2012 2.0 tdi cjaa ecu failure’s
Tdibros4
Surrey, BC, Canada
C?ID=330170
So a manual 2012 Jetta tdi came to me not running. Accident car btw. I diagnose it. Engine harness was bad for sure, put a new one in and most of the faults were gone. I traced the rest back to the ecu. Replaced it. car ran perfect no codes I call the person to come get their car they get in and it cranks but won’t start. I put the old ecu back in and it starts so I need another ecu. But I’m thinking it’s very rare to have one bad ecu but accident car ok. But then the car was fixed running perfect and I parked it for an hour and came back to a no start.
I’m wondering if there is something car related that is damaging these ecu and if so what could it be?
NostraJackAss
What is damaged in each ECU and auto-scan please.
Maybe your harness repair is incomplete.
Did load light every track?
Is ignition switch + mini harness + terminal relay's all okay?
South Molton, UK
+1 for posting an Auto-Scan :popcorn:
Tdibros4
Surrey, BC, Canada
C?ID=330170
I’ll post an auto scan in a couple hours. I mfeeling pretty confident that they were two unrelated failures because the ecu’s failed in two different manners and one still runs the car. But I’d really like to be sure before I go spend another 700 on an ecu an tuning just to have it fail again. And logic and process of elimination leads me to believe
That if the failures were related it seems to me the only thing that could cause it would be power supply which comes via ignition switch and relay like you mentioned. I did change out the ignition switch with no difference but I do not know which relay powers the ecu in this car and I would really like to test the wiring to and from it and the relay it self but the guys at Malone are telling me if another ecu runs the car there is nothing wrong with the power supply. Anyways auto scan soon to be added. Thanks again to everyone! you helped me get this car code free and running right once I really appreciate it and I’m sure we can do it again
Tdibros4
Surrey, BC, Canada
C?ID=330170
Everything except this mini harness and the terminal relays because I’m not familiar with this mini harness or which relays to test I have the Bentley for cbea engine code not cjaa or any mk6 or mk7 Bentley’s I have been trying to get signed up to use ETKA and Odis but vw says because I’m in Canada for some reason my login won’t work. Needless to say I’m lacking in wiring diagrams for mk6 and mk7 tdi. Auto scan coming
Tdibros4
Surrey, BC, Canada
C?ID=330170
So here are two auto scans. The first one is the ecu that came with the car the second is one I bought and had an immo delete and manifold intake flap delete tuned by Malone. I installed it and ran great then I parked it and it never started the car again but other one will run the car
Wednesday,24,July,2019,10:04:23:45192
VCDS Version: 19.6.0.6 (x64)  HEX-NET CB: 0.4505.4
VIN: 3VWWL7AJ0DM401307   License Plate:
Mileage: 136650km-84910mi   Repair Order: Blk jetta bad ecu#1
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56 77
VIN: 3VWWL7AJ0DM401307   Mileage: 136650km-84910miles
   Part No SW: 03L 906 019 HE    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000SG  8174
   Revision: 12H15---    Serial number:
   Coding: 0050072
   Shop #: WSC 00066 000 00000
   VCID: 75A216E81C71BEE7B6-8020
8 Faults Found:
000387 - Fuel Temp. Sensor A (G81)
               P0183 - 000 - Open or Short to Plus
                    Voltage: 12.24 V
                    Temperature: 36.0°C
                    Temperature: 39.6°C
                    Temperature: 30.6°C
                    Temperature: -90.0°C
000403 - Fuel Pressure Sensor (G247)
               P0193 - 000 - Short to Plus - MIL ON
                    Fault Status: 11100000
                    Voltage: 12.16 V
                    Inj. Quantity: 0.0 mg/str
                    Temperature: 30.6°C
                    Temperature: 36.0°C
                    Temperature: 39.6°C
008215 - Intake Manifold Flap Position Sensor (Bank 1)
               P2017 - 000 - Short to Plus
                    Voltage: 12.16 V
                    Lambda: 4.7 %
                    Lambda: 11.0 %
                    Bin. Bits: 00000000
                    Voltage: 5.016 V
001158 - Exhaust Gas Recirculation Sensor 2
               P0486 - 000 - Electrical Malfunction
                    Voltage: 12.16 V
                    Lambda: 99.4 %
                    Lambda: 0.8 %
                    Voltage: 4.864 V
                    Bin. Bits: 00000000
009573 - Turbocharger Boost Control Position Sensor Circuit
               P2565 - 000 - Signal too High - MIL ON
                    Date: 2013.12.14
                    Time: 00:02:19
                    Voltage: 12.16 V
                    Temperature: 36.0°C
                    Lambda: -2.4 %
                    Bin. Bits: 00000000
                    Voltage: 4.864 V
001030 - EGR Sensor 1
               P0406 - 000 - Signal too High
                    Date: 2013.12.14
                    Time: 00:02:19
                    Voltage: 12.16 V
                    Lambda: -9.5 %
                    Lambda: -1.6 %
                    Voltage: 4.864 V
                    Bin. Bits: 00000000
008200 - Intake Manifold Flap; Bank 1
               P2008 - 000 - Electrical Malfunction
                    Date: 2013.12.14
                    Time: 00:02:19
                    Load: 100.0 %
                    Lambda: 99.4 %
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 36.0°C
000802 - Engine Speed Sensor (G28)
               P0322 - 000 - No Signal
                    Mileage: 136651 km
                    Date: 2013.12.14
                    Time: 00:02:22
                    Voltage: 10.79 V
                    Temperature: 36.0°C
                    Idle Stabilization: 0.0°KW
                    RPM: 148 /min
                    (no units): 1.0
Readiness: 0 0 0 1 1
   Revision: 00H31001
   Coding: B14B400C492200FB8D0E02E492200042211000
   VCID: 7DB20EC8E441E6A7FE-8028
                    Reset counter: 36
                    Mileage: 136651 km
                    Date: 2013.12.14
                    Time: 00:04:01
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 8194
                    Count: 42240
                    Count: 251
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BA    HW: 5C0 820 047 BA
   Component: J301  Klimaanlage   0204
   Revision: 2001012S    Serial number: 00000001278198
   VCID: 608C57BCB3F32B4FF5-8034
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 36
                    Mileage: 136649 km
                    Date: 2013.12.14
                    Time: 00:19:03
                    Reset counter: 76
                    Mileage: 136650 km
                    Date: 2013.12.14
                    Time: 20:16:09
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0256
   Revision: B2066001    Serial number: 04371307120423
   Coding: 73994B9A08230F0008382000240884C50082502E60000000300000000000
   VCID: 2F2EE4807EADC4373C-807A
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Serial number: 14102585131121215058
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AF    HW: 6R0 959 802 AF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  004 3465
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Serial number:     WRH00072H95
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0595039
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 H    HW: 6R0 959 812 H
   Component: J389__TSG_HR  004 3464
   Coding: 800000
03589 - Switch for Driver Side Window Regulator
                    Fault Status: 00101110
                    Reset counter: 76
                    Mileage: 136649 km
                    Date: 2013.12.14
                    Time: 00:02:15
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   014 0808
   Serial number: 003GTM08Y5D1
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3424EBEC9F8BE7EF41-8060
   Serial number: 6940000Y120000LYAK0C
   Coding: 303038
   Serial number: 3572MSME0A64557FZZZ2
   Serial number: 3582MSME6C6D6272ZZZ5
   Serial number: 3516KSME280D201FZZZU
   Serial number: 3526KSME7B553E1FZZZ8
   Serial number: 3556LSME704C5A17ZZZ/
   Serial number: 3566LSME1B0E4D17ZZZ3
   Part No SW: 5C6 920 852 A    HW: 5C6 920 852 A
   Component: KOMBI         H06 0705
   Coding: 370E00
   Shop #: WSC 00066 000 00122
   VCID: 291A0A984849AA07E2-807C
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Motor: keine Kommunikation]
                    Reset counter: 76
                    Mileage: 136651 km
                    Date: 2019.07.24
                    Time: 00:04:21
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0256
   Revision: B2066001
   Coding: 102200
   VCID: 70AC27FCA3139BCF65-8024
                    Reset counter: 76
                    Mileage: 136650 km
                    Date: 2013.12.14
                    Time: 20:16:13
   Component: IMMO          H06 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A9835948DCF611F2B-803E
   Revision: A1001003    Serial number: 7663492811
   Coding: 010100
   VCID: 2A18F594454FA11FEB-807E
                    Reset counter: 76
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 373EDCE046FD0CF764-8062
                    Reset counter: 76
                    Mileage: 136651 km
                    Date: 2013.12.14
                    Time: 00:00:39
                    Voltage: 10.88 V
                        DU
                    Temperature: 28.0°C
                    RPM: 1498 /min
            000 - - - MIL ON
                    Battery Volts: 12.4 V
                        PD
                    Temperature: 27.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0006
   Revision: -----06S    Serial number: VWZ4Z6M3455789
   Coding: 01000400020006
   VCID: 230618B022657057A8-8076
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663433608
   Coding: 0210040000010110
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A38C5D4BDEF119F9B-806E
End----------(Elapsed Time: 01:23, VBatt start/end: 11.9V/12.1V)-----------
01-Engine -- Status: Malfunction 1110
Address 01: Engine        Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 Q    HW: 03L 906 019 DA
   VCID: 3C34C3CC7FDB2FAF89-8068
No Faults Found
   Revision: 00H31001
                    Reset counter: 36
                    Mileage: 136651 km
                    Date: 2013.12.14
                    Time: 00:04:01
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 8194
                    Count: 42240
                    Count: 251
                    Reset counter: 36
                    Mileage: 136649 km
                    Date: 2013.12.14
                    Time: 00:19:03
                    Reset counter: 36
                    Mileage: 136650 km
                    Date: 2013.12.14
                    Time: 20:16:09
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
                    Reset counter: 76
                    Mileage: 136649 km
                    Date: 2013.12.14
                    Time: 00:02:15
   Coding: 00003936
   Coding: 303038
   Coding: 370E00
          U1111 00 [009] - -
                    Reset counter: 36
                    Mileage: 136651 km
                    Date: 2019.07.24
                    Time: 00:04:21
   Revision: B2066001
   Coding: 102200
                    Reset counter: 36
                    Mileage: 136650 km
                    Date: 2013.12.14
                    Time: 20:16:13
   Coding: 010100
                    Reset counter: 36
   Revision: 00H22000
                    Reset counter: 36
                    Mileage: 136651 km
                    Date: 2013.12.14
                    Time: 19:44:16
                    Voltage: 12.13 V
                        DU
                    Temperature: 18.0°C
                    RPM: 1498 /min
            000 - - - MIL ON
                        PD
                    Temperature: 27.0°C
                    Count: 2
                        SteerAng n.Init
End----(Elapsed Time: 01:21, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
NostraJackAss
This sure sounds like a possible bad G28 or a shorted part and most likely to boot something just might be to do with the tuning for FOD?
If it smells like Malone, leave it Alone?
Dont you just love the smell of FOD in the morning?
Why risk the liability?
I I do have some of it. But that's also why I asked I was hoping somebody could share a diagram of the body side of the ecu wiring on mk6 manual jetta tdi
Here you go....... print to PDF :rolleyes:
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
Tdibros4
Surrey, BC, Canada
C?ID=330170
NostraJackAss
it wants me to login and even though I'm registered. I have never been able to login
Logins work fine worldwide today..........try a different browser & without pornware on it!
Tdibros4
Surrey, BC, Canada
C?ID=330170
Not for me or my tech and I’ve been on the phone with vw about this and they haven’t been able to fix it. No worries thought you wouldn’t mind sending a picture but I’ll get the diagrams I need one way or the other. Thanks anyway oh and just FYI the crank sensor only has no signal with this ecu it gets it with other ones and start immediately
NostraJackAss
What made you think that you could get a WD here?
What circuit are you missing a track on?
If you have working ECU why not compare to find condition?
What part number wire harness did you install and if different what car did it come from?
Maybe instead of talking in riddles, describe the different ECU's used and the unique failures?
You have only multiplied FOD!
