2009 Passat ABS Coding for ACC Retrofit
raziel90
Sweden
C?ID=172805
i drive a passat cc from 2009 and i wonder if someone can help me with coding th abs module because im trying to retrofit ACC and i don`t know what value to input, here is my autoscan
Sunday,28,July,2019,22:11:48:26566
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 19.6.1.0
VIN: WVWZZZ3CZ9E551356   License Plate: DYM580
Mileage: 188890km-117370mi   Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 10 13 14 15 16 17 19 20 25 2E 36 37 42 44 46 4F
          52 53 55 56 57 5C 62 69 6C 72 77
VIN: WVWZZZ3CZ9E551356   Mileage: 188890km-117370miles
13-Auto Dist. Reg -- Status: Cannot be reached 1100
5C-Lane Maintain. -- Status: Malfunction 0010
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QF    HW: 03L 907 309
   Component: R4 2.0l TDI A000SG  9977
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 26214 051 00000
   VCID: 79C1D29C30BE9487DE-802C
               U1017 - 000 -
                    Mileage: 188882 km
                    Date: 2013.12.13
                    Time: 15:22:21
                    Voltage: 11.86 V
                    Bin. Bits: 11110010
                    Bin. Bits: 00000000
                    (no units): 33.0
               U1017 - 000 -
                    Mileage: 188882 km
                    Date: 2013.12.13
                    Time: 15:22:21
                    (no units): 0.00
                    (no units): 0.00
                    (no units): 3.0
                    Bin. Bits: 00000100
                    (no units): 33.0
049717 - No Communications with Cruise Control (Front) Distance Sensor
               U0235 - 000 -
                    Mileage: 188882 km
                    Date: 2013.12.13
                    Time: 15:22:23
                    Temperature: 17.1°C
                    Voltage: 11.86 V
                    Bin. Bits: 00000000
                    Torque: 219.0 Nm
                    Temperature: 32.4°C
               U1017 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 188882 km
                    Date: 2013.12.13
                    Time: 15:22:26
                    Voltage: 11.86 V
                    Torque: 219.0 Nm
                    Hex Value: 0xFF00
                    Bin. Bits: 11110010
008198 - Intake Manifold Flap; Bank 1
               P2006 - 000 - Stuck Closed - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 188882 km
                    Date: 2013.12.13
                    Time: 15:23:36
                    RPM: 782 /min
                    Load: 6.3 %
                    Lambda: 82.9 %
                    Mass Air / Rev.: 500.0 mg/str
                    Temperature: 29.7°C
008196 - Intake Manifold Flap; Bank 1
               P2004 - 000 - Stuck Open - MIL ON
                    Mileage: 188882 km
                    Date: 2013.12.13
                    Time: 15:23:36
                    RPM: 782 /min
                    Load: 6.7 %
                    Lambda: 90.7 %
                    Mass Air / Rev.: 495.0 mg/str
                    Temperature: 29.7°C
Readiness: 1 2 0 0 0
   Part No SW: 3C0 614 109 AG    HW: 3C0 614 109 AG
   Component: J104    C4 440 V3   0015
   Revision: --025---    Serial number: 00000796066204
   Coding: 0010000
   Shop #: WSC 05311 000 00000
   VCID: 63FD90F4A2327E57E4-8036
                    Reset counter: 241
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 16:41:24
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 150
                    Hex Value: 0x0000
                    Reset counter: 241
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 16:41:24
                    Reset counter: 241
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 16:41:24
                    Reset counter: 241
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 16:41:24
                    Reset counter: 241
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 16:41:24
   Part No SW: 3AA 907 044 E    HW: 3AA 907 044 E
   Component: Climatronic   H03 0101
   Revision: 00001K01
   Coding: 0014104808
   Shop #: WSC 80248 790 00003
   VCID: 325325B06548A7DF5F-8066
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 8
                    Reset counter: 241
                    Mileage: 188882 km
                    Date: 2019.07.23
                    Time: 15:22:20
   Revision: 00H54000    Serial number: 00000009212812
   Coding: EFE28F8910041A0047978F0017000000000BFB4764401165170000000000
   Shop #: WSC 40970 222 55394
   VCID: 335D20B45252AED754-8066
   Subsystem 1 - Part No: 3C8 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 251108 022  0602
   Coding: 00047029
   Shop #: WSC 40970
   Component: RLS     210109 054  0402
   Coding: 00471277
   Shop #: WSC 40970
                    Fault Status: 01101100
                    Reset counter: 241
                    Mileage: 188882 km
                    Voltage: 13.55 V
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 L    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0021
   Revision: --------    Serial number: 06530901409498
   Coding: 310007
   Shop #: WSC 40970 222 98706
   VCID: 44BF7368C7FC196FFD-8010
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 241
                    Mileage: 188882 km
                    Date: 2013.12.13
                    Time: 15:22:18
                    Temperature: 27.0°C
Address 13: Auto Dist. Reg
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376     HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0069
   Revision: 00000000    Serial number: 06010902520002
   Coding: 030180
   Shop #: WSC 05311 123 08193
   VCID: 66FB89E091000B7F03-8032
                    Reset counter: 241
                    Mileage: 188882 km
                    Date: 2013.12.13
                    Time: 15:22:20
                    Bin. Bits: 00000000 00000110
   Component: J234__304 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DP0CG697
   Coding: 0012340
   VCID: 3B4D08947A0266978C-806E
   Subsystem 1 - Serial number: 6333FTS605571130
   Subsystem 2 - Serial number: 6343FTS657021130
   Subsystem 3 - Serial number: 6353ETS6GQPEV5KJ
   Subsystem 4 - Serial number: 6363ETS69QOFV5KR
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AK    HW: 3C0 953 549 AK
   Component: J0527               0030
   Revision: 00032000    Serial number: 3C5953507CP
   Coding: 0200721
   Shop #: WSC 05311 000 08193
   VCID: 75D9DEAC1CA6F0E7BA-8020
   Subsystem 1 - Part No: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H31 0037
   Coding: 00000130
   Part No SW: 3C8 920 880 GX    HW: 3C8 920 880 GX
   Component: KOMBI         H03 0132
   Coding: 140D00
   Shop #: WSC 80239 123 12345
   VCID: 0827A758B354FD0FD1-805C
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 N    HW: 3C0 907 951
   Component: J533  Gateway   H14 0172
   Revision:   H14       Serial number: 1021G108310221
   Coding: F9ADFF46C0465B004002
   Shop #: WSC 05314 123 12345
   VCID: 2C6F3BC88F6CF12F15-8078
01319 - Control Module for Distance Control (J428)
                    Reset counter: 240
                    Mileage: 188882 km
                    Date: 2013.12.13
                    Time: 15:22:19
   Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 0201006B74745D545420363E00
   Shop #: WSC 00066 123 12345
   VCID: 2D6936CC7476F82702-8078
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 54631 001 1048576
   VCID: 7AC3CD9035B89F9FD7-802E
   Revision: A1001003    Serial number: 7665373401
   Coding: 020100
   Shop #: WSC 00020 790 00000
   VCID: 2B6D38D44A62F6171C-807E
   Part No SW: 3C8 959 760 B    HW: 3C8 959 760 B
   Component: Sitzmemory    H02 1001
   Revision: 00H02000
   Coding: 000039
   VCID: 345F23A8975CA9EF4D-8060
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 E
   Component: RNS-MID       H27 6276
   Revision: AB001001    Serial number: VWZ6Z7M4010128
   Coding: 0600040000000081200F
   VCID: 365B19A08120BBFF73-8062
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V12  8196
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 241
                    Mileage: 188888 km
                    Reset counter: 241
                    Mileage: 188888 km
                    Reset counter: 241
                    Mileage: 188888 km
                    Reset counter: 241
                    Mileage: 188888 km
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1533
   Revision: 71009005    Serial number: 00000765589012
   Coding: 0004351
   VCID: 40B77F7813E4054FD9-8014
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.070 0502
   Revision: 1AH02240    Serial number: 00082740297802
   Coding: 0000258
   VCID: 3941129C703E54879E-806C
   Component:    KSG PQ46 ELV 043 0612
   Coding: 18910A0001864E7F3F029D1D70C8CFCE705F41
   Component: LIN BACKUP HORN H08 9001
   Component: Neigungssensor  004 0611
   Part No SW: 1K0 907 532     HW: 3C0 907 951
   Component: EZE_2         H14 0172
   Revision: --------    Serial number: 1021G108310221
   Coding: 01030100
   Shop #: WSC 05314 000 00000
   Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245/J878  H04 0054
   Serial number: 847300039270
   Coding: 000006
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1533
   Revision: 71009005    Serial number: 00000521789114
   Coding: 0004590
   VCID: 41B17A7C18EE0C47D6-8014
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000232669
   Coding: 0000057
   Shop #: WSC 08876 000 104857
   VCID: 2867C7D89B94DD0FF1-807C
                    Fault Status: 11111101
                    Reset counter: 241
                    Mileage: 188882 km
                    Date: 2013.12.13
                    Time: 15:22:20
                    Voltage: 11.60 V
                    Count: 71
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Component: AFS-Steuergeraet    0136
   Coding: 3493064
   VCID: 345F23A8575CA9EF4D-8060
   Subsystem 1 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0003
   Coding: 00000053
   Subsystem 2 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0003
   Coding: 00000053
                    Reset counter: 241
                    Mileage: 188888 km
                    Reset counter: 241
                    Mileage: 188888 km
                    Reset counter: 241
                    Mileage: 188888 km
                    Reset counter: 241
                    Mileage: 188888 km
Address 57: TV Tuner        Labels: 7L6-919-148.clb
   Part No SW: 7L6 919 148 A    HW: 7L6 919 148
   Component: R0078 TVhybridDVB   0150
   Revision: R0H21000    Serial number: 93900501354101
   Coding: 0000801
   VCID: 3A430D9075385F9F97-806E
Address 5C: Lane Maintain.        Labels: 3C0-907-217.clb
   Part No SW: 3C0 907 217 A    HW: 4E0 907 217 C
   Component: J759  HCA           0150
   Revision: 00H07004    Serial number: 400209406000DA
   Coding: 0132002
   VCID: 2171DAFCF8AE2C47B6-8074
                    Fault Frequency: 9
                    Reset counter: 241
                    Mileage: 188882 km
                    Date: 2013.12.13
                    Time: 15:22:19
   Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
   Component: J388   TUER-SG HL   0309
   Revision: 43004101    Serial number: 00000000769112
   Coding: 0000200
   VCID: 31512ABCA84E9CC726-8064
   Component: Anhaenger     H07 0070
   Revision: 3A001001    Serial number: 00000129162821
   Coding: 0100000100000000
   VCID: 30572FB8634495CF29-8064
   Part No SW: 3C8 907 441     HW: 3C8 907 441
   Revision: 00H13000    Serial number: 525PA8-J480845
   Coding: 0030008
   Shop #: WSC 05311 000 00001
   VCID: 67E584E4560A127738-8032
Address 72: Door, Rear Right        Labels: None
   Part No SW: 3C8 959 704 D    HW: 3C8 959 794
   Component: J389   TUER-SG HR   0501
   Revision: 43004102    Serial number: 00000002825406
   Coding: 0065680
   Shop #: WSC 08224 016 263172
   Part No SW: 5K0 035 730     HW: 5K0 035 730
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669330704
   Coding: 0200000000010110
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 62F395F07528775FEF-8036
End-------------------------(Elapsed Time: 04:05)--------------------------
Sunday,28,July,2019,23:14:13:26566
5C-Lane Maintain. -- Status: OK 0000
   Coding: 0000072
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 22:55:29
                    Load: 100.0 %
                    Lambda: 97.8 %
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 32.4°C
               U1017 - 000 -
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 22:55:30
                    (no units): 0.00
                    (no units): 0.00
                    (no units): 3.0
                    Bin. Bits: 00000100
                    (no units): 33.0
               U0235 - 000 -
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 22:55:32
                    Temperature: 21.6°C
                    Voltage: 11.63 V
                    Bin. Bits: 00000000
                    Torque: 219.0 Nm
                    Temperature: 39.6°C
   Coding: 0010000
                    Reset counter: 241
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 23:03:15
                    Hex Value: 0x0000
                    Voltage: 11.50 V
                    Bin. Bits: 00011110
                    Count: 150
                    Hex Value: 0x0000
                    Reset counter: 241
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 23:03:15
   Revision: 00001K01
   Coding: 0014104808
          U1111 00 [009] - -
                    Reset counter: 241
                    Mileage: 188890 km
                    Date: 2019.07.28
                    Time: 23:01:33
   Coding: 00047029
   Shop #: WSC 40970
   Coding: 00471277
   Shop #: WSC 40970
   Coding: 310007
   Coding: 030180
   Coding: 0012340
   Coding: 0200721
   Coding: 00000130
   Coding: 140D00
                    Reset counter: 241
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 23:01:34
   Revision: AA001002
   Coding: 020100
   Revision: 00H02000
   Coding: 000039
                    Reset counter: 241
                    Mileage: 188888 km
                    Reset counter: 241
                    Mileage: 188888 km
                    Reset counter: 241
                    Mileage: 188888 km
                    Reset counter: 241
                    Mileage: 188888 km
   Coding: 0004351
   Coding: 0000258
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 241
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 23:01:33
                    (no units): 4.0
                    Voltage: 11.50 V
                    Reset counter: 241
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 23:01:33
                    (no units): 4.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 11
   Coding: 01030100
   Coding: 000006
   Coding: 0004590
   Coding: 0000057
   Coding: 3493064
   Coding: 00000053
   Coding: 00000053
                    Reset counter: 241
                    Mileage: 188888 km
                    Reset counter: 241
                    Mileage: 188888 km
                    Reset counter: 241
                    Mileage: 188888 km
                    Reset counter: 241
                    Mileage: 188888 km
   Coding: 0000801
   Coding: 0132002
   Coding: 0000200
   Coding: 0030008
                    Reset counter: 241
                    Mileage: 188890 km
                    Date: 2013.12.18
                    Time: 23:01:32
                        Reverse OFF
                    Count: 3
   Coding: 0065680
   ROD: UHVNA.rod
End-------------------------(Elapsed Time: 03:10)--------------------------
raziel90
Sweden
C?ID=172805
Hi
I've got some help with the the coding but no luck because of no communication with the radar. Yesterday i checked the wiering and it they are connecter to the right places but when i checked the resistance on the canbus cabel i only got 40 ohms insted of 60 ohms but there is no communication issues with the steering colummn and they are connected to the same pins on the gateway. The cabels that i used and brand new and the relay and twined canbus cabels are straight from VW.
dnoermann
C?ID=358118
Is the retrofitet ACC working ?
Did you test it on the Bench or in a different car ?
To be shure that the ACC is not the Problem.
rhinopower
C?ID=58979
Wiring is wrong or radar is faulty. You need to work out which
raziel90
Sweden
C?ID=172805
My multimeter was showing wrong values. The cabels are all fine and connected to the right spots and the resistance is 60 ohm i also checked the relay and it works to. So the radar must have been broken when i bought it.
rhinopower
C?ID=58979
Try connecting the wires straight to the gateway and see if you can connect to it?
golfi_vend
Tartu, Estonia
C?ID=195131
Autoscan before ABS replacement would be great help figuring out the coding for new one.
Edit: A possible code might be: 0010533
raziel90
Sweden
C?ID=172805
I tried 10533 but i got a fault for brake booster electrical problem. I only have an autoscan on swedish before abs swap but my old abs code was 0002346.
raziel90
Sweden
C?ID=172805
Now all of a sudden i have voltage to the radar and i got connection but i got these codes and i need a security code so i can code the radar
South Molton, UK
Shoud the can high and low wiers have power even when module not connected?
Please explain how/when you are measuring - the CAN will be powered by the CAN Gateway even if an attached module isn't powered.
dnoermann
C?ID=358118
ACC Login for B7 ACC is 14117
raziel90
Sweden
C?ID=172805
here is my coding on swedish befor the abs swap
onsdag,28,Juni,2017,21:58:15:26566
VCDS -- Windows-baserad VAG/VAS-emulator Tändningen Windows 8 x86
VCDS version: AER 16.8.3.3
Dataversion: 20161205 DS267.0
VIN: WVWZZZ3CZ9E551356   Reg.nr: DYM580
Mätarställning: 162130km   Rep.order: RADAR/ACC
Chassityp: 3C (3C0)
Skanna: 01 03 08 09 10 13 14 15 16 17 19 25 2E 36 37 42 44 46 4F 52
VIN: WVWZZZ3CZ9E551356   Mätarställning: 162130km
01-Motor -- Status: OK 0000
03-Bromselektronik -- Status: OK 0000
04-Styrposition -- Status: OK 0000
08-Klimatanläggning -- Status: Felfunktion 0010
09-Elektron. elcentral -- Status: OK 0000
10-park/styr-hjälp -- Status: OK 0000
13-Distansreglering -- Status: Kan ej nås 1100
14-Stötd.-elektronik -- Status: OK 0000
15-Krockkuddar -- Status: OK 0000
16-Rattelektronik -- Status: Felfunktion 0010
17-Instrument -- Status: OK 0000
19-CAN Gateway -- Status: Felfunktion 0010
25-Startspärr -- Status: OK 0000
2E-Mediaspelare 3 -- Status: OK 0000
36-Stolminne förare -- Status: OK 0000
37-Navigering -- Status: Felfunktion 0010
42-Dörrel. förare -- Status: OK 0000
44-Styrservo -- Status: OK 0000
46-Komfortcentral -- Status: OK 0000
4F-Elektr. centralenh. II -- Status: OK 0000
52-Dörrelektr. pass. -- Status: OK 0000
53-Parkeringsbroms -- Status: OK 0000
55-Helljusområde -- Status: OK 0000
56-Radio -- Status: Felfunktion 0010
57-TV-tuner -- Status: Kan ej nås 1100
5C-Filhålln.hjälp -- Status: OK 0000
62-Dörr vä. bak -- Status: OK 0000
69-Släpvagnsfunktion -- Status: OK 0000
6C-Back-kamera -- Status: Felfunktion 0010
72-Dörr hö bak -- Status: OK 0000
77-Telefon -- Status: OK 0000
Adress 01: Motor (CBB)       Labels: AER\03L-906-022-CBA.clb
   Artikelnr SW: 03L 906 022 QF    HW: 03L 907 309
   Komponent: R4 2.0l TDI G000SG  9977
   Revision: 13H01---    Serienummer: VWZCZ000000000
   Kodning: 0000072
   Verkstad #: WSC 26214 051 00000
   VCID: 79C1D29C30BE948A85-802C
Ingen felkod funnen.
Adress 03: Bromselektronik        Labels: AER\3C0-614-109-C4.clb
   Artikelnr SW: 3C0 614 109 T    HW: 3C0 614 109 T
   Komponent: J104    C4 440 V2   0013
   Revision: --025---    Serienummer: 00000786477401
   Kodning: 0002346
   Verkstad #: WSC 05311 000 00000
   VCID: 2F552CC4BE7A8A3A6B-807A
Adress 08: Klimatanläggning (J255)       Labels: AER\5K0-907-044.clb
   Artikelnr SW: 3AA 907 044 E    HW: 3AA 907 044 E
   Komponent: Climatronic   H03 0101
   Revision: 00001K01
   Kodning: 0011004803
   Verkstad #: WSC 80248 790 00003
   VCID: 325325B06548A7D204-8066
2 Funna fel:
13701376 - Nedsatt funktion på grund av att meddelande saknas
          U1111 00 [009] - -
          Bekräftad - Testad efter att minnet rensats
             frysta data:
                    Felstatus: 00000001
                    Felprioritet: 6
                    Felfrekvens: 1
                    Reset-räknare: 199
                    Mätarställning: 162138 km
                    Datum: 2017.06.28
                    Tid: 21:52:56
13701424 - Nedsatt funktion på grund av att meddelande saknas
          U1111 00 [009] - -
             frysta data:
                    Felstatus: 00000001
                    Felprioritet: 6
                    Felfrekvens: 1
                    Reset-räknare: 199
                    Datum: 2017.06.28
                    Tid: 21:52:57
Adress 09: Elektron. elcentral        Labels: 3C0-937-049-30-H.lbl
   Artikelnr SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Komponent: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serienummer: 00000009212812
   Kodning: EFE28F8910041A0047978F0017000000000BFB4764401165170000000000
   Verkstad #: WSC 40970 222 55394
   VCID: 335D20B45252AEDA0F-8066
   Subsystem 1 - Artikelnr: 3C8 955 119   Labels: AER\1KX-955-119.CLB
   Komponent: Wischer 251108 022  0602
   Kodning: 00047029
   Subsystem 2 - Artikelnr: 1K0 955 559 AH  Labels: AER\1K0-955-559-AG.CLB
   Komponent: RLS     210109 054  0402
   Kodning: 00471277
Adress 10: park/styr-hjälp (J791)       Labels: AER\1T0-919-475.clb
   Artikelnr SW: 1T0 919 475 L    HW: 1T0 919 475
   Komponent: PARKHILFE PLA H07 0021
   Revision: --------    Serienummer: 06530901409498
   Kodning: 310007
   Verkstad #: WSC 40970 222 98706
   VCID: 44BF7368C7FC1962A6-8010
Adress 13: Distansreglering
Kan ej nås
Adress 14: Stötd.-elektronik (J250)       Labels: 3C0-907-376.clb
   Artikelnr SW: 3C0 907 376     HW: 3C0 907 376
   Komponent: DAEMPFUNGS-SG H07 0069
   Revision: 00000000    Serienummer: 06010902520002
   Kodning: 010180
   Verkstad #: WSC 05311 000 08193
   VCID: 66FB89E091000B7258-8032
Adress 15: Krockkuddar        Labels: AER\5N0-959-655.lbl
   Artikelnr SW: 5N0 959 655 A    HW: 5N0 959 655 A
   Komponent: J234__304 VW10 HI   1815
   Revision: 19013000    Serienummer: 0039DP0CG697
   Kodning: 0012340
   VCID: 3B4D08947A02669AD7-806E
   Subsystem 1 - Serienummer: 6333FTS605571130
   Subsystem 2 - Serienummer: 6343FTS657021130
   Subsystem 3 - Serienummer: 6353ETS6GQPEV5KJ
   Subsystem 4 - Serienummer: 6363ETS69QOFV5KR
   Subsystem 5 - Serienummer: 00000000000000000
   Subsystem 6 - Serienummer: 00000000000000000
Adress 16: Rattelektronik        Labels: AER\3C0-953-549-SW25.lbl
   Artikelnr SW: 3C0 953 549 AK    HW: 3C0 953 549 AK
   Komponent: J0527               0030
   Revision: 00032000    Serienummer: 3C5953507CP
   Kodning: 0200711
   VCID: 75D9DEAC1CA6F0EAE1-8020
   Subsystem 1 - Artikelnr: 5K0 959 542 C  Labels: AER\3C8-959-537.CLB
   Komponent: E221__MFL-TAS   H31 0037
   Kodning: 00000130
   Verkstad #: WSC 00000
1 fel funnet:
01044 - Styrdonet är felaktigt kodat
Adress 17: Instrument (J285)       Labels: AER\3C8-920-xxx-17.clb
   Artikelnr SW: 3C8 920 880 GX    HW: 3C8 920 880 GX
   Komponent: KOMBI         H03 0132
   Kodning: 140F00
   Verkstad #: WSC 80239 000 00000
   VCID: 0827A758B354FD028A-805C
Adress 19: CAN Gateway        Labels: AER\3C0-907-530-V3.clb
   Artikelnr SW: 3C0 907 530 N    HW: 3C0 907 951
   Komponent: J533  Gateway   H14 0172
   Revision:   H14       Serienummer: 1021G108310221
   Kodning: F9ADFF46C0461B004002
   Verkstad #: WSC 05314 123 12345
   VCID: 2C6F3BC88F6CF1224E-8078
2 Funna fel:
00467 - TV-mottagare (R78)
            004 - Ingen signal/förbindelse
             frysta data:
                    Felstatus: 01100100
                    Felprioritet: 2
                    Felfrekvens: 1
                    Reset-räknare: 199
                    Tidsindikering: 0
                    Datum: 2017.06.28
                    Tid: 21:53:01
01319 - Styrdon för avståndsreglering (J428)
             frysta data:
                    Felstatus: 01100100
                    Felprioritet: 2
                    Felfrekvens: 1
                    Reset-räknare: 199
                    Tidsindikering: 0
                    Datum: 2017.06.28
                    Tid: 21:54:04
Adress 25: Startspärr        Labels: AER\3C0-959-433-25.clb
   Artikelnr SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Komponent:    IMMO         043 0383
   Revision: 00043000    Serienummer: VWZCZ000000000
   Verkstad #: WSC 54631 001 1048576
   VCID: 7AC3CD9035B89F928C-802E
   Subsystem 1 - Artikelnr: 3C0 905 861 J
   Komponent:    ELV          029 0380
Adress 2E: Mediaspelare 3 (J650)       Labels: AER\5N0-035-342.lbl
   Artikelnr SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Komponent: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serienummer: 7665373401
   Kodning: 020100
   Verkstad #: WSC 00020 790 00000
   VCID: 2B6D38D44A62F61A47-807E
Adress 36: Stolminne förare (J810)       Labels: AER\3C0-959-760.lbl
   Artikelnr SW: 3C8 959 760 B    HW: 3C8 959 760 B
   Komponent: Sitzmemory    H02 1001
   Revision: 00H02000
   Kodning: 000039
   Verkstad #: WSC 00000 000 00000
   VCID: 345F23A8975CA9E216-8060
Adress 37: Navigering (J0506)       Labels: AER\1T0-035-680.clb
   Artikelnr SW: 1T0 035 686 E    HW: 1T0 035 686 E
   Komponent: RNS-MID       H27 6276
   Revision: AB001001    Serienummer: VWZ6Z7M4010128
   Kodning: 0000040000000080000F
   Verkstad #: WSC 12345 123 12345
   VCID: 365B19A08120BBF228-8062
   Subsystem 1 - Artikelnr: 1T0 919 859 C
   Komponent: EU East V12  8196
1 fel funnet:
             frysta data:
                    Felstatus: 01100100
                    Felprioritet: 5
                    Felfrekvens: 1
                    Reset-räknare: 199
                    Tidsindikering: 0
                    Datum: 2017.06.28
                    Tid: 21:53:24
Adress 42: Dörrel. förare        Labels: AER\1K0-959-701-MAX3.lbl
   Artikelnr SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Komponent: J386  TUER-SG FT    1533
   Revision: 71009005    Serienummer: 00000765589012
   Kodning: 0004351
   VCID: 40B77F7813E4054282-8014
Adress 44: Styrservo        Labels: AER\5N1-909-144.clb
   Artikelnr SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Komponent: J500__APA-BS KL.070 0502
   Revision: 1AH02240    Serienummer: 00082740297802
   Kodning: 0000258
   VCID: 3941129C703E548AC5-806C
Adress 46: Komfortcentral        Labels: AER\3C0-959-433-46.clb
   Komponent:    KSG PQ46 ELV 043 0612
   Kodning: 18910A0001864E7F3F029D1D70C8CFCE705F41
   Subsystem 1 - Artikelnr: 1K0 951 605 D
   Komponent: LIN BACKUP HORN H08 9001
   Subsystem 2 - Artikelnr: 3C0 951 171 C
   Komponent: Neigungssensor  004 0611
   Subsystem 3 - Artikelnr: 3C0 951 171 C
   Komponent: Innenraumueberw.004 0611
Adress 4F: Elektr. centralenh. II (J520)       Labels: AER\1K0-907-532.clb
   Artikelnr SW: 1K0 907 532     HW: 3C0 907 951
   Komponent: EZE_2         H14 0172
   Revision: --------    Serienummer: 1021G108310221
   Kodning: 01030100
   Verkstad #: WSC 05314 000 00000
   Subsystem 1 - Artikelnr SW: 6R0 959 591     HW: 6R0 959 591
   Komponent: J245/J878  H04 0054
   Serienummer: 847300039270
   Kodning: 000006
Adress 52: Dörrelektr. pass.        Labels: AER\1K0-959-702-MAX3.lbl
   Artikelnr SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Komponent: J387  TUER-SG BT    1533
   Revision: 71009005    Serienummer: 00000521789114
   Kodning: 0004590
   VCID: 41B17A7C18EE0C4A8D-8014
Adress 53: Parkeringsbroms        Labels: AER\5N0-907-801.clb
   Artikelnr SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Komponent: J540 EPB3  VW-10498 0003
   Revision:   009       Serienummer: 00000000232669
   Kodning: 0000057
   Verkstad #: WSC 08876 000 1048576
   VCID: 2867C7D89B94DD02AA-807C
Adress 55: Helljusområde        Labels: AER\5M0-907-357-V2.lbl
   Artikelnr SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Komponent: AFS-Steuergeraet    0136
   Revision: 00H04000    Serienummer:
   Kodning: 3493064
   VCID: 345F23A8575CA9E216-8060
   Subsystem 1 - Artikelnr: 1K0 941 329   Labels: AER\3D0-941-329.CLB
   Komponent: AFS-Lst.-Modul l    0003
   Kodning: 00000053
   Subsystem 2 - Artikelnr: 1K0 941 329   Labels: AER\3D0-941-329.CLB
   Komponent: AFS-Lst.-Modul r    0003
   Kodning: 00000053
Adress 56: Radio (J0506)       Labels: AER\1T0-035-680.clb
1 fel funnet:
             frysta data:
                    Felstatus: 01100100
                    Felprioritet: 5
                    Felfrekvens: 1
                    Reset-räknare: 199
                    Tidsindikering: 0
                    Datum: 2017.06.28
                    Tid: 21:53:24
Adress 57: TV-tuner
Kan ej nås
Adress 5C: Filhålln.hjälp        Labels: AER\3C0-907-217.clb
   Artikelnr SW: 3C0 907 217 A    HW: 4E0 907 217 C
   Komponent: J759  HCA           0150
   Revision: 00H07004    Serienummer: 400209406000DA
   Kodning: 0130002
   VCID: 2171DAFCF8AE2C4AED-8074
Adress 62: Dörr vä. bak        Labels: AER\1K0-959-703-GEN3.lbl
   Artikelnr SW: 3C8 959 703 B    HW: 1K0 959 795 Q
   Komponent: J388   TUER-SG HL   0309
   Revision: 43004101    Serienummer: 00000000769112
   Kodning: 0000200
   VCID: 31512ABCA84E9CCA7D-8064
Adress 69: Släpvagnsfunktion (J345)       Labels: AER\1K0-907-383-V2.clb
   Artikelnr SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Komponent: Anhaenger     H07 0070
   Revision: 3A001001    Serienummer: 00000129162821
   Kodning: 0100000100000000
   VCID: 30572FB8634495C272-8064
Adress 6C: Back-kamera        Labels: AER\5N0-907-441.clb
   Artikelnr SW: 3C8 907 441     HW: 3C8 907 441
   Komponent: J772__Rearview      0040
   Revision: 00H11000    Serienummer: 525PA8-J2X1245
   Kodning: 0030008
   Verkstad #: WSC 98765 666 38384
   VCID: 67E584E4560A127A63-8032
1 fel funnet:
03006 - Backningskamerasystem ej kalibrerat
             frysta data:
                    Felstatus: 01100000
                    Felprioritet: 2
                    Felfrekvens: 1
                    Reset-räknare: 199
                    Tidsindikering: 0
Adress 72: Dörr hö bak        Labels: saknas
   Artikelnr SW: 3C8 959 704 D    HW: 3C8 959 794
   Komponent: J389   TUER-SG HR   0501
   Revision: 43004102    Serienummer: 00000002825406
   Kodning: 0065680
   Verkstad #: WSC 08224 016 263172
Adress 77: Telefon (J412)       Labels: AER\7P6-035-730.clb
   Artikelnr SW: 5K0 035 730     HW: 5K0 035 730
   Komponent: TELEFON       H09 1020
   Revision: 1B001001    Serienummer: 00007669330704
   Kodning: 0200000000010110
   ROD: UHVNA.rod
   VCID: 62F395F075287752B4-8036
2 Funna fel:
9457425 - Minusutgång audiokanal för tal/telefon
          B104F 11 [000] - kortsl. mot gods
          Intermittent fel - Ej bekräftad - Testad efter att minnet rensats
9457169 - Plusutgång audiokanal för tal/telefon
          B104E 11 [000] - kortsl. mot gods
Slut------------------------(Förfluten tid: 02:46)-------------------------
raziel90
Sweden
C?ID=172805
and this is the latest in english
Tuesday,06,August,2019,15:50:13:26566
Mileage: 188930km-117395mi   Repair Order:
VIN: WVWZZZ3CZ9E551356   Mileage: 188930km-117395miles
   Component: R4 2.0l TDI 0000SG  9977
   Coding: 0000072
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 000 -  - MIL ON
                    Mileage: 188934 km
                    Date: 2013.12.27
                    Time: 22:30:03
                    (no units): 0.00
                    (no units): 0.00
                    (no units): 3.0
                    Bin. Bits: 00000000
                    (no units): 0.0
   Coding: 0010000
                    Reset counter: 248
                    Mileage: 188934 km
                    Date: 2013.12.27
                    Time: 22:56:03
                    Hex Value: 0x0000
                    Voltage: 11.50 V
                    Bin. Bits: 00011111
                    Count: 150
                    Hex Value: 0x0000
   Revision: 00001K01
   Coding: 0014104808
          U1111 00 [009] - -
                    Reset counter: 248
                    Mileage: 188934 km
                    Date: 2019.08.06
                    Time: 22:56:03
   Coding: 00047029
   Shop #: WSC 40970
   Coding: 00471277
   Shop #: WSC 40970
                    Reset counter: 33
                    Mileage: 188934 km
                    Voltage: 11.95 V
   Coding: 310007
Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
   Part No SW: 3C0 907 567 J    HW: 3C0 907 567 G
   Component: AC201  RDW A    031 0232
   Revision: 00031000    Serial number: 00000000900473
   Coding: 0010000
   VCID: 325325B0AD48A7DF5F-8066
                    Reset counter: 248
                    Mileage: 188934 km
                    Date: 2013.12.27
                    Time: 22:56:03
                    Count: 4
                    Reset counter: 248
                    Mileage: 188934 km
                    Date: 2013.12.27
                    Time: 23:28:54
                    Count: 4
                    Reset counter: 248
                    Mileage: 188934 km
                    Date: 2013.12.27
                    Time: 23:28:56
                    Count: 4
   Coding: 030180
                    Reset counter: 248
                    Mileage: 188934 km
                    Date: 2013.12.27
                    Time: 22:56:03
                    Bin. Bits: 00000000 00000001
   Coding: 0012340
   Coding: 0200721
   Coding: 00000130
   Coding: 140D00
   Revision: AA001002
   Coding: 020100
   Revision: 00H02000
   Coding: 000039
                    Reset counter: 248
                    Mileage: 188928 km
                    Reset counter: 248
                    Mileage: 188928 km
                    Reset counter: 248
                    Mileage: 188928 km
                    Reset counter: 248
                    Mileage: 188928 km
   Coding: 0004351
   Coding: 0000258
   Coding: 01030100
   Coding: 000006
   Coding: 0004590
   Coding: 0000057
   Coding: 3493064
   Coding: 00000053
   Coding: 00000053
                    Reset counter: 248
                    Mileage: 188928 km
                    Reset counter: 248
                    Mileage: 188928 km
                    Reset counter: 248
                    Mileage: 188928 km
                    Reset counter: 248
                    Mileage: 188928 km
   Coding: 0000801
   Coding: 0132002
   Coding: 0000200
   Coding: 0030008
   Coding: 0065680
   ROD: UHVNA.rod
End-------------------------(Elapsed Time: 02:52)--------------------------
dnoermann
C?ID=358118
Coding: 0010000
ACC is wrong coded.
Change Coding from
- 0010000 Automatic Gearbox to
- 0010100 Manual Gearbox
raziel90
Sweden
C?ID=172805
ACC is wrong coded.
Change Coding from
I tried but it doesn't allow me to change the coding. If i rememberd right i get a security accses message when i press Go and when i get coding help it say 0= manual an 1= automatic
The OP registered his VCDS and is now Verified. Moving to Retrofits.
golfi_vend
Tartu, Estonia
C?ID=195131
You need enable adaption with security access and then from there you need to enable adaption channel for coding enable.
raziel90
Sweden
C?ID=172805
Hi.
I have now change the radar coding to 10100 which deleted my transmission fault
raziel90
Sweden
C?ID=172805
0025386 rejected
0010538 rejected
0026922 rejected
0027434 rejected
0010533 fault 02534( electrical fault vacuum sensor G483
0002346 rejected
0010000 fault 01042 (CM not coded)
