Modifying software end stops in 44 Steering Assist MQB mk 7.5 golf
Tac
C?ID=316947
Hi all, I own a Golf R that came with 19" wheels from the factory. Due to those wheels, it seems VW modifies the software slightly so the steering wheel doesn't turn quite as far.
On the other hand, my partners GTI has 18" wheels, and has no modifications made to the software of the steering assist. That little bit makes all the difference in maneuverability, and now that I have my R on 18" wheels too, I'd like to modify these software end stops to GTI levels. How do I know these are software controlled? There was adaptation channel that (IDE05162-Software end stop) that when toggled to "Not Active" allowed me to turn my steering wheel as far as the GTI, maybe even further? Unfortunately, I saw no adaptation channels for the actual adjustment of where the end stops are, even though they seem to be stored in mm values, as per Adv. Measuring.
Autoscan:
Tuesday,16,July,2019,19:49:03:35522
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 19.6.1.0 (x64)  HEX-V2 CB: 0.4508.4
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
          47 4B 52 5F 75 A5 A9 D6 D7
VIN: WVWV   Mileage: 13906km-8640miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (J623-DJJA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 P    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 092500122466010E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259P 001003
   ROD: EV_ECM20TFS0208V0906259P.rod
   VCID: 4DC461CDED59B24F71F-8019
17176 - Databus
                    Mileage: 13897 km
                    Date: 2019.07.15
                    Time: 20:14:38
                    Engine speed: 1331.00 /min
                    Normed load value: 28.6 %
                    Coolant temperature: 35 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 11.992 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
   Part No SW: 0GC 300 012 A    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1403
   Revision: 00H06V07
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 211CED7DC141462FE57-8075
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 60518000001916
   Coding: 01FA6BA1542121714577030960CB6980D62A84A2C0069677384250D8C2A8430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 035087F57B9DB43FD7B-8057
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0472298748
   Coding: 032C0C
   VCID: 3C223C0946E30BC7D61-8069
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010000110500401211140A
   VCID: 6D84C14D4D19524F11F-8039
   Air quality sensor:
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001805700259
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06569EE148AF8117F05-8053
   Component: WWS    180201  043 0551
   Serial number:         180210123856
   Component: RLHS  047 0105
   Serial number: S8Y18M02D28H17M49S10
   Coding: 00A8DD
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 45
                    Mileage: 7972 km
                    Date: 2019.03.11
                    Time: 19:01:34
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418018053
   Coding: 0471155811
   VCID: 4BC06FD5134DBC7F6FB-801F
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 330047C159FFC728949C810580401600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E26360150FF19D7F85-806B
0846 - Databus
          [FAULT_LEARNING_PLAUS_BR_REIFENUMFANG]
                    Reset counter: 3
                    Mileage: 13897 km
                    Date: 2019.07.15
                    Time: 20:14:39
                    Control Module temperature: 35 °C
                    Voltage terminal 15: 12.0 V
1236 - Databus
          [FAULT_TIMEOUT_BV1_POSITION]
                    Fault Frequency: 12
                    Reset counter: 245
                    Mileage: 5468 km
                    Date: 2019.02.05
                    Time: 14:14:32
                    Control Module temperature: 42 °C
                    Voltage terminal 15: 12.7 V
                    Velocity_vehicle_reference: 0.09 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.53 m/s²
1127 - Databus
          [FAULT_TIMEOUT_PSD_04]
                    Reset counter: 221
                    Mileage: 10961 km
                    Date: 2019.06.17
                    Time: 13:10:22
                    Control Module temperature: 44 °C
                    Voltage terminal 15: 12.1 V
1218 - Databus
          [FAULT_TIMEOUT_PSD_05]
                    Reset counter: 221
                    Mileage: 10961 km
                    Date: 2019.06.17
                    Time: 13:10:22
1219 - Databus
          [FAULT_TIMEOUT_PSD_06]
                    Reset counter: 221
                    Mileage: 10961 km
                    Date: 2019.06.17
                    Time: 13:10:22
   Serial number: 10021841350419
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 382A201972DB27E7329-806D
   Serial number: 003GCR09VJK8
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47C853E50F25581F4B3-8013
   Occupant Detection:
   Serial number: IBH000000000008LJ45H
   Coding: 303344
   Subsystem 2 - Part No SW: -----------    HW: 480 002 402 18
   Serial number: 357000000006AB79BC2/
   Subsystem 3 - Part No SW: -----------    HW: 480 002 802 18
   Serial number: 35800000000A2468BC2S
   Subsystem 4 - Part No SW: -----------    HW: 480 402 702 18
   Serial number: 3510001AB28F9E51751C
   Subsystem 5 - Part No SW: -----------    HW: 480 402 402 18
   Serial number: 3520001BB293E204B3B6
   Subsystem 6 - Part No SW: -----------    HW: 480 402 802 18
   Serial number: 35500019D28F9E53153F
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 802 18
   Component: FrontSensor_P  000 6149
   Serial number: 35600019B28F9E56858T
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 18021808491243
   Coding: 0C10
   VCID: 094C95DD59B1EE6F9D7-805D
   Part No SW: 5G1 920 891 A    HW: 5G1 920 891 A
   Component: KOMBI         407 3193
   Coding: 0BAD301B7F8CCF0502887B0B54010000A0000000
   VCID: 2B000F55B38D9C7F4FB-807F
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007455119
   Coding: 030100047F085900FB0082FA9C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF.rod
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 29170002784760057493
   Coding: 35FFFF
   Serial number: 7223206704
   Serial number: HA1-00025.01.18
   Coding: 0001
   VCID: 4CC26CC91643BB47661-8019
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 222
                    Mileage: 10961 km
                    Date: 2019.06.17
                    Time: 13:13:33
   Revision: 00000000    Serial number: 18000057734003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 343214296EB3C3871E1-8061
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
                    Reset counter: 2
                    Mileage: 13880 km
                    Date: 2019.07.14
                    Time: 23:09:42
   Component: HRE_Master    H12 0080
   Serial number: 0471302682
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D24310D5DF902CFE1F-8069
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0470453345
   Coding: 020111
   Serial number: 160218EBD14426
   Coding: 003F1320D000040000000000
   VCID: 43D047F53B1D743F97B-8017
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000019680385
   Coding: 111000
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B203F1543ED0CFFDFB-806F
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1HMD01VBXC
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E060641809FE957685-807B
0570 - Loudspeaker 2 in Double-Subwoofer
          B130D 13 [008] - Open Circuit
                    Reset counter: 2
                    Mileage: 7859 km
                    Date: 2019.03.10
                    Time: 12:03:25
                    Voltage terminal 30: 12.1 V
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 13021811600559
   Coding: 000000050100165206710F01020000000000000000000000000000000000
   VCID: 72BED23154278DB7CCD-8027
13705489 - Databus
          [PSD_04 data bus missing message]
                    Reset counter: 221
                    Mileage: 10961 km
                    Date: 2019.06.17
                    Time: 13:10:22
   Serial number: 180218EBH24134
   Coding: 003F1320DE00040000800000
   VCID: 42DE42F124077D379CD-8017
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000019604903
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0867
   Coding: 027310020000000051220002001808001F0507F401200405C6
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 333017356BBDC4BF07B-8067
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZJV0396592
   Subsystem 2 - Part No SW: 3G0 919 866 BP    HW: -----------
   Component: NAR 2018  --- 0715
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 05021812P21453
   Coding: 0003070000000201002213548150890094000E200120
1122664 - Databus
          [TIMEOUT_PSD_04]
                    Reset counter: 221
                    Mileage: 10961 km
                    Date: 2019.06.17
                    Time: 13:10:22
                    Outside air temperature: 28.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 423.2 s
                    mid: 01 F0
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 180127202574
   VCID: 2F381B458795E05F633-807B
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392C251D49D13EEFCD7-806D
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:55, VBatt start/end: 12.3V/12.3V)-----------
Thanks!
Looking at the data for that module, it isn't obvious to me either.
Tac
C?ID=316947
Here is an adaptation map if that's any use:
;SW:3Q0-909-144-L   HW:3Q0-909-144-L ---  Steering Assist
;Component:EPS_MQB_ZFLS  507 5081, Coding:911F0000
;EV_SteerAssisMQB,015157,EV_SteerAssisMQB_015.rod
;Wednesday,24,July,2019,10:07:21:35522
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: 3B203F1543ED0CFFDFB-806F
IDE03724-Straight line running,active ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE06419-Driving profile switchover,Direct: controlled over threshold value ,1
IDE09571-RPM monitoring,active ,1
Elapsed Time: 00:02
Additionally, I peeked at Basic Settings and saw the following options:
IDE06133-Software end-stop reset seems promising, is there any documentation on what it actually does anywhere, and what the steps are?
If there is, I've not seen it.
downtime
Finland
C?ID=280813
I don’t believe that you can change the steering with adaptation. Only way to change the characteristics is to flash a new steering map to the rack. And that you cannot do with VCDS.
Tac
C?ID=316947
I do have access to VCP, but I don't have any idea where to get started with finding parameter files. Is this something I finally need to get erwin/odis stuff for?
siLc
Tallinn, Estonia
C?ID=330192
Do try to figure this out on your own - it's rather bad form asking for support for a competing product. All I can tell the parameters are selected and downloaded within VCP's user interface, provided the cable owner has their subscription active (IIRC). ODIS can also do this but I don't know if you can download parameters from ErWin.
Tac
C?ID=316947
Sorry, I'm not looking for support for VCP. I'm aware of the VCP file manager, I just didn't expect them to have the needed characteristics (in fact, having just now verified, they do not). My question was meant to be more general, if there was a known source, ideally somewhere from VW, to get these characteristics.
Ideally I want to follow up on the "IDE06133-Software end-stop reset" process, as that seems like it'll do what I need it to, without having to flash anything. Is this the kind of information erwin would have? I assume this maps to a process in the controller, so there have to be instructions for it somewhere, I'm just not sure where to look.
Bruce
Near Philadelphia, PA, USA
..... so there have to be instructions for it somewhere, I'm just not sure where to look.
Oh that such a published source was available. Can you imagine how much easier our job would be if VAG published such?
We too seek that information. Unfortunately, that is kept very close to the vest and is not available to the public to the best of our knowledge.
TBAx
DE
C?ID=287144
^downtime:
Unfortunately not. The thread you links is mainly regarding ZF Gen.3 and APA-BS racks, that were used in the Golf MK VI and the like.
However there are some steering characteristics parameter files available (in VCP System), but I would rather try the aforementioned Basic setting to reset the max. steering angle before eventually going into the uncertainty of parameter files.
downtime
Finland
C?ID=280813
Ah ok. Sorry I didn’t read the complete thread through.
Thanks for clarifying :)
Tac
C?ID=316947
So good news/bad news.
Good news is that the software end stop reset process is the same as on the mk6, documented here: http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist#Steering_Limit_Stop_Adaptation You'll receive a "Finished correctly" immediately, but it will go to "Not adapted" until you work through the steps. It's actually even a little simpler. as it'll consider itself adapted when you start turning the steering wheel back for step 4.
The bad news is, while it did let me turn the steering wheel past(!) the previous stop locations when I was doing the basic setting, upon it being finished, the old end stops were back.
I'm not sure where to go next from here, I'm a little hesitant to flash new parameters to the rack, as I certainly do not have a copy of the original ones. I did source frf files with the newest software version directly from VW (all it took is a flight to Germany ;)), but I'm not sure if flashing those would revert the parameter changes. I could always just turn off the software end-stops in the adaptation, but I'm not sure if that has potential for doing any damage long term. Does anyone more familiar with the functionality of these steering racks know how valuable that function is?
For reference:
darkchina811
ITALY
C?ID=333184
depending on the module, parameterization will or won't be affected by flashing a software upgrade, so it looks like jumping a plane without the parachute.
I would say live with it. if you persist, be careful.
Tac: Seldom has this forum seen such dedication in the process of solving a problem - respect!!
