2010 VW Jertta Sportwagen TDIturn off lamp warning in speedo face.
clifford.hubbard
C?ID=377203
I replaced tag lamps with LEDs. Is there a workaround to turn off defective lamp signal in VCDS?
thanks
Cliff
Wednesday,22,August,2018,18:06:05:40333
VCDS Version: 18.2.1.5 (x64)
Data version: 20180518 DS287.2
VIN: 3VWTL7AJ8AM662893   License Plate:
Mileage: 178510km-110920mi   Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 37 42 44 46 4F 52 56 62 65
          72 77
VIN: 3VWTL7AJ8AM662893   Mileage: 178510km-110920miles
2E-Media Player 3 -- Status: Malfunction 1010
37-Navigation -- Status: Not registered 0011
Address 01: Engine
Address 03: ABS Brakes
Address 08: Auto HVAC
Address 09: Cent. Elect.
Address 15: Airbags
Address 16: Steering wheel
   Part No SW: 5K0 920 970 Q    HW: 5K0 920 970 Q
   Component: KOMBI         H03 0305
   Coding: 270D00
   Shop #: WSC 00066 000 00147
   VCID: 3C7C2FC3B7F62AA438-8068
   Part No SW: 1K0 907 530 AE    HW: 1K0 907 951
   Component: J533  Gateway   H06 0112
   Revision:   H06 01    Serial number: 161209F2001243
   Coding: E9807F07001613002002
   Shop #: WSC 00066 000 00000
   VCID: 6AD0D99B45E264149A-803E
01304 - Radio
                    Fault Status: 00110100
                    Reset counter: 134
                    Mileage: 177727 km
                    Date: 2013.01.04
                    Time: 07:27:10
            000 -  -
                    Fault Frequency: 140
                    Mileage: 177979 km
                    Date: 2013.01.07
                    Time: 17:01:09
03272 - Control Module for Audio Interface
                    Reset counter: 134
                    Mileage: 177756 km
                    Date: 2013.01.04
                    Time: 10:54:57
Address 1C: Position Sensing
   Component: IMMO          H03 0305
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD0D99B8DE264149A-803E
Address 2E: Media Player 3
   Part No SW: 3C0 035 684 C    HW: 3C0 035 684
   Component: RNS-MID       H17 1140
   Revision: AB001001    Serial number: VWZ6Z7H6200096
   Coding: 04000400040000A600
   Shop #: WSC 05311 000 08193
   VCID: 234EF4BF2248755C19-8076
            000 -  -
                    Fault Frequency: 21
                    Reset counter: 103
                    Mileage: 177976 km
                    Fault Status: 00101011
                    Fault Frequency: 8
                    Reset counter: 143
Address 44: Steering Assist
Address 46: Central Conv.
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Component: EZE_2         H06 0112
   Coding: 050B0500
   VCID: 66C8ADAB91FA4074BE-8032
Address 52: Door Elect, Pass.
            000 -  -
                    Fault Frequency: 21
                    Reset counter: 103
                    Mileage: 177976 km
                    Fault Frequency: 8
                    Reset counter: 143
Address 62: Door, Rear Left
Address 65: Tire Pressure
Address 72: Door, Rear Right
Address 77: Telephone
End-------------------------(Elapsed Time: 03:28)--------------------------
Address 56,3C0 035 684 C,recoded (Long Coding),from,04000400040000A600,to,06000400040000A600,(05311/000/08193),
Address 56,3C0 035 684 C,recoded (Long Coding),from,06000400040000A600,to,06010400040000A600,(05311/123/08193),
Address 56,3C0 035 684 C,recoded (Long Coding),from,06010400040000A600,to,06010440040000A600,(05311/123/08193),
Address 56: DTCs cleared
TBAx
DE
C?ID=287144
Unfortunately no. Not with VCDS.
In your Auto-Scan many modules aren’t reachable. Did you create it with ignition on and doors unlocked?
clifford.hubbard
C?ID=377203
No i did not. Just placed the leds in holders. The doors where un locked...ignition was off
Can we get you to post a current scan, using the interface you registered recently, rather than a scan from nearly a year ago, that was done with a totally different interface?
clifford.hubbard
C?ID=377203
Yes will do when i get a moment...
clifford.hubbard
C?ID=377203
2010 Jetta Sportwagen TDI Auto scan
Wednesday,07,August,2019,22:15:05:61365
VCDS Version: 19.6.1.0 (x64)
Mileage: 207920km-129195mi   Repair Order:
          72 77
VIN: 3VWTL7AJ8AM662893   Mileage: 207920km-129195miles
   Part No SW: 03L 906 019 CL    HW: 03L 906 022 TS
   Component: R4 2,0L EDC G000SG  9971
   Revision: 12H03---    Serial number:
   Coding: 0050072
   Shop #: WSC 06103 444 999999
   VCID: 77D3327F0622F1F7A8-8022
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 114B600C492800FC881306ED921C0042300000
   VCID: 78D13143CB3CFE8FA1-802C
   Part No SW: 5K0 937 085 G    HW: 5K0 937 085 G
   Component: BCM PQ35 B++  111 0128
   Revision: BI111001
   Coding: 29380E3F902F3EC480080081440000C405000086535D8560648020000000
   VCID: 3753F27F86A231F768-8062
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 18021  21  0512
   Coding: 009795
            010 - Open or Short to Plus
Address 15: Airbags
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Coding: 0000532
   VCID: 78D131430B3CFE8FA1-802C
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Coding: 270D00
   VCID: 3C59ED53B78412AF85-8068
   VCID: 6AF51B0B45905C1F27-803E
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223T7DK404
   Coding: 0000002
   VCID: 7EDD275B2918C0BFEB-802A
   VCID: 6AF51B0B8D905C1F27-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667729189
   VCID: 266D2F3B5108B87FC3-8072
   Coding: 06010440040000A600
   Shop #: WSC 05311 123 08193
   VCID: 236B362F223A4D57A4-8076
00857 - CD Changer Unit (R41)
02633 - Antenna for Satellite Tuner
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0307
   Revision: 13101005    Serial number: 0000359790
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide_VW36.rod
   VCID: 2773223F5E02A177F8-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000004587424
   Coding: 000490
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [009] - Electrical Failure
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 3147CC67A8C6EFC726-8064
   Coding: 050B0500
   VCID: 66ED6F3B9188787F03-8032
   Component: J245EE20SKB13  H01 0220
   Component: J394EE20SKB13  H01 0220
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           111 0821
   Coding: 018705
02904 - Hard Warning 3
02903 - Hard Warning 2
02801 - Hard Warning
End-------------------------(Elapsed Time: 02:26)--------------------------
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
When you buy good quality LED they have simulator and not trigger light bulb warning.
clifford.hubbard
C?ID=377203
came from amazon. these are the ones i got...
LED Monster 4pcs Ice Blue T10 194 168 Wedge 5-5050-SMD LED License Plate Light Lamp Bulb 12V (5 SMD)
clifford.hubbard
C?ID=377203
Found code”Cold Diagnosis License Plate Light, Active”. Un checked box and saved. Light still on...
TBAx
DE
C?ID=287144
The Software and variant of your BCM do not support this bit it seems.
