Tiguan N5 2011 ABS lost coding
Marko_O2
Slovenia
C?ID=297545
This is my first post so I hope I don't mess up :-)
I need help with coding of ABS module on Tuguan Y 2011.
Car was brought to me with ABS/ESP lights on.
When I scanned for dtcs there was this one : "01044 - Control Module Incorrectly Coded"
Coding was 000000000
Some mechanic killed coding by entering incorrect value. I don't know why they messed with coding since they only changed oil and brake pads....
Anyway... I tried to do coding but there is no help in coding section for this module. (I use latest vcds version) That is why I tutn to you.
I found some coding help on the net but they didn't work.
Car details: (I also left full autoscan)
Tuguan 2.0tdi y2011
CFFA engine 100 kW
4x4
DSG
tyre monitoring button present
black abs sensors in the back
OFF-road or not that I don't know how to see ???
Please help me with this code or if you have some table of engine codes so I can calculate it.
I found some on the net but there was no 100kW tdi engine on list ....
Thank you
Best regrads
Marko
Friday,19,July,2019,19:59:38:63817
VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
VIN: WVGZZZ5NZBW079714   License Plate:
Mileage: 196010km-121794mi   Repair Order:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 37 42 44 46 4F 52 53 55
          56 62 69 72 77
VIN: WVGZZZ5NZBW079714   Mileage: 196010km-121794miles
Address 01: Engine (J623-CFFA)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 JF    HW: 03L 907 309 R
   Component: R4 2,0L EDC   H23 7417
   Revision: 42H23---    Serial number: 00000000000000
   Coding: 00250012043600080000
   Shop #: WSC 01324 020 00200
   ASAM Dataset: EV_ECM20TDI01103L906018JF 003001
   ROD: EV_ECM20TDI01103L906018JF_VW36.rod
   VCID: 77BE0BE4CE340DF7A8-8022
   Part No SW: 0BH 300 011 S    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H08 1805
   Revision: 00H08V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 3228FAF065D628DF5F-8066
Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
   Part No SW: 5N0 614 109 Q    HW: 5N0 614 109 Q
   Component: J104    C4 450 V210 0006
   Revision: --H28---    Serial number: 00000003581605
   Coding: 0000000
   VCID: 393ACDDC70A0DB879E-806C
                    Reset counter: 16
                    Mileage: 196016 km
                    Date: 2013.12.09
                    Time: 00:42:06
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 169
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000002
   VCID: 6E902E80B16E4C3F7B-803A
   Part No SW: 5K0 937 087 M    HW: 5K0 937 087 M
   Component: BCM PQ35 H    011 0046
   Revision: BE011001
   Coding: 40180A3B88251AC040080080B400092443553088736D85605C8000000040
   VCID: 3FCEA3C4AE84F5B7A0-806A
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 22121  012 0203
   Serial number: N1955119   °203!
   Coding: 009795
   Component: RLS 171210 05  54  0403
   Coding: 03304D
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 P    HW: 3T0 919 475 C
   Component: PARKHILFE PLA H08 0116
   Revision: --------    Serial number: 13991034233272
   Coding: 118103
   VCID: 48DCB818FB4AB20F11-801C
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__200 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PRCHBJ5
   Coding: 0012336
   VCID: 4CD484082F325E2F35-8018
   Subsystem 1 - Serial number: 6332MTS651333380
   Subsystem 2 - Serial number: 6342MTS691633380
   Subsystem 3 - Serial number: 6351HTS67KHFI9KJ
   Subsystem 4 - Serial number: 6361HTS6MGSJI9KR
   Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101222201018
   Coding: 1982140000
   VCID: 7CB414C8F7122EAFC5-8028
   Component: E221__MFL-TAS  H07 0013
   Coding: 820000
   Part No SW: 5N0 920 872 A    HW: 5N0 920 872 A
   Coding: 110F01
   VCID: 302CF0F86BDA1ACF29-8064
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 171210F1003391
   Coding: 356002
   Shop #: WSC 01042 202 104269
   VCID: 312AF5FC68D013C726-8064
   Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
   Component: Haldex 4Motion      0042
   Coding: 0000005
   Component: IMMO          H20 0420
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A9822908D86A01F27-803E
Address 37: Navigation (J794)       Labels:| 3C0-035-270.clb
   Part No SW: 3C0 035 270 B    HW: 3C0 035 270
   Component: RNS310        H19 0353
   Revision: 10000000    Serial number: VWZ1Z2K3888383
   Coding: 000004010400000000000000
   ASAM Dataset: VW_RNS310 A02007
   ROD: EV_VWRNS310UDS.rod
   VCID: 197A2D5C1860FB877E-804C
   Part No SW: 5N0 959 701 E    HW: 5N0 959 701 E
   Component: Tuer-SG         009 2112
   Coding: 0004286
   VCID: 373ECBE446B4CDF768-8062
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.287 0802
   Revision: 1AH03831    Serial number: 00103550320801
   Coding: 0000258
   VCID: 3B36D7D47A9CE9978C-806E
   Component: EZE_2         H35 0614
   Coding: 050B0500
   VCID: 6FAE3384BE64453770-803A
   Component: J245EE20SKB13  H02 0220
   Part No SW: 5N0 959 702 E    HW: 5N0 959 702 E
   Component: Tuer-SG         009 2111
   Coding: 0004542
   VCID: 383CC8D84BAAC28F61-806C
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000094961
   Coding: 0023057
   VCID: 3326FFF452CC21D754-8066
   Coding: 1361094
   VCID: 3424FCE857C226EF4D-8060
   Coding: 00000020
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000020
   Part No SW: 5N0 959 703 D    HW: 5N0 959 703 D
   Component: Tuer-SG         007 2102
   Coding: 0000144
   Shop #: WSC 01324 020 1012552
   Revision: 3A001001    Serial number: 00000140135910
   Coding: 410D000100000000
   VCID: 302CF0F863DA1ACF29-8064
   Part No SW: 5N0 959 704 D    HW: 5N0 959 704 D
   Coding: 0000144
   Part No SW: 5K0 035 730 A    HW: 5K0 035 730 A
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007661530148
   Coding: 0A00000000000001
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 23060FB42A2CB157A4-8076
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
          [Bedieneinheit für Handyvorbereitung (Drei Tasten Module): Unterbrechung]
                    Reset counter: 16
                    Mileage: 196016 km
                    Date: 2019.07.19
                    Time: 00:42:08
9457939 - Telephone baseplate
          B1051 13 [009] - Open Circuit
          [Halterung für Handyhalter (Baseplate): Unterbrechung]
                    Reset counter: 16
                    Mileage: 196016 km
                    Date: 2019.07.19
                    Time: 00:42:08
9458453 - Cellular Antenna
          B1053 15 [009] - Open or Short to Plus
          [GSM-Antenne: Unterbrechung/Kurzschluß nach Plus]
                    Reset counter: 16
                    Mileage: 196016 km
                    Date: 2019.07.19
                    Time: 00:42:08
End----------(Elapsed Time: 01:27, VBatt start/end: 12.4V/12.3V)-----------
Marko_O2
Slovenia
C?ID=297545
Thank you,
I will try it on monday when I get the car back.
Best regards
Marko
Marko_O2
Slovenia
C?ID=297545
I tryed your coding but it is not ok....
these are dtcs now ...
Tuesday,23,July,2019,17:42:44:63817
VCDS Version: Release 19.6.1 Running on Windows 7 x86
Control Module Part Number: 5N0 614 109 Q    HW: 5N0 614 109 Q
  Component and/or Version: J104    C4 450 V216 0006
           Software Coding: 0056641
            Work Shop Code: WSC 01324 020 00200
01324 - Control Module for All Wheel Drive (J492)
                    Reset counter: 22
                    Mileage: 196226 km
                    Date: 2031.14.30
                    Time: 22:28:04
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 242
                    Hex Value: 0x0000
                    Reset counter: 22
                    Mileage: 196226 km
                    Date: 2031.14.30
                    Time: 22:28:04
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 247
                    Hex Value: 0x0000
                    Reset counter: 22
                    Mileage: 196226 km
                    Date: 2031.14.30
                    Time: 22:28:04
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 219
                    Hex Value: 0x0000
                    Reset counter: 22
                    Mileage: 196226 km
                    Date: 2031.14.30
                    Time: 22:28:04
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 169
                    Hex Value: 0x0000
Marko_O2
Slovenia
C?ID=297545
There are no DTCs on other modules....
Marko_O2
Slovenia
C?ID=297545
Hi.
Still the same....
Same 4 dtcs as before
NostraJackAss
Any chance you can find a car or scan in your region or from someone or maybe go visit a dealership for some test drives to grab scans?
Marko_O2
Slovenia
C?ID=297545
Hi
I tried to find a car to scan, but noone had similar engine...
But I DID IT .... I think...
I was trying all possible codings and I found one that works. There are no DTCs. Car drives normaly.
Can anyone check what this coding stands for?
0011591
Thanks for help anyway :-)
Marko_O2
Slovenia
C?ID=297545
