Set Passat B6 hill hold on by default
adamrj
C?ID=214457
I wonder if anyone knows whether it's possible to enable hill hold full-time on a Passat B6? It has hill hold installed from new, but defaults to off on every start cycle. Scan below.
Thanks,
Adam
Friday,02,August,2019,18:36:27:31354
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWZZZ3CZ9E021693   License Plate: PASSAT
Mileage: 290640km-180595mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ9E021693   Mileage: 290640km-180595miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BL    HW: 03L 907 309
   Component: R4 2,0L EDC G000SG  2650
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 84224 152 600198
   VCID: 70AC2F6063D969CF69-8024
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - Intermittent
                    Fault Frequency: 46
                    Mileage: 290087 km
                    Date: 2019.06.19
                    Time: 18:16:26
                    Lambda: 11.8 %
                    Lambda: -2.4 %
                    Voltage: 0.380 V
                    Bin. Bits: 00000000
006481 - Radiator Fan 2 (V177)
               P1951 - 000 - Movement Restricted / Jammed - Intermittent
                    Mileage: 290573 km
                    Date: 2019.07.22
                    Time: 18:01:23
                    RPM: 1265 /min
                    Speed: 11.0 km/h
                    Temperature: 50.4°C
                    Temperature: 81.0°C
                    Temperature: 29.7°C
                    Lambda: 21.3 %
                    Lambda: 0.0 %
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000785849746
   Coding: 0001298
   Shop #: WSC 05311 000 00000
   VCID: 2B16F80C8A7F4A171C-807E
   Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
   VCID: 77BE147C06B73EF7A8-8022
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 01000008409879
   Coding: 00888F0700041A00470A00000F000000000859435C000100000000000000
   Shop #: WSC 05124 000 00000
   VCID: 6FAE2C1C7EE7763770-803A
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 290508 022  0601
   Coding: 00046997
   Shop #: WSC 05124
   Component: J234__006 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPC8RWXX
   Coding: 0012342
   VCID: 3B36C84C7A1FDA978C-806E
   Subsystem 1 - Serial number: 6333FTS655021268
   Subsystem 2 - Serial number: 6343FTS617121598
   Subsystem 3 - Serial number: 6353ETS6EK7VTVNH
   Subsystem 4 - Serial number: 6363ETS69L4OTVNP
   Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507AT
   Coding: 0000112
   Part No SW: 3C0 920 971 E    HW: 3C0 920 971 E
   Component: KOMBIINSTRUMENT VD1 2416
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007405
   Shop #: WSC 00488 210 175951
   VCID: 271E043C96976E77F8-8072
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 H    HW: 3C0 907 951
   Component: J533__Gateway   H13 0142
   Revision:   H13       Serial number: 2600P08616079A
   Coding: F9807F060002022003
   VCID: 26000938919D777FC3-8072
01304 - Radio
                    Fault Frequency: 122
                    Reset counter: 143
                    Mileage: 289799 km
                    Date: 2019.06.07
                    Time: 17:10:59
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: 393AD2447023E8879E-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1518
   Revision: 72009005    Serial number: 00000309288612
   Coding: 0000693
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 195    2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A18FD088585531FE7-807E
   Component:    KSG PQ46 ELV 042 0472
   Coding: 1891020051030E7630049C1D70085FCE107C01
   Shop #: WSC 05311 123 12345
   Component: LIN BACKUP HORN H08 9001
   Component: Neigungssensor  004 0611
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1518
   Revision: 72009005    Serial number: 00000795888626
   Coding: 0000692
                    Fault Status: 00101100
                    Reset counter: 139
                    Mileage: 290182 km
                    Date: 2019.06.22
                    Time: 15:51:56
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   008       Serial number: 00000000059905
   Coding: 0000057
   VCID: 281C07009B89610FF1-807C
Address 56: Radio
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000487216
   Coding: 0000144
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000482879
   Coding: 0000144
   VCID: 71AA2A6468D360C766-8024
End----------(Elapsed Time: 01:29, VBatt start/end: 12.2V/12.2V)-----------
diskoboy
Denmark
C?ID=50403
I’ve read somewhere years ago that the 53-module should be a E or newer module.
United States
I can't confirm or deny this is possible either but I checked our VW EPB Generation 3 and EPB Generation 4 files and we don't have anything like that documented for CAN controllers.
Some of the newer VW/Audi models with UDS protocol 53 modules have Adaptation channels (for things like auto-apply EPB with the door open and similar) but that doesn't apply to this car.​
siLc
Tallinn, Estonia
C?ID=330192
On the RoW Passat B7 EPB4 3AA907801 there is an adaptation channel, which enables the Auto-Hold menu in MFA, which lets you choose between having autohold on by default, off by default or the default behaviour. This late-model B6 with it's 3C8 EPB might or might not have it.
