7N0 907 530 BC CAN Gateway / Persistent Battery Module Problem
325_guy
C?ID=135444
I've updated my gateway in preparation for a MIB2 installation and noticed that with the 7N0 907 530 BC gateway, address 61- Battery Regulator shows up in the installed modules list even though I do not have it selected in Installed Modules. I get the errors for both the regulator and the gateway being unable to communicate with it. My car being a 2006 Mk5 Jetta, there is no battery regulator installed.
61- Battery Regulator goes away if I select "Module not coded" in the Long Coding for the gateway. The other two options are Platform- PQ35/PQ36 and Platform- PQ45/PQ46. Although PQ35 is the proper option, I experimented with selecting both and both selections bring back Module 61 and the associated errors. Am I affecting anything by selecting "Module not coded" to suppress the errors?
Autoscan:
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 47 52 56 62 65 72 77
7D
VIN: 3VWCT81K96M853017 Mileage: 495020km-307591miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H05--- Serial number: VWZ7Z0F9021843
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 63CFBB49A2B58E57E4-8036
Readiness: 0 0 0 0 X
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 73EFCB0912551ED794-8026
Part No: 1K0 820 047 GS
Component: Climatic PQ35 120 0606
VCID: 7BFFE3293A055697CC-802E
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000504314
Coding: 04018E1700041500070000001E0000000029B5035C0000
Shop #: WSC 00066 123 12345
VCID: 37773F1946ADB2F768-8062
Component: Wischer 061206 020 0501
Coding: 00065535
Shop #: WSC 00066
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 69 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D077VF7
Coding: 0013881
VCID: 6CDDD0754F6BC12F55-8038
Subsystem 1 - Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Subsystem 2 - Serial number: 6332MSME13031560X
Subsystem 3 - Serial number: 6342MSME1303140F%
Subsystem 4 - Serial number: 6351HSME0B480A6DJ
Subsystem 5 - Serial number: 6361HSME0B4C225CG
Subsystem 6 - Serial number: 63727SME0B2F127A8
Subsystem 7 - Serial number: 63827SME0B2F09211
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0002021
VCID: 010391C158E93C4796-8054
Component: E0221 002 0010
Part No SW: 1K0 920 973 D HW: 1K0 920 973 D
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F9021843
Coding: 0023203
VCID: 2E591A7DB9F7733F3B-807A
Part No SW: 7N0 907 530 BC HW: 7N0 907 530 AN
Component: J533 Gateway H56 1663
Revision: H56 Serial number: 06011603000105
Coding: 351022
Shop #: WSC 09003 957 00200
VCID: 72E1CE0DAD4F17DF9F-8026
03406 - Control Module for Battery Monitoring
Reset counter: 98
Mileage: 495025 km
Time: 20:16:35
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0004
Revision: 00005000 Serial number: 1293324T2GZJ04
Coding: 0000003
VCID: 3973392170B9A4879E-806C
Component: IMMO 3HL 1610
Shop #: WSC 25159 444 68464
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1127
Revision: 32008001 Serial number: 00000503169130
Coding: 0001205
VCID: 3B7F23297A8596978C-806E
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
VCID: 346D081557DB59EF4D-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0218
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186407F6D04048560880F0488DC00
VCID: 040D98D547FB296FBD-8050
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000102854
VCID: 2A51166D851F1F1FE7-807E
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1127
Revision: 32008001 Serial number: 00000048769129
Coding: 0001204
VCID: 3C7D20357F8B91AF85-8068
Part No SW: 1K0 035 180 AF HW: 1K0 035 180 AF
Component: Radio Prem-8 H05 0008
Revision: -----09S Serial number: VWZ4Z7N3462047
Coding: 01010000010007
VCID: 64CDB85567BB896F1D-8030
Reset counter: 98
Mileage: 495025 km
Time: 20:08:52
Reset counter: 98
Mileage: 495025 km
Time: 20:08:52
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12005001 Serial number: 00000000799556
Coding: 0001168
VCID: 3E792A3D699783BFAB-806A
Component: RDK 0440
Coding: 0100101
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12005001 Serial number: 00000000769867
Coding: 0001168
VCID: 3F8757396E9D8AB7A0-806A
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660254358
Coding: 0A10040000010100
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 356B351194A140E77A-8060
9455635 - Telephone Microphone
B1048 13 [009] - Open Circuit
Reset counter: 98
Mileage: 495025 km
Time: 20:09:28
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Reset counter: 98
Mileage: 495025 km
Time: 20:09:28
Component: PTC-Element 0404
VCID: 2D5B1D71B4F1082702-8078
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 02:09)--------------------------
Strange.
What do you have in the Gateway's Adaptation Channel 18?
Spacewalker
Poland
C?ID=159607
Old cars use 2 x GND wire go GW
when in NEW cars (with battery monitor system) one of that wire is going to LIN to battery
so you must remove one GND wire
compare ELSA drawing
325_guy
C?ID=135444
Strange.
ERROR: Adaptation channel not available (or words to that effect- forgot to screenshot).
New observation:
Changed "Platform" to PQ35, errors for gateway and battery regulator came back.
Cleared all codes, then re-ran full autoscan. No errors. Battery regulator gone.
Exit VCDS and power cycled ignition, errors and battery regulator are back.
None of this is causing a driveability concern. I'm just a curious person and would love to figure out the "why" behind this!
325_guy
C?ID=135444
I presume it matters which one? And removing that one wire from the gateway will make it forget about trying to find a ghost battery regulator?
325_guy
C?ID=135444
Thanks to all for the tips! Once I get some time I'll pull that pin from the gateway plug and tape it back.
Working on these cars is so interesting. On one hand, it's neat how modular and common many components across the years are. On the other, it's always interesting to see what kind of quirks pop up when you combine parts in "non-standard configurations". :D
NZDubNurd
New Zealand
C?ID=230482
It's like Lego... but with a few bits of meccano scattered in there.
And then the platform changes...
and it's like all different coloured poo.
