Coding out error message on reverse light bulbs Audi a1
vw754
C?ID=52227
I would like to fit led reverse light bulbs,
I've tried a few canbus ones, still show error / bulb out..... I would like to know if I can disable the error warning with vcds?? ... Audi a1 2011
South Molton, UK
Please post a full unedited VCDS Auto-Scan of your A1 so we can see how your A1 is configured.
vw754
C?ID=52227
Friday,05,July,2019,18:01:53:07086
VCDS Version: 19.6.0.6 (x64)
VIN: WAUZZZ8X5CB039627   License Plate: A1 61 PLATE TDI
Mileage: 219220km-136216mi   Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
VIN: WAUZZZ8X5CB039627   Mileage: 219220km-136216miles
   Part No SW: 03L 906 023 KQ    HW: 03L 906 023 KP
   Component: R4 1.6l TDI   H63 9978
   Revision: --H63---    Serial number:
   Coding: 00114016030501080000
   Shop #: WSC 00046 790 00000
   ASAM Dataset: EV_ECM16TDI02103L906023KQ 003015
   ROD: EV_ECM16TDI02103L906023KG.rod
   VCID: 7F0710B2E6E6D2B7EC-802A
10116 - Fuel Rail/System Pressure
          P0087 00 [096] - Too Low
                    Mileage: 218826 km
                    Date: 2019.05.14
                    Time: 17:31:09
                    Engine speed: 1911.75 /min
                    Vehicle speed: 102 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 14.456 V
                    Unlearning counter according OBD: 27
                    Fuel high pressure: actual value-FUP_FIL: 72.083 MPa
                    Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
                    Fuel level-FTL_CAN: 14 l
                    Fuel temperature-TFU: 62 °C
                    Fuel Metering Valve-VCV: 19.775 %
                    Fuel Pressure Regulator Valve-PCV: 38.029 %
                    Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 79931.641 kPa
10117 - Fuel Pressure Regulation Valve 2 Control Difference
          P229B 00 [104] - Pressure too High
                    Fault Frequency: 60
                    Mileage: 213452 km
                    Date: 2018.11.19
                    Time: 13:18:55
                    Engine speed: 892.75 /min
                    Normed load value: 27.5 %
                    Vehicle speed: 3 km/h
                    Coolant temperature: 58 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 14.118 V
                    Unlearning counter according OBD: 15
                    Fuel high pressure: actual value-FUP_FIL: 48.187 MPa
                    Engine status-SF_ENG_STATE: PL
                    Fuel temperature-TFU: 6 °C
                    Fuel Metering Valve-VCV: 27.116 %
                    Fuel Pressure Regulator Valve-PCV: 0.000 %
                    Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 31555.176 kPa
Readiness: 0 1 0 0 0
   Part No SW: 6R0 907 379 BB    HW: 6R0 907 379 AH
   Component: ESP8.2i front H07 0001
   Revision: --------
   Coding: 330448E9437000BBCC2B12E4C2D800920C00
   Shop #: WSC 00046 000 00000
   VCID: 7F0710B2EAE6D2B7EC-802A
   Part No SW: 8X0 820 045 A    HW: 8X0 820 045 A
   Component: J255 Klima Manuell  0140
   Revision: 0000707S    Serial number: 03030005858844
   VCID: 346D0F9E5720C1EF41-8060
                    Reset counter: 162
                    Mileage: 218708 km
                    Date: 2019.05.12
                    Time: 07:55:43
   Part No SW: 8X0 907 063 G    HW: 8X0 907 063 G
   Component: BCM PQ35  M   110 0655
   Revision: 00110 AE
   Coding: 0E000A2CA805F100201841E020000154538B6C0A01CF4122DC0887830045
   VCID: 4085534ED3986D4FD5-8014
   Subsystem 1 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
   Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
   Component: Airbag10.41   H04 0008
   Revision: --------    Serial number: 003JJ0039CR6
   Coding: 30314539303330303034554A305238583053
   ASAM Dataset: EV_Airba1041BPAAU210 001015
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 48954B6EF3A8550F1D-801C
   Serial number: 3554VRB40570M8GC60TN
   Serial number: 3575HRB405J0OPMG2OOP
   Serial number: 3585HRB40510N3MG8OFP
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB405B0MFP6I0U8
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
   Revision: FF010016    Serial number: 20110913100937
   Coding: 1184004000
   VCID: 39733EAAB8423C8792-806C
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H08 0009
   Part No SW: 8X0 920 980 D    HW: 8X0 920 980 D
   Component: KOMBI_MEDIUM  H03 0179
   Coding: 41DE00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
   VCID: 4085534EDB986D4FD5-8014
   Part No SW: 8U0 907 468 A    HW: 8U0 907 468 A
   Component: GAT 4CAN 1L M H10 0044
   Revision: 1P040023    Serial number: 2341P119180144
   Coding: FBCF005A000100010153
   Subsystem 1 - Part No SW: 8K0 915 181 H    HW: 8K0 915 181 H
   Component: J367-BDM  H07 0171
   Serial number: 00000000007100549523
   Serial number: 11278001482021200181
   Component: IMMO          H03 0179
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 D    HW: 8X0 959 793 D
   Component: TSG FA        H09 0409
   Coding: 011E02200101000100
   VCID: 4E997D7619CC8B3F57-801A
   Part No: 6R0 423 156 B
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F6700F2EA06E2373C-807A
   Part No SW: 8X0 959 792 D    HW: 8X0 959 792 D
   Component: TSG BF        H09 0409
   VCID: 4D9B7A7A14CAB0272E-8018
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Reset counter: 165
                    Mileage: 218732 km
                    Date: 2019.05.13
                    Time: 18:00:59
   Part No SW: 8X0 035 183 E    HW: 8X0 035 183 C
   Component: RMC Cnct      H51 0775
   Coding: 01010001008051070023000103010000010000
   VCID: 39733EAAB0423C8792-806C
   Subsystem 1 - Part No SW: 8X0 919 603     HW: 8X0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9462IW0B0139570
End-------------------------(Elapsed Time: 02:41)--------------------------
vw754
C?ID=52227
                    Mileage: 218826 km
                    Date: 2019.05.14
                    Time: 17:31:09
                    Fault Frequency: 60
                    Mileage: 213452 km
                    Date: 2018.11.19
                    Time: 13:18:55
   Revision: --------
                    Reset counter: 162
                    Mileage: 218708 km
                    Date: 2019.05.12
                    Time: 07:55:43
   Revision: 00110 AE
   Coding: 1184004000
   Coding: 41DE00
   Coding: 000002
   Coding: 11251
   Shop #: WSC 00046
                    Reset counter: 165
                    Mileage: 218732 km
                    Date: 2019.05.13
                    Time: 18:00:59
ANYONE?????
vw754
C?ID=52227
No luck with this then?
langers2k
C?ID=224085
Typically on PQ35 BCM's, the lighting configuration is controlled by byte 18 and the underlying light config in the BCM EEPROM.
Not sure if that also applies to the 8X0 907 063 G in your car, if it does, you'll probably need a different tool :)
