ABS - Steering assist coding passat B7
mohamed
Egypt
C?ID=211960
Could you help me with correct coding and adaption for this control of ABS and Steering assist , as they changed them and dont copy the old codes , i checked the wiring and every thing is okay
Friday,02,August,2019,07:13:01:22511
VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
VIN: WVWZZZ3CZBP321321   License Plate:
Mileage: 172430km-107143mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4F 52 53 56 62 72
VIN: WVWZZZ3CZBP321321   Mileage: 172430km-107143miles
Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 DH    HW: 03C 907 309 E
   Component: 1.4l R4 TSI   H15 7738
   Revision: L5H15---    Serial number: VWZCZ000000000
   Coding: 00250012002400000000
   Shop #: WSC 00028 028 00034
   ASAM Dataset: EV_ECM14TFS01103C906016BF 001006
   ROD: EV_ECM14TFS01103C906016BF.rod
   VCID: E89CFC841324B40FB1-80BC
Readiness: 1110 0101
   Part No SW: 0AM 300 048 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 9059
   Revision: 00043014    Serial number: CU501804246493
   Shop #: WSC 74565 000 00000
   VCID: B93A69C0F00EFD871E-80EC
Address 03: ABS Brakes        Labels: None
   Part No SW: 3AA 698 109     HW: 3AA 614 109 M
   Component: J104   C2 450M V489 0012
   Revision: --H07---    Serial number: 00000003620508
   Coding: 0000363
   Shop #: WSC 36002 360 89777
   VCID: F6A0A2FC819052FF33-80A2
                    Fault Status: 01101000
                    Reset counter: 137
                    Mileage: 172436 km
                    Date: 2013.12.23
                    Time: 04:07:12
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
                    Reset counter: 137
                    Mileage: 172436 km
                    Date: 2013.12.23
                    Time: 04:07:12
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000001002
   Shop #: WSC 00028 028 00021
   VCID: EE908A9C31C06A3FFB-80BA
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 A    HW: 3AA 937 087 A
   Component: BCM PQ47 H    413 0452
   Revision: BB413001
   Coding: 000000000000000000180280540081E443516488406C8D60648040200040
   Shop #: WSC 00028 028 00001
   VCID: B83C6CC40B04E48FE1-80EC
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 15121  10  0603
   Coding: 00B795
   Component: RLS 060111 05  54  0403
   Coding: 033028
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 137
                    Mileage: 172436 km
                    Date: 2013.12.23
                    Time: 04:10:46
                    Voltage: 11.95 V
                    Reset counter: 137
                    Mileage: 172436 km
                    Date: 2013.12.23
                    Time: 04:10:47
                    Voltage: 12.00 V
02738 - Bulb for Tail/Brake Light; Left
                    Reset counter: 137
                    Mileage: 172436 km
                    Date: 2013.12.23
                    Time: 04:10:45
                    Voltage: 11.90 V
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
   Component: PARKHILFE PLA H04 0007
   Revision: --------    Serial number: 20431034402587
   Coding: 108105
   ASAM Dataset: EV_EPHVA2C000000000 001006
   ROD: EV_EPHVA2C000000000_001_VW36.rod
   VCID: BC3470D4373CC8AF05-80E8
13638929 - Databus
          [Steuergerät für Lenkhilfe-J500 - mLenkhilfe_3 - kein Signal/keine Kommunikation]
                    Reset counter: 137
                    Mileage: 172436 km
                    Date: 2019.08.02
                    Time: 04:07:12
13679382 - Databus
          [Steuergerät für Lenkhilfe-J500 - mLenkhilfe_2.LH2_Checksumme - unplausibles Signal]
                    Reset counter: 137
                    Mileage: 172436 km
                    Date: 2019.08.02
                    Time: 04:07:12
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PS1FKC
   Coding: 0012337
   Shop #: WSC 00028 790 00012
   VCID: CCD42014AF9C782FB5-8098
   Subsystem 1 - Serial number: 6332MTS668533480
   Subsystem 2 - Serial number: 6342MTS647193480
   Subsystem 3 - Serial number: 6351HTS6A1NGJ9KJ
   Subsystem 4 - Serial number: 6361HTS6U1JIJ9KJ
   Part No SW: 5K0 953 569 AS    HW: 5K0 953 569 AS
   Revision: --X01---    Serial number: 20151130300631
   Coding: 1992250000
   Shop #: WSC 54569 001 1048576
   VCID: 895AD900286E2D074E-80DC
   Serial number: 70000000000000131901
   Coding: E30000
   Part No SW: 3AA 920 870     HW: 3AA 920 870
   Coding: 160F00
   VCID: EFAE979836CA6337F0-80BA
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 040111F1002858
   Coding: 461006
   VCID: B42458F4176C00EFCD-80E0
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0399
   Revision: 00043000    Serial number: VWZCZ000000000
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0529
   Revision: 12110009    Serial number: 0002049417
   Coding: 0010B7
   Shop #: WSC 00028 028 00216
   VCID: B52265F0141619E7FA-80E0
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000001873357
   Coding: 000090
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.3       1502
   VCID: B02C54E423743CCFA9-80E4
   Component:    KSG PQ47 ELV 043 0631
   Coding: 00910A0002860E763004941570084F0B607801
   Component: EZE_2         H41 1614
   Coding: 00000008
   VCID: EFAE97983ECA6337F0-80BA
   Subsystem 1 - Part No SW: 3AA 919 204     HW: 3AA 919 204
   Component: Analoguhr  003 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0529
   Revision: 14110009    Serial number: 0002034340
   Coding: 0010B6
   VCID: B62062FC091012FFF3-80E2
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000001864336
   Coding: 000090
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000109124
   Coding: 0022057
   VCID: B3265BE8D26207D7D4-80E6
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  041 0167
   Revision: 00000001    Serial number: VWZ1Z3L5176448
   Coding: 0500040004
   VCID: E288EEACFD18DE5F6F-80B6
                    Reset counter: 137
                    Mileage: 172436 km
                    Date: 2013.12.23
                    Time: 04:07:24
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 137
                    Mileage: 172436 km
                    Date: 2013.12.23
                    Time: 04:07:16
03138 - Input AUX IN
                    Reset counter: 137
                    Mileage: 172436 km
                    Date: 2013.12.23
                    Time: 04:07:29
End----------(Elapsed Time: 01:39, VBatt start/end: 12.2V/12.2V)-----------
