C5 RS6 won't run readiness tests, did PO code them out?
Peterwick
C?ID=209748
I have failed emissions, and want to solve this with the help of this group if possible.
I bought this car without ever seeing it, and spent 5 months with it on the lift, it went together well, no leaks, no major issues. Power steering whined and I replaced the pump. After a few test drives I tried emissions, I will continue every 60 days until I get it to pass legally. I had no MIL so I thought I give it a shot.
I found a blown fuse to SAI, replaced it, and pulled blower out and it works fine. Put a new relay in to be sure. I have 01101101 for readiness, no MIL on. I do not get SAI codes, currently have 0441 evap flow low. I am unable to run any readiness tests, (no script available)?
I have my VAGCOM on a toughbook with bad LAN and wireless, so software is old. I have new version on it now, but says the cable is not up to date....
I will get a new enthusiast version soon.
How can I see if the SAI test is trying to run? Why when I run xxx77 I start test, but it doesn't show test on- or run blower. Is there some requirement I haven't met? car running, ebrake on.
I am in CT, and plan to get somebody(Jack) to supply / code a new airbag controller. Maybe during the winter?
Nothing else seems too concerning?
What do you see?
[Thursday,18,July,2019,20:57:56:63906
VCDS Version: 15.7.1.0
Data version: 20150904
VIN: WUAPV54B63N904793   License Plate:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2006))
          75 76 77
Address 01: Engine        Labels: 077-907-558-BCY.lbl
   Part No: 4D1 907 558 D
   Component: 4.2l V8/5VT     G   0003
   Coding: 0006752
   Shop #: WSC 13364 153 403078
   VCID: 2F6D1966BDE4EE46F4-5140
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01L-927-156.lbl
   Part No: 4B0 927 156 FL
   Component: AG5 01L 4.2l5VT USA 0305
   Coding: 0000002
   VCID: 76E3EC02023E9F8E77-5140
18265 - Load Signal
            P1857 - 003 - Error Message from ECU - Intermittent
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 AD
   Component: ESP 5.7 RS 6        2310
   Coding: 06697
   VCID: 63C5A556F1AC1A2620-5124
01119 - Gear Recognition Signal
            35-10 -  -  - Intermittent
Address 06: Seat Mem. Pass        Labels: None
   Part No: 4B0 959 760 C
   Component: Sitzmemory R1 BF    0205
   Coding: 00003
   VCID: 2D51036EE7E89C56C6-4B1A
            06-10 - Signal too High - Intermittent
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AR
   Component: A6-Klimavollautomat 0208
   Coding: 00010
   VCID: 6ADBC87216864B6EE3-2580
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4B0 959 655 Q
   Component: Airbag 8.4EP        3001
   Coding: 0000707
   Shop #: WSC 00000 785 00200
   VCID: 3E7334226A8E17CE6F-5140
01217 - Side Airbag Igniter; Driver Side (N199)
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 983 D
   Component: KOMBI+WEGFAHRS. VDO D13
   Coding: 03284
   Shop #: WSC 05314
   VCID: 2959F77ED30080762A-5140
   WUAPV54B63N904793     AUZ7Z0C2418783
Address 35: Centr. Locks        Labels: 4B0-962-258.lbl
   Part No: 4B0 962 258 M
   Component: Central Lock/Alarm  D38
   Coding: 15945
   Shop #: WSC 08316
   VCID: 3365151601CCCAA690-4EEA
13 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -  -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
            35-00 -  -
01374 - Alarm triggered by Terminal 15
            35-00 -  -
01369 - Alarm triggered by Hood Switch
            35-00 -  -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 -  -
01561 - Rear left door
            59-00 - Can't Unlock
01574 - Alarm triggered by Door Contact Switch; Rear Right
            35-00 -  -
01573 - Alarm triggered by Door Contact Switch; Rear Left
            35-00 -  -
01366 - Opened Due to Crash Signal
            30-00 - Open or Short to Plus
00951 - Tailgate Central Locking Motor Relay (J398)
01586 - Locking Cylinder Contact Switch; Passenger Side (F242); Close
01585 - Locking Cylinder Contact Switch; Passenger Side (F242); Open
01141 - Luggage Compartment Unlocking Switch (E165)
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0204
   Coding: 00001
   VCID: 2C570E6ADCF2955ED1-4B1A
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00050
   VCID: 040786CA14E2BD1E79-4B4C
   Part No: 4B0 035 195 N
   Component: symphony II NP2    0400
   Coding: 00201
   Shop #: WSC 00003
   VCID: 2B550D76D9FC9266D8-5092
            49-00 - No Communications
00856 - Radio Antenna
            36-00 - Open Circuit
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
Address 75: Telematics        Labels: 8E0-035-616.lbl
   Part No SW: 8E0 035 616 A    HW: 8E0 035 616 A
   Component: Telematik USA1
   Coding: 0002003
   Shop #: WSC 08353 444 66568
   VCID: 2345E556E12C5A2660-5124
01531 - Emergency Battery
            002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist        Labels: 8Z0-919-283.lbl
   Part No: 8Z0 919 283
   Component: Parkingsyst. A6 RDW D08
   Coding: 01116
   VCID: 020B80D20EF6B32E4B-5140
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
            31-00 - Open or Short to Ground
01548 - Sensor for Parking Aid; Rear Right (G206)
            37-00 - Faulty
End-------------------------(Elapsed Time: 04:]
NostraJackAss
I don't adapt used ABS or SRS units due to liability reasons & only new from dealer & encourage you to check with OEM and NHTSA for recalls since free.
Vehicle Identification No.WUAPV54B63N904793
ModelAudi RS6 qu.
RS6
Date of production02.07.2003
Model year2004
Sales type4B45EZ
Engine CodeBCY
Transmission CodeGAG
Emission standard0GLEmission standard TLEV
Coding: 0006752
Correct part......only way to know if FOD is to check code or try and see if you can run readiness code tests.
Let's start with a scan that shows the actual DTC's okay?
Please also post the OBD2 data 0x33-MODES 01-01, 03, 07, 09 if supported.
Time to JPPSG to qualify FOD, however, if you had a blown fuse for SAI PUMP and no aforementioned SAI fault, that would imply tampering now wouldn't it?
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
https://forums.ross-tech.com/showthread.php?3147-What-is-Jack-talking-about-0x01-08-000
Prepare to qualify!
