Golf MK7.5 G85 basic setting
racofuy
New Zealand
C?ID=197081
I cannot clear basic setting codes using the procedure below, sensor has been out of car due to dash replacement.
https://forums.ross-tech.com/showth...ensor-(G85)-Calibration-in-44-Steering-Assist
The message box "running" never changes, can log in fine, select steering angle and click go.
Wednesday,24,July,2019,15:56:32:41053
VCDS Version: 19.6.0.2 (x64)
Workshop Code: 666 12345 054321
VIN: WVWZZZAUZJW149977   License Plate:
Mileage: 24km-14mi   Repair Order:
Chassis Type  AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 4B 52 5F A5 A9
VIN: WVWZZZAUZJW149977   Mileage: 24km-14miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 C    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091900324464050B2000
   Shop #: WSC 12345 666 54321
   ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
   ROD: EV_ECM20TFS0205G0906259C.rod
   VCID: 2E53F94F71B7183F33-807A
17169 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [175] - -
                    Fault Frequency: 13
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:19
                    Engine speed: 0.00 /min
                    Coolant temperature: 50 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 12.167 V
                    ACC variants (coding): ACC with braking until at standstill/Stop & Go
                    CCS Switch: CCS operating unit
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    ACC variants: ACC with Stop & Go
                    Engine: operating status: ES
Readiness: 1010 0001
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 63257000001151
   Coding: 01FA93A13424217547800607E0CAA980C92C84E26007957738425038C2A9430B00000012121212B835351919323200
   Shop #: WSC 00046 000 00000
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 030578FB8AB545578C-8056
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 16
                    Mileage: 24 km
8277 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 01:03:10
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 01:03:10
16385 - TPMS Display
          C1146 F2 [008] - EEPROM Malfunction
                    Reset counter: 56
                    Mileage: 24 km
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Revision: 00001K08
   Coding: 0012000420010000110500001210142A
   VCID: 6CD73347872BAA2F5D-8038
   Air quality sensor:
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:24
                    Outside air temperature: 15.0 °C
                    Engine speed: 0 /min
                    Temperature after evaporator: 14.3 °C
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001733200812
   ROD: EV_BCMBOSCH_018.rod
   VCID: 081F6FD7B393660FD9-805C
   Component: WWS    171102  042 0551
   Serial number:         171111033250
   Component: RLHS  047 0105
   Serial number: S9Y17M11D29H15M39S32
   Coding: 00A8DD
   Serial number: 000000000ZY173000GUM
   Serial number: 00000000000000046658
262936 - Sensor for anti-theft alarm system
          B1330 29 [009] - Signal Implausible
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:19
555797 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:22
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417617320
   Coding: 0371167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50AF87B70B436ECF41-8004
12648721 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:19
13697025 - Control Module
          U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 01:01:53
13637426 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:19
13679386 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:19
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 330067C115FFC728949C810580400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E73C90FA1D7E8BFA3-806A
9 Faults Found:
2055 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:20
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 12.1 V
0803 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:20
2101 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:20
0931 - Databus
                    Fault Frequency: 11
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:20
0101 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:20
0928 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:20
1075 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:20
2119 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:20
2068 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:20
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    005 0336
   Serial number: 003VWR3LSKF8
   Coding: 98CCC000000000005C000000008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 09196AD3A8991F07C6-805C
   Belt Pretensioner left:
   Serial number: 34169677E06021851041
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E07021850200
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 411 17
   Serial number: 357000000000A84D882P
   Subsystem 4 - Part No SW: -----------    HW: 480 002 411 17
   Serial number: 3580000000045C09882L
   Subsystem 5 - Part No SW: -----------    HW: 480 402 411 17
   Serial number: 3510001C72839D06B588
   Subsystem 6 - Part No SW: -----------    HW: 480 402 411 17
   Serial number: 3520001C92839D03357%
   Subsystem 7 - Part No SW: -----------    HW: 480 402 611 17
   Serial number: 3550001AB2796E02E64D
1050117 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 01:02:36
   Part No SW: 5Q0 953 507 GK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 23111704401267
   Coding: 0C10
   VCID: 050166E384817B67A2-8050
617752 - Selector Lever Park Position Lock Switch
          B1162 29 [009] - Signal Implausible
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:22:05
                    Operating time: 1228 min
                    Supply voltage: Terminal 30: 12.8 V
                    Vehicle speed: 11 km/h
                    Voltage at switch: 5.02 V
                    Terminal 15 status: active
                    System status: 30
   Part No SW: 5G1 920 756 C    HW: 5G1 920 756 C
   Component: KOMBI         302 0310
   Coding: 27AD19086F88000801886B0B5401000000000000
   VCID: 2D51FE437CB163270A-8078
16776983 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:19
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007086889
   Coding: 030100347F085900FB00027C1C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF.rod
   VCID: 387FDF1783F3D68F69-806C
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 27150000245620045065
   Coding: 28FFFF
   Serial number: 2952266004
          U1101 00 [009] - Active
                    Fault Frequency: 9
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:19
                    Supply voltage: Terminal 30: 11.9 V
                    Terminal 15: On
8526363 - Crash Shut-Down
          B189C F0 [009] - Active
                    Fault Frequency: 26
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:19
                    Terminal 15: On
   Component: HRE_Master    H12 0080
   Serial number: 0460702225
   Coding: 02011203
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D71CE03ACD1F3A7BA-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0460293131
   Coding: 020112
   Serial number: 071117EK510734
   Coding: 003E02208001048100001000
   VCID: 4385B8FBCA358557CC-8016
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 00020000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B75C01BB2C5FD9784-806E
15873 - Steering angle sensor
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 01:18:40
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 13.25 V
                    Temperature: 31.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 13.28 V
                    uAdSensI_SwitchedKl30_xdu16: 13.24 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Serial number: 121117EKA33711
   Coding: 003E00208E01048100801000
   VCID: 428BBDFFD52F8C5FC7-8016
   Part No SW: 3Q0 035 846     HW: 3Q0 035 846
   Component: MU-S-N-ER     H24 0245
   Serial number: VWZAZ2R0642410
   Coding: 02730208FF00000051510001001828001F0207D601200100C7
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 6ED3394FB137583F73-803A
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHT3234340
          B201A 00 [009] - -
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:19
                    Voltage terminal 30: 12.3 V
                    Status_Software_Version_Management-module_name: D
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:19
0513 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:21
0518 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:21
0523 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:21
0528 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:21
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 27111712P21176
   Coding: 000307000000010100020054C150A90088000E200020
   VCID: 3C77C307B7CBFAAF8D-8068
1135140 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:20
                    Control Module temperature: 23 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 361.1 s
                    mid: 02 65
                    Status of camera: System malfunction
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1135139 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:20
                    mid: 02 64
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
0646 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Fault Frequency: 13
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:19
                    System run time: 359.8 s
                    mid: 00 29
                    Status of camera: operational
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1123173 - Databus
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 00:07:19
                    System run time: 360.3 s
                    mid: 02 E0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
0659 - Steering
          C10AC F2 [009] - Lane-Holding Assistance Not Coded
                    Reset counter: 16
                    Mileage: 24 km
                    Date: 2019.07.22
                    Time: 01:01:54
                    Control Module temperature: 28 °C
                    System run time: 3.4 s
                    Voltage terminal 15: 12.0 V
                    mid: 02 A6
                    Engine_Running_Info: 1
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Component: SAS-GEN 2     H06 0014
   Serial number: 171013203235
   VCID: 6BD5305B8225AD1754-803E
End-------------------------(Elapsed Time: 04:56)--------------------------
downtime
Finland
C?ID=280813
Have you cleared the errors before taking the autoscan? Because that seems to have all sorts of issues from which the G85 is the smallest one.
Clearing the DTCs and taking a new autoscan should show only the currently active problems.
NostraJackAss
Reset counter: 16
Mileage: 24 km
8277 - Databus
Reset counter: 16
Mileage: 24 km
Date: 2019.07.22
Time: 01:03:10
P1612 00 [009] - -
Reset counter: 16
Mileage: 24 km
Date: 2019.07.22
Time: 01:03:10
C1146 F2 [008] - EEPROM Malfunction <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< WTF!
Reset counter: 56
Mileage: 24 km
ABS module might be FUBAR!
Car is brand new why not SVM & get free under warranty?
You could re-code default & to road test but aforementioned is advised!
racofuy
New Zealand
C?ID=197081
My bad, too much in a hurry and didn't see pages 2 and 3.
Will try procedure outlined on page 2 today.
Yes car is new but was imported damaged from another country so not sure how any warranty would be viewed, probably not favorably.
Thanks for replies gents.
racofuy
New Zealand
C?ID=197081
Update, this procedure below worked for me. Steer assist light is out.
Will clear all codes now and see what comes back.
The shorter procedure further down on page 2 did not work for me.
We haven't verified this on a car yet but this should be what ODIS is doing when it runs the G85 calibration, but in VCDS terms:
1) Test step: Edge detection
Start the engine
Point the front wheels straight ahead
[44-Steering Assist]
[Security Access - 16]
Enter 19249
[Do It!]
Select these in [Adv Meas Values]:
[IDE04510-MAS03732] Steering angle sensor: slope detection index - Steering angle speed negative dropping slope on curve
[IDE04510-MAS03733] Steering angle sensor: slope detection index - Steering angle speed negative rising slope on curve
[IDE04510-MAS03734] Steering angle sensor: slope detection index - Steering angle speed positive dropping slope on curve
[IDE04510-MAS03735] Steering angle sensor: slope detection index - Steering angle speed positive rising slope on curve
[IDE04510-MAS03736]Steering angle sensor: slope detection index - Index mark
Slowly turn the steering wheel to the right and left, passing the index mark (approx. 45°) until all 4 slope detection indexes have been recognised (detected) and the index mark is set to (1).
[Done, Go Back]
2) Test step: Steer. angle sens. calibration
[Basic Settings - 04]
[Show Measuring Data]
Select the following items:
[IDE02216-IDE05795] Steering angle sensor: basic setting - End basic setting
[IDE02216-MAS03161] Steering angle sensor: basic setting - Start
In Basic Settings, pick [MAS00815] Steering angle sensor
[Go!]
It should show Running
- Turn the steering wheel slowly to the right and then to the left mechanical stop.
- Turn the steering wheel back to the mid position, the status should be indicated as Permitted. (IDE02216-MAS03161 or IDE02216-IDE05795 ?)
Note: in a test on the car it never showed permitted in either of those?
(after one or both show permitted, stop moving wheel and point straight)
Wait for it to show Finished correctly?
[Stop]
Note: in a test on the car there were no faults and no warning lamps.
3) Test step: Evaluation of basic setting (no VCDS needed)
Turn the steering wheel to the right end stop.
Turn the steering wheel to the left end stop.
Turn the steering back to its center position.
Check the yellow fault lamp on the dash.
The fault lamp on the dash must go out.
Stop the engine.
Check and clear DTCs
