Arteon Engine Retardation issue
Midori
C?ID=195228 (NRRT)
I have personal problem (hard to live with) concerning the minimal engine braking (speed decrease) when lifting my foot off the accelerator. It's a 2018 Arteon 2.0L 190 Tsi DSG-7.
Whether in Normal or Sports mode the deceleration is nil on the level ineffective on downwards slopes. Decending a steep hill, the brakes will cause engine braking to cut in, but not consistantly when decending the same hill repeatedly.
In Tiptronic mode, whether dropping just one, two gears or even three gears has little effect also. At 5000 rpm in 2nd gear there is still no improvement - just engine noise! The dealer says the vehicle is all OK.
Is there anyway to use VCDS to modify the engine/gearbox/torque retardation effectiveness when taking foot off the gas?
My first thought is the Tilt sensing feature which does seem to have effect on steep hills. This system recognises me applying the brake pressure on a steep hill somehow. Then when I take foot of brake, I can feel the car is then being held back and assume it is doing so via torque control rather than doing so by applying my brakes automatically.
Hi,
Please post an Auto-Scan so people can see exactly how this vehicle is equipped and what we know about the control modules in it.
MasterTommy
Amsterdam
C?ID=295586
Are we talking driving modes or transmission modes?
Midori
C?ID=195228 (NRRT)
Saturday,10,August,2019,13:50:47:56590
VCDS Version: 19.6.1.0 (x64)
Uwe: Here you go, but with some errors relating to the type of interface.
MasterTommy:
In all drive modes, the engine braking effect is negligable, except for ECO Mode, when management engages neutral and the car rolls on forever.
The effect is no different in Auto, TipTronic mode & or paddles, and left stick manual paddles only mode.
VW Arteon 190 2.0L Tsi DSG7  (United Kingdom EU version)
VIN: WVWZZZ3HZJE52xxxx
Mileage: 20811km-12931mi
Chassis Type  3H-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 4B 52 5F 6C 75
          A5 BB BC CA
VIN: WVWZZZ3HZJE520740   Mileage: 20811km-12931miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CZPB)       Labels:. 06L-907-115-V1.clb
   Part No SW: 5NA 907 115 H    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0002
   Revision: 1DH31000
   Coding: 012500122464050B34000000000000000000000000000000
   Shop #: WSC 05311 115 00304
   ASAM Dataset: EV_ECM20TFS0115NA907115H 001003
   ROD: EV_ECM20TFS0115NA907115H_VW48.rod
   VCID: 43831370CA48D657C4-8016
14629 - Fuel Pump Control Module
          P025C 00 [032] - Short to Ground
17156 - Databus
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
33226 - Please Check Fault Codes in Body Control / Central Electric Module
          U1021 00 [032] - -
   Part No SW: 0GC 300 040 P    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1401
   Revision: 00H06V07
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 316F49B860F454C726-8064
33345 - No Communication With Transmission Fluid Pump
          U0287 00 [047] - -
                    Mileage: 10054 km
                    Date: 2018.12.17
                    Time: 17:26:04
                    Engine speed: 0.00 /min
                    Coolant temperature: 71 °C
                    Clutch: primary stat: New
                    selected gear: GANG_R
                    Driving position: P
                    Engine torque: -20 Nm
                    Control Module temperature: 60 °C
                    Accelerator position: 14.5 %
                    DTC memory status: 286
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 60548000000804
   Coding: 0DEC92943422236C477E060460C349B0492CC4E2600692713842F078C229420B00000012121212B835351919323200
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 0303D3708AC8165784-8056
   Part No SW: 3Q0 959 435 F    HW: 3Q0 959 435 F
   Component: VWKESSYMQB    027 0907
   Revision: 00027000    Serial number: 0472444313
   Coding: 102F0F0723
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 3D776588ACACA0A7B2-8068
   Part No SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
   Component: Climatronic   H04 2001
   Revision: 00001K10
   Coding: 1412001420011001111500000010182A
   VCID: 78F9B49CC30E458FA1-802C
   Air quality sensor:
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0245
   Revision: --------    Serial number: 865831011801HK
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0605CA64B9FA237FA3-8052
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    180117  043 0607
   Serial number:         180127063925
   Component: RLHS  047 0105
   Serial number: SAY18M02D27H21M36S56
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G8 941 633     HW: 3G8 941 633
   Serial number: 22 08 2017  10001396
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY180080HTU
   Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0006
   Serial number: 00000000000000055879
   Ceiling Light Module:
   Subsystem 6 - Part No SW: 3G0 947 105 D    HW: 3G0 947 105 D
   Component: J528 Dachelek  H08 0009
   Serial number: 18021900010190D
   Coding: F38380
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418018043
   Coding: 0471151811
   Shop #: WSC 05311 115 00068
   VCID: 4B933B50E2181E173C-801E
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 32017FC259FFC728949C812481400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   ROD: EV_ACCBOSCHVW416_002_VW48.rod
   VCID: 3E756284A1AABBBFAB-806A
   Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W6P3QQPV5
   Coding: 98FCC0C00C0000005C5400CF008840000065
   Shop #: WSC 05311 000 08193
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0819C45CB3EE350FD1-805C
   Belt Pretensioner left:
   Serial number: 3G8857705B0037S01309
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 3G8857706B0037S01742
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 402 18
   Serial number: 357000000001678D1C2M
   Subsystem 4 - Part No SW: -----------    HW: 454 001 402 18
   Serial number: 35800000000AC89C6D22
   Subsystem 5 - Part No SW: -----------    HW: 454 801 702 18
   Serial number: 35100A06EB613000000H
   Subsystem 6 - Part No SW: -----------    HW: 454 801 702 18
   Serial number: 3520092E0BC13000000J
   Subsystem 7 - Part No SW: -----------    HW: 454 801 202 18
   Serial number: 3550084D02D13000000E
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 454 801 902 18
   Component: PedP_Sensor_D  304 0149
   Serial number: 22800E3758313000000D
   Subsystem 9 - Part No SW: -----------    HW: 454 801 702 18
   Component: PedP_Sensor_P  304 0149
   Serial number: 22900B9C98913000000W
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 454 801 702 18
   Component: PedP_Sensor_C  304 0149
   Serial number: 23000B9CD8913000000S
   Subsystem 11 - Part No SW: -----------    HW: 454 001 101 18
   Component: PedP_Sens_D_2  008 0887
   Serial number: I0M0000000027A24D923
   Subsystem 12 - Part No SW: -----------    HW: 454 001 101 18
   Component: PedP_Sens_P_2  008 0887
   Serial number: I0N00000000F8B24D92J
   Part No SW: 5Q0 953 521 AH    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20180227201435
   Coding: 0810
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 3G0 920 791 C    HW: 3G0 920 791 C
   Component: KOMBI         407 3195
   Coding: 27A4111B6F84060001806B031001000800000000
   VCID: 295FA1D848242C07EE-807C
   Component: GW MQB High   518 5323
   Serial number: 15021810800879
   Coding: 030300047F085900FB00025E1C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 3879749C838E858F61-806C
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29180000390230078081
   Coding: 2DFFFF
   Serial number: 7588600000180212020B
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
197169 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
                    Reset counter: 145
                    Mileage: 19746 km
                    Date: 2019.07.14
                    Time: 13:18:27
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: OFF
   Serial number: 18000035497009
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 336343B09AE866D754-8066
   Serial number: 0000305727016
   Coding: 003F4A02D001028000001000
   VCID: 479B0760FE70FA7718-8012
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 91170000
   Shop #: WSC 00015 115 00304
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B736B90B2B8AE978C-806E
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Serial number: 0000304306849
   Coding: 003F4002DE01028000001000
   VCID: 46850A64F97AE37FE3-8012
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    851 0867
   Coding: 02840301FF00000051110101008808001F0506E6012000008E
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 326D46B465F26FDF5F-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHV0310774
   Subsystem 2 - Part No SW: 5NA 919 866 R    HW: -----------
   Component: ECE AS 19/20  --- 1115
   Coding: 0184030162002017000040
   VCID: 397F7198B8849C879E-806C
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0718
   Revision: --------
   Coding: 02840301EA42380D3F1CBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: 3C71688CB7B6A9AF85-8068
   Part No SW: 3Q0 980 654 J    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0273
   Serial number: 27011812P10598
   Coding: 0004080400000401000213448150A90094000E300040
1275 - Unknown Error Code
          B182E F0 [008] - Unknown Error Elaboration
                    Reset counter: 89
                    Mileage: 17532 km
                    Date: 2019.07.01
                    Time: 16:22:51
                    Control Module temperature: 47 °C
                    Outside air temperature: 25.0 °C
                    Vehicle speed: 39.03 km/h
                    System run time: 3920.4 s
                    Voltage terminal 15: 12.5 V
                    mid: 01 63
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 3
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
   Component: TSG HFS       012 0032
   Serial number: 0000305632591
   Coding: 000A40020101028000001000
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
   VCID: 499F0158E8640C070E-801C
   Component: TSG HBFS      012 0032
   Serial number: 0000305632590
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
65605 - Switch for Interior Door Handle
          B132E 29 [008] - Signal Implausible
                    Mileage: 14292 km
                    Date: 2019.05.12
                    Time: 12:45:11
65637 - Switch for Exterior Door Handle
          B132F 29 [008] - Signal Implausible
                    Mileage: 14292 km
                    Date: 2019.05.12
                    Time: 12:45:11
Address CA: Sunroof
End-------------------------(Elapsed Time: 06:01)--------------------------
I don't see anything in the documented channels or coding bits that would influence "compression braking".
Engine has four fault codes, but the ones that might be relevant are all "Intermittent - Not Confirmed" and haven't been reported to the Gateway.
However, the fault in the Transmission, U0287 is "Confirmed", not flagged Intermittent, and reported to the Gateway. I wonder whether this has any effect on what you're experiencing?
Have you tried clearing fault codes to see if that changes anything?
Midori
C?ID=195228 (NRRT)
I did not think this was worthy of attention considering the date (2018.12) and location of the vehicle (Parked position, 0 mph, 0 rpm).
Probably a conflict of shutdown processes at a time when the vehicle is normally in my garage..
Does this now draw a blank on engine compression braking issues?
U0287 00 [047] - -
Mileage: 10054 km
Date: 2018.12.17
Time: 17:26:04
Driving position: P
What's annoying is that your TCU isn't giving a Fault Frequency with that code, so we don't know how often it has occurred since the freeze frame data was written on the first occurrence. But since it's not flagged "Intermittent", it seems to me that it likely occurs regularly.
Sometimes the presence of fault codes has strange effects. Like I said, I suggest clearing it to see what happens.
Other than that, I don't have any ideas, but I don't claim to know everything.
Midori
C?ID=195228 (NRRT)
I cleared the code, toggled the ignition on and off, rescanned a couole of times with engine off and at tickover.
Here is today's the scan with engine running.
   Revision: 00H06V07
          U0287 00 [047] - -
                    [B]Fault Frequency: 3[/B]
                    Mileage: 20811 km
                    Date: [B]2019.08.11[/B]
                    Time: 12:14:10
                    [B]Coolant temperature: 19 °C[/B]    <<<<---this looks right for cold overnight in garage at tickover. -?
                    Driving position: P
                    Engine torque: -40 Nm
                    [B]Control Module temperature: 21 °C[/B] <<<<-------- ?
For ease of comparison, here is a copy of the originally posted scan. There seems an strange difference on coolant and module temperatures. (but would have to buy new interface to re-confirm.
U0287 00 [047] - -
Mileage: 10054 km
Date: [B]2018.12.17[/B]
Time: 17:26:04
[B]Coolant temperature: 71 °C[/B]     <<<< --cold overinght engine not running  --?
Driving position: P
[B]Control Module temperature: 60 °C[/B]  <<<< -------------------?
Strange that
Well since it comes right back with the current date, I'd say that's definitely a problem.
But I do not know whether it's related to your lack of compression braking.
As for the module and fluid temperatures, I'm not surprised they're close in both sets of data. I believe this is one of those transmissions that uses a "Mechatronic" module that's bolted right to the transmission itself.
Midori
C?ID=195228 (NRRT)
Ok, thanks for helping. I conclude the Arteon is NOT the vehicle to buy !
siLc
Tallinn, Estonia
C?ID=330192
I'd suggest keeping an eye on the instantaneous fuel consumption figure. When true engine braking occurs, it should read 0.0l/100km. If its some other non-zero figure and your foot is off the gas pedal, then the engine/gearbox are just coasting. I remember RoW Passat B7 with the ubiquitous 2.0 TDI CR engine (CFFB, CFGB, CFGC) with the DQ250 DSG had coasting as an option one could enable in the MFA.
Midori
C?ID=195228 (NRRT)
I will take a look at that on next run.
The Arteon has three drive modes selectable via MODE switch and Infotainment panel. Normal and Sports Mode are much the same, except gearbox mapping in Sports mode drops 2 gears compared with the gear used in Normal Mode. Engine compression braking effect seems the same in both these modes.
The third mode 'ECO' introduces Coasting. When the foot comes off the gas the gearbox is put into Neutral and in the UK version the engine continues to tick over. Without the gear train Coasting enables the car to roll, and save more fuel that (say) 7th gear - which would be the off-gas gear in Normal mode.
After 7000 miles I don't use ECO mode anymore, even though I enjoyed seeing the 'average since-start' MPG creep upwards during Coasting. In the other modes MPG is quite good on a run.
I will report back on the instantaneous MPG's
Midori
C?ID=195228 (NRRT)
I had the diesel B7 36535Y CFFB TDi & NJK DSG 6 which I part exchanged for this Arteon. Sad to say, that vehicle had superb engine braking and cornering.
I could only find the mpg gauge. Whenever I take foot of gas it hits the limit of the sweep = infinit miles / gallon. I guess EU6 emission targets result in zero engine braking and I have to live with it.
