Anyone help with fault code (P2002 CNHA engine)
vw754
C?ID=52227
replaced dpf sensor...............but getting this fault
64 plate audi a6 tdi
Wednesday,31,July,2019,14:53:18:07086
VCDS Version: 19.6.1.0 (x64)
VIN: WAUZZZ4G0EN185537   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F
          62 72 AC
VIN: WAUZZZ4G0EN185537   Mileage: 88499km-54990miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 BD    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8244
   Revision: 85H23---
   Coding: 0A254012242401080000
   Shop #: WSC 45974 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021BD 002005
   ROD: EV_ECM20TDI01104L906021BD_002.rod
   VCID: 68D5ABEE9368750F31-803C
19226 - Particulate Trap Bank 1
          P2002 00 [237] - Efficiency Below Threshold
                    Mileage: 88327 km
                    Date: 2019.07.30
                    Time: 14:38:31
                    Engine speed: 1290.00 /min
                    Normed load value: 48.6 %
                    Vehicle speed: 35 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 71 °C
                    Voltage terminal 30: 14.400 V
                    Exhaust mass flow of low-pressure EGR: calculated: 3.019
                    Differential pressure ratio: low-pressure EGR: 21.8 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 27.7 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 23.4 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 89.55 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 38.96 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 27.0 hPa
Readiness: 1 1 0 0 0
   Part No SW: 4G0 927 153     HW: 0CK 927 156 P
   Component: 0CK 20TDI RdW H02 0003
   Revision: --H02---    Serial number: 0000000120
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL382021 002011
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 66C9A5D6997C637F03-8032
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 06A29F016045F980DB00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A7121A6BD44379F97-806E
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0551
   Coding: 01B83046000000000000
   VCID: 7AF1E1A6F5C4F79FD7-802E
   Serial number: 0214000130974005
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 BB    HW: 4G0 820 043 BB
   Component: KLIMA 2 ZONEN H14 0096
   Serial number: 11071400111495
   Coding: 3421090821
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 60C5B3CE7B580D4FF9-8034
   Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
   Revision: 20012002    Serial number: 00000001774733
   Coding: 2600201040349FE00181008300001D0C0F9DC30827090201000004606100
   VCID: 6ED9DDF6B98CAB3F7B-803A
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 140625  H37 0080
   Serial number:         140707083408
   Coding: 0045F7
   Serial number: 22882302
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 14 07 2014  00001156
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 8FA80437000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061419602064
   Coding: 08C306
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71E3C68AA0B2B4C766-8024
1079316 - Center Rear Right Parking Aid Sensor
          B1078 14 [008] - Open or Short to Ground
                    Reset counter: 152
                    Mileage: 88321 km
                    Date: 2019.07.30
                    Time: 13:01:09
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00JP6WY
   Coding: 3032343631324E303235554A305234473053
   VCID: 36693596895CD3FF73-8062
   Serial number: 3575HRB400Q50RHSCPQU
   Serial number: 3585HRB405F2MKOU7H6D
   Serial number: 3515JRB405P2SLKAJH3A
   Serial number: 3525JRB405P2SLKA40S4
   Serial number: 3554VRB400652MR4N1IQ
   Serial number: 3564VRB400452MR4JA4G
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20140714000091
   Coding: 000034
   VCID: 3065038E6338FDCF29-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
   Component: MDieGb        H43 0411
   Revision: 27450259    Serial number: 658120714592041
   Coding: 33A60A000B412600010000
   ASAM Dataset: EV_RBC7KMID 004048
   ROD: EV_RBC7KMID.rod
   VCID: 3F8750B2A66612B7A0-806A
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001476965
   Coding: 00CD074400
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72E1C986A5B48FDF9F-8026
   Serial number: 0874093903
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 14043000000000000089
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA720B77M7
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 336F0C829A2EC6D754-8066
   Component: TSG FA        H03 0507
   Coding: 011C16004001620002080002
   VCID: 47974852F6B65A7718-8012
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0009754873
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0341755770
   Coding: 011B062280B900008320080400010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
02616 - Fuel Tank Cap; Unlock
                    Fault Status: 00101001
                    Reset counter: 194
                    Mileage: 88490 km
                    Date: 2019.07.31
                    Time: 10:01:29
   Revision: CJ007001    Serial number: 00000000123512
   VCID: 1D3BCA3A04AA60A792-8048
   Component: TSG BF        H03 0507
   VCID: 46894556F1BC437FE3-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001136892
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D5B1AFA7C0A902702-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140712-0002-060
   Coding: 112196101000A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G0 035 192 H    HW: 4G0 035 192 F
   Component: RMC Nav Plus  H55 0801
   Coding: 0101000101415B47082B060301020100000000
   VCID: 2757E8D256F6BA77F8-8072
   Subsystem 1 - Part No: 8X0 919 884 F
   Component: P23-50-13.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464F/0E2669161
   Subsystem 3 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NGB000VS
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 49934E6AE0A2AC070E-801C
   Component: TSG HR        H03 0507
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 141841460
   ROD: EV_RDCMA00100_008.rod
   VCID: 2B5F14E2421E9E171C-807E
End-------------------------(Elapsed Time: 05:10)--------------------------
Did you do the Basic Setting?
IDE01772 -- Adaptation of diff. pressure sensor particulate filter
vw754
C?ID=52227
Yes, I did that, finished correctly and all seemed good for 2 days.
Gone But Not Forgotten
Verify the pipe is not plugged from DPF to PSI sensors, very common now!
vw754
C?ID=52227
Thanks, il check it, is it one of the pipes from dpf to the pressure sensor, one of 2 rubber hoses?
All conduit from the DPF including barb on DPF must be cleaned and verified for obstruction.
Did you think to install traps or filters with inspection glass or clear plastic & to collect the debris & so it doesn't smoke another PSI sensor?
Cheap insurance............
vw754
C?ID=52227
Cheers..... Not my car, just one I fitted a sensor to.
I often wonder why this was not a thought for a service, for so many miles accumulated and to shift liability to consumer for failing to do it but hey here it's under useful life warranty for 15 years 150K?
