B6 Passat Discover Media Retrofit
dieseltje
The Netherlands
C?ID=148044
Bumping this threat.
Retrofitted also Discover Media in my B6 passat 2008
All works fine, only the issue with readablillity of the screen at day.
Brightness is highest.
Now I found in adaptation maps the possibillity to change value for
Dimming_Ambient Illimination Information control unit X1 u/t X3
Dimming_Ambient Illimination Information control unit Y1 u/t Y3
Dimming Illumination for Display Unit X1 u/t X6
Dimming Illumination for Display Unit Y1 u/t Y6
Is this also the behaviour for dimming at day or only with lights on?
Or is Xx for daytime and Yx for nighttime?
dieseltje
The Netherlands
C?ID=148044
good evening.
Today I connected my VCP cable to my B6 2008 Passat with Discover Media PQ system.
Only one fault is still in module 5F of the DM.
This fault says
Break / short to ground. Lamp OFF status unknown.
This same fault I find in the Gen.3 climatronic unit and occasionally in my B7 Gateway.
Any way to solve this question?
A 2008 B6 is quite different than a 2012 NMS, so split from this thread.
kamold
Australia
C?ID=241363
You need to check what the extended UDS error message is. That's just a generic fault 'break/short to ground'.
It's likely an SVM fault in the Discover unit, and a databus missing message in the climatronics. If so nothing to worry about doesn't affect anything.
dieseltje
The Netherlands
C?ID=148044
Posting a VCDS Auto-Scan might be a good idea :thanks:
I don't have troubles with settings in VCDS. Only the Error in climatronic and Discover Media, where everybody is telling me to ignore it, seems to have a connection with the brightness of the temperature figures and the brightness of the Discover Media Screen (during day time).
As I understand, the B7 BCM has some extra Canbus signals that should support brightness of screens via lightsensor input.
My suspicion is somewhat confirmed by the scan with VCP where the same fault says "Break / short to ground. Lamp OFF status unknown"
I have retrofitted in my 2008 B6, B7 Gateway, B7 CMM, B7 coulor cluster, Discover Media dab+ and 3rd Generation Climatronic unit.
   Part No SW: 35D 907 044 B    HW: 35D 907 044 B
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0600004A02
   ROD: EV_ACClimaBHBVW411_VW46.rod
   VCID: 2649DC71592F0D7FCB-8072
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 14
                    Reset counter: 15
                    Mileage: 376448 km
                    Date: 2019.06.07
                    Time: 14:32:46
   Part No SW: 7N0 907 530 BC    HW: 1K0 907 951
   Component: J533  Gateway H41 1663
   Revision:   H41       Serial number: 260112F2002064
   Coding: 462006
   VCID: 72E1F021AD6721DF97-8026
03175 - Invalid Data Set
                    Reset counter: 15
                    Mileage: 376451 km
                    Date: 2019.06.07
                    Time: 15:32:33
   Part No SW: 5C0 035 680 C    HW: 5C0 035 680 C
   Component: MU-S-ND-ER    H22 0245
   Serial number: VWZAZ2R8029459
   Coding: 027302010000000011111105018808001F0106D4002001008F
   ROD: EV_MUStd4CTSAT_VW46.rod
   VCID: 2143CF6D3001EA47BE-8074
   Subsystem 1 - Part No SW: 5NA 919 866 R    HW: -----------
   Component: ECE AS 19/20  --- 1115
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 15
                    Mileage: 376448 km
                    Date: 2019.06.07
                    Time: 14:32:48
                    Voltage terminal 30: 11.9 V
                    BAP-BAP_Function_ID: 02
South Molton, UK
Any reason why you've posted an edited VCDS Auto-Scan? The full Auto-Scan often shows important other details/information.
dieseltje
The Netherlands
C?ID=148044
I was at work didn't have my home laptop with me.
Saturday,08,June,2019,08:19:10:51200
VCDS Version: 19.6.0.2
Dealer/Shop Name: Haarsma
VIN: WVWZZZ3CZ8E231165   License Plate: xxxxxx
Mileage: 376480km-233933mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 25 36 42 44 46 47 4F 52
          53 5F 62 69 72
VIN: WVWZZZ3CZ8E231165   Mileage: 376480km-233933miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 CN    HW: 03L 907 309
   Component: R4 2,0L EDC F001AG  6220
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 66565 257 00032
   VCID: 73EFF525127D28D79C-8026
   Part No SW: 02E 300 050 D    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 1464
   Revision:    51112    Serial number: 00000902190468
   VCID: 132F95A532BD88D73C-8046
   Part No SW: 3C0 698 109 E    HW: 3C0 614 109 AF
   Component: J104    C4 440 V3   0017
   Revision: --025---    Serial number: 00000104023403
   Coding: 0024854
   VCID: 2C5D2E598FC3372F1D-8078
   Revision: 00001K02
   Coding: 0600004A02
9473393 - Motor for Right Temperature Flap
          B108D 71 [008] - Actuator stuck
                    Reset counter: 55
                    Mileage: 376455 km
                    Date: 2019.06.07
                    Time: 15:57:05
          U1111 00 [009] - -
                    Fault Frequency: 14
                    Reset counter: 15
                    Mileage: 376448 km
                    Date: 2019.06.07
                    Time: 14:32:46
   Revision: 00H54000    Serial number: 01000008249495
   Coding: F5888F3510041A1147000F000F00000080195D436400010C000000000000
   VCID: 71E3FF2D68611AC76E-8024
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 070308 003  0205
   Coding: 00049077
   Shop #: WSC 12345
   Component: RLS     150408 046  0204
   Coding: 00995365
   Shop #: WSC 12345
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 56D 919 475 A    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0006
   Revision: --------    Serial number: 35821333801492
   Coding: 318101
   ASAM Dataset: EV_EPHVA18VW4110000 001007
   ROD: EV_EPHVA18VW4110000.rod
   VCID: 336F35259AFD68D75C-8066
Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
   Part No SW: 3C0 907 567 M    HW: 3AA 907 567
   Component: AC201  RDW A    036 0243
   Revision: 00036000    Serial number: 00000000507894
   Coding: 0010000
   VCID: 356B0B3D5C8976E772-8060
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 24011201770002
   Coding: 030180
   VCID: 2757D17556251477F0-8072
   Component: J234__005 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DP7DDMR3
   Coding: 0012341
   Shop #: WSC 05311 000 00000
   VCID: 3B7F1D057AADA09784-806E
   Subsystem 1 - Serial number: 6333FTS679040708
   Subsystem 2 - Serial number: 6343FTS643870708
   Subsystem 3 - Serial number: 6353ETS6T8U1TVNP
   Subsystem 4 - Serial number: 6363ETS6VSJ1TVNP
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AH    HW: 3C0 953 549 AH
   Component: J0527               0030
   Revision: 00035000    Serial number: 3C0953507
   Coding: 0201822
   VCID: 72E1F0216D6721DF97-8026
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
   Part No SW: 3C8 920 880 T    HW: 3C8 920 880 T
   Component: KOMBI         H04 1008
   Coding: 160D000000
   VCID: 3D7B131DACB9AEA7BA-8068
   Coding: 462006
                    Reset counter: 15
                    Mileage: 376451 km
                    Date: 2019.06.07
                    Time: 15:32:33
   Part No SW: 3AA 959 433 F    HW: 3AA 959 433 E
   Component:    IMMO         042 0429
   Shop #: WSC 43138 001 1048576
   VCID: 3C7D1E197FA3A7AF8D-8068
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000001
   Part No SW: 3C0 959 701 A    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0321
   Revision: 12101005    Serial number: 0000886354
   Coding: 0011F7
   ROD: EV_DCU42BroseDriveSide_VW36.rod
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0307
   Serial number: 00000000331050
   Coding: 0000D0
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.135 H08 1901
   Component:    KSG PQ47 ELV 042 0714
   Coding: 1891020051034E7F00021C1F7008CFCE707801
   Component: LIN BACKUP HORN H08 9001
   Component: Neigungssensor  004 0611
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 3C0 035 456 J    HW: 3C0 035 456 J
   Component: DSP 10 Kanal
   Revision: 00H05001    Serial number: 75815000315901
   VCID: 2757D17596251477F0-8072
   Component: EZE_2         H41 1663
   Coding: 00000009
   VCID: 6FE7F955BE550C3778-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0004
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0006086936
   Coding: 0011F6
   VCID: 36690C31898F7DFF7B-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0307
   Serial number: 00000000340928
   Coding: 0000D0
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   008       Serial number: 00000000055708
   Coding: 0000057
   Shop #: WSC 12346 987 64321
   VCID: 2855D2499B3B1B0FF9-807C
          U1111 00 [009] - -
                    Reset counter: 15
                    Mileage: 376448 km
                    Date: 2019.06.07
                    Time: 14:32:48
   Part No SW: 1K0 907 383 D    HW: 1K0 907 383 B
   Component: Anhaenger     H16 0070
   Revision: 3A002001    Serial number: 00000110888610
   Coding: 0100000200000000
   Shop #: WSC 05314 000 00000
   VCID: 2E59245179DF453F33-807A
End-------------------------(Elapsed Time: 03:30)--------------------------
kamold
Australia
C?ID=241363
This is the climatronics fault with ext UDS:
Part No SW: 3AD 907 044 G HW: 3AD 907 044 G
Component: Climatronic H03 0404
Coding: 0039050004
Shop #: WSC 12345 123 61029
VCID: 372BD5178FC3E79F63E-8062
U1111 00 [009] - -
[Steuergerät für Bordnetz - kein Signal/Kommunikation]
It can't communicate with the BCM because I don't have one. I still have CECM Bordnetz, same as you.
So it might be possible that this is related, although it doesn't cause issues with the version of climatronics panel that I have (a different part number to yours).
dieseltje
The Netherlands
C?ID=148044
My Issue is not that I have this fault, but I suspect that this fault is part of the missing message of dimming signal screen DM and visibility of the figures on the climatronics during (sunny) daytime.
It looks like the dimming signal is inverse, more light, less visibility on screen and climatronic.
Are here guys, who can pick up this signal to do some reverse engineering and make the dimming signal suitable for this setup?
kamold
Australia
C?ID=241363
Can you try a different climatronics panel?
I know the one I have works for example.
siLc
Tallinn, Estonia
C?ID=330192
Funnily enough, neither of my Discover Medias (680B and 680G) I had do any screen brightness changes in regards to ambient light level. Though I have a B7. Perhaps its something you could just turn off in coding/adp?
dieseltje
The Netherlands
C?ID=148044
Its a typicle B6 issue, as this dimm signal is comming via the BCM. B6 doesn’t have BCM.
dieseltje
The Netherlands
C?ID=148044
@Kamold
Whats your climatronic p/n?
siLc
Tallinn, Estonia
C?ID=330192
There aren't many other original options in regards to Climatronic panel. Either 3AA 907 044 or 1K8 907 044 with the appropriate suffix. From the autoscan, your's is the most widespread variant with only seat heating option so if you want to get another one, simply search the base part number and see suitable listings come up. 1K8 if you want the clima knobs to match those on the Discover Media, 3AA for original B7 style chrome knobs. If you want it all to match, including the mirror knob, I have one in Discover Media style mirror knob (no folding mirrors) laying around :)
But compared to the Chinese version 35D, I don't think using a 3AA or 1K8 panel would make a major difference in regards to this DTC.
dieseltje
The Netherlands
C?ID=148044
Thanks. For the looks I maybe will change to the 1K8 type. But back to my problem, the dimming issue. How much work will it take to change my bord netz to BCM?
dieseltje
The Netherlands
C?ID=148044
I have sorted oud one error. Afterwards it was a clear and obvious error.
The fault was revering to UDS and also BAP. So I selected all BAP functions in Adaptations and checked them all. Only the ones I surely new that were necessary I activated (parkassist) all others deactivated.
One of the adaptions which was wrong coded was gen2 amplifier. After deactivating, error was gone.
This adaptation is only necessary when you have new type dynaudio Amp (UDS type) 3AA 035 466. I have the CAN type 3C0 035 456.
