'10 Golf GTI Will not learn steering angle G85
MDCARCARE
NC, USA
C?ID=203365
I fitted this car with a new brake controller. Some of you may remember the post i created trying to code this module. However it was determined that module was wrong. So we got the CORRECT module from the dealer and coded it. Ive got all the basic settings performed but it will not take G85 Steering Angle sensor. Ive tried this relearn in module 44 and 03 multiple times with no success. As always the auto scan is attached. I did not put a module in this car for this issue.
Thursday,08,August,2019,17:30:31:46456
VCDS Version: 19.6.1.0 (x64)
VIN: WVWHV7AJ7AW079881   License Plate:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 55 56 62 65
          72 77
VIN: WVWHV7AJ7AW079881   Mileage: 198530km-123360miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AM    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0030
   Revision: AAH06---    Serial number:
   Coding: 0403010A1C070160
   VCID: 71E929F6681C62C766-8024
Readiness: 0010 0101
   Part No SW: 02E 300 051 R    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1930
   Revision: 04844002    Serial number: 00000907180071
   VCID: 224B16BAFD7A895FAF-8076
   Part No SW: 1K0 907 379 BA    HW: 1K0 907 379 BA
   Component: ESP MK60EC1   H45 0109
   Revision: 00H45001
   Coding: 114B600CC9290003881306EC931A0041B108
   Shop #: WSC 00001 000 00000
   VCID: 72EB26FAAD1A59DF9F-8026
                    Fault Status: 01100101
                    Reset counter: 60
                    Mileage: 198535 km
                    Date: 2013.12.29
                    Time: 05:42:19
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 295
                    Count: 48896
                    Count: 1
   Part No SW: 3C8 907 336 N    HW: 3C8 907 336 N
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 387FD4D283E6F38F61-806C
Address 09: Cent. Elect.
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   019 0706
   Serial number: 003C4D073F0E
   Coding: 00003031
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3979D1D6B8ECEA879E-806C
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--0004LACP00
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 3572MSME08037249ZZZQ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 3582MSME0E774149ZZZ/
   Serial number: 3512QSME283B3135ZZZR
   Serial number: 3522QSME14272F78ZZZ
   Serial number: 35527SME04111400ZZZU
   Serial number: 35627SME08211400ZZZ-
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Fault Frequency: 11
                    Reset counter: 97
                    Mileage: 198526 km
                    Date: 2019.08.07
                    Time: 18:15:02
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           055 0111
   Coding: 0001632
   VCID: 76E31AEA017245FFB3-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
   Part No SW: 5K6 920 970 G    HW: 5K6 920 970 G
   Component: KOMBI         H05 0206
   Coding: 270F00
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 080709F1002115
   Coding: ED817F07001612000002
   VCID: 66C34AAA51D2B57F03-8032
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223T5VMZ04
   Coding: 0000002
   VCID: 7EF302CA29420DBFEB-802A
   Component: IMMO          H05 0206
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667511421
   VCID: 26430AAA5152757FC3-8072
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2109
   Coding: 0001204
   VCID: 3169E9F6A89C22C726-8064
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 74     2901
   Revision: 00H17000
   VCID: 2F6DEF8EBEA8343730-807A
Address 46: Central Conv.
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001204
   VCID: 326BE6FAAD9A19DF5F-8066
   Component: AFS-Steuergeraet    0142
   Coding: 1446940
   VCID: 3467E0E2578E17EF4D-8060
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000022
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0034
   Revision: -----19S    Serial number: VWZ4Z7J1107953
   Coding: 0100040004
   VCID: 61C959B678FCD247F6-8034
                    Reset counter: 55
                    Mileage: 198526 km
                    Date: 2013.12.28
                    Time: 18:13:37
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Part No SW: 1K0 937 087 G    HW: 1K0 937 087 G
   Component: RDK           103 0521
   Coding: 018705
   VCID: 3561DDE69CF40EE77A-8060
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0001168
   VCID: 3561DDE65CF40EE77A-8060
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 C    HW: 1K8 035 730 C
   Component: Telefon       H08 6600
   Revision: 00008000    Serial number: 20389520180607
   Coding: 412100
   VCID: 29590196404C5A07EE-807C
End-------------------------(Elapsed Time: 02:43)--------------------------
NostraJackAss
Did you login the ABS controller with observation of caption code provided and commence the basic settings for G85 & road test?
DrPeter
16.4905° S, 151.7375° W
In addition to what Jack has mentioned, you may want to have a look at the Measuring Value Block group [007] in the [44-Steering Assist] controller.
The following fields will be useful and should help to determine the "status" of the G85-Steering Angle sensor.
MVB [007], field (1) = Steering Angle Sensor (G85)
---> This is the 'live' value of the G85 sensor in degrees and should reflect the movement of the steering wheel, the Range is: [-720.0...+720.0 °]
MVB [007], field (2) = Steering Angle Speed
---> Speed at which the G85 sensor changes value
MVB [007], field (3) = Calibration,Status (G85)
---> This is the 'status' of the G85 Sensor, Range is: [Yes] or [No]
MVB [007] (4) = Initialization Status (G85)
---> This is the important one!! The G85 Sensor MUST be initialized before it can be calibrated!
---> Range is: [SteerAng Init] or [SteerAng n.Init]
If the G85 sensor has not been initialized, you will need to change this status. You can typically do this by performing a slow (15-20mph) parking lot road test, then come to a complete stop and turn the steering wheel from one 'end-stop' to the other 'end-stop', hold at the stops for about 10-15 seconds. Then check the MVB group [007], field (4) to verify the [SteerAng Init] is displayed.
Hope this helps,
drpeter
MDCARCARE
NC, USA
C?ID=203365
drpeter thank you sorry it had taken so long to get back. this vehicle has went to the back burner.
Address 44: Steering Assist (1K0 909 144 H)
11:01:19
-1.49° Steering Angle Sensor (G85)
0.0°/s Steering Angle Speed
calibrated Calibration Status (G85)
SteerAng Init Initialization Status (G85)
I went right into module 44 and veiwed the data. I did the parking lot test drive and field for changed to steerang init. The light went right off. Wow thank you for your help. i was missing one important step that i didn't know about.
