Transmission won't adapt 255 error
64bit
Egypt
O?ID=419934
Hello guys,
In order to find out why my gearbox is horrible I ran the basic settings for the transmission (Using the HEX-V2) - stuck on 255/192 https://ibb.co/SwM02jr"
no idea what it means but i guess it's something wrong with the mechatronic unit and of course because there's no fault codes the dealer claim that everything I experience is normal for this drivetrain:facepalm: guess i'm stuck with this lemon forever...
Any idea why the transmission won't adapt?
here's the AutoScan :
Sunday,21,July,2019,17:50:30:52234
VIN: WVWZZZ6RZFY279292   License Plate:
Mileage: 43383km-26956mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 02 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFY279292   Mileage: 43383km-26956miles
Address 01: Engine (J623-CJZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BB    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H21 9314
   Revision: R4H21---
   Coding: 01250012230411080000
   Shop #: WSC 10690 730 00000
   ASAM Dataset: EV_ECM12TFS01104E906027BB 001010
   ROD: EV_ECM12TFS01104E906027BB.rod
   VCID: 6597B1D1E5ED068F59F-8030
   CAN Converter 01:
   Part No SW: 0CW 300 048 S    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 6560
   Revision: 00043014    Serial number: CU501502095372
   Shop #: WSC 00788 648 00255
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 4CC164756647D7C7661-8018
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08506601150219
   Coding: 21DD2885892A33C9111610720053841491CC88080005CB098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 33331F891BB9A83F07B-8066
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H03 0108
   Serial number:  1502131B-0320
   Coding: 200000011000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 1D67D9318D3D0E4FC1F-8048
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [008] - -
                    Reset counter: 88
                    Mileage: 43054 km
                    Date: 2019.07.06
                    Time: 20:15:18
                    Voltage terminal 30: 14.3 V
                    Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 B    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H07 0065
   Serial number: 001098078832
   Coding: 000018404253007B4B844000400703881000580251010000000000000000
   ASAM Dataset: EV_BCMA0 004008
   ROD: EV_MQBA0.rod
   VCID: 2F3B13F9F7918CDF633-807A
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003021550345083
   Coding: 0400A0
   Subsystem 2 - Part No SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU026011550268194
   Coding: 1400A0
   Subsystem 3 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8611
   Serial number: KU0KU006021550374267
   Coding: 0400A0
   Subsystem 4 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8611
   Serial number: KU0KU005021550363798
   Coding: 1400A0
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag01B 001 0330
   Revision: --------    Serial number: 003LM0095C5Y
   Coding: 88C0C000000000005C0000CA000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 313F1581E1A59A2F757-8064
   Subsystem 1 - Part No SW: -----------    HW: 410 820 202 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A518F2600529E
   Subsystem 2 - Part No SW: -----------    HW: 410 820 202 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00A519B7D32D37-
   Subsystem 3 - Part No SW: -----------    HW: 442 151 202 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00B718F262641BE
   Subsystem 4 - Part No SW: -----------    HW: 442 151 202 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00B718F2624926E
   Part No SW: 6C0 920 740 A    HW: 6C0 920 740 A
   Component: KOMBI         211 0290
   Coding: 0704090821800808000000001000000000000000
   VCID: 2019E0C5BA4F23A7EA9-8074
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H07 0065
   Revision: --------    Serial number: 001098078832
   Coding: 03010004370A560070000000000000010001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   Subsystem 1 - Part No SW: 6C0 959 442     HW: 6C0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H04 0019
   Serial number: 0491504303300520AB1B
   Coding: 240000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 62052J12292821572744
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3211
   Serial number: PF330640
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: 323D1A8DE4A3A1370CD-8066
   Part No SW: 6C0 035 869 B    HW: 6C0 035 869 B
   Component: MU-E--ER      820 6230
   Serial number: 20111400010772
   Coding: 02620000BE00000041110001000130001F0000840000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001017
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 2A0D02EDCC73E9F7B4D-807E
End----------(Elapsed Time: 00:42, VBatt start/end: 12.1V/12.0V)-----------
NostraJackAss
Similar stories for like kind alliances in tech?
https://www.autoblog.com/2019/07/11...h-automatic-problems-before-after-production/
Component: GSG DQ200-MQB H43 6560 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< This firmware level?
Have you checked TSB's because isn't there a firmware update for this trans?
64bit
Egypt
O?ID=419934
I'll ask the dealer if there's any firmware updates available but it won't solve the
Adapting issues - something is faulty
NostraJackAss
Well isn't that the point, if a controller needed a firmware update, than that would imply the mechanics of the component controlled were less than accurately controlled & could of most likely damaged it, right?
64bit
Egypt
O?ID=419934
Sure I agree but at the dealer, they don't get this logic. no ECU fault = CAR IS FINE.
I'm actually tired of booking my car for their "investigations" but I got no choice.
Thank you mate I'll report back
Golftwincharged
Guyana
C?ID=320847
what do you refer to as horrible? what are the symptoms you're having? update to 6561 firmware , not necessary the mech unit has an issue, the clutch and engagement bearings can also relate to unsuccessful basic settings , this 0CW is the updated version of the 0AM, plenty of dry clutch related issues..
