2012 Audi A4 Allroad SAT NAV
invernesspl
C?ID=345478
I have a 2012 Audi A4 Allroad, The vehicle seems to have had SAT NAV enabled originally, but the display just says 'Please insert Data Medium'. I don't seem to have the original DVD or SD Card (not sure which it should be)
I have tried a 2012 SD Card from VW, but when inserted nothing happens. Does this system use SD Card for the Sat Nav or is it a DVD?
I also read that some models later than 2009 had the DVD drive locked so you can't eject once the Sat Nav disk was inserted by the dealer? Is this the case and can this be overridden with the VCDS if that is the case?
Any help or knowledge would be much appreciated!
Thanks.
siLc
Tallinn, Estonia
C?ID=330192
To find out, post an autoscan of your vehicle so we can see what MMI you have.
invernesspl
C?ID=345478
HI,
Here is the Autoscan. Thanks.
Friday,26,July,2019,11:39:18:41168
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: WAUZZZ8K0DA117808   License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F 62 72
VIN: WAUZZZ8K0DA117808   Mileage: 61750km-38369miles
Address 01: Engine (------CDNC)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115     HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0008
   Revision: ECH09---
   Coding: 32190013242601022000
   Shop #: WSC 27985 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115 001010
   ROD: EV_ECM20TFS0118K5907115.rod
   VCID: 6FBBD0D47717017F777-803A
5456 - Starter Will Not Turn
          P3054 00 [032] - Jammed or Electrical Malfunction
                    Mileage: 61670 km
                    Date: 2019.07.09
                    Time: 09:33:16
                    Engine speed: 0.00 /min
                    Coolant temperature: 30 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 11.732 V
                    Median injection timing: 0.000 ms
                    Engine operating condition: Part. load
                    Engine operating condition-Test_Program_Channel 87: 6
4219 - EVAP Emission Control Sys
          P0441 00 [096] - Incorrect Flow
   Part No SW: 8K9 907 379 L    HW: 8K9 907 379 L
   Component: ESP8 quattro  H09 0100
   Coding: 011544
   Shop #: WSC 06335 000 00000
   VCID: 4BC3644423CF1D5F3BF-801E
   Part No SW: 8K0 907 064 GC    HW: 8K0 907 064 FC
   Component: BCM2 2.0      H11 0621
   Coding: 03B24000000000000000
   VCID: 77ABE8B40FC749BFAF7-8022
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0512000051877021
   Serial number: 2312000170630016
   Part No SW: 8K2 820 043 T    HW: 8K2 820 043 T
   Revision: D1000000    Serial number: 01050820121142
   Coding: 642402C000
   VCID: 3A2D31807C5594D7909-806E
03037 - Rear Temperature Selection Potentiometer (G538)
                    Fault Status: 00101010
                    Reset counter: 7
                    Mileage: 61685 km
                    Voltage: 11.90 V
                    Voltage: 4.90 V
   Part No SW: 8K0 907 063 DD    HW: 8K0 907 063 DD
   Revision: 04016001    Serial number: 00000459292402
   Coding: 290000308034A7C00081000300001F1F001D070827080201000008000000030000000024000000
   VCID: 74B1DFB81EB122A78A5-8020
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 300712  H06 0080
   Serial number: SWF12070305276
   Coding: 00FD11
   Serial number: 20482151
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002407124589
   Serial number: F248CC36000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD94VDS7
   Coding: 30534435363030303030554A3052384B3053
   VCID: 48C95B483239F64716D-801C
   Serial number: 6334MSME6F633104B
   Serial number: 6344MSME701114480
   Serial number: 6352QSME6B1B4566R
   Serial number: 6362QSME342015700
   Serial number: 63732SME5918357E8
   Serial number: 63832SME2C18336C4
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20130726000443
   Coding: 000017
   Shop #: WSC 54929 000 1048576
   VCID: 51FF762CC1E3378F413-8004
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 982 C    HW: 8K0 920 982 C
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RBH7AFK7D
   Coding: 3384290202012600010000
   VCID: 34311FB85E3162A74A5-8060
   Part No SW: 8R0 907 468 H    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0051
   Revision: 1Y050025    Serial number: 2541Y127270196
   Coding: 80CF07FF00
   VCID: 44D14F780E91D227FA5-8010
   Serial number: 8472447901
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 12194002420011200410
            000 -  -  - Intermittent
                    Reset counter: 248
                    Mileage: 61598 km
                    Date: 2019.06.24
                    Time: 13:49:34
                    Bin. Bits:    10000
                    Voltage: 12.00 V
                    Count: 10
   Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000035809798
   Coding: 011002204001410001
   VCID: 50F97328CAE93E874ED-8004
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0022742561
   Coding: 100000000001
   Shop #: WSC 00860 210 94821
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34311FB85EB162A74A5-8060
   Revision: 00002001    Serial number: 0181213698
   Coding: 013B062220BA00408030023680000000
   Revision: 00005001    Serial number: 94813005169002
   VCID: 2D070ADCBD1B336F05B-8078
   Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000035831073
   VCID: 4FFB7054D7D7217F577-801A
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 10000000082855
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 38292B8842D986C766D-806C
   Part No SW: 4G0 035 061 D    HW: 4G0 035 061
   Component: Radio U DAB   H60 0100
   Revision: AB001007    Serial number: 470G/0C7533755
   Coding: 010103010000000001
   VCID: 1E65DD10C0BDD8F78C1-804A
02983 - Connection between Impedance Converter 1 and Window Antenna
                    Fault Status: 00101011
                    Reset counter: 247
                    Mileage: 61593 km
                    Date: 2019.04.10
                    Time: 10:47:56
                    Voltage: 14.80 V
                    Reset counter: 247
   Part No SW: 8R2 035 652 A    HW: 8R2 035 652
   Component: B-BN-EU       H62 0175
   Revision: --------    Serial number: 147GW0C7515061
   Coding: 01010101000681ED01800B4E000000030000
   VCID: 323D19A0A4256C97589-8066
   Subsystem 1 - Part No SW: 8T0 919 604     HW: 8T0 919 604
   Component: DU6 Basic  H42 0098
   Serial number: 9465H00C2563098
   Subsystem 2 - Part No SW: 8T0 919 611     HW: 8T0 919 611
   Component: E0380 Bedient  H01 0100
   Serial number: 00000001232687
   Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000036022505
   Coding: 010002204001210001
   VCID: 43D34C640B9FD51FC3F-8016
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000036022522
End----(Elapsed Time: 01:36, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
invernesspl
C?ID=345478
Here is what I get on the sat Nav display.
https://ibb.co/h1HqD0Y
I have confirmed the car did come with Sat Nav when new.
siLc
Tallinn, Estonia
C?ID=330192
According to THIS, you have MMI 3G High. But you can verify on your own like THAT. This should also answer your question.
invernesspl
C?ID=345478
Thanks, I'll have a good read of that, still unsure if the Nav data should be on the SD Card or a DVD though
