The other day I noticed that once in awhile the car would kick a bit when engine load changed - it almost felt like a bad engine mount, but would only do it on occasion. Later on that day I came to a stop sign and the car went into limp mode. It had a hard time idling, it was hunting. It responded to the throttle just fine though. I pulled the codes and saw what was listed.
I checked the connector on the TB to make sure it wasn't taunt, unplugged and plugged it back in.
I checked measuring block 62 and all looked good. The pedal angles looked like what they're supposed to all through the pedal travel
I unplugged the MAF to see if that would make any difference and it didn't
I did a TB adaptation and that made no difference
I figured unplugged the MAF might have thrown a new code, so let me clear everything and see what's still in here. As soon as I did that the car runs normal. Did a 15 minute drive around town and it's still good.
I know something is going to die on me at the worst possible time so I'd like to find the root cause of this. Any guesses?
Auto scan here:
Auto scan here:
Friday,19,July,2019,19:49:29:30793
VCDS Version: 19.6.1.0 (x64)
Mode 03: Emission related fault codes
Address 7E8: 2 Faults Found:
P0121 - Throttle Position Sensor (G69): Implausible Signal
P0221 - Angle Sensor 2 for Throttle (G188): Implausible Signal
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWEV71K89W109834 Mileage: 260230km-161699miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: VWX7Z0H83N488U
Coding: 0403010A18070160
VCID: 69D34A474001AB072E-803C
012408 - Throttle Control
P3078 - 000 - Airflow at Idle too Low
Mileage: 258332 km
Time: 19:02:06
RPM: 2340 /min
Load: 12.2 %
Speed: 80.0 km/h
Temperature: 97.0°C
Temperature: 32.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.716 V
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Mileage: 260228 km
Time: 22:14:40
RPM: 2050 /min
Load: 16.1 %
Speed: 55.0 km/h
Temperature: 96.0°C
Temperature: 39.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.589 V
000289 - Throttle Position Sensor (G69)
P0121 - 000 - Implausible Signal - MIL ON
Fault Status: 11100000
Mileage: 260228 km
Time: 22:15:11
RPM: 1642 /min
Load: 17.2 %
Speed: 44.0 km/h
Temperature: 97.0°C
Temperature: 45.0°C
Voltage: 13.335 V
000545 - Angle Sensor 2 for Throttle (G188)
P0221 - 000 - Implausible Signal - MIL ON
Mileage: 260228 km
Time: 22:15:11
RPM: 1642 /min
Load: 17.2 %
Speed: 44.0 km/h
Temperature: 97.0°C
Temperature: 45.0°C
Voltage: 13.335 V
005445 - Throttle Valve Controller
P1545 - 000 - Malfunction - MIL ON
Date: 2047.15.31
Time: 31:63:63
Load: 0.0 %
Temperature: 30.0°C
Temperature: 30.0°C
Voltage: 11.811 V
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 113B600D49220003881306E7921D00413000
Shop #: WSC 51040 001 1048576
VCID: 7EF9091BE98F3CBFEB-802A
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 176
Mileage: 260228 km
Count: 32768
Count: 4608
Count: 8193
Count: 49975
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78F51F030BAB028FA1-802C
Revision: 00H54000 Serial number: 00000008791290
Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
Shop #: WSC 00000 785 00200
VCID: 336FE82F524D21D754-8066
Component: Wischer 280808 021 0501
Coding: 00038805
Revision: 00000000 Serial number: AUZ4Z7H0402709
Coding: 0000100
00003 - Control Module
Fault Status: 00101110
Fault Frequency: 18
Reset counter: 91
Mileage: 225105 km
Time: 18:13:32
Fault Frequency: 8
Reset counter: 83
Mileage: 254509 km
Time: 11:49:15
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0BWM5H
Coding: 0013899
VCID: 6CDD33534FF3BE2F55-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME3F044458E
Subsystem 3 - Serial number: 6342MSME3F326574H
Subsystem 4 - Serial number: 6352QSME45080E1EN
Subsystem 5 - Serial number: 6362QSME0704193CE
Subsystem 6 - Serial number: 63727SME186C182B9
Subsystem 7 - Serial number: 63827SME185929735
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 051 0101
Coding: 0002022
VCID: 010372E75871434796-8054
Component: E0221 002 0010
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
Part No SW: 1K6 920 974 H HW: 1K6 920 974 H
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0003000 Serial number: VWX7Z0H83N488U
Coding: 0007203
VCID: 3973DA077021DB879E-806C
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 260808F2000791
Coding: E9811F070013020000
VCID: 356BD6375C393FE77A-8060
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T42D203
VCID: 7DFB0E17248927A7F2-8028
Component: IMMO VDD 2416
Component: Tuer-SG 006 1207
Coding: 0001077
VCID: 3875DF034B2BC28F61-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Coding: 139006885103281B0904058FB0080A04889C00
VCID: 040D7BF34763566FBD-8050
Coding: 0001076
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74ED2B3317C366EF8D-8020
Component: Radio PM6 019 0037
Revision: 00019000 Serial number: VWZ5Z7H2255538
Coding: 0040401
VCID: 29530A4780816B07EE-807C
Component: RDK 0450
Coding: 0100101
Fault Status: 01110100
Reset counter: 9
Mileage: 237457 km
Time: 07:02:42
End-------------------------(Elapsed Time: 01:49)--------------------------
