2016 Tiguan S - Did I Change ATF Correctly?
ttrifko2
C?ID=377110
I have three questions for the community, highlighted in bold below.
First, the basics: 2016 Tiguan S with 4-motion, 2.0L 6-speed automatic transmission. I had the Stage I ECU upgrade installed from APR set at 93 Octane. Odometer is currently at 42,000 miles.
I just followed all the steps to change the ATF:
- Took out the drain plug and stand pipe and drained the old ATF
- Removed ATF pan, replaced filter and gasket, reinstalled
- Put the stand pipe back in
- Pumped in about 5-6 quarts of ATF
- Had the wife start the car and start cycling through R, D, S, and manual mode 1 and 2, and back to park
- As she cycled through I pumped in another quart
- After she cycled twice she left it in park with engine running and foot on the brake
- When VCDS displayed 40 degrees Celsius ATF temperature, I removed the pump adapter and let the ATF trickle back out
- When it stopped trickling and only lightly drizzled I replaced the drain plug with a new crush washer
- Car in park, I checked for leaks
- Drove the car around and parked it again, engine running, checked for leaks again
Question 1: Did I do that all right?
Question 2: If I screwed it up, how will I know? Will the shifting start to act funny? Will the ATF temperature exceed a certain temperature while driving? Will everything seem fine and then BAM! the tranny explodes while my wife is driving our daughter?
When I test drove it the shifting seemed totally fine. The ATF temperature never exceeded 60 degrees Celsius during my short test run.
I ran the auto scan while parked with engine running after the test run.
Question 3: Why is there a malfunction in Central Electronics (Line 9)? Could it have something to do with APR installing a custom flash for the ECU?
I would sincerely appreciate any insight into my three questions. I am but a humble DIY guy trying to save money by doing my own maintenance. I was dumbfounded when I found out the procedure for my vehicle.
Thank you,
Theo
Wednesday,07,August,2019,17:46:38:43947
VIN: WVGBV7AX3GW577137   License Plate:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 42 44 46 4C 52 53 5F
          62 72
VIN: WVGBV7AX3GW577137   Mileage: 68930km-42831miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 JP    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 06 1335
   Revision: P3H08---    Serial number:
   Coding: 0423010A190F0160
   VCID: 025D8A716805ABA7DCD-8056
   Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
   Component: AQ 250 6F           2627
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 074B9B6543278E8F8B3-8052
   Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
   Component: J104   C6 450M VDF7 0021
   Revision: --H07---    Serial number: 00000009076993
   Coding: 0005161
   VCID: 78A9E8993ED9F177F29-802C
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0389948687
   Coding: 030C0C
   VCID: 372B2BA57FC73E0F3B3-8062
   Part No SW: 561 907 426 G    HW: 561 907 426 G
   Component: AC Manuell    H03 0506
   Revision: 00001K02
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1F1BE305F737664FD33-804A
   Part No SW: 5K0 937 084 N    HW: 5K0 937 084 N
   Component: BCM PQ35 B    122 0183
   Revision: BG122001
   Coding: EF1A0A1B80232EC4008800C11400044448510086566D8DF064800000A040
   VCID: 3D27398D5D7B145FE1F-8068
   Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS316 301115  24  0664
   Coding: 009795
   Component: RLS 221215 05  54  0403
   Coding: 02304D
   Part No SW: 5N0 959 655 AB    HW: 5N0 959 655 AB
   Component: J234__005 VW10 HI   5418
   Revision: 36023000    Serial number: 003MAPRJW2R
   Coding: 0012341
   VCID: 7DA7F98D11FBD45FA1F-8028
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 0000000000RLSP
   Subsystem 3 - Serial number: 0026.10.150000300000650008ÿ†63
   Subsystem 4 - Serial number: 650008ÿ†6332MTS605663125+ÿ†63
   Subsystem 5 - Serial number: 63125+ÿ†6342MTS6074931252ÿ†63
   Subsystem 6 - Serial number: 931252ÿ†6351HTS6MPLA4EKJFÿ†63
   Subsystem 7 - Serial number: A4EKJFÿ†6361HTS69R1P1EKR5ÿ†63
   Subsystem 8 - Serial number: P1EKR5ÿ†63727TS6JEIPSDKJTÿ†63
   Subsystem 9 - Serial number: PSDKJTÿ†63827TS6HH3C3EKJMÿ
   Subsystem 10 - Serial number: C3EKJMÿ
   Part No SW: 5K0 953 501 DM    HW: 5K0 953 569 AP
   Revision: FF010042    Serial number: 20151211300400
   Coding: 1102140000
   VCID: 78A9E8993259F177F29-802C
   Serial number: 0933302
   Coding: 820000
   Part No SW: 5N0 920 973 L    HW: 5N0 920 973 L
   Component: KOMBI         H04 1008
   Coding: 211F010000
   VCID: 3D27398D5DFB145FE1F-8068
   Part No SW: 7N0 907 530 AT    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1663
   Revision:   H57       Serial number: 131215F1001318
   Coding: 356022
   VCID: 025D8A716405ABA7DCD-8056
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00013.11.15
   Coding: 0001
   VCID: 52FD7A31F465FB272CD-8006
   Component: IMMO          H04 1008
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC2D17CF553E774D-803E
   Revision: 00000000    Serial number: 15000260863003
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 303910B99AA9E9377A9-8064
   Part No SW: 5N0 959 701 H    HW: 3C0 959 793 H
   Component: TUER-SG FT    002 0601
   Revision: 13100010    Serial number: 0010169822
   Coding: 0004B4
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
   VCID: 3A2D32914CD52367C4D-806E
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  010 1505
   Serial number: 00000009635653
   Coding: 000490
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.285 1401
   Revision: 1BH04841    Serial number: 00153270164201
   Coding: 0000258
   VCID: 41DF457D2D8370BF857-8014
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0010266599
   Coding: 0004B4
   VCID: 392F2D9D49D3287FCD7-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  010 1505
   Serial number: 00000009647861
   Coding: 000490
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000980834
   Coding: 0026156
   VCID: 382928997E593177329-806C
   Part No SW: 561 035 150     HW: 561 035 150
   Component: MU-E--US      857 6495
   Serial number: 04121500011967
   Coding: 02130600FF00000041220001001000001F0000D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 4ACD62511C35B3E754D-801E
End----------(Elapsed Time: 01:22, VBatt start/end: 13.5V/13.6V)-----------
Your fluid change procedure sounds OK to me, but I can't say I've ever done that myself, so if anyone has another opinion, please chime in here.
The Gateway sometimes gets out of synch with the actual status of a module.
Try clearing fault codes directly in 09:
[Select]
[09 - Cent. Elect]
[Fault Codes]
[Clear Codes]
If that doesn't resolve it, go to the Auto-Scan screen and:
[Gateway Installation List]
[Clear all DTCs] (make sure "Use CAN Command" is checked).
