Request for change - SRI value table output - A8 D4 [and others] ...
JulianHicks
Kent, UK
C?ID=265735
The VCDS SRI 'button' is a useful tool between services, as you can select it, watch the Instrument panel channel values being read quickly and seeing the table of values displayed. Then you cancel the reset you've invoked, but you have a text log of the value table, I believe, in the Debug folder. :)
For example [a slightly modified recent sample from my A8]:
Monday,15,July,2019,20:36:13:53697
VCDS Release 19.6.1:  SRI Reset-SRI1.CLB -- Data version: 20190529 DS308.0
WAUZZZ4H4GN002801
Control Module Part Number: 4H0 920 910 R       Labels:  .*4H0-920-xxx-17.clb-SRI1
Component:TDieGB------- H53 0803, Coding:33A608001B412600010000
Operation: Please select an operation -- 1/3
Channel        Description                           Current val.       New val.
IDE00342-ESI: Resetting ESI                                              ESI: Service Reminder Status          Warning active     ---
IDE00510-ESI: distance driven from inspection                            ESI: Distance since Inspection        27800 km [17290 mi]---
IDE00511-ESI: time from inspection                                       ESI: Time since Inspection            721 Days           ---
IDE00515-ESI: oil quality                                               *ESI: Oil Quality                      good oil quality   ---
IDE00517-ESI: soot entry                                                 ESI: Soot Quantity                    18500 km [11500 mi]---
IDE00518-ESI: thermal load                                               ESI: Thermal Load                     26600 km [16500 mi]---
IDE01153-SIA: maximum value of distance to service                      *SIA: Maximum Distance to Service      14500 km [9000 mi] ---
IDE01154-SIA: maximum value of time to service                          *SIA: Maximum Time to Service          365 Days           ---
IDE03349-FIX: Max. distance until next mileage-related inspection       *FIX: Maximum Distance to Inspection   15900 km [9800 mi] ---
IDE03350-FIX: Maximum time until next time-dependent inspection         *FIX: Maximum Time to Inspection       730 Days           ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection   FIX: Distance since Inspection        11900 km [7442 mi] ---
IDE03352-FIX: Time since last time-dependent inspection                  FIX: Time since Inspection            306 Days           ---
However; having looked at the complete set of Adaptation values from the Instrument cluster, it appears that there are some other service related channel values that are not reported by the VCDS SRI function for some reason.
These are:
IDE00512-ESI: minimum value km-driving distance/inspection
IDE00513-ESI: maximum value km-driving distance/inspection
IDE00514-ESI: maximum value of time between inspections
IDE00827-ESI: minimum value of time between inspections
Can I suggest the SRI function for these instrument clusters is modified to read and display these values as well, please?
Seeing ALL the values is helpful in diagnosing oddities in MMI service display. As discussed in another of my posts, I've 'discovered' that IDE03349-FIX' appears incorrect.:(
Julian
