09 2.0t CCTA VW GTI - throttle body issues?
gh0st
CT, USA
C?ID=120622
The other day I noticed that once in awhile the car would kick a bit when engine load changed - it almost felt like a bad engine mount, but would only do it on occasion. Later on that day I came to a stop sign and the car went into limp mode. It had a hard time idling, it was hunting. It responded to the throttle just fine though. I pulled the codes and saw what was listed.
I checked the connector on the TB to make sure it wasn't taunt, unplugged and plugged it back in.
I checked measuring block 62 and all looked good. The pedal angles looked like what they're supposed to all through the pedal travel
I unplugged the MAF to see if that would make any difference and it didn't
I did a TB adaptation and that made no difference
I figured unplugged the MAF might have thrown a new code, so let me clear everything and see what's still in here. As soon as I did that the car runs normal. Did a 15 minute drive around town and it's still good.
I know something is going to die on me at the worst possible time so I'd like to find the root cause of this. Any guesses?
Auto scan here:
Friday,19,July,2019,19:49:29:30793
VCDS Version: 19.6.1.0 (x64)
Mode 03: Emission related fault codes
Address 7E8: 2 Faults Found:
P0121 - Throttle Position Sensor (G69): Implausible Signal
P0221 - Angle Sensor 2 for Throttle (G188): Implausible Signal
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWEV71K89W109834   Mileage: 260230km-161699miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AE    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0030
   Revision: AAH03---    Serial number: VWX7Z0H83N488U
   Coding: 0403010A18070160
   VCID: 69D34A474001AB072E-803C
012408 - Throttle Control
               P3078 - 000 - Airflow at Idle too Low
                    Mileage: 258332 km
                    Time: 19:02:06
                    RPM: 2340 /min
                    Load: 12.2 %
                    Speed: 80.0 km/h
                    Temperature: 97.0°C
                    Temperature: 32.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.716 V
000257 - Mass Air Flow Sensor (G70)
               P0101 - 000 - Implausible Signal
                    Mileage: 260228 km
                    Time: 22:14:40
                    RPM: 2050 /min
                    Load: 16.1 %
                    Speed: 55.0 km/h
                    Temperature: 96.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.589 V
000289 - Throttle Position Sensor (G69)
               P0121 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 260228 km
                    Time: 22:15:11
                    RPM: 1642 /min
                    Load: 17.2 %
                    Speed: 44.0 km/h
                    Temperature: 97.0°C
                    Temperature: 45.0°C
                    Voltage: 13.335 V
000545 - Angle Sensor 2 for Throttle (G188)
               P0221 - 000 - Implausible Signal - MIL ON
                    Mileage: 260228 km
                    Time: 22:15:11
                    RPM: 1642 /min
                    Load: 17.2 %
                    Speed: 44.0 km/h
                    Temperature: 97.0°C
                    Temperature: 45.0°C
                    Voltage: 13.335 V
005445 - Throttle Valve Controller
               P1545 - 000 - Malfunction - MIL ON
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 30.0°C
                    Temperature: 30.0°C
                    Voltage: 11.811 V
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 113B600D49220003881306E7921D00413000
   Shop #: WSC 51040 001 1048576
   VCID: 7EF9091BE98F3CBFEB-802A
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 176
                    Mileage: 260228 km
                    Count: 32768
                    Count: 4608
                    Count: 8193
                    Count: 49975
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78F51F030BAB028FA1-802C
   Revision: 00H54000    Serial number: 00000008791290
   Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 336FE82F524D21D754-8066
   Component: Wischer 280808 021  0501
   Coding: 00038805
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0402709
   Coding: 0000100
00003 - Control Module
                    Fault Status: 00101110
                    Fault Frequency: 18
                    Reset counter: 91
                    Mileage: 225105 km
                    Time: 18:13:32
                    Fault Frequency: 8
                    Reset counter: 83
                    Mileage: 254509 km
                    Time: 11:49:15
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0BWM5H
   Coding: 0013899
   VCID: 6CDD33534FF3BE2F55-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME3F044458E
   Subsystem 3 - Serial number: 6342MSME3F326574H
   Subsystem 4 - Serial number: 6352QSME45080E1EN
   Subsystem 5 - Serial number: 6362QSME0704193CE
   Subsystem 6 - Serial number: 63727SME186C182B9
   Subsystem 7 - Serial number: 63827SME185929735
   Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
   Coding: 0002022
   VCID: 010372E75871434796-8054
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1K6 920 974 H    HW: 1K6 920 974 H
   Component: KOMBIINSTRUMENT VDD 2416
   Revision: V0003000    Serial number: VWX7Z0H83N488U
   Coding: 0007203
   VCID: 3973DA077021DB879E-806C
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 260808F2000791
   Coding: E9811F070013020000
   VCID: 356BD6375C393FE77A-8060
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T42D203
   VCID: 7DFB0E17248927A7F2-8028
   Component: IMMO            VDD 2416
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: 3875DF034B2BC28F61-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Coding: 139006885103281B0904058FB0080A04889C00
   VCID: 040D7BF34763566FBD-8050
   Coding: 0001076
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74ED2B3317C366EF8D-8020
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio PM6       019 0037
   Revision: 00019000    Serial number: VWZ5Z7H2255538
   Coding: 0040401
   VCID: 29530A4780816B07EE-807C
   Coding: 0100101
                    Fault Status: 01110100
                    Reset counter: 9
                    Mileage: 237457 km
                    Time: 07:02:42
End-------------------------(Elapsed Time: 01:49)--------------------------
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
Before clearing codes what are the long term fuel trims at idle and part load?
+or- 5% is good.
Also TSB for Throttle Body harness would be a good guess for P0121, P0221 & P1545
Also check your PM I left you one.
Good Luck
Jef
HQ
Take a look at the wiring harness and connector at the throttle body itself. There was an updated terminal housing and terminals for the throttle body. The wires were cut, new wires crimped in and taped up. This was to fix a poor electrical/mechanical connection at the throttle body itself that can cause those types of fault codes.
I did a quick bit of searching and found this:
https://f01.justanswer.com/mike2765/85dc77fc-ef80-4b58-9270-29d8edbb3f46_throttle+tsb.pdf
Verify with your local VW dealer that the part numbers provided are applicable to your VIN.
When this repair is done, it is important to be 100% you don't get any wires mixed up... I did these one wire at a time, double checking the correct location of each wire before I went to the next wire to cut/crimp.
gh0st
CT, USA
C?ID=120622
I drove the car 45 miles to work today and it was OK. I'll check the fuel trim later on.
As far as the TSB, it hasn't been done on my car, but there looks like plenty of slack on the cable. From my understanding the issues was caused because the cable was too tight and the wires would be pulled out of the connector, right?
vwtech
Wilkes-Barre, PA
C?ID=7573
No the pins in connector go bad.
Very common even on older MK4 models but no TSB was ever made for them. They started to fail later in life with high mileage.
MK5 failed at much lower mileage therefor the TSB was produced.
And the parts are not cheap pig tail wires costly for just short pig tails.
Good Luck
NostraJackAss
Stan Lee Marvel Comics is correct ( VWTECH )
When someone can't get the connectors, I have found that taking TV apart drilling holes and soldering wires to the PINS in the TV stationary and crimp clip, then route wires out & fill connector with RTV silicone and too extend the needed length to make new plug in safe area or back to ECU directly + a strain relief with spiral-wrap does a nice trick.
gh0st
CT, USA
C?ID=120622
Ah, ok. That sounds like it applies then. I'll look into doing that. I checked the long term fuel trim (for the 45 miles this morning) and idle was at -0.2% and load was at 0.8%.
