Intermittent failure(s) from rear of car (2010 Audi A3 8P)
uniqueflh
C?ID=328993
Hey there everybody. Wondering in anyone would have any insight to some errors that I'm getting on my dash - and (obviously) on my scan.
Scan is below, but a few details to clarify.
- Seems like I am getting a lot of circuit failure codes from the rear of the car. Including a Bulb Out Warning for a turn signal that is actually working properly.
I am also getting random factory alarm events.
Not positive, but i believe I've solved the alarm issue - the seal/grommet around the rear wiper is letting some moisture seep-in, and it's caused corrosion to form on (what I believe) is the glass breakage sensor. I've cleaned away the corrosion and ordered a new grommet. Alarm has not tripped since cleaning - BUT, it has not rained since I've done the work. Fingers crossed.
I'd like to solve the BOW issue to get that silly light to go out on the dash. Does anyone have any insight on the location of a connector/harness that would possibly impact the other errors? I have pulled the tail lights a few times (over the last 4-years) to clean & re-secure connections...but this problem continues to pop-up. I seem to recall reading that ground/earth corrosion on the VAG cars is common, and that (maybe) the fault is due to insufficiently gauged wires from the factory. Regardless of the root cause - has anyone found a way to successfully eliminate these silly issues? It's really an inconvenience to have to pull the tail lights every few months.
Anyway - any help youse guys can offer is appreciated!!!
Thursday,18,July,2019,20:34:10:42977
VIN: WAUMFAFM8AA145568   License Plate:
Chassis Type: FM-AU35 (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 22 25 42 44 46 47 52 55 56 62
          65 72 77
VIN: WAUMFAFM8AA145568   Mileage: 187720km-116643miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 8P0 907 115 AM    HW: 8P0 907 115 Q
   Revision: AAH16---    Serial number: AUX7Z0J2FN20IQ
   Coding: 0103010A1C0F0160
   Shop #: WSC 06314 000 00000
   VCID: 7DA7046271FB10FFA1F-8028
               P0299 - 000 - Control Range Not Reached - Intermittent
                    Mileage: 187423 km
                    Date: 2019.06.29
                    Time: 20:15:38
                    RPM: 2970 /min
                    Load: 74.9 %
                    Speed: 100.0 km/h
                    Temperature: 98.0°C
                    Temperature: 51.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.462 V
   Part No SW: 02E 300 012 K    HW: 02E 927 770 AT
   Component: GSG DSG AG6     541 2111
   Revision:    54104    Serial number: 00001809290774
   Shop #: WSC 57193 002 1048576
   VCID: 186935F67E99D5D7129-804C
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 1150600F492600FF881006EA92210041390000
   VCID: 7AAD0F7E6CD527C784D-802E
   Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
   Component: KlimavollautomatH09 0150
   Revision: 000887      Serial number: 8P0820043BN
   VCID: 79AF107265D32CDF8D7-802C
   Part No SW: 8P0 907 063 D    HW: 8P0 907 063 D
   Component: BCM PQ35  M   105 0575
   Revision: 00105 AK
   Coding: 2E000A0FB81336E4287041E000100945419E62AA104DD969E40008840040
   Shop #: WSC 06314 123 12345
   VCID: 3537DC42054B08BF29F-8060
   Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
7 Faults Found:
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Reset counter: 161
                    Mileage: 186317 km
                    Date: 2019.05.04
                    Time: 06:32:28
                    Voltage: 13.95 V
                        Term 50 Off
                    Fault Status: 00101010
                    Fault Frequency: 92
                    Reset counter: 200
                    Mileage: 186407 km
                    Date: 2019.05.05
                    Time: 18:49:18
                    Voltage: 13.95 V
                        Term 50 Off
                    Fault Status: 00100111
                    Reset counter: 164
                    Mileage: 186409 km
                    Date: 2019.05.05
                    Time: 18:50:21
                    Voltage: 14.00 V
                        Term 50 Off
                    Fault Status: 00101100
                    Fault Frequency: 12
                    Reset counter: 200
                    Mileage: 185184 km
                    Date: 2018.11.17
                    Time: 14:40:32
                        Term 15 Off
                    Voltage: 12.15 V
                        Term 50 Off
03533 - Right Brake / Signal Light Lamp 2
                    Fault Frequency: 11
                    Reset counter: 200
                    Mileage: 186748 km
                    Date: 2019.05.10
                    Time: 16:50:11
                    Voltage: 13.85 V
                        Term 50 Off
01403 - Glass-Break Sensors; Rear
                    Reset counter: 195
                    Mileage: 187473 km
                        Term 15 Off
                    Voltage: 12.05 V
                        Term 50 Off
                    Fault Status: 00101110
                    Reset counter: 167
                    Mileage: 186480 km
                    Date: 2019.05.07
                    Time: 20:17:13
                    Voltage: 13.95 V
                        Term 50 Off
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7K0571506
   Coding: 0000100
   VCID: 3635DB4E144D03A7205-8062
                    Reset counter: 134
                    Mileage: 186850 km
                    Date: 2019.05.11
                    Time: 09:44:32
01304 - Radio
                    Fault Frequency: 97
                    Reset counter: 196
                    Mileage: 187529 km
                    Date: 2019.07.11
                    Time: 13:20:25
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
   Component: Airbag AU1042 H06 0160
   Revision: --------    Serial number: 003FC00153B7
   Coding: 303142393041303030374A55304C38503053
   ROD: EV_Airba10AURB4.rod
   VCID: 50F98DD69A694D971A9-8004
   Subsystem 1 - Part No SW: 8P0 910 339 C    HW: 8P0 959 339 C
   Component: BF-Gewichtss.  H02 0030
   Serial number: 5810000R0000004CR7
   Serial number: 3572DRB40000AE3921D
   Serial number: 3582DRB40000AE3449D1
   Serial number: 35128RB4000056B7D99Z
   Serial number: 35228RB4000056C1F09O
   Serial number: 35547RB40000573B6B5S
   Serial number: 35647RB40000573C4ADZ
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0014142
   VCID: 46D5AB8E64AD9327B05-8012
   Component: E0221           H02 0100
   Part No SW: 8P0 920 982 N    HW: 8P0 920 982 N
   Component: KOMBIINSTR. VDO H03 0990
   Revision: D0H03005    Serial number: 2242J005002261
   Coding: 0017288
   Shop #: WSC 62954 001 1048576
   VCID: 44D1B1865291A137AE1-8010
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K1030100D0
   Coding: ED837F07100702002102
   VCID: 698F403215739C5F7D7-803C
01304 - Radio
                    Reset counter: 200
                    Mileage: 185034 km
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 43D3B29A579FA60F97B-8016
   Revision: D0H03005    Serial number: AUX7Z0J2FN20IQ
   Part No SW: 8P0 959 801 N    HW: 8P0 959 801 N
   Component: Tuer-SG         H04 0100
   Coding: 0001213
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 232    3501
   Revision: 00H22000
   VCID: 392FD0722553ECDFCD7-806C
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158067916442
   Part No SW: 8P0 959 802 N    HW: 8P0 959 802 N
   Coding: 0001213
   VCID: 47CBA68A63A78A2F4B3-8012
   Part No: 8P3 907 357
   Coding: 0000013
   VCID: 7AAD0F7E60D527C784D-802E
Address 56: Radio
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0001176
   Shop #: WSC 06314 000 1012544
   VCID: 42DDB79E4885AF079CD-8016
Address 65: Tire Pressure        Labels: 8J0-907-273.lbl
   Part No SW: 8J0 907 273 A    HW: 8J0 907 273 A
   Component: J502-RDK        H03 0370
   Revision: --H03-H0    Serial number: 13373700443496
   Coding: 0860021
   Shop #: WSC 06435 000 00000
   VCID: 2F3BEE2AEB17326F633-807A
02214 - Tire Pressure Warning
                    Reset counter: 195
                    Mileage: 187474 km
                    Date: 2019.07.11
                    Time: 09:19:43
                    Bin. Bits: 00001000 10100101
                    Voltage: 14.00 V
                    Text:  25,5°C; -1,25bar;3451164639;00h; 27°C
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0001176
   Part No SW: 8P0 862 335 AB    HW: 8P0 862 335 T
   Component: FSE_256x BT     H38 0600
   Revision: 00000000    Serial number: 00000005032491
   Coding: 0001277
   VCID: 76B51B4E54CD43A7E05-8022
02503 - Output Wire to Radio
                    Reset counter: 75
                    Mileage: 185034 km
                    Date: 2018.11.14
                    Time: 17:50:15
End----------(Elapsed Time: 01:30, VBatt start/end: 13.7V/13.8V)-----------
DrPeter
16.4905° S, 151.7375° W
I would suggest to clear codes, perform an [Output Tests] in the [09-Cent. Elect.] (J519) controller and see if there are any issues with any of the lights you had fault codes for. Also after the Output test, see if any of the codes return.
For inspection purposes, it maybe necessary to remove some rear C-pillar trim to access the connections and ground for the rear lights, see the Official Factory Repair Information for information about these connectors and grounds.
From what I can see, the Ground (#61), Left C-pillar, is for the W3-Luggage compartment lamp and the X-License-Plate Light. The ground (#62), is for the M8-Right rear turn signal bulb and is on the Right C-pillar, so you may have a concern on both side?
If the lights do work, the faults come back and there are no connection issues, it is possible the J519-Vehicle electrical system control module may be faulty.
I, personally had a concern with the rear wiper motor failing due to water leaking through the rear seal, on a A3, that took out/damaged the J519 controller and in that case the left front turn signal would blink a few times and then would stop... Weird failure, so I tend not to rule out the weird or improbable when working with these vehicles.
If you clear the codes and any come back, post a new Auto-Scan for us to see, this may help pin point the actual source or at least the right place to start looking.
Hope this helps,
drpeter
