Audi A6-Level sensor broken
stondula
India
C?ID=334075
Below is my car's scan result. It is a RHD, and issue is front-right level sensor (threading is broken) i.e. threading end that connects to wheel side.
Can someone help with the front-right level sensor part number please? Since the sensor is working fine I would like to see if I could get one in open market here.
Thursday,25,July,2019,23:09:46:11426
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZED4G3DY002451
Mileage: 56024km-34811mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 28 34 36 3B 42 44 46 52
          53 55 5F 62 72 8F 90
VIN: WAUZED4G3DY002451   Mileage: 56024km-34811miles
Address 01: Engine (J623-CMGB)       Labels: None
   Part No SW: 03L 906 018 LC    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9979
   Revision: 45H25---
   Coding: 0A034012242400080000
   Shop #: WSC 64639 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018LC 003013
   ROD: EV_ECM20TDI01103L906018LC.rod
   VCID: F6A091D049EB1FFF33-80A2
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 4G2 927 155 D    HW: 0AW 927 156 K
   Component: 0AW 20TDI RdW H05 0001
   Revision: --H05---    Serial number: 0000000169
   Shop #: WSC 90001 790 00000
   ASAM Dataset: EV_TCMVL381 A02432
   ROD: EV_TCMVL381.rod
   VCID: AE1079B0F13B673FBB-80FA
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 06A147016085E280DB00
   Shop #: WSC 90001 000 00000
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: B62051D0096B5FFFF3-80E2
0706 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [SCL_FA_Niveau_Druck_VL_Error]
                    Reset counter: 3
                    Mileage: 55921 km
                    Date: 2019.07.24
                    Time: 21:31:24
                    VzRef: 27
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 16
                    Uz: B1
0708 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [SCL_FA_Niveau_Druck_VR_Error]
                    Reset counter: 3
                    Mileage: 55921 km
                    Date: 2019.07.24
                    Time: 21:31:20
                    VzRef: 23
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 18
                    Uz: B1
   Part No SW: 4H0 907 064 CT    HW: 4H0 907 064 CT
   Component: BCM2 2.0      H33 0433
   Coding: 01983046000000000000
   VCID: FDB28EFC64DD4CA772-80A8
   Part No SW: 4G0 820 043 AD    HW: 4G0 820 043 AD
   Component: KLIMA 4 ZONEN H13 0086
   Serial number: 06031300041557
   Coding: 3421607889
   ASAM Dataset: EV_AirCondiComfoUDS 002040
   VCID: E18AD28CF065884776-80B4
   Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
   Revision: 19012002    Serial number: 00000001521633
   Coding: 2600201040349FE08981008080001D0CCF9DC30823090201000008606101
   VCID: ED92BEBC34BDDC27C2-80B8
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 130303  H36 0080
   Serial number:         130309102841
   Coding: 0045F7
   Serial number: 21024995
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
   Component: E1 - LDS  H07 0044
   Serial number: 24 02 2013  00000034
   Serial number: B8080996000000000001
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 C    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0490
   Revision: 00000008
   VCID: AD127EBCF43D1C2782-80F8
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061306001500
   Coding: 08C105
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: F1AAA2CC208538C7E6-80A4
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00CBJ71
   Coding: 30323436313230303232554A305234473053
   Serial number: 3575HRB400K50EV4GPE-
   Serial number: 3585HRB40531S1NK68AD
   Serial number: 3515JRB400E50CTSPGMB
   Serial number: 3525JRB400E50CTSC8HT
   Serial number: 3554VRB40084UON8CP3C
   Serial number: 3564VRB40084UON8H9GF
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20130208000697
   Coding: 000034
   VCID: B02C67C8E30F71CFA9-80E4
   Subsystem 1 - Part No SW: 4G0 951 528 E    HW: 4G0 951 528 E
   Component: E221 - MFL  H09 0010
   Part No SW: 4G8 920 932 D    HW: 4G8 920 932 D
   Component: TDieRdw       H79 0515
   Revision: 28460208    Serial number: 658040313596006
   Coding: 33A609001B410008010000
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: B02C67C8EB0F71CFA9-80E4
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000844933
   Coding: 00C1034400
   ASAM Dataset: EV_GatewPkoUDS 001018
   Serial number: 3864680103
   Part No SW: 4G0 919 158 J    HW: 4G0 919 158 J
   Component: KLIMA FOND    H07 0086
   Serial number: 22021300041481
   Coding: 22
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
0027 - Motor for Rear Left Upper Body Vent
          B10D3 07 [008] - Mechanical Failure
                    Reset counter: 246
                    Mileage: 55068 km
                    Date: 2019.06.29
                    Time: 16:37:01
                    Voltage terminal 30: 13.29 V
                    Outside air temperature: 26.5 °C
                    Left Rear Upper Body Vent Motor-Act.val.: 9998
                    Left Rear Upper Body Vent Motor-Specified value: 11335
                    Left Rear Upper Body Vent Motor-Stop open: 11406
                    Left Rear Upper Body Vent Motor-Stop closed: 10000
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008000
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
455689 - Sensor for Ride-Height
          C1048 07 [009] - Mechanical Failure
                    Reset counter: 218
                    Mileage: 56017 km
                    Date: 2019.07.25
                    Time: 11:57:11
455690 - Sensor for Ride-Height
          C1048 07 [008] - Mechanical Failure
                    Reset counter: 3
                    Mileage: 56018 km
                    Date: 2019.07.25
                    Time: 11:57:19
677389 - Ride-Height System; Plausibility Error
          C1046 00 [008] - -
                    Reset counter: 3
                    Mileage: 55921 km
                    Date: 2019.07.24
                    Time: 21:30:56
455693 - Sensor for Ride-Height
                    Reset counter: 3
                    Mileage: 55959 km
                    Date: 2019.07.24
                    Time: 23:05:28
          C10C8 00 [008] - -
                    Reset counter: 3
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000053833662
   Coding: 0078130000002001000001010101102030303232203232
   VCID: F7BE9CD446E166F728-80A2
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H02 0056
   Revision: --------    Serial number: EJ1BPA8202TW7V
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Component: TSG FA        H03 0507
   Coding: 011F16005E01628002080002
   VCID: C7DE2C147681D67798-8092
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0027303374
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: B2286DC0E50343DFDF-80E6
   Revision: 00002001    Serial number: 0303515700
   Coding: 011A062000B901848020080002010E0F0000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO2051692%
   Coding: 901F00
01512 - Control Module for Sliding Roof
                    Fault Status: 01100101
                    Reset counter: 180
                    Mileage: 55133 km
                    Date: 2019.07.02
                    Time: 19:00:11
   Component: TSG BF        H03 0507
   VCID: C6C02110718BCF7F63-8092
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000617643
   ROD: EV_ParkiBrake_VW51.rod
   VCID: AB1670A4C22912179C-80FE
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 130314-0002-017
   Coding: 11215F101000A200
   ROD: EV_HeadlRegulBasic.rod
   VCID: AD127EBCFC3D1C2782-80F8
   Part No SW: 4G0 035 182 L    HW: 4G0 035 182 J
   Component: RMC Cnct Plus H54 0801
   Coding: 0101000001E1DB47482B060303010000000000
   VCID: AA1875A0C5D30B1F67-80FE
   Subsystem 1 - Part No SW: 4G0 919 603 A    HW: 4G0 919 603 A
   Component: DU6 Basic  H43 0084
   Serial number: 9464B60D2576889
   Subsystem 2 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
   Component: E380 BDT C7  H11 0204
   Serial number: 90349MC70018Z
   Component: TSG HL        H03 0507
   Coding: 010F14004001628002080002
   VCID: C9DA2A2C609520078E-809C
   Component: TSG HR        H03 0507
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: B12A62CCE00578C7A6-80E4
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:20, VBatt start/end: 12.3V/12.3V)-----------
Address 34: DTCs cleared
Address 03: DTCs cleared
Address 28: DTCs cleared
DrPeter
16.4905° S, 151.7375° W
- Have you look on the part itself? Should be a number that begins with [4G0] [ or [4H0] and is 9 or 10 characters long.
If you can not see the number, there is a website called Parts Link 24 . This is where you can enter in your VIN number and find the exact parts you are looking for, its does require a payment for access, looks like $10(US) a day or $30(US) for a month. Or just call the dealership and ask for the part number, some will give it to you.
Hope this helps,
drpeter
