VW Passat 2008 - fault code 01279
Harry2014
C?ID=363851
Hi I have a vw passat in with fault code 01279, the light is on the dash and the auto parking brake is not working. Manually putting parking brake is working fine. I have tried to follow the reset sensor instructions but i keep getting an error code when i get to the group 020 stage:
Longitudinal Acceleration Sensor (G251)
Prerequisites:
System voltage at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 004
[Go!]
Check field 4, the value has to be between -1.5 and +1.5 m/s².
[Done, Go Back]
[53 - Parking Brake]
[Basic Settings - 04]
Group 020
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The status of the Longitudinal Acceleration Sensor (G251) is now being displayed.
[Done, Go Back]
To make sure the basic setting was successful, check the sensor again.
Group 004
[Go!]
Check field 4, the value has to be between -2.5 and +2.5 m/s².
[Done, Go Back]
Any help please??
Autoscan included.
Tuesday,23,July,2019,11:39:52:04590
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWZZZ3CZ8E172687   License Plate: VW PASSAT
Mileage: 232610km-144537mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ8E172687   Mileage: 232610km-144537miles
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 FG    HW: 03G 906 018 FG
   Component: R4 2.0l PPD1.5      0907
   Revision: --H55---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 05314 000 00000
   VCID: EFAE5CBCFE8C6237F0-80BA
Readiness: N/A
   Part No SW: 02E 300 050 D    HW: 02E 927 770 AD
   Component: GSG DSG         082 1404
   Revision: 04808020    Serial number: 00000902181108
   Shop #: WSC 04940 001 00001
   VCID: 9366304CB264E6D7B4-80C6
   Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
   Component: J104    C4 440 V2   0003
   Revision: --020---    Serial number: 00000785044853
   Coding: 0001294
   Shop #: WSC 05311 000 00000
   VCID: 9F0E6C7C4EACB2B700-80CA
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 CR    HW: 3C0 907 044 CR
   Component: ClimatronicPQ46 132 0811
   Revision: 00132023    Serial number: 00000000000000
   VCID: F3A650CC92A446D714-80A6
   Revision: 00H54000    Serial number: 01000007952895
   Coding: E1880F0700041A00470A00000F00000000085D435C000100000000000000
   Shop #: WSC 05124 000 00000
   VCID: F1AA5AC4E8B874C7E6-80A4
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 100108 022  0601
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     160108 046  0204
   Coding: 00208933
   Shop #: WSC 05124
   Component: J234__006 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DP0C9A50
   Coding: 0012342
   VCID: BB36B8ECFA74CE970C-80EE
   Subsystem 1 - Serial number: 6333FTS631803447
   Subsystem 2 - Serial number: 6343FTS660503527
   Subsystem 3 - Serial number: 6353ETS6F586SVNP
   Subsystem 4 - Serial number: 6363ETS66EU8SVNH
   Part No SW: 3C0 953 549 AB    HW: 3C0 953 549 AB
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507AM
   Coding: 0001004
   VCID: EC944BB0CF9A992FD5-80B8
   Part No SW: 3C0 920 960 N    HW: 3C0 920 960 N
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007405
   Shop #: WSC 00401 067 57207
   VCID: AE1081B839062B3FBB-80FA
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P081160A2B
   Coding: FD807F060002022003
   VCID: A306608C62C4965724-80F6
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: B93AA2E4F048FC871E-80EC
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Component: J386  TUER-SG FT    1132
   Revision: 32008001    Serial number: 00000627888115
   Coding: 0000693
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.135 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: B620A9D8C15613FFF3-80E2
   Component:    KSG PQ46 ELV 042 0472
   Coding: 0191020051030E763004941570085FCE1078A1
   Shop #: WSC 00401 210 82584
   Component: LIN BACKUP HORN H08 9001
   Component: Neigungssensor  004 0611
   Component: J387  TUER-SG BT    1132
   Revision: 32008001    Serial number: 00000062588105
   Coding: 0000692
   VCID: BC34BBF0FF7AC9AF05-80E8
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000319606
   Coding: 0000057
   VCID: A91A72A400E84C076E-80FC
                    Fault Status: 11110101
                    Reset counter: 245
                    Mileage: 227787 km
                    Voltage: 13.90 V
                    Count: 101
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No: 1K0 035 186 AD
   Component: Radio GR0       034 0033
   Revision: 0003404S    Serial number: VWZ2Z2H5070305
   Coding: 0040400
   VCID: E89C37A0DB62B50FB1-80BC
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000148399
   Coding: 0000144
   VCID: F0AC5FC0E3B27DCFE9-80A4
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000161632
   Coding: 0000144
End----------(Elapsed Time: 01:38, VBatt start/end: 14.3V/14.3V)-----------
Thanks!
Jef
HQ
When the car parked on a flat and level surface, connect to 53-08-004.4. What is the reading from the G251 sensor? Have parts been replaced on this?
