Saturday,10,August,2019,13:50:47:56590
-- Windows Based VAG/VAS Emulator Running on Windows 7 x64
Version: 19.6.1.0 (x64)
Uwe: Here you go, but with some errors relating to the type of interface.
MasterTommy:
In all drive modes, the engine braking effect is negligable, except for ECO Mode, when management engages neutral and the car rolls on forever.
The effect is no different in Auto, TipTronic mode & or paddles, and left stick manual paddles only mode.
VW Arteon 190 2.0L Tsi DSG7 (United Kingdom EU version)
VIN: WVWZZZ3HZJE52xxxx
Mileage: 20811km-12931mi
Chassis Type 3H-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 4B 52 5F 6C 75
A5 BB BC CA
VIN: WVWZZZ3HZJE520740 Mileage: 20811km-12931miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
BC-Door Rear Pass -- Status: Malfunction 0010
Address 01: Engine (J623-CZPB) Labels:. 06L-907-115-V1.clb
Part No SW: 5NA 907 115 H HW: 06L 907 309 B
Component: R4 2.0l TFSI H31 0002
Revision: 1DH31000
Coding: 012500122464050B34000000000000000000000000000000
Shop #: WSC 05311 115 00304
ASAM Dataset: EV_ECM20TFS0115NA907115H 001003
ROD: EV_ECM20TFS0115NA907115H_VW48.rod
VCID: 43831370CA48D657C4-8016
14629 - Fuel Pump Control Module
P025C 00 [032] - Short to Ground
17156 - Databus
17158 - Implausible Data Received from ESP Control Module
U0416 00 [032] - -
33226 - Please Check Fault Codes in Body Control / Central Electric Module
U1021 00 [032] - -
Part No SW: 0GC 300 040 P HW: 0GC 927 711 G
Component: GSG DQ381 H06 1401
Revision: 00H06V07
ROD: EV_TCMDQ381061_VW37.rod
VCID: 316F49B860F454C726-8064
33345 - No Communication With Transmission Fluid Pump
U0287 00 [047] - -
Mileage: 10054 km
Date: 2018.12.17
Time: 17:26:04
Coolant temperature: 71 °C
Clutch: primary stat: New
selected gear: GANG_R
Driving position: P
Engine torque: -20 Nm
Control Module temperature: 60 °C
Accelerator position: 14.5 %
DTC memory status: 286
Part No SW: 5Q0 614 517 CR HW: 5Q0 614 517 AD
Component: ESC H25 0523
Revision: 00000000 Serial number: 60548000000804
Coding: 0DEC92943422236C477E060460C349B0492CC4E2600692713842F078C229420B00000012121212B835351919323200
Shop #: WSC 00015 115 08193
VCID: 0303D3708AC8165784-8056
Part No SW: 3Q0 959 435 F HW: 3Q0 959 435 F
Component: VWKESSYMQB 027 0907
Revision: 00027000 Serial number: 0472444313
Coding: 102F0F0723
VCID: 3D776588ACACA0A7B2-8068
Part No SW: 5G0 907 044 DP HW: 5G0 907 044 DP
Component: Climatronic H04 2001
Revision: 00001K10
Coding: 1412001420011001111500000010182A
ASAM Dataset: EV_ACClimaBHBVW37X 006146
VCID: 78F9B49CC30E458FA1-802C
Air quality sensor:
Part No SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 034 0245
Revision: -------- Serial number: 865831011801HK
ROD: EV_BCMBOSCH_018.rod
VCID: 0605CA64B9FA237FA3-8052
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 180117 043 0607
Serial number: 180127063925
Component: RLHS 047 0105
Serial number: SAY18M02D27H21M36S56
Coding: 00A8DD
Subsystem 3 - Part No SW: 3G8 941 633 HW: 3G8 941 633
Component: E1 - LDS MQB H01 0032
Serial number: 22 08 2017 10001396
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY180080HTU
Subsystem 5 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0006
Serial number: 00000000000000055879
Ceiling Light Module:
Subsystem 6 - Part No SW: 3G0 947 105 D HW: 3G0 947 105 D
Component: J528 Dachelek H08 0009
Serial number: 18021900010190D
Coding: F38380
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418018043
Coding: 0471151811
Shop #: WSC 05311 115 00068
VCID: 4B933B50E2181E173C-801E
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 32017FC259FFC728949C812481400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
ROD: EV_ACCBOSCHVW416_002_VW48.rod
VCID: 3E756284A1AABBBFAB-806A
Part No SW: 3Q0 959 655 BK HW: 3Q0 959 655 BK
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003W6P3QQPV5
Coding: 98FCC0C00C0000005C5400CF008840000065
Shop #: WSC 05311 000 08193
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0819C45CB3EE350FD1-805C
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 3G8857705B0037S01309
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3G8857706B0037S01742
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 001 402 18
Serial number: 357000000001678D1C2M
Subsystem 4 - Part No SW: ----------- HW: 454 001 402 18
Serial number: 35800000000AC89C6D22
Subsystem 5 - Part No SW: ----------- HW: 454 801 702 18
Serial number: 35100A06EB613000000H
Subsystem 6 - Part No SW: ----------- HW: 454 801 702 18
Serial number: 3520092E0BC13000000J
Subsystem 7 - Part No SW: ----------- HW: 454 801 202 18
Serial number: 3550084D02D13000000E
Pedestrian Protection Driver:
Subsystem 8 - Part No SW: ----------- HW: 454 801 902 18
Component: PedP_Sensor_D 304 0149
Serial number: 22800E3758313000000D
Subsystem 9 - Part No SW: ----------- HW: 454 801 702 18
Component: PedP_Sensor_P 304 0149
Serial number: 22900B9C98913000000W
Pedestrian Protection Center:
Subsystem 10 - Part No SW: ----------- HW: 454 801 702 18
Component: PedP_Sensor_C 304 0149
Serial number: 23000B9CD8913000000S
Subsystem 11 - Part No SW: ----------- HW: 454 001 101 18
Component: PedP_Sens_D_2 008 0887
Serial number: I0M0000000027A24D923
Subsystem 12 - Part No SW: ----------- HW: 454 001 101 18
Component: PedP_Sens_P_2 008 0887
Serial number: I0N00000000F8B24D92J
Part No SW: 5Q0 953 521 AH HW: 5Q0 953 569 A
Revision: FF033033 Serial number: 20180227201435
Coding: 0810
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 3G0 920 791 C HW: 3G0 920 791 C
Component: KOMBI 407 3195
Coding: 27A4111B6F84060001806B031001000800000000
VCID: 295FA1D848242C07EE-807C
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 15021810800879
Coding: 030300047F085900FB00025E1C0F00010001070000000000000000000000
ROD: EV_GatewNF.rod
VCID: 3879749C838E858F61-806C
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29180000390230078081
Coding: 2DFFFF
Serial number: 7588600000180212020B
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
197169 - Controls in Steering Wheel
U108E 00 [008] - No Communications
Reset counter: 145
Mileage: 19746 km
Date: 2019.07.14
Time: 13:18:27
Supply voltage: Terminal 30: 12.2 V
Terminal 15: OFF
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000035497009
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 336343B09AE866D754-8066
Component: TSG FS 011 0032
Serial number: 0000305727016
Coding: 003F4A02D001028000001000
VCID: 479B0760FE70FA7718-8012
Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5081
Coding: 91170000
Shop #: WSC 00015 115 00304
ROD: EV_SteerAssisMQB_015.rod
VCID: 3B736B90B2B8AE978C-806E
Address 4B: Multifunc. Module
Interface not compatible.
Component: TSG BFS 011 0032
Serial number: 0000304306849
Coding: 003F4002DE01028000001000
VCID: 46850A64F97AE37FE3-8012
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 851 0867
Coding: 02840301FF00000051110101008808001F0506E6012000008E
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 326D46B465F26FDF5F-8066
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHV0310774
Subsystem 2 - Part No SW: 5NA 919 866 R HW: -----------
Component: ECE AS 19/20 --- 1115
Component: RVC Compact H12 0231
Coding: 0184030162002017000040
VCID: 397F7198B8849C879E-806C
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0718
Revision: --------
Coding: 02840301EA42380D3F1CBE000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW25.rod
VCID: 3C71688CB7B6A9AF85-8068
Part No SW: 3Q0 980 654 J HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0273
Serial number: 27011812P10598
Coding: 0004080400000401000213448150A90094000E300040
1275 - Unknown Error Code
B182E F0 [008] - Unknown Error Elaboration
Reset counter: 89
Mileage: 17532 km
Date: 2019.07.01
Time: 16:22:51
Control Module temperature: 47 °C
Outside air temperature: 25.0 °C
Vehicle speed: 39.03 km/h
System run time: 3920.4 s
Voltage terminal 15: 12.5 V
mid: 01 63
Status of camera: operational
Engine_Running_Info: 1
Software_Info_4: 3
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Part No SW: 5Q4 959 595 E HW: 5Q4 959 595 B
Component: TSG HFS 012 0032
Serial number: 0000305632591
Coding: 000A40020101028000001000
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
VCID: 499F0158E8640C070E-801C
Component: TSG HBFS 012 0032
Serial number: 0000305632590
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
65605 - Switch for Interior Door Handle
B132E 29 [008] - Signal Implausible
Mileage: 14292 km
Date: 2019.05.12
Time: 12:45:11
65637 - Switch for Exterior Door Handle
B132F 29 [008] - Signal Implausible
Mileage: 14292 km
Date: 2019.05.12
Time: 12:45:11
Address CA: Sunroof
End-------------------------(Elapsed Time: 06:01)--------------------------
