Hello Everybody,
Could you tell me how i should proceed on VCDS to bleed entierly the brake fluid on my Golf V ? (Clutch, ABS/ESP, Brake calipers)
For ABS part: I know that there is an option in VCDS to bleed ABS but i don't know where it is ?
Could you give me your tips and tricks ?
Look forward to hearing from you
Best regards
See below my autoscan of my "VW GOLF 5 - 105HP-77KW - 1.9L TDI - BLS"
- What part of brake system must i bleed in the first time ?
- What is the complete process to make the bleeding with success for all components ?
Best regards
Sunday,21,July,2019,14:34:20:47337
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWZZZ1KZ8W177162 License Plate:
Mileage: 229740km-142753mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: WVWZZZ1KZ8W177162 Mileage: 229740km-142753miles
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 021 QJ HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 1984
Revision: --H07--- Serial number: VWX7Z0GN3NE8E7
Coding: 0000071
Shop #: WSC 02271 995 97128
VCID: 77AB16E8E3C6CA2FFB3-8022
Revision: 00H11001
Coding: 0021121
Shop #: WSC 01392 785 00200
VCID: 73B322F8F7BEA60FC7B-8026
Part No SW: 1K0 907 044 CQ HW: 1K0 907 044 CQ
Component: ClimatronicPQ35 130 1212
Revision: 00130022 Serial number: 00000000000000
VCID: 78A915D4EED8C557F29-802C
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Revision: 00H54000 Serial number: 00000005255840
Coding: E58B8F2700041500471400001400000000097F075C000100000000000000
Shop #: WSC 00000 785 00200
VCID: 71BF28F08DA2941F357-8024
Component: Wischer 131107 021 0501
Coding: 00038805
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 191107 046 0204
Coding: 00208933
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1L6LZ4
Coding: 0013111
Shop #: WSC 01373 785 00200
VCID: 3D27C4C0817A207FE1F-8068
Subsystem 1 - Serial number: 6332MSME3151696CE
Subsystem 2 - Serial number: 6342MSME303475611
Subsystem 3 - Serial number: 6352QSME43342767D
Subsystem 4 - Serial number: 6362QSME462D0D77U
Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD
Component: J0527 636 0070
Coding: 0002022
VCID: 75B71CE0F9CAB83FE9F-8020
Component: E0221 002 0010
Part No SW: 1K0 920 874 B HW: 1K0 920 874 B
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0GN3NE8E7
Coding: 0007103
Shop #: WSC 24886 002 1048576
VCID: 2C01F9846A00B9F7461-8078
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07A300A5C
Coding: E9807F0E0002020002
VCID: 3039EDF44628DD177A9-8064
Component: IMMO VDD 1216
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 006 1219
Coding: 0000180
VCID: 392FD0D095521C5FCD7-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3537DCE0B94AF83F29F-8060
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Coding: 809002005103087F2D0484056008CF03E0FC00
VCID: 03537238A71E968FD7B-8056
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000436
VCID: 3A2DCFDC90541747C4D-806E
Part No SW: 1K0 035 186 AD HW: 1K0 035 186 AD
Component: Radio BVX 037 0048
Revision: 00037000 Serial number: VWZ1Z2G6330308
Coding: 0040400
VCID: 68894594BE7855D7629-803C
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1206
Coding: 0000144
Shop #: WSC 01392 785 1012552
VCID: 3829D5D4AE580557329-806C
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 22 Einparkhilfe 0101
VCID: 2D07F480511AB0FF51F-8078
End----------(Elapsed Time: 01:16, VBatt start/end: 12.2V/12.2V)-----------
