Coding ABS Module
ThatDude
Chicago, USA
C?ID=370464
I hope everyone is doing well!
New user of the VCDS software here. I've got a 2009 GTI that had a bad abs module. The original ABS model was thrown out without retrieving the original coding. Out of desperation of needing a functioning vehicle (before the ABS recall happened), I replaced the original abs module with a module out of a 2011 Jetta. It "seems" to function, but I am really uncertain as to whether this module can be coded or not to my vehicle. Any help on this matter would be greatly appreciated. Below I attached the scan of the abs module first & then the auto scan with the fault codes.
Thanks!
Sunday,28,July,2019,13:01:01:14274
VCDS Version: Release 19.6.1 (x64) Running on Windows 10 x64
                Address 03: ABS Brakes       Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
  Component and/or Version: ESP MK60EC1   H31 0121
           Software Coding: 00000000000000000000000000000000000000
            Work Shop Code: WSC 00066 000 00000
                      VCID: 7BA3F60F93E61CFF9FB-802E
                    Reset counter: 234
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 42240
                    Fault Status: 01100101
                    Reset counter: 29
                    Mileage: 253708 km
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 279
                    Count: 42240
                    Count: 65280
                    Reset counter: 29
                    Mileage: 253708 km
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 295
                    Count: 42240
                    Count: 65280
                    Reset counter: 29
                    Mileage: 253708 km
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 270
                    Count: 42240
                    Count: 65280
________________________________________________________________________________
Sunday,28,July,2019,13:11:08:14274
VIN: WVWEV71K19W133621   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWEV71K19W133621   Mileage: 265580km-165023miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AE    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0030
   Revision: AAH03---    Serial number: VWX7Z0H93N77VW
   Coding: 0403010A18070160
   Shop #: WSC 85573 554 600234
   VCID: 698FBC47E57A9E6F7D7-803C
006481 - Radiator Fan 2 (V177)
               P1951 - 000 - Movement Restricted / Jammed - Intermittent
                    Mileage: 265414 km
                    Time: 10:09:12
                    RPM: 2775 /min
                    Load: 23.5 %
                    Speed: 113.0 km/h
                    Temperature: 90.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.843 V
   Revision: 00H31001
   Shop #: WSC 00066 000 00000
                    Reset counter: 162
                    Mileage: 265580 km
                    Count: 16391
                    Count: 8192
                    Count: 195
                    Count: 46848
                    Reset counter: 162
                    Mileage: 265580 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 279
                    Count: 43008
                    Reset counter: 162
                    Mileage: 265580 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 295
                    Count: 43008
                    Reset counter: 162
                    Mileage: 265580 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 270
                    Count: 43008
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78A9E903AED037E7F29-802C
   Revision: 00H54000    Serial number: 00000008574964
   Coding: A78D8F214004150047140000001400000038770B5C000100000000000000
   VCID: 33331E2FF73614BF07B-8066
   Component: Wischer 250908 021  0501
   Coding: 00038805
   Shop #: WSC 01357
                    Fault Status: 00101010
                    Fault Frequency: 8
                    Reset counter: 200
                    Mileage: 264938 km
                    Voltage: 13.90 V
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0426202
   Coding: 0000100
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0C1NC
   Coding: 0013899
   VCID: 6C81C553EA888B47061-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME3D0141362
   Subsystem 3 - Serial number: 6342MSME4005290F7
   Subsystem 4 - Serial number: 6352QSME1B0E303AJ
   Subsystem 5 - Serial number: 6362QSME60081F36H
   Subsystem 6 - Serial number: 63727SME186C044FA
   Subsystem 7 - Serial number: 63827SME186C121E6
   Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
   Coding: 0002022
   VCID: 015F84E7FD0A762FC57-8054
   Part No SW: 1K6 920 974 H    HW: 1K6 920 974 H
   Component: KOMBIINSTRUMENT VDD 2416
   Revision: V0003000    Serial number: VWX7Z0H93N77VW
   Coding: 0007203
   Shop #: WSC 02120 444 84272
   VCID: 392F2C07D55AEEEFCD7-806C
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 240908F2001478
   Coding: E9811F070013020000
   VCID: 35372037F9420A8F29F-8060
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T46WV03
   VCID: 7DA7F81781F212CFA1F-8028
   Component: IMMO            VDD 2416
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: 38292903EE50F7E7329-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   Coding: 139006885103081B09040585B0080A04889C00
   VCID: 04518DF3E2186307EE1-8050
   Coding: 0001076
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74B1DD33B2B85387DE1-8020
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio PM6       125 0037
   Revision: 00125000    Serial number: VWZ5Z7H2265781
   Coding: 0040402
   VCID: 290FFC4725FA5E6FBD7-807C
   Coding: 0100101
End----------(Elapsed Time: 01:13, VBatt start/end: 12.1V/12.0V)-----------
A complete Auto-Scan (to see how the vehicle is equipped) that also shows the complete VIN is absolutely essential here. Portions of the VIN mus be embedded in the coding.
ThatDude
Chicago, USA
C?ID=370464
Is this the correct scan that you need to see? I used auto scan>>Auto- Detect (CAN only)>>start
I apologize if it's not, I looked at the videos and it seemed like the only option.
Sunday,04,August,2019,12:59:29:14274
VIN: WVWEV71K19W133621   Mileage: 266310km-165477miles
   Revision: 00H31001
                    Reset counter: 162
                    Mileage: 265580 km
                    Count: 16391
                    Count: 8192
                    Count: 195
                    Count: 46848
                    Reset counter: 162
                    Mileage: 265580 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 279
                    Count: 43008
                    Reset counter: 162
                    Mileage: 265580 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 295
                    Count: 43008
                    Reset counter: 162
                    Mileage: 265580 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 270
                    Count: 43008
   Coding: 00038805
   Shop #: WSC 01357
   Coding: 0000100
   Coding: 0013899
   Coding: 0002022
   Coding: 0007203
   Coding: 0001077
   Coding: 1390068851034E3F2D040585B0080A04889C00
   Coding: 0001076
   Coding: 0000003
   Coding: 0040402
                    Reset counter: 187
                    Mileage: 266312 km
                    Time: 00:55:12
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 187
                    Mileage: 266312 km
                    Time: 00:55:12
                    Reset counter: 187
                    Mileage: 266312 km
                    Time: 00:55:12
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 187
                    Mileage: 266312 km
                    Time: 00:55:12
   Coding: 0100101
End----(Elapsed Time: 01:07, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
Yes, that's fine. Assuming the ABS control module is correct for the car, I'm confident someone will be able to get you a usable coding based on that.
ThatDude
Chicago, USA
C?ID=370464
Sounds good. Thanks for your help Uwe. I'm looking forward to trying a code provided by someone in these forums.
To reiterate, my abs module is from a 2011 Jetta and my cars is a 2009 GTI, But I heard of people having success coding it and it accepting the coding in this scenario.
Any help in generating the code is very much appreciated on my part!
Thanks in advance.
NostraJackAss
Vehicle Identification No.WVWEV71K19W133621
ModelGolf 2,0
GO
Date of production14.10.2008
Model year2009
Sales type1K19W2
Engine CodeCCTA
Transmission CodeKNU
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA <<<<<<<<<<<<<<<<<<<<<<<< FOD check PASS!
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ <<<<<<<<<<<<<<<<<<<<<<<<<<< FOD Check FAIL!
Revision: 00H31001
LEGACY POSSIBILITY
PART NUMBERDESCRIPTIONREMARK
1K0 907 375 ANControl unit for ABS
1K0 614 517 BD
1K0 907 379 AD
1K0 907 379 CD
1K0 907 375 APControl unit for ABS
1K0 614 517 BE
1K0 907 379 AE
1K0 907 375 AE
1K0 614 517 BK
1K0 907 379 AP
[TABLE="class: vinInfoTable, width: 533"]
[TR]
[TH="align: left"]Special editions[/TH]
[TD="class: prCode"]E0A[/TD]
[TD]Without special action equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PC[/TD]
[TD]Wheel bolts with anti-theft protection
(unlockable)[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle class differentiation
units/platform components[/TH]
[TD="class: prCode"]0HA[/TD]
[TD]Vehicle class differentiation -1K0-[/TD]
[/TR]
[TR]
[TH="align: left"]tail pipe[/TH]
[TD="class: prCode"]0P1[/TD]
[TD]Rear side exhaust tailpipe[/TD]
[/TR]
[TR]
[TH="align: left"]drive-off assistance[/TH]
[TD="class: prCode"]UG0[/TD]
[TD]Without hill start assist/hill descent
control/comfort driving assist[/TD]
[/TR]
[TR]
[TH="align: left"]Emission standard[/TH]
[TD="class: prCode"]7GB[/TD]
[TD]Emission standard ULEV 2[/TD]
[/TR]
[TR]
[TH="align: left"]Trailer hitch[/TH]
[TD="class: prCode"]1D0[/TD]
[TD]without trailer towing[/TD]
[/TR]
[TR]
[TH="align: left"]airbag[/TH]
[TD="class: prCode"]4UM[/TD]
[TD]Driver's and front passenger air bag, NAR with front
passenger air bag deactivation (2-stage) -
SMART airbag with automatic deactivation[/TD]
[/TR]
[TR]
[TH="align: left"]Aktivkohlebehälter / Ottopartikelfilter[/TH]
[TD="class: prCode"]1E4[/TD]
[TD]Activated carbon canister (ORVR)
and siphoning device for fueling[/TD]
[/TR]
[TR]
[TH="align: left"]Aerials[/TH]
[TD="class: prCode"]8ZH[/TD]
[TD]Antenna for AM/FM reception, "diversity"[/TD]
[/TR]
[TR]
[TH="align: left"]Exterior mirror setting[/TH]
[TD="class: prCode"]6XN[/TD]
[TD]Exterior mirrors, power-adjustable/
separately heated[/TD]
[/TR]
[TR]
[TH="align: left"]Left exterior mirror[/TH]
[TD="class: prCode"]5SH[/TD]
[TD]Left exterior mirror, flat (US)[/TD]
[/TR]
[TR]
[TH="align: left"]Right exterior mirror[/TH]
[TD="class: prCode"]5RR[/TD]
[TD]Right exterior mirror, convex (US)[/TD]
[/TR]
[TR]
[TH="align: left"]Drive type[/TH]
[TD="class: prCode"]1X0[/TD]
[TD]Front-wheel drive[/TD]
[/TR]
[TR]
[TH="align: left"]"Multimedia"video/DVD/notebook connection[/TH]
[TD="class: prCode"]9WC[/TD]
[TD]Without "Multimedia" in vehicle[/TD]
[/TR]
[TR]
[TH="align: left"]Equipment levels[/TH]
[TD="class: prCode"]A8H[/TD]
[TD]Top sports equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type in rear[/TH]
[TD="class: prCode"]1KV[/TD]
[TD]Disc brakes in rear (Geomet D)[/TD]
[/TR]
[TR]
[TH="align: left"]batteries[/TH]
[TD="class: prCode"]J1L[/TD]
[TD]Battery 280 A (60 Ah)[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type, front[/TH]
[TD="class: prCode"]1LV[/TD]
[TD]Silver caliper[/TD]
[/TR]
[TR]
[TH="align: left"]Components with special surface[/TH]
[TD="class: prCode"]6FF[/TD]
[TD]Exterior mirror housing and various attachments
colour coded to vehicle[/TD]
[/TR]
[TR]
[TH="align: left"]Battery/alternator capacity[/TH]
[TD="class: prCode"]NY0[/TD]
[TD]Standard battery/alternator capacity[/TD]
[/TR]
[TR]
[TH="align: left"]Component part sets with
country-specific design requirements[/TH]
[TD="class: prCode"]B0D[/TD]
[TD]Assembly kit, USA corresponding vehicle
version (not California), various parts[/TD]
[/TR]
[TR]
[TH="align: left"]vehicle tools and jack[/TH]
[TD="class: prCode"]1S1[/TD]
[TD]vehicle tools and jack[/TD]
[/TR]
[TR]
[TH="align: left"]Brake systems[/TH]
[TD="class: prCode"]1AT[/TD]
[TD]Electronic stability control (ESC)[/TD]
[/TR]
[TR]
[TH="align: left"]Owner's manuals[/TH]
[TD="class: prCode"]0VM[/TD]
[TD]Information kit in American English[/TD]
[/TR]
[TR]
[TH="align: left"]Operating voltage[/TH]
[TD="class: prCode"]9Z0[/TD]
[TD]Operating voltage 12 V[/TD]
[/TR]
[TR]
[TH="align: left"]brake wear indicator[/TH]
[TD="class: prCode"]9U1[/TD]
[TD]brake wear indicator[/TD]
[/TR]
[TR]
[TH="align: left"]Heated washer nozzles[/TH]
[TD="class: prCode"]9T1[/TD]
[TD]Heated washer nozzles in front[/TD]
[/TR]
[TR]
[TH="align: left"]CD ROM/DVD/SD card[/TH]
[TD="class: prCode"]7QA[/TD]
[TD]Without CD/DVD for navigation[/TD]
[/TR]
[TR]
[TH="align: left"]CD changer/CD player[/TH]
[TD="class: prCode"]7A9[/TD]
[TD]CD changer preparation (front)[/TD]
[/TR]
[TR]
[TH="align: left"]"Charism"[/TH]
[TD="class: prCode"]2H0[/TD]
[TD]Without "drive select"[/TD]
[/TR]
[TR]
[TH="align: left"]Chrome package[/TH]
[TD="class: prCode"]QJ0[/TD]
[TD]Without aluminum/chrome work package[/TD]
[/TR]
[TR]
[TH="align: left"]General operating permit, alterations[/TH]
[TD="class: prCode"]C24[/TD]
[TD]Operating permit, alteration[/TD]
[/TR]
[TR]
[TH="align: left"]Roof rails/roof load rack[/TH]
[TD="class: prCode"]3S0[/TD]
[TD]Without roof rails/roof load rack[/TD]
[/TR]
[TR]
[TH="align: left"]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FE[/TD]
[TD]Tilting and sliding glass sunroof with
sunbshade[/TD]
[/TR]
[TR]
[TH="align: left"]Suspension system in rear[/TH]
[TD="class: prCode"]1JE[/TD]
[TD]Rear sports shock absorption[/TD]
[/TR]
[TR]
[TH="align: left"]Suspension system in front[/TH]
[TD="class: prCode"]G05[/TD]
[TD]Shock absorption in front[/TD]
[/TR]
[TR]
[TH="align: left"]Load-through hatch/ski bag[/TH]
[TD="class: prCode"]3X0[/TD]
[TD]without load through system[/TD]
[/TR]
[TR]
[TH="align: left"]Insert for the filling up of unleaded
fuel/fuel type[/TH]
[TD="class: prCode"]2G7[/TD]
[TD]Filler neck module 1 with insert[/TD]
[/TR]
[TR]
[TH="align: left"]Installation differentiation for components[/TH]
[TD="class: prCode"]0EN[/TD]
[TD]Installation differentiation for
transmission MQ 350
-- vehicle components --[/TD]
[/TR]
[TR]
[TH="align: left"]Theft protection system[/TH]
[TD="class: prCode"]7AG[/TD]
[TD]Electronic immobilizer
with anti-theft alarm system (for USA)[/TD]
[/TR]
[TR]
[TH="align: left"]Inserts[/TH]
[TD="class: prCode"]5MD[/TD]
[TD]Decorative aluminum inserts[/TD]
[/TR]
[TR]
[TH="align: left"]Scuff plates[/TH]
[TD="class: prCode"]7M6[/TD]
[TD]Protective film for scuff plate[/TD]
[/TR]
[TR]
[TH="align: left"]Park distance control[/TH]
[TD="class: prCode"]7X0[/TD]
[TD]Without park distance control[/TD]
[/TR]
[TR]
[TH="align: left"]Electric interface for external use[/TH]
[TD="class: prCode"]UF1[/TD]
[TD]Electric interface for external use[/TD]
[/TR]
[TR]
[TH="align: left"]Manufacturing sequence differentiation[/TH]
[TD="class: prCode"]0FA[/TD]
[TD]Standard manufacturing sequence[/TD]
[/TR]
[TR]
[TH="align: left"]window regulator[/TH]
[TD="class: prCode"]4R4[/TD]
[TD]Power windows with comfort operation and
circuit breaker[/TD]
[/TR]
[TR]
[TH="align: left"]fire extinguisher[/TH]
[TD="class: prCode"]6A0[/TD]
[TD]without fire extinguisher[/TD]
[/TR]
[TR]
[TH="align: left"]Pedestrian protection[/TH]
[TD="class: prCode"]VL0[/TD]
[TD]Standard pedestrian protection measures[/TD]
[/TR]
[TR]
[TH="align: left"]Pedal cluster[/TH]
[TD="class: prCode"]VF1[/TD]
[TD]pedal cluster[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight activation[/TH]
[TD="class: prCode"]8K4[/TD]
[TD]Separate daytime running lights
NAR[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Alternators[/TH]
[TD="class: prCode"]8GU[/TD]
[TD]Alternator 140 A[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category rear axle[/TH]
[TD="class: prCode"]0YD[/TD]
[TD]Weight range 4
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category front axle[/TH]
[TD="class: prCode"]L95[/TD]
[TD]Suspension range 95
[/TR]
[TR]
[TH="align: left"]Base engine[/TH]
[TD="class: prCode"]TQ2[/TD]
[TD]4-cyl. petrol engine 2.0 l assembly 06J.B[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage netting/pocket on backrest(s)[/TH]
[TD="class: prCode"]4U5[/TD]
[TD]Luggage pockets on backrest[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage compartment cover[/TH]
[TD="class: prCode"]3U1[/TD]
[TD]Folding trunk cover[/TD]
[/TR]
[TR]
[TH="align: left"]cruise control system[/TH]
[TD="class: prCode"]8T2[/TD]
[TD]Electronic cruise control system (CCS)[/TD]
[/TR]
[TR]
[TH="align: left"]Garage door opener[/TH]
[TD="class: prCode"]VC0[/TD]
[TD]without Garage door opener[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage compartment trim[/TH]
[TD="class: prCode"]5A7[/TD]
[TD]Comfort luggage compartment trim with
service lid/snap-on cover[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission specifications[/TH]
[TD="class: prCode"]G0K[/TD]
[TD]6-speed manual transmission[/TD]
[/TR]
[TR]
[TH="align: left"]Brackets[/TH]
[TD="class: prCode"]3P0[/TD]
[TD]Without bracket for first aid kit and
warning triangle[/TD]
[/TR]
[TR]
[TH="align: left"]handle for hand brake lever[/TH]
[TD="class: prCode"]6PC[/TD]
[TD]handbrake lever grip (leather)[/TD]
[/TR]
[TR]
[TH="align: left"]Rear spoiler[/TH]
[TD="class: prCode"]5J4[/TD]
[TD]Body-colored rear spoiler[/TD]
[/TR]
[TR]
[TH="align: left"]Rear window wiper and washer system[/TH]
[TD="class: prCode"]8M1[/TD]
[TD]Rear window wiper washer system with
intermittent wipe[/TD]
[/TR]
[TR]
[TH="align: left"]Rear seats[/TH]
[TD="class: prCode"]3NU[/TD]
[TD]Rear bench seat, not split, split backrest, folding
centre armrest[/TD]
[/TR]
[TR]
[TH="align: left"]Heating and air-conditioning system[/TH]
[TD="class: prCode"]9AP[/TD]
[TD]Climatic air-conditioning system (semi-automatic)[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamps[/TH]
[TD="class: prCode"]8JF[/TD]
[TD]Twin headlamps for driving on the right
(gas discharge) w/ integrated high beam
(US design)[/TD]
[/TR]
[TR]
[TH="align: left"]Customized installation[/TH]
[TD="class: prCode"]FC1[/TD]
[TD]Customized installation[/TD]
[/TR]
[TR]
[TH="align: left"]Interior light in footwell[/TH]
[TD="class: prCode"]6T1[/TD]
[TD]Interior light in footwell[/TD]
[/TR]
[TR]
[TH="align: left"]Instrument clusters[/TH]
[TD="class: prCode"]U5C[/TD]
[TD]Instrument cluster, mph speedometer
- USA -[/TD]
[/TR]
[TR]
[TH="align: left"]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L2[/TD]
[TD]Breakaway interior rearview mirror,
dimming[/TD]
[/TR]
[TR]
[TH="align: left"]Sticker (customized or special edition)[/TH]
[TD="class: prCode"]0KA[/TD]
[TD]Without decals and emblems[/TD]
[/TR]
[TR]
[TH="align: left"]Body style[/TH]
[TD="class: prCode"]K8G[/TD]
[TD]Hatchback[/TD]
[/TR]
[TR]
[TH="align: left"]Cassette and CD storage unit[/TH]
[TD="class: prCode"]4W0[/TD]
[TD]without cassette / CD tray[/TD]
[/TR]
[TR]
[TH="align: left"]coolbox[/TH]
[TD="class: prCode"]1W2[/TD]
[TD]Glove compartment cooling system[/TD]
[/TR]
[TR]
[TH="align: left"]child safety[/TH]
[TD="class: prCode"]4H3[/TD]
[TD]Manual child lock[/TD]
[/TR]
[TR]
[TH="align: left"]Electronic map cooling system[/TH]
[TD="class: prCode"]QS0[/TD]
[TD]Without electronic map cooling system[/TD]
[/TR]
[TR]
[TH="align: left"]Child seats[/TH]
[TD="class: prCode"]QA0[/TD]
[TD]without child seat[/TD]
[/TR]
[TR]
[TH="align: left"]Climatic zones[/TH]
[TD="class: prCode"]0Y3[/TD]
[TD]Cold zones[/TD]
[/TR]
[TR]
[TH="align: left"]Compass/road sign display[/TH]
[TD="class: prCode"]QR1[/TD]
[TD]With compass[/TD]
[/TR]
[TR]
[TH="align: left"]headrest for seat, rear[/TH]
[TD="class: prCode"]3T2[/TD]
[TD]Three rear head restraints[/TD]
[/TR]
[TR]
[TH="align: left"]Head restraints[/TH]
[TD="class: prCode"]5ZF[/TD]
[TD]Front head restraints[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel tank treatment[/TH]
[TD="class: prCode"]2LC[/TD]
[TD]Fuel tank with special material
treatment (coextrusion)[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel quantity for initial filling[/TH]
[TD="class: prCode"]1Z2[/TD]
[TD]Increase in initial standard fuel
filling[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel systems[/TH]
[TD="class: prCode"]1A5[/TD]
[TD]Petrol injector fuel system (FSI)[/TD]
[/TR]
[TR]
[TH="align: left"]Body measures[/TH]
[TD="class: prCode"]5C1[/TD]
[TD]Body measures for increased safety
requirements[/TD]
[/TR]
[TR]
[TH="align: left"]Child seat anchors in front[/TH]
[TD="class: prCode"]3G0[/TD]
[TD]Without child seat anchora in front
(ISOFIX)[/TD]
[/TR]
[TR]
[TH="align: left"]Rear license plate bracket[/TH]
[TD="class: prCode"]6P2[/TD]
[TD]License plate bracket, rear (NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Front license plate bracket[/TH]
[TD="class: prCode"]6W3[/TD]
[TD]License plate bracket front (small, NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Paint preservative/transit coating[/TH]
[TD="class: prCode"]5K0[/TD]
[TD]Without surface protection, with
additional transit coating[/TD]
[/TR]
[TR]
[TH="align: left"]Paint coating[/TH]
[TD="class: prCode"]FB0[/TD]
[TD]standard paint coating[/TD]
[/TR]
[TR]
[TH="align: left"]Rear cargo area[/TH]
[TD="class: prCode"]3GA[/TD]
[TD]Without luggage compartment floor[/TD]
[/TR]
[TR]
[TH="align: left"]Steering system arrangement[/TH]
[TD="class: prCode"]L0L[/TD]
[TD]Left-hand drive[/TD]
[/TR]
[TR]
[TH="align: left"]Reading lamp[/TH]
[TD="class: prCode"]8S4[/TD]
[TD]Two reading lights front, two rear[/TD]
[/TR]
[TR]
[TH="align: left"]steering[/TH]
[TD="class: prCode"]1N3[/TD]
[TD]Speed-related variable steering assist
(Servotronic)[/TD]
[/TR]
[TR]
[TH="align: left"]Backrest release[/TH]
[TD="class: prCode"]3H9[/TD]
[TD]Backrest release for front seats with
Easy Entry feature[/TD]
[/TR]
[TR]
[TH="align: left"]Air duct, front area[/TH]
[TD="class: prCode"]VK1[/TD]
[TD]Air duct, type 1[/TD]
[/TR]
[TR]
[TH="align: left"]Load edge protection[/TH]
[TD="class: prCode"]2P1[/TD]
[TD]Plastic loading edge protection[/TD]
[/TR]
[TR]
[TH="align: left"]Lumbar support[/TH]
[TD="class: prCode"]7P4[/TD]
[TD]Manually adjustable lumbar support in
front seats[/TD]
[/TR]
[TR]
[TH="align: left"]steering wheels[/TH]
[TD="class: prCode"]2FN[/TD]
[TD]Leather-wrapped multi-function steering
wheel with decorative aluminum inserts[/TD]
[/TR]
[TR]
[TH="align: left"]Speaker installation[/TH]
[TD="class: prCode"]8RW[/TD]
[TD]10 speakers (passive)[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight range control[/TH]
[TD="class: prCode"]8Q3[/TD]
[TD]Dynamic headlight range control
(self-adjusting while driving)[/TD]
[/TR]
[TR]
[TH="align: left"]Center armrest[/TH]
[TD="class: prCode"]6E3[/TD]
[TD]Center armrest in front[/TD]
[/TR]
[TR]
[TH="align: left"]Marten repeller[/TH]
[TD="class: prCode"]UM0[/TD]
[TD]Without marten repeller[/TD]
[/TR]
[TR]
[TH="align: left"]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q5[/TD]
[TD]Multi-function display with control[/TD]
[/TR]
[TR]
[TH="align: left"]Engine cooling[/TH]
[TD="class: prCode"]8Z6[/TD]
[TD]Hot country[/TD]
[/TR]
[TR]
[TH="align: left"]Engine specifications[/TH]
[TD="class: prCode"]D2L[/TD]
[TD]4-cylinder petrol engine 2.0 L/147 KW (16 V)
Turbo FSI, homogeneous
Basic engine is: T59/T61/TQ2/TU2/TD6/TN6[/TD]
[/TR]
[TR]
[TH="align: left"]Left vanity mirror[/TH]
[TD="class: prCode"]4SH[/TD]
[TD]Left vanity mirror illuminated with
cover and special mirror imprint (NAR),
extractable[/TD]
[/TR]
[TR]
[TH="align: left"]Right vanity mirror[/TH]
[TD="class: prCode"]4TH[/TD]
[TD]Vanity mirror, right, illuminated, with
extractable[/TD]
[/TR]
[TR]
[TH="align: left"]Navigation device[/TH]
[TD="class: prCode"]7Q0[/TD]
[TD]without navigation system[/TD]
[/TR]
[TR]
[TH="align: left"]rear fog lamp[/TH]
[TD="class: prCode"]8TA[/TD]
[TD]witout rear fog lamp[/TD]
[/TR]
[TR]
[TH="align: left"]Front fog lamp/additional headlamp[/TH]
[TD="class: prCode"]8WD[/TD]
[TD]Integrated front fog light[/TD]
[/TR]
[TR]
[TH="align: left"]Upgrading measures[/TH]
[TD="class: prCode"]GP0[/TD]
[TD]Vehicles w/o special upgrade measures[/TD]
[/TR]
[TR]
[TH="align: left"]Rear of platform module base[/TH]
[TD="class: prCode"]4P0[/TD]
[TD]Rear floor panel module, type 1[/TD]
[/TR]
[TR]
[TH="align: left"]Platform group class[/TH]
[TD="class: prCode"]7PA[/TD]
[TD]Platform group class 1[/TD]
[/TR]
[TR]
[TH="align: left"]Hubcaps[/TH]
[TD="class: prCode"]1NL[/TD]
[TD]Trims for alloy wheels[/TD]
[/TR]
[TR]
[TH="align: left"]Wheels[/TH]
[TD="class: prCode"]CQ4[/TD]
[TD]Alloy wheels 7.5J x 18[/TD]
[/TR]
[TR]
[TH="align: left"]Radios[/TH]
[TD="class: prCode"]8US[/TD]
[TD]Radio "Premium"
(double-size standard radio)[/TD]
[/TR]
[TR]
[TH="align: left"]Smoker's/non-smoker's package[/TH]
[TD="class: prCode"]9JF[/TD]
[TD]Non-smoking package (NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K4[/TD]
[TD]Tire pressure monitoring system 315 MHz
High[/TD]
[/TR]
[TR]
[TH="align: left"]tire[/TH]
[TD="class: prCode"]HX9[/TD]
[TD]All-season tires 225/40 R18 92H xl (NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH="align: left"]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G1[/TD]
[TD]Space-saving spare wheel[/TD]
[/TR]
[TR]
[TH="align: left"]Restraint systems, front[/TH]
[TD="class: prCode"]4QQ[/TD]
[TD]3-point seat belts in front with
pretensioner and height adjustment,
US label[/TD]
[/TR]
[TR]
[TH="align: left"][/TH]
[TD="class: prCode"]PIT[/TD]
[TD]IPod and CD changer preparation[/TD]
[/TR]
[TR]
[TD="class: prCode"]PRW[/TD]
[TD]Wheels package Detroit with HX9[/TD]
[/TR]
[TR]
[TH="align: left"]Side airbag[/TH]
[TD="class: prCode"]4X3[/TD]
[TD]Side airbag in front, with curtain
airbag[/TD]
[/TR]
[TR]
[TH="align: left"]Gearshift knob/handle[/TH]
[TD="class: prCode"]6Q6[/TD]
[TD]Gearshift knob/handle in aluminum[/TD]
[/TR]
[TR]
[TH="align: left"]Special labels/plates[/TH]
[TD="class: prCode"]0SS[/TD]
[TD]Labels in English and French[/TD]
[/TR]
[TR]
[TH="align: left"]Locking mechanism for boot lid/cover
rear[/TH]
[TD="class: prCode"]4E2[/TD]
[TD]Tailgate/trunk lid release
from inside (electrically)[/TD]
[/TR]
[TR]
[TH="align: left"]Front seat, left[/TH]
[TD="class: prCode"]3TG[/TD]
[TD]Sports comfort seat in front, left[/TD]
[/TR]
[TR]
[TH="align: left"]Front seat, right[/TH]
[TD="class: prCode"]3SG[/TD]
[TD]Sports comfort seat, front, right[/TD]
[/TR]
[TR]
[TH="align: left"]Nameplates for sales name[/TH]
[TD="class: prCode"]QD0[/TD]
[TD]Without lettering for sales name[/TD]
[/TR]
[TR]
[TH="align: left"]Seat belt check[/TH]
[TD="class: prCode"]9P7[/TD]
[TD]Visual and acoustic seat belt reminder,
electric contact in buckle[/TD]
[/TR]
[TR]
[TH="align: left"]Outer rear seat belts[/TH]
[TD="class: prCode"]3ZD[/TD]
[TD]3-point seat belts, outer rear with US
label[/TD]
[/TR]
[TR]
[TH="align: left"]Center rear seat belts[/TH]
[TD="class: prCode"]3C8[/TD]
[TD]3-point seat belt, center rear with US
label[/TD]
[/TR]
[TR]
[TH="align: left"]seat covers[/TH]
[TD="class: prCode"]N2K[/TD]
[TD]Seat trim covers in fabric[/TD]
[/TR]
[TR]
[TH="align: left"]Seat adjustment[/TH]
[TD="class: prCode"]3L3[/TD]
[TD]Manual height adjustment for front seats[/TD]
[/TR]
[TR]
[TH="align: left"]seat heater[/TH]
[TD="class: prCode"]4A3[/TD]
[TD]seat heating for front seats separat controlable[/TD]
[/TR]
[TR]
[TH="align: left"]Safety head restraint system[/TH]
[TD="class: prCode"]3K0[/TD]
[TD]w/o safety head restraint system[/TD]
[/TR]
[TR]
[TH="align: left"]Side lights[/TH]
[TD="class: prCode"]7R4[/TD]
[TD]Side marker lamps and turn signal
repeaters (turn signals with white lens)[/TD]
[/TR]
[TR]
[TH="align: left"]Horns[/TH]
[TD="class: prCode"]8Y1[/TD]
[TD]Two-tone horn[/TD]
[/TR]
[TR]
[TH="align: left"]Control number (no PR family)[/TH]
[TD="class: prCode"]S3S[/TD]
[TD]Control (in-plant)[/TD]
[/TR]
[TR]
[TH="align: left"]Side and rear windows[/TH]
[TD="class: prCode"]4KC[/TD]
[TD]Side and rear windows in heat-insulating
glass[/TD]
[/TR]
[TR]
[TH="align: left"]Protective side molding[/TH]
[TD="class: prCode"]4B2[/TD]
[TD]Body-colored protective side molding[/TD]
[/TR]
[TR]
[TH="align: left"]Sunroof roller blind for rear/side windows[/TH]
[TD="class: prCode"]3Y0[/TD]
[TD]without roller blind[/TD]
[/TR]
[TR]
[TH="align: left"]Supertone system and tone sequence
control[/TH]
[TD="class: prCode"]9J0[/TD]
[TD]Without supertone system and tone
sequence control[/TD]
[/TR]
[TR]
[TH="align: left"]power outlet[/TH]
[TD="class: prCode"]7B2[/TD]
[TD]12 volt socket in luggage compartment[/TD]
[/TR]
[TR]
[TH="align: left"]Bumper[/TH]
[TD="class: prCode"]2JG[/TD]
[TD]bumper in color of vehicle[/TD]
[/TR]
[TR]
[TH="align: left"]Rear stabilizer[/TH]
[TD="class: prCode"]0BF[/TD]
[TD]Rear stabilizer[/TD]
[/TR]
[TR]
[TH="align: left"]Front stabilizer bar[/TH]
[TD="class: prCode"]0AE[/TD]
[TD]Front stabilizer bar[/TD]
[/TR]
[TR]
[TH="align: left"]Drawers under front seats[/TH]
[TD="class: prCode"]QN0[/TD]
[TD]Without drawers under front seats[/TD]
[/TR]
[TR]
[TH="align: left"]Heavy-duty/sports version[/TH]
[TD="class: prCode"]2UC[/TD]
[TD]Sports version[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamp washer system[/TH]
[TD="class: prCode"]8X0[/TD]
[TD]Without headlamp washer system[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield wiper intermittent control/
light/rain sensor[/TH]
[TD="class: prCode"]8N4[/TD]
[TD]Windshield wiper intermittent control
with potentiometer (four speeds)[/TD]
[/TR]
[TR]
[TH="align: left"]Special approval measures[/TH]
[TD="class: prCode"]3M0[/TD]
[TD]Without special measures[/TD]
[/TR]
[TR]
[TH="align: left"]Nameplate set[/TH]
[TD="class: prCode"]0NH[/TD]
[TD]Nameplate set "GTI"[/TD]
[/TR]
[TR]
[TH="align: left"]Special alarm systems[/TH]
[TD="class: prCode"]9A0[/TD]
[TD]Without taxi alarm system[/TD]
[/TR]
[TR]
[TH="align: left"]Door storage compartments in front[/TH]
[TD="class: prCode"]3YR[/TD]
[TD]Door pockets with insert mats[/TD]
[/TR]
[TR]
[TH="align: left"]Mass damper for steering wheels[/TH]
[TD="class: prCode"]1Q0[/TD]
[TD]steering wheel without balance weight[/TD]
[/TR]
[TR]
[TH="align: left"]Door and lid locking system[/TH]
[TD="class: prCode"]4K0[/TD]
[TD]Central locking w/ radio remote control
and interior controls[/TD]
[/TR]
[TR]
[TH="align: left"]Type approval countries/countries with
special requirements[/TH]
[TD="class: prCode"]B34[/TD]
[TD]Legal requirements USA[/TD]
[/TR]
[TR]
[TH="align: left"]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D2[/TD]
[TD]Carrier frequency 315 MHz[/TD]
[/TR]
[TR]
[TH="align: left"]Partition[/TH]
[TD="class: prCode"]3CA[/TD]
[TD]without partition[/TD]
[/TR]
[TR]
[TH="align: left"]Door and side trim panels[/TH]
[TD="class: prCode"]4AF[/TD]
[TD]Door and side trim panel in foam film
and woven fabric[/TD]
[/TR]
[TR]
[TH="align: left"]doors[/TH]
[TD="class: prCode"]0A1[/TD]
[TD]2 doors[/TD]
[/TR]
[TR]
[TH="align: left"]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QV8[/TD]
[TD]Satellite radio reception NAR[/TD]
[/TR]
[TR]
[TH="align: left"]Front underbody guard[/TH]
[TD="class: prCode"]1SA[/TD]
[TD]Without additional front underbody guard[/TD]
[/TR]
[TR]
[TH="align: left"]Identification plates[/TH]
[TD="class: prCode"]1EB[/TD]
[TD]without identification plate[/TD]
[/TR]
[TR]
[TH="align: left"]Delivery equipment[/TH]
[TD="class: prCode"]2A8[/TD]
[TD]Delivery equipment, water border[/TD]
[/TR]
[TR]
[TH="align: left"]First aid kit / warning triangle[/TH]
[TD="class: prCode"]1T0[/TD]
[TD]Without first-aid material, without warning triangle[/TD]
[/TR]
[TR]
[TH="align: left"]Two-way radio installation preparation[/TH]
[TD="class: prCode"]9D0[/TD]
[TD]without prepared for two way radio system[/TD]
[/TR]
[TR]
[TH="align: left"]Preparation for rotating beacon/siren
combination[/TH]
[TD="class: prCode"]9F0[/TD]
[TD]Without preparation for rotating
beacon/siren combination[/TD]
[/TR]
[TR]
[TH="align: left"]Telephone / telematics[/TH]
[TD="class: prCode"]9W0[/TD]
[TD]Without car phone preparation/
installation[/TD]
[/TR]
[TR]
[TH="align: left"]Additional warning lights[/TH]
[TD="class: prCode"]9TC[/TD]
[TD]Additional retro-reflectors (door area)[/TD]
[/TR]
[TR]
[TH="align: left"]LongLife Service Regime[/TH]
[TD="class: prCode"]QG0[/TD]
[TD]without service interval extension[/TD]
[/TR]
[TR]
[TH="align: left"]Heat accumulator system/auxiliary heater[/TH]
[TD="class: prCode"]7E0[/TD]
[TD]W/o heat accumulator/auxiliary heating[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield Glass[/TH]
[TD="class: prCode"]4GF[/TD]
[TD]Windshield in heat-insulating glass[/TD]
[/TR]
[TR]
[TH="align: left"]Washer fluid level indicator[/TH]
[TD="class: prCode"]8W1[/TD]
[TD]Washer fluid level indicator[/TD]
[/TR]
[TR]
[TH="align: left"]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH="align: left"]floor mats[/TH]
[TD="class: prCode"]0TD[/TD]
[TD]Front and rear floor mats[/TD]
[/TR]
[TR]
[TH="align: left"]Additional body panels,
side[/TH]
[TD="class: prCode"]6EA[/TD]
[TD]Without additional side body covers
(stone guard)[/TD]
[/TR]
[TR]
[TH="align: left"]Additional child seat anchors[/TH]
[TD="class: prCode"]3B7[/TD]
[TD]Child seat anchors as per Canadian
requirements a. ISOFIX child seat system[/TD]
[/TR]
[TR]
[TH="align: left"]Auxiliary heating system[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[/TABLE]
ThatDude
Chicago, USA
C?ID=370464
Hi Jack, I see that you provided the coding "0403010A18070160". I tried this and it does not work. Are you suggesting that my module is not able to be coded to my car? Are the legacy possibility "remarks" the correct controller that I need to buy in order to be coded? I am quite a novice when it comes to this stuff. I am trying my best to understand so I apologize. If you could give a little more insight I would really appreciate it!
NostraJackAss
That was not a coding to ABS and from your scan provided to verify the config and which is in possible FOD error!
NostraJackAss
Coding: 114B000C092500FD881100E6901A0000000000 FULL STRIP LHD
Coding: 113B600D492500FD881106E6921A0041300000 NETech LHD 312/253 stripped
I don't see any scans on net with a match to this part number.
Scans of the net "base hardware abstract" NOT YOUR CODING OP!
Coding: 113B600D49280003880F06E8921A00413000
Coding: 113B600D492600FC881206E4921E0041B100
Coding: 113B600D49240000880D06E7921900413800
Coding: 113B600D49280000881306ED921D0041B100
ThatDude
Chicago, USA
C?ID=370464
113B600D492500FD881106E6921A0041300000 was accepted . After doing the basic settings for the different sensors everything works flawlessly and no more flashing lights! I appreciate your help in getting the right coding! Thank you Jack and NEtech for getting me the right code.
