Problems seeing Module 53 options on a Touareg
shabazmo
Hook, UK
C?ID=9427
I am using VCDS release 19.6.1 on Windows XP.
I was looking to retract the brake linings on a 2014 Touareg 7p, so entered module 53 Parking brake, Basic settings. The only options I got was
Static current measuring mode
Air gap calibration
Electromechanical parking brake erase activation counter
Lamp Test
Reset start up
Setze Einschleif-Zustand
Its UDS protocol. Why cant I see the option to retract or replace the parking brake linings.
I have tried this on my A7 and I can see the options to retract and change the brake linings.
Santos
rhinopower
C?ID=58979
Some cars you need to go into the ABS to perform lining replacement. Check your ABS instead of 53 Parking break
No, a 7P Touareg definitely has a 53-Parking Brake module. But... It's a totally different animal than most EPB systems. Instead of using the the service brake's pads, it uses a set of dedicated brake shoes for the parking brake. These press outward against the interior of the rotor like a conventional drum brake. Have a look at the pictures here.
This means you can change the disc pads without every touching the parking brake. However, if you change the rotors, then air-gap adjustment and griding-in will probably be required. See also the Wiki article Santos linked to above.
shabazmo
Hook, UK
C?ID=9427
Thank you Uwe and everyone else. I have read the notes and watched the video and it appears that you don't go into basic settings on address 53 to retract the epb, but instead go into the Output test to "open calliper", do the work and then "close calliper" (meaning the motor for the shoes). This in-turn will produce a fault code which can only be cleared when the grinding process is done. Can someone confirm that my thinking is correct?
My next thought is why cant I just remove and replace the discs without touching retracting the epb shoes. I should be able to do this given there is an airgap. I will of course have the risk of the epb activating whilst the disc is removed, but removal will only be for about 20 seconds.
Dare I try to remove the disc without isolating the epb. MMM! You thoughts would be appreciated.
Finally the scan details are below:
Tuesday,06,August,2019,09:30:46:10945
VCDS Version: 19.6.1.0
VIN: WVGZZZ7PZED048738   License Plate:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 65
          6D 72
VIN: WVGZZZ7PZED048738   Mileage: 103535km-64333miles
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0007
   Revision: 53H41---
   Coding: 292A4012232601020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P0907401F 001008
   ROD: EV_ECM30TDI_VW52.rod
   VCID: 326097EC6505A0DF5F-8066
5618 - Engine Off Timer Performance
          P150A 00 [096] - -
   Part No SW: 0C8 927 750 BQ    HW: 0C8 927 750 BQ
   Component: AL1000 AISIN  002 2530
   Coding: 003568
   Shop #: WSC 21075 002 1048576
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002.rod
   VCID: 7CFC79D4F7C1A6AFC5-8028
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 412340010EC818
   Coding: 5B6B13C30928255BDAFBC89690DAA450F700
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4A90EF0CED95C81F07-801E
   Part No SW: 4H0 907 064 FH    HW: 4H0 907 064 EH
   Component: BCM2 2.0      H36 0551
   Coding: 05B60016000000000000
   VCID: 74EC51F4D791EEEF8D-8020
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 0214000089798013
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
   Component: Klima 2 Zonen H21 1306
   Coding: B6A6000890
   VCID: 050A1C30840BE767AA-8050
          U1101 00 [008] - Active
                    Reset counter: 210
                    Mileage: 101479 km
                    Date: 2019.06.16
                    Time: 12:27:16
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001883621
   Coding: 26001010D1345D010021000300005D0C431D470807010241000000020000
   VCID: 6CDC49948FA1362F55-8038
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    140422  033 0021
   Serial number: 90243401140506072615
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20316622
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431     HW: 7P6 941 431
   Component: E1 - LDS  H04 0031
   Serial number: 00000000000905140171
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0026
   Revision: --------    Serial number: 28231413700671
   Coding: 108501
   ASAM Dataset: EV_VW526ParkiAssis2 001012
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 438EC228CABF1957C4-8016
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 E    HW: 7P0 959 655 E
   Component: VW10Airbag00K H10 0043
   Revision: --------    Serial number: 003NK0001H4P
   Coding: 00000000000000000000000000000000304B
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   Serial number: 3575LRB401A50OF84H4%
   Serial number: 3585LRB401E50OF880H4
   Serial number: 3517ARB405H2KCVM9OC7
   Serial number: 3527ARB405J2KCVMH08X
   Serial number: 3557BRB401C50QLP9J7Q
   Serial number: 3567BRB401C50QLOJBK+
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 01335NEE000US
   Coding: 000C35
   VCID: 3874A5C48B794A8F61-806C
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0047991 TRW 20140421
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 982 S    HW: 7P6 920 982 S
   Component: Kombi         H13 0419
   Revision: 13240270    Serial number: 658200514592030
   Coding: 332731002B00260001000C
   ASAM Dataset: EV_KombiUDSRBVW526 001020
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 4E98E31C11FDE43F5B-801A
   Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6032
   Revision: --------    Serial number: 00000001393862
   Coding: 000D07AD00
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3F86CED8A6577DB7A0-806A
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 41128118475701187155
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 14133001493011200181
16384 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] - -
                    Fault Frequency: 72
                    Reset counter: 222
                    Mileage: 98710 km
                    Date: 2019.05.19
                    Time: 12:36:36
                    Voltage terminal 30: 14.7 V
                    Voltage terminal 15: 14.7 V
                    Control Module temperature: 36 °C
                    System status: Terminal 15 on
                    IN ESP_standstill flag: no standstill detected
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000103201216
   Coding: 011D1620D001451005080002
   VCID: 7AF07FCCF5F5989FD7-802E
   Revision: 00002001    Serial number: 0335487804
   Coding: 011B1E2228B9109583200624010000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO28986007
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO29263376
   Coding: 191100
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000103470223
   Coding: 011D1620D001451005080000
   VCID: 4894D504FB993A0F11-801C
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1451100775
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3668ABFC896DBCFF73-8062
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 018E00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 130000
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109E50E7926865
   Coding: 010105020100000003
   VCID: 285475845BD9DA0FF1-807C
   Part No SW: 7P6 035 670 G    HW: 7P6 035 670 A
   Component: H-BNT-EU      H40 0822
   Revision: --------    Serial number: 444EQ0EB000503
   Coding: 010101050040E1ED01000B0E00000003F00401030000000000
   VCID: 3972A0C0B07353879E-806C
   Subsystem 1 - Part No: 8R0 060 884 BT
   Component: EUR 2014  1903
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H27 0045
   Serial number: VWZ8Z9PA20165A
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H26 0045
   Component: CD-Database  5950
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000103503334
   Coding: 011814200001251005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 K    HW: 7P6 907 273 K
   Component: RDKBERU25     H09 0009
   Serial number: 10000000130746
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 448CC134CFB11E6FFD-8010
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 127400299
   Coding: 0533314002
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000103502287
End-------------------------(Elapsed Time: 05:16)--------------------------
Why would the EPB activate while you've got the disk off?
If you're replacing the disks, you might have to adjust the air gap and do the grinding in through, but personally, I would try it without and see what happens.
