ASAM data is missing for 75-Telematic. @ HEX-NET
pjunger
Denmark
C?ID=362297
Have run AutoScan - and gets message "No ASAM data for: "EV_OCULowMQBLGE""
I have ran the update function, there is followed by the AutoScan, and the rerun AUTOSCAN without any changes in results.
AUTOSCAN result, below
#hndoc:?docid=000051DA&xt=hnh:FAB7642319CA5EA494C52C2C5C14534C915AD630055AE399CA564D7CC8A1FFAA
VCDS Mobile 0.4508.0.4
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 23 29 2B 39 3C 42 44
	 4B 51 52 5F 69 75 8C A5 A9 C0 C6 D6 D7
C0-Act. For Ext. Noise -- Status: OK 0000
Address 01: Engine  (CUKB J623)	Labels: 04-01.clb
	Part No SW: 04E 906 023 BN	HW: 04E 907 309 F
	Component: 1.4l TFSI hy  H22 4518
	Revision: X3H22---
	Coding: 011D001A647405083008
	ASAM Dataset: EV_ECM14TFS01104E906023BN 008006
	ROD: EV_ECM14TFS01104E906023BN.rod
	VCID: 6D9D5AB76EDF7617F0542E-8038
No fault codes found.
Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
	Part No SW: 0DD 300 046 F	HW: 0DD 927 770 C
	Component: GSG DQ400E    H32 1601
	Revision: 00032056
	ROD: EV_TCMDQ400021.rod
	VCID: 2B1994AF904BB827AEA040-807E
Address 03: ABS Brakes  (J104)	Labels: 5Q-03.clb
	Part No SW: 5Q0 614 517 DB	HW: 5Q0 614 517 AH
	Component: ESC           H62 0856
	Revision: 00000000
	Coding: 01FA40A138202175477C060561CB2980021C84E26086947338B15078C2A203
	ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
	ROD: EV_Brake1UDSContiMK100OMG_003_VW37.rod
	VCID: 74AB4FD30DF5A7DF3F9A63-8021
Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
	Part No SW: 5Q0 959 435 C	HW: 5Q0 959 435
	Component: VWKESSYMQB    021 0803
	Revision: 00021000
	Coding: 032C0C
	VCID: 3C3BA7F365252F9F374A0B-8069
Address 08: Auto HVAC  (J255)	Labels: 5G0-907-044.clb
	Part No SW: 5GE 907 044 AP	HW: 5GE 907 044 AP
	Component: Climatronic   H04 1702
	Revision: 00001K01
	Coding: 0002101420011101050500000010102A
	VCID: 8A57B12BFF71412FF5766D-80DF
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 - 	Part No SW: 3Q0-963-231-E
	Serial Number: -00101.1V.2A20370068
	Subsystem 4 -
	Subsystem 5 - 	Component: H02
Address 09: Cent. Elect.  (J519)	Labels: 5Q0-937-08X-V2.clb
	Part No SW: 5Q0 937 084 CP	HW: 5Q0 937 084 CF
	Component: BCM MQBAB M+  H36 0253
	ROD: EV_BCMMQB_018.rod
	VCID: 88538B23E17D333FE34247-80DD
	Subsystem 1 - 	Part No SW: 5G1-955-119-A	Labels: 5Qx-955-119-V1.clb
	Component: WWS    180223043 0551
	Serial Number:         180303100911
	Subsystem 2 - 	Part No SW: 5Q0-955-547-B	Labels: 5Q0-955-547.clb
	Component: RLHS         047 0105
	Serial Number: S9Y18M03D20H05M18S45
	Coding: 00A8DD
	Subsystem 3 - 	Part No SW: 5Q0-951-172
	Serial Number: 000000000ZY1804418TT
	Subsystem 4 - 	Part No SW: 5Q0-951-605-A
	Serial Number: 00000000000026205291
	Subsystem 5 - 	Part No SW: 8V3-959-591-A
	Component: J245 PS73.404H04 0005
	Serial Number: 0000FST001ZV17300000
	Coding: 181801
204546 - Remote key 2
	B147A 18 [009] - Current Too Low
Address 10: Park/Steer Assist  (J791)	Labels: 5Q0-919-298.clb
	Part No SW: 5QA 919 298 C	HW: 5QA 919 298 A
	Component: PLA 3.0 12K
	Coding: 1271167951
	ASAM Dataset: EV_EPHVA2CAU3700000 009037
	VCID: 50E3E343D9ADBBFFFB32EF-8005
Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
	Part No SW: 5Q0 907 572 H	HW: 5Q0 907 572 H
	Coding: 550067C95DFFC728949C810580400600000000000000000000
	ROD: EV_ACCBOSCHVW416_002.rod
Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
	Part No SW: 5Q0 959 655 S	HW: 5Q0 959 655 S
	Component: AirbagVW20    010 0870
	Coding: 98CCC000002000005C0000CF004800000065
	Subsystem 1 - 	Part No SW: --------------
	Component: SideSensor_Df001 0887
	Serial Number: 35700000000937381D2I
	Subsystem 2 - 	Part No SW: --------------
	Component: SideSensor_Pf001 0887
	Serial Number: 35800000000D5165BC2S
	Subsystem 3 - 	Part No SW: --------------
	Component: SideSensor_Dr000 6149
	Serial Number: 3510001C5294859281E3
	Subsystem 4 - 	Part No SW: --------------
	Component: SideSensor_Pr000 6149
	Serial Number: 3520001BD298CB02F53G
Address 16: Steering wheel  (J527)	Labels: 5Q-16.lbl
	Part No SW: 5Q0 953 507 HN	HW: 5Q0 953 549 E
	Revision: --------
	Coding: 0C10
	ROD: EV_SMLSKLOMQB_VW37.rod
	VCID: 89558E27FA774A37FC4C7A-80DC
Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
	Part No SW: 5G1 920 794 A	HW: 5G1 920 794 A
	Component: KOMBI         408 3195
	Coding: 07AC7B186FCC000801886B1B5701000080000000
	VCID: 2D1D9AB7AE5FB617B0D46E-8078
Address 18: Aux. Heat  (J364)	Labels: 5Q0-963-272.clb
	Part No SW: 5Q0 963 272 K	HW: 5Q0 963 272 K
	Component: STH-MQB       008 0080
	Coding: 13C1
	VCID: 3E3FADFB73393D8F197E31-806B
Address 19: CAN Gateway  (J533)	Labels: 3Q0-907-530-V1.clb
	Part No SW: 3Q0 907 530 M	HW: 3Q0 907 530 D
	Component: GW MQB EV     618 6322
	Coding: 020100176EF11000FB00527A5C1D00000001070100010000000300000000
	ROD: EV_GatewNF_VW48.rod
	VCID: 3935BEE76A171AB72C2CEA-806C
	Subsystem 1 - 	Part No SW: 5G0-959-442-N	Labels: 3C8-959-537.clb
	Component: E221__MFL-DC1H11 0040
	Serial Number: 29180000171590088042
	Coding: 2DFFFF
	Subsystem 2 - 	Part No SW: 5QE-915-181-A
	Component: J367-BDMHellaH10 9070
	Serial Number: 7729216704
8531970 - Quiescent Current
	U1406 00 [008] - Too High
Address 23: Brake Booster  (J539)	Labels: None
	Part No SW: 5QE 909 059 G	HW: 5QE 909 059 B
	Component: EBKV          H14 0211
	Coding: 02720100331900000002060500
	ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
	ROD: EV_BrakeBoostBoschMQBOMG_004.rod
	VCID: 52E7E94BD7A1C9EFCD2615-8007
Address 29: Left Light  (J1018)	Labels: 8V0-907-399.clb
	Part No SW: 8V0 907 399 D	HW: 8V0 907 399 D
	Component: LCM_MLBevo
	Shop #: WSC 00000 000
	ROD: EV_LCMLeftHELLAAU736_AU37.rod
	VCID: 47D1C81F2CE37C47AAD88C-8012
Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
	Part No SW: 5Q0 905 861 A	HW: 5Q0 905 861 A
	Revision: 00000000
	Coding: 7900000000000000
	ROD: EV_ELVMarquMQB_004.rod
	VCID: 342B8FD34D75E7DFFF1AA3-8061
Address 39: Right Light  (J1023)	Labels: 8V0-907-399.clb
	ROD: EV_LCMRightHELLAAU736_AU37.rod
Address 3C: Lane Change  (J1086)	Labels: 5Q0-907-686.clb
	Part No SW: 5Q0 907 686 C	HW: 5Q0 907 686 C
	Component: HRE_Master    H12 0080
	Coding: 02012103
	ROD: EV_HREntryHella.rod
	VCID: 3D3DAAF77E3F269700743E-8068
Address 42: Door Elect, Driver  (J386)	Labels: 5QX-959-X93-42.clb
	Part No SW: 5Q0 959 593 E	HW: 5Q0 959 593 B
	Coding: 003F1620D000040000001000
	ROD: EV_DCUDriveSideEWMAXKLO.rod
	VCID: 43C9DC0F18DB506776B078-8016
Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
	Part No SW: 5Q0 909 144 AA	HW: 5Q0 909 144 AA
	Component: EPS_MQB_ZFLS  131 1081
	Coding: D30A0000
	ROD: EV_SteerAssisMQB_015.rod
	VCID: 73A94CCF08FBA0E7269068-8026
Address 4B: Multifunc. Module  (J745)	Labels: None
	Part No SW: 3Q0 907 338	HW: 3Q0 907 338
	Coding: 000000050100164A00604F01020000000000000000000000000000000000
	VCID: F2A7C9CBF7E129EFAD66F5-80A7
Address 51: Electric Drive  (J841)	Labels: None
	Part No SW: 5G0 907 080 E	HW: 5G0 907 080 E
	Component: LE Gen 3.3
	Revision: 00H15000
	Coding: C0020000000000000000
	ASAM Dataset: EV_DMCM08530115G0907080E 001008
	ROD: EV_DMCM08530115G0907080E.rod
	VCID: 29156EA79AB7AA375C8C5A-807C
Address 52: Door Elect, Pass.  (J387)	Labels: 5QX-959-X92-52.clb
	Part No SW: 5Q0 959 592 E	HW: 5Q0 959 592 B
	Coding: 003F1020DE00040000801000
	ROD: EV_DCUPasseSideEWMAXKLO.rod
	VCID: 42C7D90B07C1596F7D8645-8017
Address 5F: Information Electr.  (J794)	Labels: 5N-5f.clb
	Part No SW: 5NA 035 043 B	HW: 5NA 035 043
	Component: MU-H-N-EU     H54 1161
	Coding: 02731001FF0000004111000100080A231F0109F4012004009E
	ROD: N/A
	VCID: 352DB2D7460FFED7C804D6-8060
	No ASAM data for: "EV_MUHig4CGen2HBAS"
	Subsystem 1 - 	Part No SW: 5G6-919-606
	Component: ABT_High-2   H52 9130
	Serial Number: VWZ6ZJW0841290
	Subsystem 2 - 	Part No SW: V03-959-806-FM
	Component: ECE 2019/2020--- 0177
	Serial Number: --------------------
	Subsystem 3 - 	Part No SW: V03-959-800-EG
	Component: Gracenote2   --- 1016
003077 - ROD - Unknown faultcode
Address 69: Trailer  (J345)	Labels: 5Q0-907-383.clb
	Part No SW: 5Q0 907 383 M	HW: 5Q0 907 383 M
	Component: Anhaenger     H27 0260
	Revision: 8B001004
	Coding: 0100000202000000
	VCID: 41C5D60702C74277649C52-8014
136203 - Supply Voltage
	P1757 00 [009] - Open Circuit
Address 75: Telematics  (J949)	Labels: 5QE-035-285.clb
	Part No SW: 5NA 035 284 B	HW: 5NA 035 284 B
	Component: OCULowMQBLGE  H17 0718
	Revision: --------
	Coding: 02739001EA42B80D3FFCBE000045400382E708
	ASAM Dataset: EV_OCULowMQBLGE 004044
	ROD: N/A
Address 8C: Hybrid Battery  (J840)	Labels: None
	Part No SW: 5Q0 915 182 D	HW: 5Q0 915 182 C
	Component: BECM          H05 0921
	Coding: 00000000
	ASAM Dataset: EV_BECM09620115Q0915182 006041
	ROD: EV_BECM09620115Q0915182.rod
	Subsystem 1 - 	Part No SW: 5Q0-915-250-E
	Component: BJBH28 0240
	Subsystem 2 - 	Part No SW: 5QE-915-591-K
	Component: 6D1          H14 0481
	Serial Number: V013C17C2131058
	Subsystem 3 - 	Part No SW: 5QE-915-591-K
	Component: 6D2          H14 0481
	Serial Number: V013C17C2131057
	Subsystem 4 - 	Part No SW: 5QE-915-591-K
	Component: 6D3          H14 0481
	Serial Number: V013C17C2131069
	Subsystem 5 - 	Part No SW: 5QE-915-591-K
	Component: 6D4          H14 0481
	Serial Number: V013C17C2131070
	Subsystem 6 - 	Part No SW: 5QE-915-591-K
	Component: 6D5          H14 0481
	Serial Number: V013C17C2131072
	Subsystem 7 - 	Part No SW: 5QE-915-591-K
	Component: 6D6          H14 0481
	Serial Number: V013C17C2131071
	Subsystem 8 - 	Part No SW: 5QE-915-591-K
	Component: 6D7          H14 0481
	Serial Number: V013C17C2131073
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 3Q0-980-65X-A5.clb
	Part No SW: 3Q0 980 654 H	HW: 3Q0 980 654 A
	Component: MQB_B_MFK     H09 0272
	Coding: 000307000000040100222355C150A90098000E300040
	Shop #: WSC 16072 002 1048576
	ROD: EV_MFKBoschMQBB_VW48.rod
Address A9: Struct. Borne Sound  (J869)	Labels: 5G-a9.lbl
	Part No SW: 5G0 907 159 C	HW: 4H0 907 159 A
	Component: SAS-GEN 2     H07 0017
	VCID: 2E1F9DBBA359CD0F89DE61-807B
Address C0: Act. For Ext. Noise  (----)	Labels: 5QE-035-335.clb
	Part No SW: 5QE 035 335 M	HW: 5QE 035 335 B
	Component: E_SOUND_SG    H10 0223
	Coding: 90
	ASAM Dataset: EV_ENoiseS1NNVW3707 007015
	ROD: EV_ENoiseS1NNVW3707_007.rod
	VCID: 4BD9F42F308B98278EE0A0-801E
Address C6: Batt. Chrg.  (J1050)	Labels: None
	Part No SW: 5QE 915 682 AF	HW: 5QE 915 682 AF
	Component: OBC KOSTAL    H40 4013
	Revision: --------
	Coding: 115068222000
	ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
	ROD: EV_OBCSinglPhaseKLOMQB12P.rod
	VCID: 9165A647922772F734BCA2-80C4
Address D6: Light Ctrl Left 2  (A31)	Labels: None
	Part No SW: 7P5 941 572 A	HW: 7P5 941 572 A
	Component: LED1L         H06 0002
	ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
	ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Address D7: Light Ctrl Right 2  (A27)	Labels: None
	Component: LED1R         H06 0002
	ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
	ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End--(Elapsed Time: 03:35, VBatt start/end: 14.6/14.6 Vign: 0.0)-
Mari
C?ID=150535
During update-procedure files have to be collected and downloaden to HEX-Net, if you don't see this happen, a new autoscan will be no different because there is still no file present! You are also missing the file for 5F.
It's probably best to descibe step by step what you did and what happened or not happened!
I can tell you I had no succes with downloading updates using VCDS-mobile, I did it by using a PC and the config/update tool provided with VCDS
Moving to HEX-NET Support.
Shaun
I've switched your interface to the alpha channel, where there is a new update. Please download that update and then try again, and see it helps.
Jeromeo
Australia
C?ID=335683
I always have same the issue if I use iPad then I have to connect through AP network (don’t have wifi network), I can connect to dongle and do a scan. But because I cannot connect to the net. I got the message “No ASAM in AP mode do you want to continue”
What am I missing?
Thanks.
I don’t know how to post screen shot from my device to explain better what I’m talking about.
What am I missing?
Thanks.
If you have no WiFi network, after you do an Auto-Scan, you'll have to connect your HEX-NET to a PC and update it using the VCIConfig utility.
Mari
C?ID=150535
... does you phone have internet when there is no Wi-Fi present? If so, use your phone as hotspot, connect both Hex-Net and iPad to your phone... problem solved (99%)... in 1% of the cases you still need a PC to update your Hex-Net because update couldn't be downloaded by VCDS-Mobile...
Jeromeo
Australia
C?ID=335683
Ok thanks it make sense but it's not really practical. Need 2 different devices to do mobile tests. Or wait to go home and plug in pc for the results.
