SKODA MY16 Autoscan Unsupported Vehicle
processpaul
C?ID=43225
Hi
I have run an autoscan of my new car as below,
However when went into to individual modules I cannot carry out any adaptions as it shows a popup saying "unsupported Vehicle".
As the auto scan ran, and read module coding for most of them, I was under the presumption I would be able to communicate with the modules even though I still have Hex-CAN-USB. I am keen to carry out some mods on 09 and
I presume I do now need to upgrade to HEX-V2?
Thank you ROSS-Tech Team for supporting my Hex-Can for so long:)
Wednesday,31,July,2019,20:44:22:37649
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 19.6.0.2
VIN: TMBKJ7NE9G0180866   License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 20 42 44 52 5F 69
VIN: TMBKJ7NE9G0180866   Mileage: 78598km-48838miles
Address 01: Engine (J623-CRMB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BP    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H22 1198
   Revision: B5H22---
   Coding: 011D0012033501090000
   Shop #: WSC 73430 031 12345
   ASAM Dataset: EV_ECM20TDI01104L906026BP 002002
   ROD: EV_ECM20TDI01104L906026BP_002.rod
   VCID: 79F2792CF84A4387D6-802C
   Part No SW: 0D9 300 041 H    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4902
   Revision: 06253104    Serial number: TFK01512160545
   Shop #: WSC 73430 031 00063
   ROD: EV_TCMDQ250021.rod
   VCID: 1D3A4DBC0C22DFA79A-8048
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
          P1734 00 [002] - -
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 60126000000356
   Coding: 1C078A912428096C007F060641C9243851249000608224F210610070C002
   ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
   VCID: 4B9EF3E4E256011734-801E
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 162
                    Mileage: 41798 km
                    Date: 2017.12.11
                    Time: 17:11:31
   Part No SW: 5E0 907 044 Q    HW: 5E0 907 044 Q
   Component: Climatronic   H04 1002
   Revision: 00001K07
   Coding: 02110104002100011005000000101000
   Shop #: WSC 73430 031 00000
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 336E8B049AA679D75C-8066
   Air quality sensor:
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
                    Reset counter: 166
                    Mileage: 78455 km
                    Date: 2019.05.02
                    Time: 13:50:28
                    Voltage terminal 30: 14.1 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.val.: 1
                    Auxiliary heater: in stages-Specified value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86580501162422
   Coding: 0F021942424702FB07A04082B10C07280000000000000000000000000000
   Shop #: WSC 73430 790 12345
   ROD: EV_BCMBOSCH_015.rod
   VCID: 030E1BC48A8609578C-8056
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 151205  041 0570
   Serial number:         151217072526
   Coding: 065DDD
   Component: RLHS  037 0059
   Serial number: S2Y16M01D15H15M53S49
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY152720D5A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064582722
7 Faults Found:
550677 - Databus
787212 - Windshield Washer Pump
          B1261 01 [008] - Electrical Failure
139528 - Control Relay for Terminal 15 Load
          B12E6 11 [008] - Short to Ground
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 0
                    Mileage: 76675 km
                    Date: 2019.03.13
                    Time: 09:03:35
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
197384 - Lock Module for Central Locking; Rear Right
          B12DC 29 [008] - Signal Implausible
262664 - Switch for Interior Monitoring / Inclination Sensor
          B131B 29 [008] - Signal Implausible
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331528005160
   Coding: 0001050111
   VCID: 3D7AAD3CACE2BFA7BA-8068
12658704 - Databus
                    Reset counter: 48
                    Mileage: 2651 km
                    Date: 2016.05.06
                    Time: 10:48:10
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 15121503212430
   Coding: 00001200FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A70A620BDCC889F9F-806E
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPRXM585
   Coding: 98CCC000000000005C5400CC008800000065
   Shop #: WSC 73430 790 00000
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F2627F4D6CE7D3718-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 912 15
   Serial number: 3576U000000DE435981M
   Subsystem 2 - Part No SW: -----------    HW: 454 000 801 16
   Serial number: 3586U000000477702812
   Subsystem 3 - Part No SW: -----------    HW: 454 802 212 15
   Serial number: 3516R7F1D7709000000F
   Subsystem 4 - Part No SW: -----------    HW: 454 802 012 15
   Serial number: 3526R1CEE7709000000L
   Subsystem 5 - Part No SW: -----------    HW: 454 801 610 15
   Serial number: 3556V21A6E508000000A
   Part No SW: 5Q0 953 507 GP    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 17011604221223
   Coding: 1410
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 0A1036E0ADAC581FCF-805E
   Part No SW: 5E0 920 951 B    HW: 5E0 920 951 B
   Component: KOMBI         324 6422
   Coding: 27A40A082180A60001886A011000000000000000
   VCID: 2648625059741C7FCB-8072
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004390483
   Coding: 030100045F087300EB0002481C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000C0451080116
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001601040686
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 01028F6B76765D525220343E01
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: 2B5E93644296211714-807E
   Component: TSG FS        010 0031
   Serial number: 0000182344540
   Coding: 00150020D001040000001100
   VCID: 4796CFD4FE3EE57710-8012
   Serial number: 00000000000008486742
   Coding: 1D0200
589825 - Local Data Bus
          U10BA 00 [008] - No Communication
                    Mileage: 9568 km
                    Date: 2016.07.06
                    Time: 15:16:57
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 8103
   VCID: 448CD8D8CF08CE6FF5-8010
   Component: TSG BFS       010 0031
   Serial number: 0000182824883
   VCID: 4688C2D0F934FC7FEB-8012
   Serial number: 00000000000008531217
   Coding: 050200
   Part No SW: 5Q0 035 874 A    HW: 5Q0 035 874 A
   Component: MU-S-ND-ER    H24 0245
   Serial number: SKZAZ2S8224209
   Coding: 03730201FF00000011111201008800002F0200C601200100C6
   Shop #: WSC 73430 790 00063
   ROD: EV_MUStd4CTSAT_VW41.rod
   VCID: 32608E0065BC70DF57-8066
   Subsystem 1 - Part No SW: 5E0 919 605 J    HW: 5E0 919 605 J
   Component: ABT_Std-2_Nav  H41 1028
   Serial number: SKZ8Z9SBT01JEK
   Subsystem 2 - Part No SW: 5L0 051 236 H    HW: -----------
   Component: ECE 2016  --- 0521
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0203
   Revision: 8C001003    Serial number: 0387671170
   Coding: 0100000202000000
   VCID: 3E78AA30A1E4A4BFA3-806A
136203 - Supply Voltage
          P1757 00 [009] - Open Circuit
                    Reset counter: 133
                    Mileage: 72165 km
                    Date: 2019.01.04
                    Time: 12:39:08
End-------------------------(Elapsed Time: 05:06)--------------------------
There's a reason that 19.6.0.2 isn't current anymore. ;)
Click here.
processpaul
C?ID=43225
Uwe.
Thank you, that worked.
I've never seen this happen before on other cars I've had to see me for a few coding modifications. Is the typical behaviour now for latest versions.
I really thought it was my modules weren't supported.
Uwe.
No, it was a bug in that particular version.
