Polo AW Park Assist Coding Help
golfman
C?ID=103115
Guys, I'm going to retrofit the park assist to my 2018 VW Polo AW RHD and wondering if anyone could help with the coding? I already have the 8 sensors on the car, so I'll add the remaining 4 sensors and just need to know what needs to be coded.
Any help would be fantastic.
Scott
Monday, 15, July, 2019,15: 06: 00: 03210
VCDS - Windows Based VAG / VAS Emulator Running on Windows 7 x86
VCDS Version: 19.6.1.0 HEX-V2 CB: 0.4508.4
www .Ross-Tech.com
Dealer / Store Name: VCDS
Workshop Code: 444 03743 000001
VIN: WVWZZZAWZKU007157 License Plate: SL68XKS
Mileage: 10669km-6629mi Repair Order:
Chassis Type: AW-VW27 ( 3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 3C 44 5F CA
VIN: WVWZZAWZKU007157 Mileage: 10669km-6629miles
01 Engine - Status: OK 0000
02-Auto Trans - Status: OK 0000
03-ABS Brakes - Status: OK 0000
08-Auto HVAC - Status: OK 0000
09-Cent. Elect. - Status: OK 0000
10-Park / Steer Assist - Status: OK 0000
13-Auto Dist. Reg - Status: OK 0000
15-Airbags - Status: OK 0000
17-Instruments - Status: OK 0000
19-CAN Gateway - Status: OK 0000
3C-Lane Change - Status: OK 0000
44-Steering Assist - - Status: OK 0000
5F Information Electr. - Status: OK 0000
CA-Sunroof - Status: OK 0000
Address 01: Engine (J623 -DKRF ) Labels:. 04E-907-309-V1.clb
  Part No SW: 04C 906 025 M HW: 04C 907 309 BB
  Component: R3 1.0l TFS H20 6196
  Revision: D7H20000 Code
  : 0125003223041D080000
  Shop #: WSC 31414 790 00200
  ASAM Dataset: EV_ECM10TFS01104C906025M 002003
  ROD: EV_ECM10TFS01104C906025B_002_VW27.rod
  VCID: 2A0D01F4AC7FE1F7B4D-807E
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
  Part No SW: 0CW 300 042 D HW: 0AM 927 769E
  Component: GSG DQ200G2_M H05 1606
  Revision: 00005008 Serial number: CU501806176987
  Shop #: WSC 17734 418 534600
  ROD: EV_TCMDQ200021_VW27.rod
  VCID: 372B28806FCD4C1F3B3-8062
  Part No SW: 2Q0 614 517 AD HW: 2Q0 614 517 N
  Component: ESC_base_vFGS H23 0223
  Serial number: 08514728180704
  Coding: 0A034C64354150B432FDAC1B24E142A649124D26226A242444541254452442659248B26444562424222A482AA251D64A3D8A6B52BC
  ASAM data set: 004032 EV_Brake1BOSCHESPMQBA0
  ROD: EV_Brake1BOSCHESPMQBA0.rod
  VCID: 70B9D39C4A23DB273A9-8024
Address 08: Auto HVAC (J255) Labels: * Redir Fail!
  Part No SW: 2G0 907 044 L HW: 2G0 907 044 L
  Component: Climatronic H03 0501
  Coding: 0121000008000100011008010244010D000000000000000000000000
  Shop #: WSC 03743 444 00001
  ASAM Dataset: EV_ACClimaBHBMQBA0 004017
  ROD: EV_ACClimaBHBMQBA0_VW27.rod
  VCID: 2D070AE89D91F6CF51F-8078
  Part No SW: 2Q0 937 090 A HW: 2Q0 937 090
  Component: BCM A0 Hours + H98 0926
  Serial Number: 00001817500231
  ASAM Dataset: EV_BCMA0 204001
  ROD: EV_BCMA0_204.rod
  VCID: 3039139C8AA39B277A9-8064
  Subsystem 1 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
  Component: RLHS 052 0107
  Serial number: SAY18M07D11H03M24S29
  Coding: 0038DD
  Drivers Door Control Modules:
  Subsystem 2 - Part No SW: 2Q2 959 881 D HW: 2Q2 959 881 D
  Component: FHSG_DRV 001 0002
  Serial number: 00000000000021749146
  Coding: 1F0037
  Subsystem 3 - Part No SW: 2Q2 959 882 D HW: 2Q2 959 882 D
  Component: FHSG_PSG 001 0002
  Serial number: 00000000000021753752
  Code: 058037
  Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
  Serial number: 000000000ZY181501S2X
  Component: Siren, DWA 005 0314
  Serial number: 00000000000099190056
  Subsystem 6 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 GB
  Component: FOND_FHSG_DRV 006 0007
  Serial number: 00000000000022454493
  Coding: 1F0000
  Subsystem 7 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 GB
  Component: FOND_FHSG_PSG 006 0007
  Serial number: 00000000000022520572
  Coding: 070000
Address 10: Park / Steer Assist (J446) Labels: | 5Q0-919-294.clb
  Part No SW: 5QA 919 294 C HW: 5QA 919 294
  Component: PDC 8 Channel H07 0050
  Serial number: 000308418018181 Code
  : 0471155011
  ASAM Dataset: EV_EPHVA18AU3700000 009039
  ROD: EV_EPHVA18AU3700000_009_VW27.rod
  VCID: 4CC1676C064BDFC7661-8018
Address 13: Auto Dist. Reg (J428) Labels: | 2Q0-907-572.clb
  Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
  Component: ACCCONTIMQB H02 0233
  Code: 3200600248FF8748949C8145004087
  VCID: 3E253DA440F77D57F85- 806A
Address: Airbags (J234) Labels: * None
  Part No SW: 2Q0 959 655 AG HW: 2Q0 959 655 AG
  Component: VW22Airbag 010 0248
  Revision: --------
  Code: 88CCC0C0000000005C5400CF008800000065
  ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
  ROD: EV_AirbaVW22BPAVW27X.rod
  VCID: 025D8954748FD9B7DCD-8056
  Subsystem 1 - Part No SW: ----------- HW: 442 061 207 18
  Serial number: 3577Y20B127578D2E47A
  Subsystem 2 - Part No SW: ----------- HW: 442 061 207 18
  Serial number: 3587Y20B127578D3D235
  Subsystem 3 - Part No SW: ----------- HW: 442 0B0 707 18
  Serial number: 351778299293EDC5510T
  Subsystem 4 - Part No SW: ----------- HW: 442 0B0 707 18
  Serial number: 35277829B293EDC3E465
  Subsystem 5 - Part No SW: ----------- HW: 442 132 705 18
  Component: FrontSensor_D 290 118A
  Serial number: 355AG11B5298CB11C69%
Address 17: Instruments (J285) Labels: | 5G0-920-XXX-17.clb-SRI3
  Part No SW: 2G0 920 790A HW: 2G0 920 790A
  Component: COMBI 506 1701
  Coding: 20AD010821802600018872095001000000000000
  ASAM Dataset: EV_DashBoardVDDMQBA0 001026
  ROD: EV_DashBoardVDDMQBA0_VW27.rod
  VCID : 2517F2C8C561CE8F99F-8070
Address 19: CAN Gateway (J533) Labels: | 3Q0-907-530-V1.clb
  Part No SW: 3Q0 907 530Q HW: 3Q0 907 530C
  Component: GW MQB High 518 5344
  Serial number: 14061811602488
  Coding: 030100046F085600FA0002481C0F0001000107000000000000000000
  ROD: EV_GatewNF.rod
  VCID: 3D273AA84DF1664FE1F-8068
  Component: 1-00-02-00-04
  Subsystem 2 - Part No SW: 2G0 959 442K HW: 2G0 959 442K
  Component: E221__MFL-DC1 H02 0052
  Serial number: 39170002831130077484
  Coding: 25FFFF
  Subsystem 3 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
  Component: J367-BDMBOSCH H02 2011
  Serial number: 10088840
Address 3C: Lane Change (J1086) Labels: * None
  Part No SW: 2Q0 907 686 A HW : 2Q0 907 686 A
  Component: HRE3_Kl15_Mst H03 0051
  Serial number: 00000435986817
  Coding: 90014500
  ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
  ROD: EV_HREntryHellaGen3Kl15_001_VW48.rod
  VCID: 38292BBC62D34367329-806C
Address 44: Steering Assist (J792) Labels: * None
  Part No SW: 2Q2 909 144 J HW : 2Q2 909 144 F
  Component: TRW_G4L_MQBA0 620 6030
  Serial number: 0646183CB4J1942
  Coding: 00000000000000000101020101000101000001
  ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
  ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
  VCID: 3A2D31B45CDF5177C4D-806E
Address 5F: Information Electr. (J794) Labels: | 5G0-035-MIB-STD2.clb
  Part No SW: 3Q0 035 874C HW: 3Q0 035 874C
  Component: MU-S-ND-ER 853 0890
  Serial number
  : Code: 02720001BE00000041110101008808001F0500F601200000CF
  ROD: EV_MUStd4CDELP_VW27.rod
  VCID: 323D199484AFA9370CD-8066
  Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
  Component: ABT_Std-2_Nav H52 8130
  Serial number: VWZ6ZHV1564256
  Subsystem 2 - Part No SW: 5NA 919 866 AG HW: -----------
  Component: ECE AS 2020 --- 1310
  Serial number: ------------ --------
Address CA: Sunroof (J245) Labels: | 4M0-907-594.clb
  Part No SW: 4M0 907 594 H HW: 4M0 907 594
  Component: SAD_STG_1 014 0005
  Code: 508000727001
  ROD: EV_SunRoofCONTIAU736_006.rod
  VCID: 3B2334B053E5687FDFB-806E
End ---------- (Elapsed Time: 01:17, VBatt start / end: 12.0V / 12.0V) ----
downtime
Finland
C?ID=280813
You need the sensors, switch for PLA and naturally a new module.
Coding needs to be done to ABS, instruments and code the PLA module correctly.
golfman
C?ID=103115
Can anyone help please with exactly what the coding changes need to be?
Kind Regards
Scott
