replaced dpf sensor...............but getting this fault
64 plate audi a6 tdi
Wednesday,31,July,2019,14:53:18:07086
VCDS Version: 19.6.1.0 (x64)
VIN: WAUZZZ4G0EN185537 License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F
62 72 AC
VIN: WAUZZZ4G0EN185537 Mileage: 88499km-54990miles
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 BD HW: 04L 907 309
Component: R4 2,0L EDC H23 8244
Revision: 85H23---
Coding: 0A254012242401080000
Shop #: WSC 45974 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906021BD 002005
ROD: EV_ECM20TDI01104L906021BD_002.rod
VCID: 68D5ABEE9368750F31-803C
19226 - Particulate Trap Bank 1
P2002 00 [237] - Efficiency Below Threshold
Mileage: 88327 km
Date: 2019.07.30
Time: 14:38:31
Engine speed: 1290.00 /min
Normed load value: 48.6 %
Vehicle speed: 35 km/h
Coolant temperature: 89 °C
Intake air temperature: 71 °C
Voltage terminal 30: 14.400 V
Exhaust mass flow of low-pressure EGR: calculated: 3.019
Differential pressure ratio: low-pressure EGR: 21.8 kg/h
Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 27.7 hPa
Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 23.4 hPa
Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 89.55 %
Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 38.96 %
Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 27.0 hPa
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4G0 927 153 HW: 0CK 927 156 P
Component: 0CK 20TDI RdW H02 0003
Revision: --H02--- Serial number: 0000000120
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL382021 002011
ROD: EV_TCMDL382021_AU57.rod
VCID: 66C9A5D6997C637F03-8032
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Coding: 06A29F016045F980DB00
VCID: 3A7121A6BD44379F97-806E
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0551
Coding: 01B83046000000000000
VCID: 7AF1E1A6F5C4F79FD7-802E
Serial number: 0214000130974005
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 BB HW: 4G0 820 043 BB
Component: KLIMA 2 ZONEN H14 0096
Serial number: 11071400111495
Coding: 3421090821
ASAM Dataset: EV_AirCondiBasisUDS 004002
ROD: EV_AirCondiBasisUDS_004.rod
VCID: 60C5B3CE7B580D4FF9-8034
Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0130
Revision: 20012002 Serial number: 00000001774733
Coding: 2600201040349FE00181008300001D0C0F9DC30827090201000004606100
VCID: 6ED9DDF6B98CAB3F7B-803A
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 140625 H37 0080
Serial number: 140707083408
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 22882302
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 14 07 2014 00001156
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 8FA80437000000000001
Revision: 11001001 Serial number: 61061419602064
Coding: 08C306
VCID: 71E3C68AA0B2B4C766-8024
1079316 - Center Rear Right Parking Aid Sensor
B1078 14 [008] - Open or Short to Ground
Reset counter: 152
Mileage: 88321 km
Date: 2019.07.30
Time: 13:01:09
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00JP6WY
Coding: 3032343631324E303235554A305234473053
VCID: 36693596895CD3FF73-8062
Serial number: 3575HRB400Q50RHSCPQU
Serial number: 3585HRB405F2MKOU7H6D
Serial number: 3515JRB405P2SLKAJH3A
Serial number: 3525JRB405P2SLKA40S4
Serial number: 3554VRB400652MR4N1IQ
Serial number: 3564VRB400452MR4JA4G
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20140714000091
Coding: 000034
VCID: 3065038E6338FDCF29-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Part No SW: 4G8 920 950 S HW: 4G8 920 950 S
Component: MDieGb H43 0411
Revision: 27450259 Serial number: 658120714592041
Coding: 33A60A000B412600010000
ASAM Dataset: EV_RBC7KMID 004048
ROD: EV_RBC7KMID.rod
VCID: 3F8750B2A66612B7A0-806A
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Revision: -------- Serial number: 00000001476965
Coding: 00CD074400
VCID: 72E1C986A5B48FDF9F-8026
Serial number: 0874093903
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 14043000000000000089
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H03 0056
Revision: -------- Serial number: EJ1BPA720B77M7
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 336F0C829A2EC6D754-8066
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011C16004001620002080002
VCID: 47974852F6B65A7718-8012
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0009754873
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0341755770
Coding: 011B062280B900008320080400010E470000000000000000000000000000
02616 - Fuel Tank Cap; Unlock
Fault Status: 00101001
Reset counter: 194
Mileage: 88490 km
Date: 2019.07.31
Time: 10:01:29
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000123512
VCID: 1D3BCA3A04AA60A792-8048
Component: TSG BF H03 0507
VCID: 46894556F1BC437FE3-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001136892
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D5B1AFA7C0A902702-8078
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 140712-0002-060
Coding: 112196101000A300
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G0 035 192 H HW: 4G0 035 192 F
Component: RMC Nav Plus H55 0801
Coding: 0101000101415B47082B060301020100000000
VCID: 2757E8D256F6BA77F8-8072
Subsystem 1 - Part No: 8X0 919 884 F
Component: P23-50-13.06 0001
Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464F/0E2669161
Subsystem 3 - Part No SW: 4G2 919 610 B HW: 4G2 919 610 B
Serial number: 90349NGB000VS
Component: TSG HL H03 0507
Coding: 010814004001620002080002
VCID: 49934E6AE0A2AC070E-801C
Component: TSG HR H03 0507
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0010
Revision: 00000000 Serial number: 141841460
ROD: EV_RDCMA00100_008.rod
VCID: 2B5F14E2421E9E171C-807E
End-------------------------(Elapsed Time: 05:10)--------------------------
