Recirculation when in auto are
Demo3
C?ID=335057
I am wanting to use the recirculation option when in Auto air temp mode. Is this the coding?
Automatic Air Recirculation
this places the option in the AC setting on the nav screen.
08 Auto HVAC
Long coding
Byte 4
Bit 4-5 use drop down box and select “10 Recirculation Air settings (after ignition cycle) stored.
South Molton, UK
What car, what HVAC module?
Please post an Auto-Scan - many things were changed by VAG from 2016 onwards which meant different coding/adaptation changes may be needed.
Demo3
C?ID=335057
08 Auto HVAC
Long coding
Byte 4
Monday,10,June,2019,20:18:37:21870
VCDS Version: 19.6.0.5 (x64)  HEX-V2 CB: 0.4505.4
VIN: 3VWCA7AU2FM500815   License Plate:
Gateway Installation List:  5Q0 907 530 AC
Monday,10,June,2019,20:22:21:21870
                Address 01: Engine       Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 997 022 N    HW: 04L 907 309
  Component and/or Version: R4 2.0l TDI   H23 9459
           Software Coding: 011D0012032410081000
            Work Shop Code: WSC 20130 444 00000
              ASAM Dataset: EV_ECM20TDI01104L997022N 004002 (VW37)
                       ROD: EV_ECM20TDI01104L997022N.rod
                      VCID: 3B23CBC283E0F63FDF4-806E
8197 - EGT Sensor 1 Bank 1
          P2478 00 [236] - Exhaust Gas Temperature Out of Tolerance
                    Mileage: 45422 km
                    Date: 2019.06.08
                    Time: 08:41:57
                    Engine speed: 1573.00 /min
                    Normed load value: 80.0 %
                    Vehicle speed: 55 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: 102 °C
                    Ambient air pressure: 700 mbar
                    Voltage terminal 30: 14.140 V
                    Engine torque: 132.7 Nm
                    Current operating mode_2-Bits 0-7: 0
                    Current operating mode_2-Bits 0-7: 32
                    Particle filt.inlet temp.sens.1 bank 1: raw value: 653.4 °C
                    Particle filter outlet temp.sens.1 bank 1: raw value: 617.3 °C
                    Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value: 538.8 °C
                    Injection release status-Bits 0-7: 63
Readiness: 1 1 0 0 0
The data you've posted above is only the Gateway's installation list and the ECU, and doesn't include the HVAC module at address 08.
Demo3
C?ID=335057
08 Auto HVAC
Long coding
Byte 4
Monday,03,September,2018,16:31:04:21870
VCDS Version: 18.2.1.2  HEX-V2 CB: 0.4411.4
Mileage: 32368km-20112mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75
VIN: 3VWCA7AU2FM500815   Mileage: 32368km-20112miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 D    HW: 04L 907 309
   Component: R4 2.0l TDI   H23 9283
   Revision: 85H23---
   Shop #: WSC 04908 444 00000
   ASAM Dataset: EV_ECM20TDI01104L906021D 004017
   ROD: EV_ECM20TDI01104L906021D_004.rod
   VCID: 26150AB668625BD72BB-8072
   Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 03253104    Serial number: TFK01412062102
   Shop #: WSC 00066 790 00201
   ROD: EV_TCMDQ250021.rod
   VCID: 231313A21B50AEFF4C5-8076
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 53404000000896
   Coding: 04FA6AA12420096C007F020181C82520562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   ROD: N/A
   VCID: 47CBA732CF28A2DFF0D-8012
   Revision: 00021000    Serial number: 0351474282
   Coding: 030C0C
   VCID: 3A2DCEC68CDACF377F3-806E
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 02020124600100010005004012111400
   VCID: 42DDB626E40A87F7273-8016
   Air quality sensor:
329479 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 15 [008] - Open or Short to Plus
                    Reset counter: 149
                    Mileage: 32362 km
                    Date: 2018.08.31
                    Time: 15:21:31
                    Voltage terminal 30: 12.7 V
                    Outside air temperature: 31.0 °C
                    Interior temperature: 27.9 °C
                    Actual value for fresh air/recirculation air flow flap: 46
                    Actual value for fresh air/recirculation air flow flap: 6.5 %
                    Specified value for fresh air/recirc air flow flap: 46
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Revision: --------    Serial number: 86582711140229
   Coding: 00511A464041A2E969E44000001407001800000000000000000000000000
   Shop #: WSC 00066 790 07031
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4ACD9E06DC3A5FB7EF3-801E
   Component: WWS    141018  043 0581
   Serial number:         150114084629
   Component: RLHS  037 0059
   Serial number: S4Y14M12D03H18M25S29
   Coding: 06A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H02 0003
   Serial number: 0000FST0001HMTX00000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H02 0003
   Serial number: 0000FST0001HLMP00000
   Coding: 191800
                    Fault Frequency: 126
                    Reset counter: 149
                    Mileage: 29291 km
                    Date: 2018.06.24
                    Time: 12:32:55
   Serial number: 003GCR00THW7
   Occupant Detection:
   Serial number: IBH0000J140001UQ5E0H
   Coding: 303137
   Subsystem 2 - Part No SW: -----------    HW: 480 001 411 14
   Serial number: 3570000000015AD8E11P
   Subsystem 3 - Part No SW: -----------    HW: 480 001 411 14
   Serial number: 35800000000C9209E11L
   Subsystem 4 - Part No SW: -----------    HW: 480 400 412 14
   Serial number: 3510002BB18B3AB3B106
   Subsystem 5 - Part No SW: -----------    HW: 480 400 212 14
   Serial number: 35200029B18B3AB551EF
   Subsystem 6 - Part No SW: -----------    HW: 480 401 411 14
   Serial number: 3550002C5188FC11A057
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 411 14
   Serial number: 3560002C7188FC102231
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141203500626
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 0451703EBE9E49C755F-8050
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA5121A2980CF05020878001000000000000000
   Shop #: WSC 00066 790 00195
   VCID: 65974DBA55E490CFE21-8030
   Revision: --------    Serial number: 21121410000112
   Coding: 0901000800087300EF00020A1C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07029
   ROD: EV_GatewConti_011_VW37.rod
   VCID: 72BD26E6942A7777773-8026
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29140002590240094482
   Coding: 29FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0017742
131687 - No Communications with Emergency Call Module
          U10E1 00 [008] - -
          [Timeout Knoten 0x67 / 75 - Notrufmodul]
                    Reset counter: 142
                    Mileage: 32244 km
                    Date: 2018.08.28
                    Time: 16:26:16
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: OFF
   Revision: 00000000    Serial number: 14000337476004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E0FEAEBE3947A5F-8060
   Serial number: 031214060502IW
   Coding: 003A13200000040000000000
   VCID: 40D9BC2EEA0695E7317-8014
   Serial number: 00000000000000509039
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43D3B322FB108EFF2C5-8016
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC4022EEW
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst12C1ALPI 001007
   ROD: EV_AMPMst12C1ALPI.rod
   VCID: 639353A25BD0EEFF0C5-8036
   Serial number: 27121406050622
   Coding: 003A13200C00040000000000
   VCID: 3FDBBFD297F8EA1F48D-806A
   Serial number: 00000000000000431379
   Coding: 091000
   Coding: 060A00010B000400
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 5G0 035 876     HW: 5G0 035 876
   Component: MU-S-NS-US    014 0645
   Serial number: V7B01412140069
   Coding: 027302020000000021220002001800001F0100340100010546
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 698F418AB9FCB4AFC69-803C
   Subsystem 1 - Part No SW: 5G0 919 605 K    HW: 5G0 919 605 K
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS600CNM
   Subsystem 2 - Part No SW: 5G0 919 866 S    HW: -----------
   Component:  NAR 2015  --- 0022
   Component: OCULowMQBUS   007 0564
   Shop #: WSC 00066 790 07177
   ROD: EV_OCULowMQB.rod
End----(Elapsed Time: 02:07, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
08 Auto HVAC
Long coding
Byte 4
Yes, now that we can see the exact HVAC module you've got, we can confirm that those instructions appear to be applicable to that module.
Demo3
C?ID=335057
Thanks Dr. Strange!
