2011 VW Passat ABS Coding
m3nt4l
C?ID=348982
I will be working on a 2011 VW Passat in the next couple of days ( sorry I haven’t had a chance to scan it yet).
The ABS was replaced with a replacement and now needs coding.
I have the following information and was wondering if anyone would be able to provide the correct coding for it:
VIN: Wvwzzz3czbe759923
ABS Part Nr:3AA614109N
Here is the PR Code:
Thanks for your help
m3nt4l
C?ID=348982
A full autoscan would be useful. Any chance of posting one? See below :)
I’m going to be with the car tomorrow so will post one then. I thought maybe with the above information it might be possible to obtain the information
m3nt4l
C?ID=348982
Tuesday,23,July,2019,09:14:54:08713
VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
VIN: WVWZZZ3CZBE759923   License Plate:
Mileage: 159210km-98928mi   Repair Order: ft11 nys
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 37 42 44 46 4F 52 53 56 61
          62 72
VIN: WVWZZZ3CZBE759923   Mileage: 159210km-98928miles
   Part No SW: 03L 906 018 BF    HW: 03L 907 309 N
   Component: R4 2.0l TDI   H24 9978
   Revision: 47H24---    Serial number: 00000000000000
   Coding: 00190012042501080000
   Shop #: WSC 00156 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BF 003008
   ROD: EV_ECM20TDI01103L906018BF.rod
   VCID: 6FAE2D9BB6BF053770-803A
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
                    Mileage: 159214 km
                    Date: 2019.07.23
                    Time: 08:22:37
                    Engine speed: 0.00 /min
                    Coolant temperature: 18 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 12.040 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 4
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
4891 - EGR Valve (N18)
          P0403 00 [237] - Malfunction
                    Mileage: 159214 km
                    Date: 2019.07.23
                    Time: 08:23:18
                    Engine speed: 901.50 /min
                    Normed load value: 41.2 %
                    Coolant temperature: 19 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 14.820 V
                    Air mass: actual value (mg/stroke): 509.3 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 15.00 %
                    EGR Solen.val.: actual value: 106.87 %
                    EGR valve: offset closed: 3.13 %
                    Actuator for high pressure EGR: status-Bits 0-7: 0
                    Actuator for high pressure EGR: status-Bits 0-7: 55
                    High press EGR actuator: actual unconditioned volt val: 689.0 mV
Readiness: 1 1 0 0 1
   Part No SW: 3AA 614 109 N    HW: 3AA 614 109 N
   Component: J104   C2 450M VD71 0005
   Revision: --H07---    Serial number: 00000003826968
   Coding: 0008037
   Shop #: WSC 00028 790 00011
   VCID: 383CD6C74B71828F61-806C
                    Reset counter: 113
                    Speed: 252.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.50 V
                    Bin. Bits: 00011111
                    Count: 212
                    Hex Value: 0x0000
                    Reset counter: 113
                    Reset counter: 113
   Part No SW: 5K0 907 044 ED    HW: 5K0 907 044 ED
   Component: Climatronic   H17 1010
   Revision: 00001003
   Coding: 0000000003
   Shop #: WSC 00015 115 00000
   VCID: 71AA2BE3A08B13C766-8024
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 B    HW: 3AA 937 087 B
   Component: BCM PQ47 H+   413 0452
   Revision: BC413001
   Coding: 0000000000000000009800209400802443517788406007600080C7200041
   Shop #: WSC 05311 000 00000
   VCID: 393AD3C3B07B9B879E-806C
   Subsystem 1 - Part No SW: 3C8 955 119 E    HW: 3C8 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 22041  10  0603
   Coding: 00B795
   Component: RLS 200511 05  54  0403
   Coding: 0330ED
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 77631113104092
   Coding: 108003
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 7CB40AD7F7C96EAFC5-8028
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 04051102850001
   Coding: 010180
   Shop #: WSC 05314 000 00000
   VCID: 271E05BB56CF1D77F8-8072
                    Fault Status: 00101101
                    Reset counter: 153
                    Mileage: 159214 km
                    Date: 2013.12.13
                    Time: 08:22:33
                    Bin. Bits: 00000000 00001010
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__306 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0P9EUPLI
   Coding: 0012342
   VCID: 4CD49A172FE91E2F35-8018
   Subsystem 1 - Serial number: 6332MTS634211111
   Subsystem 2 - Serial number: 6342MTS632681111
   Subsystem 3 - Serial number: 6351HTS6BOHM0AKR
   Subsystem 4 - Serial number: 6361HTS651ON0AKJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010040    Serial number: 20110510100404
   Coding: 0182270000
   VCID: 72A824EFA58D28DF9F-8026
   Coding: E20000
   Part No SW: 3C8 920 970 P    HW: 3C8 920 970 P
   Coding: 440F01
   Shop #: WSC 05314 115 00000
   VCID: 393AD3C3B87B9B879E-806C
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 030511F1001405
   Coding: 469007
   VCID: 312AEBE3680B53C726-8064
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0399
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 76A018FF01E534FFB3-8022
   Part No SW: 3C0 035 279     HW: 3C0 035 279
   Component: RNS315        H05 0010
   Serial number: VWZAZ2L3348065
   Coding: 000004110400000000011000
   ASAM Dataset: EV_RNS315VWEUV1UDS A01005
   ROD: EV_RNS315VWEUV1UDS.rod
   VCID: 608C5EA77B61AA4FF9-8034
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0502
   Revision: 12110009    Serial number: 0002874756
   Coding: 0202B5
   Shop #: WSC 05311 115 00000
   VCID: 6D923793BCB3F72742-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000002170257
   Coding: 000090
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 207    3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 3424E2F7571966EF4D-8060
                    Fault Status: 01101101
                    Reset counter: 113
                    Mileage: 159214 km
                    Date: 2013.12.13
                    Time: 09:02:15
                    Voltage: 12.63 V
                        DD
                    Temperature: 30.0°C
   Component:    KSG PQ47 ELV 043 0631
   Coding: 01910A0001860E763604941570085FCE107C01
   Subsystem 1 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HORN H11 9005
   Component: Neigungssensor  004 0611
   Component: EZE_2         H35 0614
   Coding: 00000008
   VCID: 6FAE2D9BBEBF053770-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0502
   Revision: 14110009    Serial number: 0002870309
   Coding: 0202B4
   VCID: 6E90309FB1B50C3F7B-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000002168671
   Coding: 000090
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000352327
   Coding: 0022067
   VCID: 3326E1EB521761D754-8066
                    Fault Frequency: 14
                    Reset counter: 113
                    Mileage: 159214 km
                    Date: 2013.12.13
                    Time: 08:22:35
                    Voltage: 12.00 V
                    Count: 104
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Component: Batt.regelung H35 0614
   Coding: 030B185A
   VCID: 71AA2BE3A88B13C766-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370471837
End----------(Elapsed Time: 01:30, VBatt start/end: 12.6V/12.6V)-----------
United States
After checking the scan sent via e-mail I agree with Jef's baseline coding however I don't believe it is L0R Right-hand drive specific. If you end up with new DTCs using that value please try: 0004016
That's basically Jef's coding but with RHD active.
0FB0 | 0004016
0DB0 | 0003504
rhinopower
C?ID=58979
001,0,Current Wheel Speed
001,1,Speed Sensor,Front Left (G47),Range: 0.0...255.0 km/h
001,2,Speed Sensor,Front Right (G45),Range: 0.0...255.0 km/h
001,3,Speed Sensor,Rear Left (G46),Range: 0.0...255.0 km/h
001,4,Speed Sensor,Rear Right (G44),Range: 0.0...255.0 km/h
B001,0,Brake System Bleeding
B001,1,Status, ,
B001,2, , ,
B001,3, , ,
B001,4, , ,
003,0,Switches and Warning Lights
003,1,Clutch (F36),& Interlock (N110),1x = Clutch Pedal Switch
operated\nx1 = Interlock Switch active (P/N)
003,2,Brake System,Warning L. (K118)
003,3,ABS,Warning L. (K47)
003,4,ASR/ESP,Warning L. (K155)
004,0,Steering Angle / Lateral Acceleration / Rotation Rate
004,1,Steering Angle,Sensor (G85),Range: -720.0...+720.0 °\nTolerance
(when straight): ±2.5 °
004,2,Lateral Acc.,Sensor (G200),Specification (Standing): ± 1.5 m/s²
004,3,Rotation Rate,Sensor (G202),Range: -69.0...+69.0
°/s\nSpecification: ± 1.5 °/s
004,4,Longitudinal,Acc. Sensor (G251),Specification: ± 1.5 m/s²
005,0,Brake Pressure && Steering Angle Sensor Status
005,1,Brake Pressure,Sensor (G201),Specification: ± 3.0 bar
005,2,Steering Angle,Sensor (G85) Status,Range: Initialised/N.
Initialised/Implausible
005,3,ASR/ESP-Button,(E256),Range: ON/OFF
005,4,Brake Light,Switch (F)
006,0,Voltage Supply
006,1,Voltage,Terminal 15
006,2,Voltage,Term.30 (Valves),Range: 0.0...20.5 V
006,3,Voltage,Term.30 (Logic),Range: 0.0...20.5 V
006,4,Voltage,Pump Motor,Range: 0.0...20.5 V
007,1,EDS Shut-Off,(Overtemp.),1xxx = Front Left\nx1xx = Front
Right\nxx1x = Rear Left\nxxx1 = Rear Right
008,0,Adaptation Status
008,1,Adaptation,Overboost
008,3,Adaptation,Vacuum Level
009,2,Brake Pressure,Sensor (G201)
009,3,Vacuum Pressure,Regulator
010,1,Trailer,Stabilization
010,2,Input,Signals,1xx = Wipers ON\nx1x = Drivers Door OPEN\nxx1 =
Reverse Gear ENGAGED
011,0,Speed Encoder Errors (Front Left)
011,1,Encoder Errors,(G47) Minimum
011,2,Encoder Errors,(G47) Maximum
011,3,Encoder Errors,(G47) Average
012,0,Speed Encoder Errors (Front Right)
012,1,Encoder Errors,(G45) Minimum
012,2,Encoder Errors,(G45) Maximum
012,3,Encoder Errors,(G45) Average
013,0,Speed Encoder Errors (Rear Left)
013,1,Encoder Errors,(G46) Minimum
013,2,Encoder Errors,(G46) Maximum
013,3,Encoder Errors,(G46) Average
014,0,Speed Encoder Errors (Rear Right)
014,1,Encoder Errors,(G44) Minimum
014,2,Encoder Errors,(G44) Maximum
014,3,Encoder Errors,(G44) Average
018,0,Tire Pressure Monitoring (TPMS) III
018,1,TPMS Button,Status,Range: Operated/Not Oper.
B042,0,Tire Pressure Monitoring System (TPMS) Reset
B042,1,Tire Pressure,Monitoring System
B042,2, , ,
B042,3,Reset Status
B042,4, , ,
B042,11,Resetting the Tire Pressure Monitoring System (TPMS) through this
B042,12,Basic Setting will erase all learned Values and active Warnings.
B042,13,It can also be used in cases where TPMS has been retroffitted but
B042,14,the required TPMS Button is not installed yet.
053,3,ESP-Off,Lamp/Message,Range: Lamp ON/ Lamp OFF
053,4,ASR/ESP,Warning L. (K155),Range: ON/OFF
B060,0,Adjustment of Steering Angle Sensor (G85)
B060,1,Adjustment
B060,2,Adjustment,Status,Specification: OK
B060,3,Steering Angle,Sensor (G85),Range: -720.0...+720.0 °\nTolerance
B061,0,Adjustment of Rotation Rate & Lateral/Longit. Acc. Sensor
(G200/G202/G251)
B061,1,Adjustment
B061,2,Adjustment,Status,Specification: OK
B066,0,Adjustment of Brake Pressure Sensor (G201)
B066,1,Adjustment
B066,2,Adjustment,Status,Specification: OK
B066,3,Brake Pressure,Sensor (G201),Specification: ± 7.0 bar
070,1,ESP-Status,,Range: Activated/Not Activated
070,2,ASR-Status,,Range: Activated/Not Activated
070,3,EDS-Status,,Range: Activated/Not Activated
070,4,Auto-Hold,Status,Range: Activated/Not Activated
071,1,Parking Brake,Status,Range: Activated/Not Activated
111,0,Front Left Wheel Speed Sensor
111,1,Status Air Gap,Measurement (FL)
111,2,Air Gap,Measurement (FL)
111,3,Status Rotation,Direction (FL)
111,4,Rotation,Direction (FL)
112,0,Front Right Wheel Speed Sensor
112,1,Status Air Gap,Measurement (FR)
112,2,Air Gap,Measurement (FR)
112,3,Status Rotation,Direction (FR)
112,4,Rotation,Direction (FR)
113,0,Rear Left Wheel Speed Sensor
113,1,Status Air Gap,Measurement (RL)
113,2,Air Gap,Measurement (RL)
113,3,Status Rotation,Direction (RL)
113,4,Rotation,Direction (RL)
114,0,Rear Right Wheel Speed Sensor
114,1,Status Air Gap,Measurement (RR)
114,2,Air Gap,Measurement (RR)
114,3,Status Rotation,Direction (RR)
114,4,Rotation,Direction (RR)
125,0,CAN-Databus Powertrain (Communication)
125,1,Engine,Electronics,Range: Engine 1/Engine 0\nSpecification: Engine
125,2,Transmission,Electronics (J104),Range: Transm. 1/Transm. 0
125,3,Instrument Cluster,(J285),Range: Instruments 1/Instruments
0\nSpecification: Instruments 1
125,4,Steering Angle,Sensor (G85),Range: Steer. ang. 1/Steer. ang.
0\nSpecification: Steer. ang. 1
126,0,CAN-Databus Powertrain (Communication)
126,1,Gateway,(J533),Range: Gateway 1/Gateway 0\nSpecification: Gateway 1
126,2,Airbag,(J234),Range: Airbag 1/Airbag 0\nSpecification: Airbag 1
126,3,All-Wheel,Drive (J492),Range: AWD 1/AWD 0\nSpecification: AWD 1
126,4,Parking Brake,(J540),Range: EPB 1/EPB 0\nSpecification: EPB 1
127,0,CAN-Databus Powertrain (Communication)
127,2,Immobilizer,,Range: Immobilizer 1/Immobilizer 0\nSpecification:
Immobilizer 1
127,3,Steering Aid,(J500),Range: Steering 1/Steering 0\nSpecification:
Steering 1
127,4,Park/Steer,Assist (J791)
LC,00,0,Adaptive Cruise Control Installed (ACC)
LC,00,1,EcoFuel/CNG
LC,00,2,Alltrack
LC,00,3,Alltrack Offroad
LC,01,0,Control Module Coded [STANDART] (WHT...A Wheel Speed Sensors)
LC,01,1,RHD
LC,01,2,Indirect-TMPS installed
LC,01,3,Start/Stop installed
LC,01,4,DSG-02E installed
LC,01,6,Front Assist Installed
LC,01,7,Follow to Stop (DSG/ACC)
LC,02,0~7,B9,Engine Code: CFGB/CFGC Manual
LC,02,0~7,BC,Engine Code: CFGB/CFGC DSG
LC,02,0~7,BF,Engine Code: CFGB/CFGC DSG 4Motion
LC,02,0~7,B6,Engine Code: CFFB Manual 4Motion
LC,02,0~7,B3,Engine Code: CFFB DSG
LC,02,0~7,B0,Engine Code: CFFB Manual
LC,02,0~7,B7,Engine Code: CAYC Manual
LC,02,0~7,A4,Engine Code: BWS DSG 4Motion
LC,02,0~7,A7,Engine Code: CAYC Manual
LC,02,0~7,68,Engine Code: CAXA Manual
LC,02,0~7,6B,Engine Code: CAXA DSG
LC,02,0~7,89,Engine Code: CCZB DSG
LC,02,0~7,86,Engine Code: CCZB Manual
LC,02,0~7,71,Engine Code: CDGA DSG
LC,02,0~7,7A,Engine Code: CDAA DSG
LC,02,0~7,6E,Engine Code: CDGA Manual
S00,Brake Electronics (J104) Security Access
S01,40168 = Basic Setting Enabling
S02,50403 = Adaptation Enabling (Overboost)
S03,70605 = Adaptation Enabling (Park Steer Assist)
A021,0,Overboost (OB) / Overload Operation
A021,5,Overboost (OB) / Overload Operation
A021,6,The Overboost Level specifies how the Hydraulic System will behave
in
A021,7,an Overload Sitation. Check the Data Plate for the Engine Type/PR-
Code.
A021,8,
A021,9, 4 = PR-DB0/D4L/D4X/D31/D42
A021,10,7 = PR-D34/D38/D48/D67/D91/D93/D94/D2D/D2L/DE2/M92
A021,11,X = Other engines
A021,11,
A33,0,
A51,0,
A055,0,Brake Disc Wiper (BDW)
A055,3,Current,Setting
A055,5,Brake Disc Wiper (BDW)
A055,6,This Function is used to keep the Brake Discs dry and clear in
Rainy Weather.
A055,7,Once the Windshield Wipers are active (either manually or
automatically) for
A055,8,longer than 5 Seconds the Brake Disc Wiper will be active as well
and engage
A055,9,the Brake Pads with minimal Brake Pressure. This Procedure will be
repeated
A055,10,occasionally as long as the Windshield Wipers are active.
A055,11,
A055,12,0 = Brake Disc Wiping inactive
A055,13,1 = Brake Disc Wiping active
A056,0,Trailer Stabilization
A056,3,Stabilization,Status
A056,5,Trailer Stabilization
A056,6,0 = Trailer Stabilization inactive
A056,7,1 = Trailer Stabilization active
A056,8,
A056,9,NOTES: Check the PR-Codes for this Vehicle. Trailer Stabilization
MUST NOT be enabled
A056,10,for legal Reasons if any of the following Country Specifications
are listed:
A056,11,PR-B27/B29/B30/B34/B35/B38/B39/BU1/BU2
A061,0,Vacuum Level / Hydraulic Brake Booster (HBO/HBV)
A061,1,Brake Booster
A061,2,Brake Booster,Status
A061,5,Vacuum Level / Hydraulic Brake Booster (HBO/HBV)
A061,6,The Vacuum Level specifies how the Hydraulic Brake Booster.
A061,7,is engaged. Check the Data Plate for the Engine Type/PR-Code.
A061,9,0 = PR-D2D/D2L/D4X/D4L/D34/D38/D42/D48/D67/D91/D93/D94/DB0/DE2/M92
A061,10,1 = PR-D4X(With 1AS)
A061,11,1 = PR-D4L/D42(With 1AS)
A061,12,1 = PR-D2L/D2D/D67(With 1AS)
A061,12,X = Other Engines
A065,0,Hydraulic Braking Power Enhancement
A065,5,Hydraulic Braking Power Enhancement
A065,6,Release of Auto-Hold braking funcion.
A065,7,
A065,8,0 - Disabled 1 - Early
A065,9,2 -Normal (default) 3 - Late
A067,0,Electronic Differential Lock (XDS)
A067,5,Electronic Differential Lock (XDS)
A067,6,The Electronic Differential Lock XDS is an Enhancement to the
existing EDS-Function.
A067,7,
A067,8,0 = Electronic Differential Lock inactive (PR-1Y0)
A067,9,1 = Electronic Differential Lock active (PR-1Y3)
A094,0,Park Steer Assist (PLA)
A094,5,Park Steer Assist (PLA)
A094,6,0 = Park Steer Assist (PLA) NOT installed [PR-7X0/7X1/7X2]
A094,7,1 = Park Steer Assist (PLA) installed [PR-7X5/7X6]
This label file should make coding simple for the b7 abs
rhinopower
C?ID=58979
Thanks! golfi_vend sent us something similar in the past which we added to a FS task (to-do list for label files and coding charts). I'll add this to FS#1351 so we can use the info to build a complete chart.
Best,
I think it originated from him anyway. Makes life so simple
m3nt4l
C?ID=348982
Working!!
Thank you Dana your coding worked perfectly . Sorry for the late reply ive been away.
Thanks!!
