Hex V2 issues
Blackavant
C?ID=367969
Firstly apologies as I can not post this in the correct section.
I Recently upgraded from a genuine Hex Can to Hex V2 as my most recent car is threw up the upgrade message, the car is a 2015 A6 Allroad 3.0 272. I am having issues when attempting to code 5F and 6D whereby it will not let me code due to WSC errors, I have mailed Dana and so far has been helpful but the issue still exists even though I have set the WSC info as 12345 123 12345 as instructed. I still cannot access the Green Menu to enable ambient lighting etc, can anyone else shed some light in the issue please?
Transcript of the mails sent so far:-
Address 6D doesn't support the standard [*IDE00323*] Security Access:
Number of invalid keys advanced measuring value to see if it simply has
lock-time that needs to pass. It does use an odd one [*IDE00798*]
Number of possible access authorizations .. but I'm not sure if that is
an actual error counter or not. I wouldn't try logging in again, but I
would check that group to see what's stored.
I'm unable to check your customer file due to weather-related problems
we are still experiencing from yesterday
https://forums.ross-tech.com/showth...-Update-Failed&p=172868&viewfull=1#post172868
.. to see if you already posted in our forum. Please let me know if you
have a thread there so I can reply with any additional suggestions we
may have.
The issue with Address 5F is likely directly related to
WSC/Importer/Equipment numbers. If you aren't able to change all 3 on
the Adaptation screen you can do so directly from the main VCDS Options
screen > User Interface and Identification tab:
https://www.ross-tech.com/vcds/tour/screenshots/options-2.png
Changing those to non-zero values such as 54321 | 321 | 54321 followed
by Save and restarting VCDS would be my recommendation in that case.
Best Regards,
I tried the
> instructions below but with no luck (Both 6D and 5F throw up errors), it
> seems that the default WSC of 0000 is not being used within the coding
> area. I have attached a screen shot of my coding area and the resulting
> error I get when attempting a coding change.
> Is there anything I can do to fix? I notices on the website it says not
> to change the default WSC so I have not done that.
> Also both of the suggested 6D SA Codes do not work either.
> yes I believe 5F was
>> updated sometime last year as the car now has 2018 maps.
>> Thanks for the scan and maps. Address 6D: Trunk Elect should use these
>> SA codes:
>> 20103 = Freischaltung Codierung
>> 12345 = Freischaltung Anpassung
>> Providing address 46 is coded properly I believe 6D would need SA code
>> 12345 followed by Adaptation modifications. Some of these tweaks may
> apply:
>> Next, we don't have a single scan with that 018 software number in 5F:
>>> Address 5F: Information Electr. (J794) Labels:* None
>>> Part No SW: 4G1 035 018 HW: 4G1 035 021
>>> Component: MU-H-LND-EU 041 0389
>> The next time you connect to 5F, SA code S12345 should be accepted and
>> allow you to change the (Developer Mode Adaptation channel.
>>>>Im having issues with coding 5F for green menu
>>>> activation and coding for 6D Tailgate for close on key fob, please can
>>>> you let me know the issue with those modules? I am showing no label file
>>>> for 5F and I have no security code for 6D.
>>>> I attach a complete scan of all of my modules which I hope will help.
>>>> Many thanks
[COLOR=#1D2228][FONT='inherit']>>> Chassis Type: 4G-AU57 (4G8)[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Scan: 01 02 03 05 08 09 10 15 16 17 19 20 28 34 3B 42 44 46 52 53[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>          55 5F 62 69 6C 6D 72 AC[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> VIN: WAUZZZ4G3FN076149  Mileage: 69054km-42908miles[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 01-Engine -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 02-Auto Trans -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 03-ABS Brakes -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 04-Steering Angle -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 05-Acc/Start Auth. -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 08-Auto HVAC -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 09-Cent. Elect. -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 10-Park/Steer Assist -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 15-Airbags -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 16-Steering wheel -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 17-Instruments -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 19-CAN Gateway -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 20-High Beam Assist. -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 28-HVAC, Rear -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 34-Level Control -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 3B-Sensor Elect. -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 42-Door Elect, Driver -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 44-Steering Assist -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 46-Central Conv. -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 52-Door Elect, Pass. -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 53-Parking Brake -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 55-Headlight Range -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 5F-Information Electr. -- Status: Malfunction 0010[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 62-Door, Rear Left -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 69-Trailer -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 6C-Back-up Cam. -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 6D-Trunk Elect. -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 72-Door, Rear Right -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> AC-Reductant Control -- Status: OK 0000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']> -------------------------------------------------------------------------------[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 01: Engine (J623-CRTD)      Labels:. 059-907-401-V2.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G2 907 401 B    HW: 4G2 907 401[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: 3.0TDI EDC17  H34 0007 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: 92H34---   [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 32254012053609030000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Shop #: WSC 55802 001 1048576[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_ECM30TDI0114G2907401B 001007[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_ECM30TDI0114G2907311C.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 2411ED0B1E5899B78E1-8070[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> No fault code found.[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Readiness: 0 0 0 0 1[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 02: Auto Trans (J217)      Labels:| 0B5-927-156.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G0 927 166 H    HW: 0B5 927 156 K[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: 0B5 30 TDIRdW H03 0003 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: --H03---   [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 100001[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Shop #: WSC 02391 785 00200[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_TCMDL501021 001021[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_TCMDL501021.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 323D1B5354AC07070CD-8066[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 03: ABS Brakes (J104)      Labels:. 4G0-907-379-V2.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: ESP9 Premium  H01 0420 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: --------    Serial number: --------------[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 27A6DE45E4657BA2BB00[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_ESP9BOSCHAU57X 003019[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_ESP9BOSCHAU57X_003.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 3FDB426797FEDA6FF33-806A[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 05: Acc/Start Auth. (J393)      Labels:. 8K0-907-064-05.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: BCM2 2.0      H36 0560 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: 00002001   [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 01B9704E000000000000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 7AADF373CCDC3F4784D-802E[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: J764 ELV MLB  H40 0046[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 3215000030161011   [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 08: Auto HVAC (J255)      Labels:| 4G0-820-043-4Z.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: KLIMA 4 ZONEN H14 0112 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 06031500040621[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 36221178210000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_AirCondiComfoUDS 003008[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_AirCondiComfoUDS_003.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 6393AE175BD6DE8FB7B-8036[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 09: Cent. Elect. (J519)      Labels:. 4H0-907-063-V2.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4H0 907 063 DG    HW: 4H0 907 063 AG[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: BCM1 2.0      H20 0311 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: 14020001    Serial number: 00001016330402[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']> 0105001440349FE049014083000018000F9D67082F08020100000894E100170200400010010000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 70B9D15B9AA075173A9-8024[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 1 - Part No SW: 4G2 955 119    HW: 4G8 955 119 A  Labels:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>> 1KX-955-119.CLB[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: WWS57X 150213  H37 0080[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number:        150218203512[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 0045F7[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>> Labels: 8U0-955-559.CLB[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: G397_RLFS  H06 0002[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 23784163           [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 02006D[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: E1 - LDS  H07 0044[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 27 02 2015  00001361[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 4 - Part No SW: 4H0 907 658    HW: 4H0 907 658[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: AQ_Hum_Sensor  H03 0003[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: F7E8C897000000000001[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 10: Park/Steer Assist (J791)      Labels:| 4H0-919-475-7X5.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: PARKHILFE PLA H06 0070 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: --------    Serial number: 56291505500133[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: B91320[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_EPHVA2CAU64X0000 001011[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_EPHVA2CAU64X0000.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 3537204FA5C2103F29F-8060[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 15: Airbags (J234)      Labels:* 4H0-959-655.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: Airbag10.43  H82 0086 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: --------    Serial number: 003P1003LBV9[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 30333130313730323737554A305234473053[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_AirbaAU10BPAAU64X 001014[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_AirbaAU10BPAAU64X_VW51.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 3B23367783E6C64FDFB-806E[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Crash sensor for side airbag: driver side:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 3575HRB406536RT62PM[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Crash sensor for side airbag: front passenger side:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 3585HRB406736RT6E09F[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Crash sensor for side airbag: rear: driver side:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 3515JRB405336K448P9X[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Crash sensor for side airbag: rear: passenger side:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 3525JRB405136K44A89H[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Crash sensor for front airbag: driver side:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 3554VRB405L352USMOO$[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Crash sensor for front airbag: front passenger side:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 3564VRB4055352USF8R4[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 16: Steering wheel (J527)      Labels:. 4H0-953-568.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: Lenks.Modul  H06 0005 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: C0068538    Serial number: 90862OC4000R2[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 000035[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 3B2336778366C64FDFB-806E[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: E221 - MFL  H08 0010[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 18 02 2015  D0059087[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 17: Instruments (J285)      Labels:| 4H0-920-xxx-17.clb-SRI1[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G9 920 951    HW: 4G9 920 951[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: TDieGb    Nv  H08 0043 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: 04001037    Serial number: 658070315596043[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 33A622081B412600010600[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_RBD4K 004048[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_RBD4K_AU57.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 6E85CF23801463E7285-803A[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 19: CAN Gateway (J533)      Labels:* None[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G8 907 468    HW: 4G8 907 468[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: J533--Gateway H13 0075 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: --------    Serial number: 00000001753024[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: C0CD078118[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_GatewPkoUDS 001024[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_GatewPkoUDS_001_AU57.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 75B7E04FE542503FE9F-8020[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Battery Monitoring Control Module:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 1 - Part No SW: 8T0 915 181    HW: 8T0 915 181[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: J367-BDMHella  H03 8041[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 3910505903         [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Voltage stabilizer:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663 F[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: J532_DCDCStab  H23 0022[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 141226000000000001BD[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 20: High Beam Assist. (J844)      Labels:. 8K0-857-511.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: FLA          H04 0012 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: AA001002   [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 04028264747464545425363E00[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 7CA1F56BC6E80177961-8028[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 28: HVAC, Rear (E265)      Labels:* 4G0-919-158.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: KLIMA FOND    H08 0112 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 10031500040084[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 22[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_ClimaContrUnitRearUDS 003004[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_ClimaContrUnitRearUDS_003.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 3D27386F9DF2C87FE1F-8068[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 34: Level Control (J197)      Labels:. 4G0-907-553.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: LUFE-DAEMPFER H19 0783 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 008001[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_AirSuspe 003025[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_AirSuspe_VW51.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 2F3B1227479E2AEF633-807A[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 3B: Sensor Elect. (J849)      Labels: 4G0-907-637.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: SARA 6D      H04 0056 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: --------    Serial number: EJ1BPA820931DU[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Shop #: WSC 00000 000 00000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_SARA2 005012[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_SARA2.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 36352743B8C41B27205-8062[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 42: Door Elect, Driver (J386)      Labels:. 4H0-959-793.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G8 959 793 J    HW: 4G8 959 793 G[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: TSG FA        H03 0507 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 011C16015C01620002080002[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 47CB5A87CFAE92AF4B3-8012[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 44: Steering Assist (J500)      Labels:| 4G0-909-144.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: RCEPS        H43 0012 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: 00001000    Serial number: 0013511155[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 101100010001[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_RCEPS 009013[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_RCEPS_009.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 392F2C7F89DAF45FCD7-806C[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 46: Central Conv. (J393)      Labels:. 4H0-907-064-46.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: 00002001    Serial number: 0362709322   [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 013F0622A0B93080C320090420010F470000000000000000000000000000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 1 - Part No: 4G0 951 177[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: DWA-Sensor  H01 0010[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 2 - Part No: 1K0 951 605 C[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: LIN BACKUP HO  H05 1501[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 52: Door Elect, Pass. (J387)      Labels:. 4H0-959-792.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G8 959 792 J    HW: 4G8 959 792 G[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: TSG BF        H03 0507 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 011C16015E01620002080002[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 46D55783C8A48BA7B05-8012[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 53: Parking Brake (----)      Labels: 4H0-907-801.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: EPB-4        H04 0015 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: --------    Serial number: 00000001386621[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_ParkiBrake 001028[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_ParkiBrake_VW51.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 2D07082F4D9258FF51F-8078[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 55: Headlight Range (J745)      Labels:| 4H4-907-357-V2.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4H4 907 357 E    HW: 7P6 907 357 B[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: MxB-ECU      001 0100 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 04FE02102A630200[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 34311D4BAEB809371E1-8060[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Led Headlamp Powermodule Left:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 1 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>> Labels: 3D0-941-329.CLB[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: LED LeiMo li.  H07 7560[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: E01E00[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Led Headlamp Powermodule Right:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 2 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: LED LeiMo re.  H07 7560[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 5F: Information Electr. (J794)      Labels:* None[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G1 035 018    HW: 4G1 035 021[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: MU-H-LND-EU  041 0389 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: A588C0F7506888[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 01754201FF0A000013111101000A00132F000AE7F1700100DF[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_MUHig6C3Gen2HBAS_AU57.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 5DE798EF7DB2E87F81F-8008[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Data medium:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: ECE 2017/2018  --- 0161[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: --------------------[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Display unit 1 for multimedia system:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: DU8 C7 SV  H63 0007[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: AUZ8Z9EY800AHH     [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Multimedia Operating Unit:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: E380 BDT C7  H20 0250[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Serial number: 90349OBK0005P     [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Compact Disc Database:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: Gracenote2  --- 1012[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 1 Fault Found:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> 3073 - Cellular Antenna[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>          B1053 13 [009] - Open Circuit[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>          [GSM/UMTS aerial - open circuit][/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>          Confirmed - Tested Since Memory Clear[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>              Freeze Frame:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>                    Fault Status: 00000001[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>                    Fault Priority: 4[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>                    Fault Frequency: 1[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>                    Reset counter: 82[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>                    Mileage: 69054 km[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>                    Date: 2019.08.05[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>                    Time: 20:23:32[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>                    Voltage terminal 30: 14.0 V[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 62: Door, Rear Left (J388)      Labels: None[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G8 959 795 J    HW: 4G8 959 795 G[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: TSG HL        H03 0507 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 010814004001620002080002[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 49CF5CBFD9BA64DF5D7-801C[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 69: Trailer (J345)      Labels:| 4H0-907-383-V2.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: Anhaenger    H14 0137 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: 7B001001    Serial number: 0363024513[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 0100000202000000[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_TrailFunctGener2Hella 001005[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_TrailFunctGener2Hella_VW26.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    VCID: 33331E57ABB60E0F07B-8066[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 6C: Back-up Cam. (J772)      Labels:| 5Q0-907-441.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: D4-PA RVC Mid H07 0050 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 027502010301000700[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_CamSysRearPANAAU914 002002[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_CamSysRearPANAAU914_VW51.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 6D: Trunk Elect. (----)      Labels:* Redir Fail![/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: HDSG-Modul    H05 0150 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: 14005001    Serial number: 054500073[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Coding: 093205C011[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_HDSGAu572 001022[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_HDSGAu571.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address 72: Door, Rear Right (J389)      Labels: None[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: TSG HR        H03 0507 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Address AC: Reductant Control (J880)      Labels: 4G0-907-355.clb[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Component: SCR-Stg-G2    H10 0012 [/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    Revision: 00000000    Serial number: 150420963[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ASAM Dataset: EV_RDCMA00100 008040[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>>    ROD: EV_RDCMA00100_008.rod[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> End----------(Elapsed Time: 01:54, VBatt start/end:[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>> 13.8V/14.1V)-----------[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Monday,05,August,2019,21:21:46:13929[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> VCDS Version: 19.6.1.0 (x64)  HEX-V2 CB: 0.4508.4[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> Data version: 20190529 DS308.0[/FONT][/COLOR]
[COLOR=#1D2228][FONT='inherit']>>> [URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL][/FONT][/COLOR]
South Molton, UK
If you get Verified it will allow you to post in the correct section, plus it would help if you could post an UNEDITED Auto-Scan (the header is important).
Blackavant
C?ID=367969
Thanks for the reply Dave, i just copied and pasted from the email I sent Dana. What elements are missing? I will post them.
Cheers
Nick
Viking
C?ID=151455
Run a new autoscan (or pick the original unedited one from the logs folder) and paste the text into your post here (between code tags if possible). The amount of formatting in your post above makes it impossible to make sense of.
Blackavant
C?ID=367969
Copied from the original scan
Monday,05,August,2019,21:21:30:13929
VIN: WAUZZZ4G3FN076149   License Plate:
   Revision: 92H34---
   Revision: --H03---
   Coding: 100001
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.CLB
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.CLB
   Coding: 0105001440349FE049014083000018000F9D67082F08020100000894E100170200400010010000
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Coding: 0045F7
   Coding: 02006D
   Coding: B91320
Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.CLB
   Coding: 000035
Address 19: CAN Gateway        Labels: None
   Coding: C0CD078118
   Subsystem 1 - Part No: 8T0 915 181
   Voltage stabilizer:
   Subsystem 2 - Part No: 8K0 959 663 F
Address 20: High Beam Assist. (J844)       Labels:. 8K0-857-511.CLB
   Revision: AA001002
   Coding: 22
   Coding: 008001
   ROD: EV_SARA2.rod
Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.CLB
Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.CLB
Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.CLB
   Coding: E01E00
   Coding: E01E00
                    Reset counter: 82
                    Mileage: 69054 km
                    Date: 2019.08.05
                    Time: 20:23:32
Address 62: Door, Rear Left (J388)       Labels: NONE
   Coding: 093205C011
Address 72: Door, Rear Right (J389)       Labels: NONE
End------(Elapsed Time: 33:58, VBatt start/end: 13.2V/14.2V, Deb=2)--------
_Val
Latvia
C?ID=356659
Not worried about total time of 34 minutes it takes to do just an autoscan?
Blackavant
C?ID=367969
Lol, that Autoscan was part of the full module scan I sent to RT.
South Molton, UK
I've got the OP verified based on his new HEX-V2. Moving to Tweaks.
What's not clear to me is exactly what he's trying to accomplish, hence I'm not sure what the thread title should be, because I don't see any obvious problem directly related to the fact that he's using a HEX-V2 (as opposed to some other type of interface).
Blackavant
C?ID=367969
Thanks for the help all.
Uwe, im attempting to enable the Engineering / Green menu to enable ambient lighting. Im also trying to enable boot close from keyfob and internal switch, both modules are not accepting any coding due to WSC control module rejection. Ive changed the WSC info on the Options menu from 00000 000 00000 to 12345 123 12345 and also 02391 785 00200 all with no luck.
For some reason the car does not want to be coded!
I had a Genuine Hex Can for a few years before the V2 and my Q5 and A4 Allroad were no problems, the same goes for the wife's Q3. Just a bit stuck really
Did exit and re-start VCDS after changing the WSC, Importer, and Equipment Number on the Options screen? Those changes do not "take" until you do that.
12345 123 12345 is known to fail in some modules (we think VAG decided too many people with aftermarket scan tools were using those.
02391 785 00200 is a factory code and may not be recognized as a change.
Try something like: 15243 234 01369
Also, please post exact error message you're getting when the coding fails.
Blackavant
C?ID=367969
Hi Uwe,
I tried again using your suggestion and still no luck, the error in full is:
This workshop Identification:
WSC 13452 Importer 389 Equipment 99762
Was rejected by the control module.
The command will probably fail
Please change your values
I press ok then I get:
Error Unknown (0x00)
This happens whether ive set the set the Security Access or not.
OK, I'm stumped. Remind me, which module is this that you're trying to code?
Blackavant
C?ID=367969
Hi Uwe, I managed to get everything working so thanks for your assistance on that.
However I now have a much bigger problem, I was coding 5F (60B) which is now where the old GEM menu items are enabled. I enabled Ambient lighting there however during the coding i stepped on the usb lead which unplugged for the laptop. I reconnected and now it will not read 5F I get "No response form controller" also the MMI will not power up, centre screen says "MMI is swithched off operation not possible", how ever the power button does nothing.
Would disconnecting the battery fix it or trip to the dealer?????
My stupidity even astonishes me sometimes!
TBAx
DE
C?ID=287144
Try the battery disconnect. If five minutes don’t fix the issue the MMI could be bricked.
Blackavant
C?ID=367969
Thanks TBA, issue over. As you recommended battery power cycle for 10 mins sorted it. I knew I should have bought the wifi version lol
