Audi A6 C7.5 Facelift Upgrade Full LED (not Matrix) from Xenon with AFS
XPepino
Czech Republic
C?ID=91614
Hello
tried someone this ?
Upgrade in Audi A6 Facelift from Xenon (hope with AFS) to Full LED (not Matrix).
It have the same wiring ? (i do not have new elsa)
I have also high beam camera, and my friend have a car (RS6), where are Full Led original fitted. So it is possible download adaptation channels.
I know that Matrix need also camera in windshield, so it is already too expensive for this project :-/
Central Electric unit is the same like in car with Full LED.
My friend who has Full LED on RS6 have unit and coding:
Address 09: Cent. Elect. (J519)       Labels:. User\4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001016055802
   Coding: 0105001440349FE0890140C7A0001800CF9CC7082608020180000814E111170200400034030000
   Shop #: WSC 02391 785 00200
   VCID: 71AA214AA899BAC222-8024
I have unit and coding:
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Revision: 15020001    Serial number: 00000956571002
   Coding: 2600001400749FE00181408000001D0CCF9CC6082E090201000008206101140200400024030000
   VCID: 71EFA117A89A0CCCDB-8024
What do you think ?
XPepino
Czech Republic
C?ID=91614
So i found, that these lights are not with AFS ... So it is only normal Xenon.
XPepino
Czech Republic
C?ID=91614
Noone here did it ? It seems that it will not be plug and play...
hadez16
C?ID=289891
Where is the full Auto-Scan?
Did the change already happen?
What exactly do you want to know?
XPepino
Czech Republic
C?ID=91614
Hello
i am talking only about physical connection, if it is possible. I tried find a reduction from Xenon to LED, but on Kufatec is not available for facelift (only prefacelift).
I already have downloaded maps from Full LED car and Xenon car. Not so much differences.
XPepino
Czech Republic
C?ID=91614
So - project started :-)
I have already new Full LED facelift headlights with units (not Matrix). Now i compared wirring (not much to do on 14 pin connector (some swap + add CAN BUS)) . But there is necessary to add front leverer (4H0941285H + connector 4B0973712) and 55 Headlight range module (4H4907357D or 4H4907357E + connector 7M3972726B) + wirring.
Changes are:
J519
T17c 3 MX1 T14c 11 - cut wire
T17c 5 MX1 T14c 9 - swap to T14c 11
T17c 8 MX1 T14c 13 - swap to T14c 9
T17e 8 MX2 T14d 13 - swap to T14d 9
T17e 9 MX2 T14d 11 - cut wire
T17e 10 MX2 T14d 9 - swap to T14d 11
Add CAN BUS + Power
MX1:
T14c 8 ST1 SB12
T14c 13 CAN-HIGH J431
T14c 14 CAN-LOW J431
MX2:
T14d 8 ST1 SB6
T14d 13 CAN-HIGH
T14d 14 CAN-LOW
J519 - Leverer wiring
pls use ELSA for right connection between each leverer
G76 - rear leverer
G78 - front leverer
(hope)
T17d 5 G76 T4at 1
T17d 7 G76 T4at 2
T17d 13 G76 T4at 3
Change:
T17d 5 G78 T4s 1
T17d 7 G78 T4s 2
T17d 11 G78 T4s 4
T17d 13 G76 T4at 4
+ Coding + adaptation
I let you know!
Bogdan.audi
Ukraine
C?ID=90275
Hi.
G78-not needed.
I was doing
XPepino
Czech Republic
C?ID=91614
Late, I already did (G78 + 4H4907357E). But i have problem now. I upload new dataset via VCP to 55 - Heaglight Range - ok. Made coding.
But my headlight units are new and it seems, that there is no uploaded any firmware.
What now ? I tried do it with VCP cable but not success (not sure how to choose slave unit). Coding Slave not working.
High beam does not work now and there is error with adaptive light.
My friend with LED Headlights have this like slave:
   Coding: 04FA02102A230200
   VCID: 3424E85E9F0BCFEF4D-8060
   Coding: E01E00
   Coding: E01E00
I have now this errors
17-Instruments -- Status: Cannot be reached 0100
88-Multicont. Seat Driver -- Status: Malfunction 0010
89-Multicont. Seat Pass. -- Status: Malfunction 0010
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 0655
   Revision: 85H23---
   Coding: 12254012232401080000
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002002
   ROD: EV_ECM20TDI01104L906021FQ_002.rod
   VCID: 79BA196AF8E9F287E0-802C
   Part No SW: 4G1 927 153 G    HW: 0CJ 927 156
   Component: 0CK 20TDI RdW H05 0001
   Revision: --H05---    Serial number: 0000002243
   ASAM Dataset: EV_TCMDL382021 002028
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 2E10FA367127E53F05-807A
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041170332003398
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 06A29E41604579829B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3FCEB772A64D1CB79E-806A
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 0189700E000000000000
   VCID: 7AB80666F5EFF99FE9-802E
   Part No SW: 4G8 959 760 C    HW: 4G8 959 760 C
   Component: MEM-BFS       H04 0157
   Revision: AA000000    Serial number: 00000152599056
   Coding: C018320085006201010001010101112030303333283333
   VCID: 3A38C666B56F399FA9-806E
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 19101500040623
   Coding: 3402097E210000
   VCID: 63865B026A651857DA-8036
   Coding: 0105001400749FE00101408080001800CF9CC6082608020000000814E111140200400024030000
   VCID: 71AA214AA899BAC758-8024
   Component: WWS57X 141109  H37 0080
   Serial number:         141114150030
   Coding: 0045F7
   Serial number: 23501075
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 22 11 2014  00000555
   Serial number: AD188E57000000000001
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1002E079
   Coding: 30333130313830313833554A304C34473053
   VCID: 3B36C362B2550097B2-806E
   Serial number: 3575HRB40692QMKADH6
   Serial number: 3585HRB40572ORMG1OPI
   Serial number: 3515JRB404T32I4KK8EP
   Serial number: 3525JRB404T32I4KDHCQ
   Serial number: 3554VRB405H32PV6C85W
   Serial number: 3564VRB405732PV6CGJ2
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862NKP001J4
   Coding: 000035
   VCID: 3B36C362BA550097B2-806E
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 04 11 2014  10007750
   Part No SW: 4G8 920 933 Q    HW: 4G8 920 933 Q
   Component: TDieRdw       H07 0043
   Revision: 03001036    Serial number: 658261114592008
   Coding: 03A612000B410008080000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 3E30CA76A14715BF95-806A
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Revision: --------    Serial number: 00000001644078
   Coding: C0CD074418
   VCID: 75A2155AD4F196E784-8020
   Serial number: 2715675003
   Voltage stabilizer:
   Serial number: 14091800000000000059
5013 - Headlight Range Control Module
          U101E 00 [008] - No Communication
                    Reset counter: 94
                    Mileage: 230163 km
                    Date: 2019.10.25
                    Time: 23:45:40
                    Voltage terminal 30: 14.4 V
                    Voltage terminal 15: 14.3 V
                    Control Module temperature: 24 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   VCID: 7CB4007EFFDBC7AFFB-8028
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 27111400040081
   Coding: 20
   VCID: 3D32CD7AAC410EA78C-8068
   Component: MEM-FS        H04 0157
   Revision: AA000000    Serial number: 00000152598571
   Coding: C018330085016201010001010101112030303333203333
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720DTZMG
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3326EB429A05C8D76A-8066
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0432084805
   Coding: 040311
   Shop #: WSC 22675 401 00000
   VCID: 393AD96AB8693287A0-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0431896700
   Coding: 040311
   Component: TSG FA        H03 0511
   Coding: 011F17015E00620002080012
   VCID: 47DEAF92F69D547726-8012
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0013202325
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0353536751
   Coding: 0100063820B930808320090000010F400000000000000000000000000000
   Component: TSG BF        H03 0507
   Coding: 011F17015E00620002080002
   VCID: 46C0A296F1974D7FDD-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001285373
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D12FD3A7C219E273C-8078
   Coding: 04DA02102A630200
   VCID: 3424E85E9F0BCFEF73-8060
13679104 - Local Data Bus
          U10BA 00 [137] - No Communication
                    Reset counter: 54
                    Mileage: 230163 km
                    Date: 2019.10.25
                    Time: 23:56:12
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 54
                    Mileage: 230163 km
                    Date: 2019.10.25
                    Time: 23:56:14
   Part No SW: 4G1 035 044 G    HW: 4G1 035 044
   Component: MU-H-LN-EU    040 0910
   Serial number: A589K0E7501633
   Coding: 01750201FF0A000013110001000A00102F0006E5F1700100DF
   VCID: 23061B022AE558579A-8076
   Subsystem 1 - Part No SW: V03 959 802 DF    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9EY8007PM
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349OJD0000G
   Compact Disc Database:
   Component: Gracenote2  --- 1012
          B2000 87 [009] - Missing message
                    Reset counter: 54
                    Mileage: 230163 km
                    Date: 2019.10.25
                    Time: 23:21:56
                    Software module: status-SW_Status_Consistency: 00 28 13
                    Software module: status-SW_Status_Device: Mmx2Mmx2Mmx2M
   Component: TSG HL        H03 0507
   Coding: 010F15004000620002080002
   VCID: 49DAA9AAE089A20730-801C
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0150
   Revision: 14005001    Serial number: 325400984
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
   VCID: 3620D2568977DDFF4D-8062
   Component: TSG HR        H03 0507
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4G8 881 073     HW: 4G8 881 073
   Component: P2G           H02 0032
   Serial number: 0F5R4MU
   Coding: 766FF0
   ASAM Dataset: EV_P2GDriveSideFrnt 001006
   ROD: EV_P2GDriveSideFrnt.rod
   VCID: 6E903A36B1A7A53F45-803A
   Valve Block 1 In Driver Side Front Seat:
   Subsystem 1 - Part No SW: 4G8 907 181     HW: 4G8 907 181
   Component: PSLB  H02 0023
   Serial number: 00000000000000F5T5E2
   Valve Block 2 In Driver Side Front Seat:
   Subsystem 2 - Part No SW: 4G8 907 182     HW: 4G8 907 182
   Component: PSML  H02 0023
   Serial number: 00000000000000F5J44C
   Valve Block 3 In Driver Side Front Seat:
   Subsystem 3 - Part No SW: 4G8 907 182     HW: 4G8 907 182
   Component: PSMR  H02 0023
   Serial number: 00000000000000F5J2A9
0018 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Funktionseinschränkung wegen fehlender CAN-Botschaft]
                    Reset counter: 54
                    Mileage: 230163 km
                    Date: 2019.10.25
                    Time: 23:21:42
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 0F5R5QW
   Coding: 366FF0
   ASAM Dataset: EV_P2GPasseSideFrnt 001006
   ROD: EV_P2GPasseSideFrnt.rod
   Valve Block 1 In Passenger Side Front Seat:
   Serial number: 00000000000000F5V571
   Valve Block 2 In Passenger Side Front Seat:
   Serial number: 00000000000000F5J2C6
   Valve Block 3 In Passenger Side Front Seat:
   Serial number: 00000000000000F5J2BZ
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 230163 km
                    Date: 2019.10.25
                    Time: 23:21:42
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 143110282
   ROD: EV_RDCMA00100_008.rod
   VCID: 2B16F3224235901722-807E
What do you think ?
XPepino
Czech Republic
C?ID=91614
So i found problem in wirring, that in car are not new +12V wires to fusebox from both lights ( pin 8 on connectors to Fuse box (B) 6 and 12 fuse :-( I let you know after repair it new scan and if it is ok.
XPepino
Czech Republic
C?ID=91614
Now is high beam working (there was missing power for high beam to each headlight, but i have still errors in Headlight range:
What do you think ?
(there are some errors in comfort ventilated seats and central electric - due i have not yet clima panel with ventilation buttons)
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 19.6.2(x64) Data version: 20190930 DS308.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Thursday,31,October,2019,07:46:33:60277
VIN: WAUZZZ4G6FN044702   License Plate: 6Z7 0723
Mileage: 230167km-143019mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 06 08 09 15 16 17 19 20 28 36 3B 3C 42 44 46 52
          53 55 5F 62 6D 72 88 89 AC
   Revision: 85H23---
   VCID: 79AE1CB39957E59F8E9-802C
   VCID: 2E04FFEF1099F2276BB-807A
   VCID: 3FDAB2ABC7F30BAFF0D-806A
   VCID: 7AAC03BF9CD1EE87873-802E
   VCID: 3A2CC3BFDC512E87C73-806E
   VCID: 63925EDB0BDB0F4FB45-8036
   Coding: 0105001440749FE00101408480001800CF9CC6082608020100000814E111140200400024030000
   VCID: 71BE2493C1A7ADDF369-8024
   Coding: 0045F7
   Coding: 02006D
03455 - Function Restriction due to Faults in Other Modules
                Fault Frequency: 8
                Reset counter: 54
                Mileage: 230167 km
                Date: 2019.10.30
                Time: 16:26:05
   VCID: 3B22C6BBD3EB178FDC5-806E
   Coding: 000035
   VCID: 3B22C6BBD36B178FDC5-806E
   VCID: 3E24CFAFC0F902A7FBB-806A
   Coding: C0CD074418
   VCID: 75B61083B54F81FFEA1-8020
   Voltage stabilizer:
   Revision: AA001002
   VCID: 7CA005A796E5D0B795F-8028
   Coding: 20
   VCID: 3D26C8A3CDFF19BFE21-8068
   ROD: EV_SARA2.rod
   VCID: 3332EE9BFBBBDFCF045-8066
   Coding: 040311
   VCID: 392EDCB3D9D7259FCE9-806C
   Coding: 040311
   VCID: 47CAAA4B9FA3436F48D-8012
   VCID: 46D4A74F98A95A67B3B-8012
   VCID: 2D06F8E31D9F893F521-8078
   Coding: 04DA06102A630200
   VCID: 3430ED87FEB5D8F71DF-8060
   Coding: E01E00
   Coding: E01F00
          U1014 00 [137] - -
          [Steuergeraet falsch codiert]
                Reset counter: 54
                Mileage: 230167 km
                Date: 2019.10.30
                Time: 16:36:12
5275220 - Headlight
                Reset counter: 54
                Mileage: 230167 km
                Date: 2019.10.30
                Time: 16:36:13
5544945 - Output Stage for LED Headlamp; Right
          B149B F1 [137] - Incorrectly Coded
                Reset counter: 54
                Mileage: 230167 km
                Date: 2019.10.31
                Time: 07:42:39
5335297 - Fan 2 for Right Headlamp
          C1169 01 [137] - Electrical Failure
                Reset counter: 54
                Mileage: 230167 km
                Date: 2019.10.30
                Time: 16:36:14
   VCID: 23121EDB4B5B4F4FF45-8076
                Reset counter: 54
                Mileage: 230163 km
                Date: 2019.10.26
                Time: 19:34:04
                Voltage terminal 30: 13.2 V
   VCID: 49CEAC7389B7B51F5E9-801C
   Coding: 093205C010
   VCID: 3634D78FE8C9CAE723B-8062
   Coding: 766FF0
   VCID: 6E843FEFD019B2272BB-803A
          U1111 00 [009] - -
                Reset counter: 54
                Mileage: 230167 km
                Date: 2019.10.30
                Time: 16:26:36
   Coding: 366FF0
          U1111 00 [009] - -
                Reset counter: 54
                Mileage: 230167 km
                Date: 2019.10.30
                Time: 16:26:45
   VCID: 2B02F6FB238B870F4C5-807E
XPepino
Czech Republic
C?ID=91614
I found small diference in coding each headlight
The right coding is E01F00 but friend have E01E00. I am not able to change the coding. Any advice ?
I have:
   Coding: E01E00
   Coding: E01F00
Friend in RS6 have:
   Coding: E01E00
   Coding: E01E00
XPepino
Czech Republic
C?ID=91614
So it works now!
Helpded - upload ZDC file dataset with VCP cable to 09 - Central elec. I checked there all LED headlights with AFS parameters for my car (without Air suspension). Then i made Basic settings 55 - Headlight range (i made it with VCP also, but with VCDS it can also work :-) )
Now it is without errors. May be it will help to someone:-)
   Component: R4 2,0L EDC   H23 1649
   Revision: 85H23---
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
   Coding: 0105001440F49FE00101408480001800CF9CC6082608020100000814E111140200400024030000
   Coding: 0045F7
   Coding: 02006D
   Coding: 000035
   Coding: C0CD074418
   Voltage stabilizer:
   Revision: AA001002
   Coding: 20
   ROD: EV_SARA2.rod
   Coding: 040311
   Coding: 040311
   Coding: E01E00
   Coding: E01E00
                    Reset counter: 56
                    Mileage: 230174 km
                    Date: 2019.10.31
                    Time: 21:34:37
                    Voltage terminal 30: 12.0 V
   Coding: 093205C010
   Coding: 766FF0
          U1111 00 [009] - -
                    Reset counter: 56
                    Mileage: 230174 km
                    Date: 2019.10.31
                    Time: 21:34:23
   Coding: 366FF0
          U1111 00 [009] - -
                    Reset counter: 56
                    Mileage: 230174 km
                    Date: 2019.10.31
                    Time: 21:34:23
Bogdan.audi
Ukraine
C?ID=90275
I have 09 only coded
wrclaguna
Poland
C?ID=289360
So it works now!
   Revision: 85H23---
   Coding: 0045F7
   Coding: 02006D
   Coding: 000035
   Coding: C0CD074418
   Voltage stabilizer:
   Revision: AA001002
   Coding: 20
   ROD: EV_SARA2.rod
   Coding: 040311
   Coding: 040311
   Coding: E01E00
   Coding: E01E00
                    Reset counter: 56
                    Mileage: 230174 km
                    Date: 2019.10.31
                    Time: 21:34:37
   Coding: 093205C010
   Coding: 766FF0
          U1111 00 [009] - -
                    Reset counter: 56
                    Mileage: 230174 km
                    Date: 2019.10.31
                    Time: 21:34:23
   Coding: 366FF0
          U1111 00 [009] - -
                    Reset counter: 56
                    Mileage: 230174 km
                    Date: 2019.10.31
                    Time: 21:34:23
I have the same problem VCP zdc bcm 09 and I still have errors
marvin1980
C?ID=171833
So it works now!
   Revision: 85H23---
   Coding: 0045F7
   Coding: 02006D
   Coding: 000035
   Coding: C0CD074418
   Voltage stabilizer:
   Revision: AA001002
   Coding: 20
   ROD: EV_SARA2.rod
   Coding: 040311
   Coding: 040311
   Coding: E01E00
   Coding: E01E00
                    Reset counter: 56
                    Mileage: 230174 km
                    Date: 2019.10.31
                    Time: 21:34:37
   Coding: 093205C010
   Coding: 766FF0
          U1111 00 [009] - -
                    Reset counter: 56
                    Mileage: 230174 km
                    Date: 2019.10.31
                    Time: 21:34:23
   Coding: 366FF0
          U1111 00 [009] - -
                    Reset counter: 56
                    Mileage: 230174 km
                    Date: 2019.10.31
                    Time: 21:34:23
Thank you!. It helped me :)
