18 GTI EPC light after manual swap
   #21
racofuy
New Zealand
C?ID=197081
Try:
01FA93A13424217547800607E0CAA980C92C84E26007957734405038C2A9430B00000012121212B835351919323200
Doesn't like it unfortunately, I get
coding rejected
error 13
incorrect message length or invalid format
   #22
NEtech
Denmark
C?ID=56995
Doesn't like it unfortunately, I get coding rejected error 13, incorrect message length or invalid format
Exactly, because the length of the first Coding I posted, should be correct.
Cleared the login attempts and code S12345 now works.
When pasting the new long code and entering "do it" I get error message
Long code must be same length or have same number of hexdecimal characters.
What error message is that, please post a screen shot.
   #23
racofuy
New Zealand
C?ID=197081
Ok just tried your original code again and for what ever reason accepts it now but doesn't seem to "stick"
Took shots as I went through the process
[/IMG]
[/IMG]
[/IMG]
Then click ok,
close controller - go back. switch off and wait.
Turn on ign and re scan
[/IMG]
NEtech
Denmark
C?ID=56995
It looks changed to me, make a new Autoscan and post it.
racofuy
New Zealand
C?ID=197081
Ok so I did autoscan, cleared and re scan.
Results below,
Tuesday,06,August,2019,07:46:14:41053
VCDS Version: 19.6.1.0 (x64)
Workshop Code: 666 12345 054321
VIN: WVWZZZAUZJW149977   License Plate:
Mileage: 110km-68mi   Repair Order:
Chassis Type  AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 4B 52 5F A5 A9
VIN: WVWZZZAUZJW149977   Mileage: 110km-68miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 C    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091900322444050B2000
   Shop #: WSC 12345 666 54321
   ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
   ROD: EV_ECM20TFS0205G0906259C.rod
   VCID: 2E53F94F71B7183F3B-807A
17169 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:08
                    Engine speed: 0.00 /min
                    Coolant temperature: 13 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 12.246 V
                    ACC variants (coding): ACC
                    CCS Switch: ACC operating unit
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    ACC variants: ACC with Stop & Go
                    Engine: operating status: ES
Readiness: 1110 0001
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 63257000001151
   Coding: 01FA93A13424217547800607E0CAA980C92C84E26007957734405038C2A9430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 030578FB8AB5455784-8056
8277 - Databus
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:09
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:09
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Revision: 00001K08
   Coding: 0012000420010000110500001210142A
   VCID: 6CD73347872BAA2F55-8038
   Air quality sensor:
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:09
                    Outside air temperature: 12.0 °C
                    Engine speed: 0 /min
                    Temperature after evaporator: 14.0 °C
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001733200812
   ROD: EV_BCMBOSCH_018.rod
   VCID: 081F6FD7B393660FD1-805C
   Component: WWS    171102  042 0551
   Serial number:         171111033250
   Component: RLHS  047 0105
   Serial number: S9Y17M11D29H15M39S32
   Coding: 00A8DD
   Serial number: 000000000ZY173000GUM
   Serial number: 00000000000000046658
555797 - Databus
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:12
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417617320
   Coding: 0371167841
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50AF87B70B436ECF49-8004
13697025 - Control Module
          U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:10
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 2B0067C315FFC728949C810580400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E73C90FA1D7E8BFAB-806A
0803 - Databus
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:09
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 12.2 V
0790 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:09
2119 - Databus
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:09
2068 - Databus
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:09
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    005 0336
   Serial number: 003VWR3LSKF8
   Coding: 98CCC000000000005C000000008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 09196AD3A8991F07CE-805C
   Belt Pretensioner left:
   Serial number: 34169677E06021851041
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E07021850200
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 411 17
   Serial number: 357000000000A84D882P
   Subsystem 4 - Part No SW: -----------    HW: 480 002 411 17
   Serial number: 3580000000045C09882L
   Subsystem 5 - Part No SW: -----------    HW: 480 402 411 17
   Serial number: 3510001C72839D06B588
   Subsystem 6 - Part No SW: -----------    HW: 480 402 411 17
   Serial number: 3520001C92839D03357%
   Subsystem 7 - Part No SW: -----------    HW: 480 402 611 17
   Serial number: 3550001AB2796E02E64D
   Part No SW: 5Q0 953 507 GK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 23111704401267
   Coding: 0C00
   VCID: 050166E384817B67AA-8050
   Part No SW: 5G1 920 756 C    HW: 5G1 920 756 C
   Component: KOMBI         302 0310
   Coding: 27AD19006F88000801886B0B5401000000000000
   VCID: 2D51FE437CB1632702-8078
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007086889
   Coding: 030100347F085800FB00027C1C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF.rod
   VCID: 387FDF1783F3D68F61-806C
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29170002540300097446
   Coding: 2DFFFF
   Serial number: 2952266004
8782084 - Tiptronic Downshift Switch/Paddle in Steering Wheel
          B114E 96 [009] - Component internal failure
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:09
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: On
8782085 - Tiptronic Upshift Switch/Paddle in Steering Wheel
          B114F 96 [009] - Component internal failure
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:09
                    Terminal 15: On
          U1101 00 [009] - Active
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:09
                    Terminal 15: On
   Component: HRE_Master    H12 0080
   Serial number: 0460702225
   Coding: 02031203
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D71CE03ACD1F3A7B2-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0460293131
   Coding: 020312
   Serial number: 071117EK510734
   Coding: 003E02208801048100001001
   VCID: 4385B8FBCA358557C4-8016
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 00020000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B75C01BB2C5FD978C-806E
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Serial number: 121117EKA33711
   Coding: 003E00208E01048100801000
   VCID: 428BBDFFD52F8C5FCF-8016
   Part No SW: 3Q0 035 846     HW: 3Q0 035 846
   Component: MU-S-N-ER     H24 0245
   Serial number: VWZAZ2R0642410
   Coding: 02730008FF00000051510001001828001F0203D601200100C7
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 6ED3394FB137583F7B-803A
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHT3234340
          B201A 00 [009] - -
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:08
                    Voltage terminal 30: 12.3 V
                    Status_Software_Version_Management-module_name: D
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:09
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 27111712P21176
   Coding: 000307000000040100020050C150A80088000E200020
   VCID: 3C77C307B7CBFAAF85-8068
0646 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:09
                    Control Module temperature: 18 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 313.3 s
                    Voltage terminal 15: 12.1 V
                    mid: 00 29
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
0659 - Steering
          C10AC F2 [009] - Lane-Holding Assistance Not Coded
                    Reset counter: 23
                    Mileage: 110 km
                    Date: 2019.08.06
                    Time: 07:43:09
                    System run time: 313.9 s
                    mid: 02 A6
                    Status of camera: System malfunction
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Component: SAS-GEN 2     H06 0014
   Serial number: 171013203235
   VCID: 6BD5305B8225AD175C-803E
End-------------------------(Elapsed Time: 04:27)--------------------------
   #26
NEtech
Denmark
C?ID=56995
The Coding in ABS is changed, there are no "other DTC" appeared in ABS, from that new coding.
If the engine control module can be used for man. transmission, maybe eeprom must be changed (tuner).
I would suggest Remove Battery, for maybe 20 min.
Remove Component Protection.
racofuy
New Zealand
C?ID=197081
Thank you for all your help, I'll disconnect battery today.
Next a visit to the dealer to get CP removed.
I want to go stg 1 anyway so you suggest maybe flashing ecu with a manual file if possible?
   #29
racofuy
New Zealand
C?ID=197081
I finally was able to upgrade my VCDS cable to the latest version to enable me to carry on with this.
I enlisted the help (paid) of someone overseas with on line access to VW servers, we were able to get all the lights out, coded a new gateway, calibrated the front radar and screen mounted lane assist camera.
Got to a point where 2 things that were working now are not,
1) Mode button
2) Retro fitted GPS
It seemed like every time I had work done a new problem was created so in the end I left it as 99% of the car is working.
I'd like now to clear the last remaining errors / fault codes and get the GPS working properly.
Mode button was working fine prior to all of this, factory fitted.
GPS, this was retro fitted. Stupidly prior to any of the coding to get the manual swap working correctly. (had component protection removed locally) However! it is working in the back ground as when the low fuel light comes on the NAV asks if you want to find a gas stn.
Once you select yes it works flawlessly until you switch the car off / on.
Also when starting the car the compass N- - appears on the cluster and if you time it just right pressing the NAV button the GPS will also come on and work flawlessly until you switch the car off.
All other times press NAV and you just get "insert valid media" or something to that effect.
Thursday,27,August,2020,19:58:59:54382
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4526.4
Mileage: 9118km-5665mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 4B 52 5F A5 A9 D6 D7
VIN: WVWZZZAUZJW149977   Mileage: 9118km-5665miles
   Revision: --H13---
   Shop #: WSC 00046 000 00000
   VCID: 2E050B38C09A039BF0F-807A
16452 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
17176 - Databus
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [032] - -
   Coding: 01FA93A13424217547800607E0CAA980C92C84E26007957714405038C2A9430B00000012121212B835351919323200
   VCID: 03538A8C3B985EF34F1-8056
8277 - Databus
          [FCAN: EPS_DSR_Status signal is invalid]
                    Reset counter: 106
                    Mileage: 4337 km
                    Date: 2019.12.31
                    Time: 18:55:12
   Revision: 00001K08
   VCID: 6C81C1303606B18B9EB-8038
   Air quality sensor:
   VCID: 08499DA002BE7DAB1A3-805C
   Coding: 00A8DD
   Serial number: 000000000ZY150282SGY
545557 - Databus
          [EA_03 Datenbus fehlende Botschaft]
                    Reset counter: 30
                    Mileage: 4337 km
                    Date: 2019.12.31
                    Time: 18:55:16
555797 - Databus
          [Getriebe_11_alt aktiv]
                    Fault Frequency: 19
                    Reset counter: 24
                    Mileage: 4337 km
                    Date: 2019.12.31
                    Time: 18:55:14
   Coding: 0371167841
   VCID: 50F975C0BA6E756B823-8004
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_01.EPS_PLA_Status - PLA-Codierung in Lenkhilfe prüfen]
                    Reset counter: 74
                    Mileage: 5009 km
                    Date: 2020.01.25
                    Time: 08:53:29
   Component: ACC BOSCH MQB H10 X654
   Coding: 2B0067C115FFC728949C810560400600000000000000000000
   VCID: 3E253B7810FAF31B60F-806A
   VCID: 094F98A419B404A305D-805C
   Coding: 333135
   Coding: 333135
   Coding: 0C00
   VCID: 0557949435AC60C3615-8050
   VCID: 2D070C34CD9C7883C95-8078
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 12051910001567
   Coding: 030100340F0F58000F000000000F00000001000100000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CA1F1704666210B0EB-8028
   Coding: 2C0000
   Coding: 02031203
   VCID: 3D273C741DFCE803795-8068
   Coding: 020312
   VCID: 43D34A8C7B189EF30F1-8016
   Coding: 10020000
   VCID: 3B23326C03E8E633471-806E
21760 - Databus
          [HCA_01 Botschaft - CAN-Timeout]
                    Reset counter: 114
                    Mileage: 5009 km
                    Date: 2020.01.25
                    Time: 07:29:11
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 38.0 °C
                    KFC: 55
                    KFA: 00 00
                    Environmental conditions: 20
                    uioUdNotFilt_xdu16: 12.19 V
                    uAdSensI_SwitchedKl30_xdu16: 12.14 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
22016 - Databus
          [KFC_KOMBI_01 Botschaft - CAN-Timeout]
                    Reset counter: 114
                    Mileage: 5009 km
                    Date: 2020.01.25
                    Time: 07:29:11
                    Motor status: 00
                    KFC: 56
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 12.34 V
                    uAdSensI_SwitchedKl30_xdu16: 12.31 V
23296 - Databus
          [MOTOR_CODE_01 Botschaft - CAN-Timeout]
                    Reset counter: 114
                    Mileage: 5009 km
                    Date: 2020.01.25
                    Time: 07:29:11
                    Motor status: 00
                    KFC: 5B
                    KFA: 00 00
24064 - Databus
          [VIN_01 Botschaft - CAN-Timeout]
                    Reset counter: 114
                    Mileage: 5009 km
                    Date: 2020.01.25
                    Time: 07:29:11
                    Motor status: 00
                    KFC: 5E
                    KFA: 00 00
28672 - Databus
          [MOTOR_07 Botschaft - CAN-Timeout]
                    Reset counter: 114
                    Mileage: 5009 km
                    Date: 2020.01.25
                    Time: 07:29:11
                    Motor status: 00
                    KFC: 70
                    KFA: 00 00
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 20111710802980
   Coding: 000000070100164E01000100020000000000000000000000000000000000
   VCID: 72BDDF481422677B547-8026
   VCID: 42DD4F88640297FB047-8016
   VCID: 6E85CB38001A439BB0F-803A
          B201A 00 [009] - -
                    Reset counter: 30
                    Mileage: 4337 km
                    Date: 2019.12.31
                    Time: 18:55:44
                    Voltage terminal 30: 12.0 V
2571 - Navigation system
          B126C F2 [009] - Navigation database not enabled
                    Reset counter: 30
                    Mileage: 4337 km
                    Date: 2019.12.31
                    Time: 18:58:59
7207 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Start/stop reasons (0x27) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 30
                    Mileage: 4337 km
                    Date: 2019.12.31
                    Time: 18:55:47
                    Voltage terminal 30: 12.1 V
                    BAP-BAP_Function_ID: 02
   Coding: 000307000800010100221254C1408900D4000E200020
   VCID: 3C21317006E6E10B4EB-8068
1122597 - Local Data Bus
          U1169 00 [008] - Missing Message
          [Timeout_RDR1_Header]
                    Mileage: 5009 km
                    Date: 2020.01.25
                    Time: 07:29:11
                    Control Module temperature: 43 °C
                    Outside air temperature: 24.0 °C
                    System run time: 2163.5 s
                    mid: 01 43
                    Status of camera: limited
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   VCID: 6B83C22C3308B6B3971-803E
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7EA5FB78507A331B20F-802A
0773 - Supply Voltage for Low-Beam
          C11FD 13 [040] - Open Circuit
                    Reset counter: 0
                    Mileage: 5009 km
                    Date: 2020.01.25
                    Time: 07:29:11
                    Reset counter: 0
                    Mileage: 5009 km
                    Date: 2020.01.25
                    Time: 07:29:11
End----------(Elapsed Time: 01:43, VBatt start/end: 12.2V/12.0V)-----------
   #30
racofuy: I really don't have the definitive answer to your 2 x problems - but I assume that the MIB on this car was retrofitted from another vehicle (because of the CP error on the hex5F module on your first scan report).
If this is so and with the caveat that it's unclear how "someone overseas with on line access to VW servers" cleared the CP errors - I wonder whether the source of the problem might be the SWaP codes that are registered in your module - maybe (I'm guessing, of course):'
So - the basic concept (as I understand) is that MIB units come pre-programmed with all options included in their software (presumably it's cheaper to manufacture these modules in this manner than to use the inverse principle). However, most of the options are locked-out and a "license" is needed for activation.
To get this license, you first need to buy a type of part number from VW - for example, the number (FEC) for the Mode function is 5G0 054 809. Using the official ODIS tool, a series of "FeC keys" are generated incorporating the FeC Code, a Individualization Characteristic (generated on your car), your VIN and a specific VW signature. This process is strictly controlled by VWs servers back on the mother-ship and the end-result is a unique license that is stored in a special file called FecContainer.fec in the module. You can view these licenses like this (depending on your MIB version):
1. Hold Menu button until service mode shows.
2. Press "Function enabling codes (FEC, SWaP)"
3. Press "Installed codes"
here's a screenshot that I've thieved from the net:
   #31
racofuy
New Zealand
C?ID=197081
HI Don,
thanks for replying. A local company here removed the CP before any coding was done to resolve the issues with the manual swap (possibly via swap, not sure) . Yes both MIB components bought from an R wagon locally.
The navigation was working 100% prior to any coding changes to sort out the manual swap errors and as I say it still is working in the background now.
There is no longer any CP on any module unless I'm mistaken.
CP removal was not performed by the person overseas. I have VAS5054A here and he takes control of my PC to do the work remotely as he has access to VW.
On ours holding the menu button just gives me the SW and HW number.
racofuy
New Zealand
C?ID=197081
Anybody able to help?
   #33
racofuy
New Zealand
C?ID=197081
Made some small gains, original Gateway back in the car. Driving modes are back and working.
Managed to clear Software version management code in 5F as well.
Just Navigation left non op. At times I do get B126C F2 Nav database not enabled code pop up
Tried SD card in my Golf R works fine, Golf R SD card does not work in this car.
Sunday,20,September,2020,09:18:58:54382
Mileage: 10029km-6231mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
VIN: WVWZZZAUZJW149977   Mileage: 10029km-6231miles
   Revision: --H13---
8277 - Databus
                    Reset counter: 18
                    Mileage: 10029 km
                    Date: 2020.09.20
                    Time: 09:15:13
   Revision: 00001K08
   Air quality sensor:
   Coding: 00A8DD
555797 - Databus
                    Reset counter: 18
                    Mileage: 10029 km
                    Date: 2020.09.20
                    Time: 09:15:15
   Coding: 0371167841
                    Reset counter: 18
                    Mileage: 10029 km
                    Date: 2020.09.20
                    Time: 09:15:13
   Coding: 333135
   Coding: 333135
   Coding: 0C00
   Coding: 030100347F085900FB000268080F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 38292D6032DECD2BAA3-806C
   Coding: 2C0000
   Coding: 02031203
   Coding: 020312
   Coding: 10020000
End----(Elapsed Time: 01:38, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
