: left"]Front fog lamp/additional headlamp[/TH]
[TD="class: prCode"]8WD[/TD]
[TD]Integrated front fog light[/TD]
[/TR]
[TR]
[TH="align: left"]Rear of platform module base[/TH]
[TD="class: prCode"]4P0[/TD]
[TD]Rear floor panel module, type 1[/TD]
[/TR]
[TR]
[TH="align: left"]Platform group class[/TH]
[TD="class: prCode"]7PA[/TD]
[TD]Platform group class 1[/TD]
[/TR]
[TR]
[TH="align: left"]Hubcaps[/TH]
[TD="class: prCode"]1NL[/TD]
[TD]Trims for alloy wheels[/TD]
[/TR]
[TR]
[TH="align: left"]Wheels[/TH]
[TD="class: prCode"]C9T[/TD]
[TD]Alloy wheels 8J x 18[/TD]
[/TR]
[TR]
[TH="align: left"]Radios[/TH]
[TD="class: prCode"]8AI[/TD]
[TD]Radio "RCD510 MP3"[/TD]
[/TR]
[TR]
[TH="align: left"]Smoker's/non-smoker's package[/TH]
[TD="class: prCode"]9JA[/TD]
[TD]Non smoker version[/TD]
[/TR]
[TR]
[TH="align: left"]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K0[/TD]
[TD]Without tyre pressure monitor[/TD]
[/TR]
[TR]
[TH="align: left"]tire[/TH]
[TD="class: prCode"]HV3[/TD]
[TD]Tires 235/40 R18 95Y xl[/TD]
[/TR]
[TR]
[TH="align: left"]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH="align: left"]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G6[/TD]
[TD]Space-saving spare wheel[/TD]
[/TR]
[TR]
[TH="align: left"]Restraint systems, front[/TH]
[TD="class: prCode"]3QT[/TD]
[TD]3-point seat belts in front, with
tensioner and height adjustment[/TD]
[/TR]
[TR]
[TH="align: left"][/TH]
[TD="class: prCode"]PDD[/TD]
[TD]Adaptive chassis control[/TD]
[/TR]
[TR]
[TD="class: prCode"]PJ3[/TD]
[TD]"Interlagos" 4 alloy wheels 8 J X 18
tires 235/40 R 18[/TD]
[/TR]
[TR]
[TD="class: prCode"]PJW[/TD]
[TD]Space and weight saving spare wheel
(16-inch)[/TD]
[/TR]
[TR]
[TD="class: prCode"]PLA[/TD]
[TD]"Lights & Vision" package[/TD]
[/TR]
[TR]
[TD="class: prCode"]PU2[/TD]
[TD]Multi-function leather steering wheel[/TD]
[/TR]
[TR]
[TD="class: prCode"]RHC[/TD]
[TD]"RCD 510" 4 x 20 W, 8 speakers[/TD]
[/TR]
[TR]
[TD="class: prCode"]WD2[/TD]
[TD]Anti-theft alarm system "Plus" incl.
single door opening[/TD]
[/TR]
[TR]
[TD="class: prCode"]WDI[/TD]
[TD]Multimedia socket MEDIA-IN[/TD]
[/TR]
[TR]
[TH="align: left"]Side airbag[/TH]
[TD="class: prCode"]4X3[/TD]
[TD]Side airbag in front, with curtain
airbag[/TD]
[/TR]
[TR]
[TH="align: left"]Gearshift knob/handle[/TH]
[TD="class: prCode"]6Q2[/TD]
[TD]Gearshift knob/handle in leather[/TD]
[/TR]
[TR]
[TH="align: left"]Special labels/plates[/TH]
[TD="class: prCode"]0SS[/TD]
[TD]Labels in English and French[/TD]
[/TR]
[TR]
[TH="align: left"]Locking mechanism for boot lid/cover
rear[/TH]
[TD="class: prCode"]4E2[/TD]
[TD]Tailgate/trunk lid release
from inside (electrically)[/TD]
[/TR]
[TR]
[TH="align: left"]Front seat, left[/TH]
[TD="class: prCode"]3TG[/TD]
[TD]Sports comfort seat in front, left[/TD]
[/TR]
[TR]
[TH="align: left"]Front seat, right[/TH]
[TD="class: prCode"]3SG[/TD]
[TD]Sports comfort seat, front, right[/TD]
[/TR]
[TR]
[TH="align: left"]Seat belt check[/TH]
[TD="class: prCode"]9P3[/TD]
[TD]Seat belt reminder, electric contact in
buckle[/TD]
[/TR]
[TR]
[TH="align: left"]Outer rear seat belts[/TH]
[TD="class: prCode"]3ZB[/TD]
[TD]3-point seat belts, outer rear with ECE
label[/TD]
[/TR]
[TR]
[TH="align: left"]seat covers[/TH]
[TD="class: prCode"]N3A[/TD]
[TD]Seat trim covers in fabric[/TD]
[/TR]
[TR]
[TH="align: left"]Seat adjustment[/TH]
[TD="class: prCode"]3L3[/TD]
[TD]Manual height adjustment for front seats[/TD]
[/TR]
[TR]
[TH="align: left"]seat heater[/TH]
[TD="class: prCode"]4A0[/TD]
[TD]without seat heater[/TD]
[/TR]
[TR]
[TH="align: left"]Safety head restraint system[/TH]
[TD="class: prCode"]3K0[/TD]
[TD]w/o safety head restraint system[/TD]
[/TR]
[TR]
[TH="align: left"]Horns[/TH]
[TD="class: prCode"]8Y1[/TD]
[TD]Two-tone horn[/TD]
[/TR]
[TR]
[TH="align: left"]Side and rear windows[/TH]
[TD="class: prCode"]4KF[/TD]
[TD]heat protective glass for door, side and rear
windows, darkened from b-pillar[/TD]
[/TR]
[TR]
[TH="align: left"]power outlet[/TH]
[TD="class: prCode"]7B2[/TD]
[TD]12 volt socket in luggage compartment[/TD]
[/TR]
[TR]
[TH="align: left"]Bumper[/TH]
[TD="class: prCode"]2JC[/TD]
[TD]Comfort bumpers[/TD]
[/TR]
[TR]
[TH="align: left"]Rear stabilizer[/TH]
[TD="class: prCode"]0BE[/TD]
[TD]Rear stabilizer[/TD]
[/TR]
[TR]
[TH="align: left"]Front stabilizer bar[/TH]
[TD="class: prCode"]0AD[/TD]
[TD]Front stabilizer bar[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamp washer system[/TH]
[TD="class: prCode"]8X0[/TD]
[TD]Without headlamp washer system[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield wiper intermittent control/
light/rain sensor[/TH]
[TD="class: prCode"]8N3[/TD]
[TD]intermittent windscreen wiper with rain sensor[/TD]
[/TR]
[TR]
[TH="align: left"]Nameplate set[/TH]
[TD="class: prCode"]0ND[/TD]
[TD]Nameplate set "TDI"[/TD]
[/TR]
[TR]
[TH="align: left"]Mass damper for steering wheels[/TH]
[TD="class: prCode"]1Q0[/TD]
[TD]steering wheel without balance weight[/TD]
[/TR]
[TR]
[TH="align: left"]Door and lid locking system[/TH]
[TD="class: prCode"]4K3[/TD]
[TD]Central locking w/ radio remote control,
interior controls and SAFELOCK[/TD]
[/TR]
[TR]
[TH="align: left"]Type approval countries/countries with
special requirements[/TH]
[TD="class: prCode"]B09[/TD]
[TD]Type approval country GB/Northern
Ireland[/TD]
[/TR]
[TR]
[TH="align: left"]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D1[/TD]
[TD]Carrier frequency 433.92 to 434.42 Mhz[/TD]
[/TR]
[TR]
[TH="align: left"]Partition[/TH]
[TD="class: prCode"]3CA[/TD]
[TD]without partition[/TD]
[/TR]
[TR]
[TH="align: left"]Door and side trim panels[/TH]
[TD="class: prCode"]4AF[/TD]
[TD]Door and side trim panel in foam film
and woven fabric[/TD]
[/TR]
[TR]
[TH="align: left"]doors[/TH]
[TD="class: prCode"]0A1[/TD]
[TD]2 doors[/TD]
[/TR]
[TR]
[TH="align: left"]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QV0[/TD]
[TD]without TV/digital radio reception[/TD]
[/TR]
[TR]
[TH="align: left"]Front underbody guard[/TH]
[TD="class: prCode"]1SA[/TD]
[TD]Without additional front underbody guard[/TD]
[/TR]
[TR]
[TH="align: left"]Identification plates[/TH]
[TD="class: prCode"]1EX[/TD]
[TD]Special identification label for EC
for M1 passenger vehicles[/TD]
[/TR]
[TR]
[TH="align: left"]Delivery equipment[/TH]
[TD="class: prCode"]2A0[/TD]
[TD]Without delivery equipment[/TD]
[/TR]
[TR]
[TH="align: left"]First aid kit / warning triangle[/TH]
[TD="class: prCode"]1T0[/TD]
[TD]Without first-aid material, without warning triangle[/TD]
[/TR]
[TR]
[TH="align: left"]Telephone / telematics[/TH]
[TD="class: prCode"]9W0[/TD]
[TD]Without car phone preparation/
installation[/TD]
[/TR]
[TR]
[TH="align: left"]LongLife Service Regime[/TH]
[TD="class: prCode"]QG1[/TD]
[TD]LongLife Service Regime[/TD]
[/TR]
[TR]
[TH="align: left"]Heat accumulator system/auxiliary heater[/TH]
[TD="class: prCode"]7E6[/TD]
[TD]electric air additional heater[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield Glass[/TH]
[TD="class: prCode"]4GF[/TD]
[TD]Windshield in heat-insulating glass[/TD]
[/TR]
[TR]
[TH="align: left"]Washer fluid level indicator[/TH]
[TD="class: prCode"]8W0[/TD]
[TD]without washer water level indicator[/TD]
[/TR]
[TR]
[TH="align: left"]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH="align: left"]floor mats[/TH]
[TD="class: prCode"]0TA[/TD]
[TD]without floor mats[/TD]
[/TR]
[TR]
[TH="align: left"]Additional child seat anchors[/TH]
[TD="class: prCode"]3B4[/TD]
[TD]Child seat anchors for
child seat system ISOFIX[/TD]
[/TR]
[TR]
[TH="align: left"]Auxiliary heating system[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[/TABLE]
United States
Providing the diagnostic VIN matches the car, I believe WVWZZZ13Z9V027187 was factory coded to:
763B40F5092400016E0C02EC902000823000
The replacement steps on this page apply:
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60EC1)
If that VIN is NOT correct please post the real VIN and the Advanced ID-1A logs from addresses 01, 17 and 25 so we can take a deeper look.
[HR][/HR]
Jack,
I didn't have any CBDB Scirocco models in my cheat sheet but I located 2 that were RHD. One with and one w/o DCC and the base coding was identical. If it helps you moving forward:
13726L2009CBDBMT/6L0R1K0 907 379 AD @ 010676004000090000006E000200900000823000764009006E029000823000G0K0YA1N3G07/1JC1AT1ZE/1KD
13726L2009CBDBMT/6L0R1K0 907 379 AD @ 010676004000090000006E000200900000823000764009006E029000823000G0K0YA1N3J250/G03/UB71AT1ZE/1KD
