ACC is not working
jaap
C?ID=57764
I had some problems with my previous Passat B8 so I got another one.
The person i bought it from has made some changes with a VCDS? cable and could not change it anymore.
So when i got the car I made a log with my genuine Ross Tech cable.
The first fault in 5F is because the navi screen was changed to a later model, I think this has smething to do with a hash code?
But i dont mind this one so much. The second one there is no camera installed.
the one were i have problems with is that the ACC is not working. And all the faults it is giving in 1 engine and 13 ACC.
The guy told me he has being playing around with some adaptations but did not remember were.
I have went true a lot of adaptations and other settings but I don't know were the problem is.
Is there someone who could help me with this problem??
Regars Jaap
Friday,02,August,2019,14:10:51:23330
VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
VIN: WVWZZZ3CZGE163400   License Plate: 2-8-19
Mileage: 58944km-36626mi   Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F 69
          6D BB BC
VIN: WVWZZZ3CZGE163400   Mileage: 58944km-36626miles
Address 01: Engine (J623-CJSA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 264     HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 0925001A2474050B3000
   Shop #: WSC 05311 115 00322
   ASAM Dataset: EV_ECM18TFS0203G0906264 001007
   ROD: EV_ECM18TFS0203G0906264_VW48.rod
   VCID: 6596451A85E4740F59F-8030
17176 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 58944 km
                    Date: 2019.08.02
                    Time: 14:05:51
                    Engine speed: 0.00 /min
                    Coolant temperature: 68 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 12.343 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: 1110 0001
   Part No SW: 0CW 300 048 R    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0610
   Revision: 00005005    Serial number: CU501512306528
   Shop #: WSC 05311 115 00068
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 4BC293A20340A27F6FB-801E
   Revision: 00000000    Serial number: 60116000000586
   Coding: 0FEC6A8F34262B6F077B060041C349F0562CD4E0608292F51842F078C209
   Shop #: WSC 00015 115 00001
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7AAC06661C5AEBF784D-802E
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0710
   Revision: 00026000    Serial number: 0392280444
   Coding: 000F0F0F03
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 392ED96A59DC20EFCD7-806C
   Part No SW: 5G1 907 044 J    HW: 5G1 907 044 J
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 12020004204101011015504C00101802
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   VCID: 2F3AE7329798FE5F633-807A
   Air quality sensor:
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86582912151648
   Coding: 00031A46C2C102FF53C44004001457081C80000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 03527B826B90AA3FD7B-8056
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    151215  042 0607
   Serial number:         160112021047
   Component: RLHS  037 0059
   Serial number: S5Y16M01D25H00M31S50
   Coding: 90A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 31 10 2015  10001183
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391601402578
   Coding: 0071051911
   VCID: 44D0B89E2E1E6D07AE1-8010
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Coding: 3200670A51FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3430E85E7EBEDD871E1-8060
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_ALIGNMENT_NOT_OK]
                    Reset counter: 253
                    Mileage: 58944 km
                    Date: 2019.08.02
                    Time: 14:04:40
                    Control Module temperature: 42 °C
                    Voltage terminal 15: 12.2 V
2141 - Databus
          [FAULT_DIS_FAIL]
                    Reset counter: 253
                    Mileage: 58944 km
                    Date: 2019.08.02
                    Time: 14:04:40
   Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003STP188F4Z
   Coding: 88CCC000008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5AF7720778CEDFB33-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 101 16
   Serial number: 3576U000000C55610914
   Subsystem 2 - Part No SW: -----------    HW: 454 001 401 16
   Serial number: 3586U000000D53CCF81Z
   Subsystem 3 - Part No SW: -----------    HW: 454 801 212 15
   Serial number: 3516R3DB22A090000006
   Subsystem 4 - Part No SW: -----------    HW: 454 801 212 15
   Serial number: 3526RBD6F7709000000P
   Subsystem 5 - Part No SW: -----------    HW: 454 802 112 15
   Serial number: 3556V4C1960090000005
   Part No SW: 3Q0 953 521 AM    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0205
   Revision: FF034034    Serial number: 20160110500840
   Coding: 0410
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7BA203621360D2FF9FB-802E
   Part No SW: 3G0 920 750 A    HW: 3G0 920 750 A
   Component: KOMBI         301 6421
   Coding: 07A509182B8000080188FF021000000000000000
   VCID: 221C1E06D44A4337FCD-8076
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung]
                    Reset counter: 253
                    Mileage: 58944 km
                    Date: 2019.08.02
                    Time: 14:04:39
16777010 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_LDW_0x19 keine Kommunikation]
                    Reset counter: 253
                    Mileage: 58944 km
                    Date: 2019.08.02
                    Time: 14:04:42
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 F    HW: 5Q0 963 272 F
   Component: STH-MQB       007 0072
   Coding: 9309
   Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001306207
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 09011610520335
   Coding: 0B0300347F015900FB0002581C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 79AE196A195CE0EF8D7-802C
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29150002538530055517
   Coding: 2FFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 8842448603
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H55 0033
   Serial number: 0187580
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 1011201500010136
   Serial number: 16000008193012
   Coding: 0800000000000000
   Shop #: WSC 00015 115 08193
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BE214A412CA8AF357-8024
   Serial number: 221015BJL11935
   Coding: 00350B208000020000001000
   VCID: 43D2BB822B106A3F97B-8016
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 0103
   Shop #: WSC 00015 115 00322
   Serial number: 291015BJN02962
   Coding: 003501208000020000001000
   VCID: 42DCBE86340A63379CD-8016
   Coding: 03DA010009000000
   Shop #: WSC 05311 000 00001
   VCID: 75B6155A3544848FE9F-8020
   Part No SW: 3Q0 035 846     HW: 3Q0 035 846
   Component: MU-S-N-ER     820 0624
   Coding: 02840201FF00000051110001000808031F0100C401200100CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 6E843A365012B757285-803A
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H34 8074
   Serial number: VWZ6ZDS2240005
   Subsystem 2 - Part No SW: 5NA 919 866 AG    HW: -----------
   Component: ECE AS 2020  --- 1310
          B201A 00 [009] - -
                    Reset counter: 253
                    Mileage: 58944 km
                    Date: 2019.08.02
                    Time: 14:04:40
                    Voltage terminal 30: 12.2 V
                    Status_Software_Version_Management-module_name: C
7179 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 253
                    Mileage: 58944 km
                    Date: 2019.08.02
                    Time: 14:04:44
                    BAP-BAP_Function_ID: 02
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0203
   Revision: 8A001003    Serial number: 0392347641
   Coding: 0100000202000000
   VCID: 3B22C36253E012FFDFB-806E
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30421177000000
   Coding: 0280
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   VCID: 3FDAB77247F80EDFF33-806A
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 251115BKP04299
   Coding: 000001200100020000001000
   Shop #: WSC 53469 001 1048576
   Serial number: 251115BKP0429C
End----------(Elapsed Time: 02:23, VBatt start/end: 12.2V/12.2V)-----------
downtime
Finland
C?ID=280813
What happened to the car? Software update done to components?
          B2010 00 [009] - -
                    Reset counter: 253
                    Mileage: 58944 km
                    Date: 2019.08.02
And did you bump the radar into something?
          C1103 00 [009] - -
                    Reset counter: 253
                    Mileage: 58944 km
                    Date: 2019.08.02
                    Time: 14:04:40
jaap
C?ID=57764
No there was no updates done or bumps.
downtime
Finland
C?ID=280813
If you're absolutely sure that the ACC radar has not moved, you can zero the error by going into the ACC module and running the basic setting for the ACC adjustment. Can't remember the exact name of the basic setting item but it just sets the current position of the radar as the set values for it.
Now, if it has really moved this won't probably fix the issue as at some point it will flag the same error again as the degree of deviation from the set value will grow too high.
The instrument cluster basic setting is a new one. I've never seen that instruments need a basic setting as well :)
And here's the instructions how to remove the first error in 5F :
https://forums.ross-tech.com/showth...diagnostics-tool&p=96873&viewfull=1#post96873
And here's the calculator you can use :
http://audienthusiasts.com/Application_SVMError.html
Just scroll down to the almost bottom of the page.
jaap
C?ID=57764
I looked in the basic settings off the ACC module but there nothing for the adjustment.
Maybe somebody can post a Admap of the ACC module.
downtime
Finland
C?ID=280813
Go to module 13 -> Security settings. Use code 20103. Then open Basic settings and choose reset alignment position or zero alignment position (or something like that), press GO. That should remove the incorrect position error if the module has not moved.
jaap
C?ID=57764
I tried it again with the security code but there is nothing to choose like reseting the alignment.
In the picture you can see the options I get.
downtime
Finland
C?ID=280813
Picture is not showing up. The dropbox is not a good pic sharing service. Try something like flickr.
downtime
Finland
C?ID=280813
NEtech
Denmark
C?ID=56995
Can you see it now?
Yes that is the basic setting that must be used (IDE02164 Reset personalization settings), as downtime described in #6.
But first you need calibration board setup, and several Output Test commands.
