- May 24, 2018
- 37
- 8
- Czech Republic
- C?ID=337474
Hi guys, I have areview unit. But I wonder I have NO active adp maps to be able to change it - error: channel unavailable". I have already seen more such 6C units with this problem. The problem lasts even if I put security code. Any idea WHY?
Thursday,25,July,2019,18:57:28:32726
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Dealer/Shop Name: LF
Workshop Code: 444 00000 000000
VIN: WVWZZZyyyy407265 License Plate:
Mileage: 201143km-124984mi Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 52 55 5F
69 6C A5 CA CF
VIN: WVWZZZ3CZFP407265 Mileage: 201143km-124984miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 ET HW: 04L 907 309 R
Component: R4 2.0l TDI X21 1990
Revision: B5X21---
Coding: 011D001A04741D083000
Shop #: WSC 10000 444 00002
ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
ROD: EV_ECM20TDI01104L906026ES_002_VW48.rod
VCID: 005870D10A84FE67CA9-8054
Part No SW: 0D9 300 041 A HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4802
Revision: 05853104 Serial number: TFK01411260629
Shop #: WSC 00028 028 00024
ROD: EV_TCMDQ250021.rod
VCID: 16743689780060D7005-8042
Part No SW: 3Q0 907 379 H HW: 3Q0 907 379 H
Component: ESC H34 0906
Revision: 00000000 Serial number: 42904000000356
Coding: 0FEC6A8F34200B730779060641C849F0562CD0E0608292F1B962F078CAA9
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034001
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 3FDAB32D37FA419FF33-806A
Part No SW: 3Q0 959 435 HW: 3Q0 959 435
Component: VWKESSYMQB 023 0522
Revision: 00023000 Serial number: 0355060936
Coding: 000F0F0703
ASAM Dataset: EV_KessyHellaMQBAB 004027
ROD: EV_KessyHellaMQBAB_VW48.rod
VCID: 77AA1B0D5F4AB9DFFB3-8022
Part No SW: 5G0 907 044 CQ HW: 5G0 907 044 CQ
Component: Climatronic H04 1801
Revision: 00001K10
Coding: 12020124604101012115505001100402
Shop #: WSC 07790 995 07790
VCID: 78A818315254B6A7F29-802C
Air quality sensor:
Part No SW: 5Q0 937 086 BD HW: 5Q0 937 086 BD
Component: BCM PQ37BOSCH 028 0146
Revision: -------- Serial number: 86580112141660
Coding: 00971E46C2410AFF4BE44004201407081C80000000000000000000000000
ROD: EV_BCMBOSCH_014.rod
VCID: 7DA609257D76938FA1F-8028
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 141124 042 0607
Serial number: 141201070426
Coding: 1F4DFD
Component: RLHS 037 0059
Serial number: S4Y14M12D11H14M52S31
Coding: 06A8DD
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 17 10 2014 00001092
Sun Roof:
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000308417617164
Coding: 0C71257911
Shop #: WSC 12781 001 104857
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000.rod
VCID: 50F880919A64CEE71A9-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 A
Component: ACC BOSCH MQB H04 0196
Coding: B21F7F795DFFFF28949C8065
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3536D10505C68BCF29F-8060
Part No SW: 3Q0 959 655 AE HW: 3Q0 959 655 AE
Component: Airbag VW20 012 0195
Revision: -------- Serial number: 003R1PP7RFCD
Coding: 98FCC0C0008000005C5400CC000800000065
Shop #: WSC 00028 028 00012
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 015E75D5018EF76FC57-8054
Belt Pretensioner left:
Component: BeltPretRevFL 105 1032
Serial number: 3G1857705E0328O00083
Coding: 80000A
Belt Pretensioner right:
Component: BeltPretRevFR 105 1032
Serial number: 3G1857706E0328O00396
Coding: 80000A
Subsystem 3 - Part No SW: ----------- HW: 454 000 112 14
Serial number: 3576U0000001B4691210
Subsystem 4 - Part No SW: ----------- HW: 454 000 112 14
Serial number: 3586U000000FA391C11I
Subsystem 5 - Part No SW: ----------- HW: 454 800 312 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R73374B05000000$
Subsystem 6 - Part No SW: ----------- HW: 454 800 312 14
Component: SideSensor_Pr 111 0148
Serial number: 3526R5F224B050000001
Subsystem 7 - Part No SW: ----------- HW: 454 800 112 14
Component: FrontSensor_D 114 0149
Serial number: 3556V14FC3F05000000J
Part No SW: 3Q0 953 521 R HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20141127500777
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 3G0 920 751 HW: 3G0 920 751
Component: KOMBI 308 4311
Coding: 0BB512186F8C000808897E2B7003000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009043
VCID: 629C5A59E4C84C77BCD-8036
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 C HW: 5Q0 963 272 C
Component: STH-MQB 006 0069
Coding: 9309
ASAM Dataset: EV_AuxilParkiHeateWOS 002014
VCID: 3634D60918C080D7205-8062
Subsystem 1 - Part No SW: 5Q0 963 513 HW: 5Q0 963 513
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001027933
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 29111410800846
Coding: 0B0300345F017300FB00025E1C0F00010001070000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: 72BC2A193428DCF7CCD-8026
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0040
Serial number: 27140003062100094494
Coding: 2DFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 7498745203
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: WECHSELRICHTE H54 0033
Serial number: 0015860
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 0212201400010310
U1101 00 [009] - Active
Reset counter: 126
Mileage: 201143 km
Date: 2019.07.25
Time: 18:53:53
Supply voltage: Terminal 30: 12.1 V
Terminal 15: On
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 14000249651010
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BE2515312EE7EF357-8024
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 E HW: 3Q0 907 566
Component: MRR1Rear H16 0510
Revision: --------
Coding: 16C000
VCID: 3A2CC2392CD864B7C4D-806E
Part No SW: 5Q4 959 593 D HW: 5Q4 959 593 B
Component: TSG FS 009 0016
Serial number: 0000127482581
Coding: 00370B205800028000801000
VCID: 46D4A6C968201057B05-8012
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000000535055
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 203 2051
Revision: 00000000 Serial number: 0000092408
Coding: 01010111005010
ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
VCID: 40D8B0D14A043E678A9-8014
Part No SW: 5Q4 959 592 C HW: 5Q4 959 592 B
Component: TSG BFS 009 0015
Serial number: 0000128541534
Coding: 00350B205C00028000801000
Shop #: WSC 44444 010 00001
VCID: 44D0BCC15E1C2247AE1-8010
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000000555770
Coding: 090000
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 039A01004F210200
ROD: EV_HeadlRegulAFSMQBMLB.rod
Subsystem 1 - Part No SW: 7PP 941 572 A HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 0001
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 A HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 0001
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Part No SW: 5Q0 907 383 D HW: 5Q0 907 383 D
Component: Anhaenger H14 0137
Revision: 8A001001 Serial number: 0354678309
Coding: 0101010202020000
VCID: 3828D83112D476A7329-806C
Part No SW: 5Q0 907 556 HW: 5Q0 907 556
Component: Areaview 2 H11 0329
Serial number: C854706JG001895
Coding: 01840201E30F210000204814
Shop #: WSC 05311 115 00067
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003013
ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
VCID: 76B416095840C0D7E05-8022
Part No SW: 3Q0 980 653 F HW: 3Q0 980 653
Component: MQB_B_MFK H08 0171
Serial number: 26111411P10378
Coding: 01040802050004010022235FC14AA100DB00B0300140
VCID: 392EDD3529DE6FAFCD7-806C
Part No SW: 4M0 907 594 B HW: 4M0 907 594
Component: SAD_STG_1 009 0002
Coding: 208040748202
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 E HW: 3Q0 907 590
Revision: --------
Coding: 16C000
VCID: 372ADB0D1FCA79DF3B3-8062
End----------(Elapsed Time: 02:23, VBatt start/end: 12.2V/12.2V)-----------
