Dpf pressure sensor problem after stage 2
MrGurkan
Sweden
I have a problem I can't get rid of and have a long road trip in front of me. After I had done stage 2 and removed catalyst and diesel particulate filter at a workshop that programmed them away from ecu, I got problem with dpf pressure sensor. I have tested change sensor, checked leakage and wiring to sensor but still does not work. I have read that it should help to do a calibration of sensor with vcds. I have search but I cannot get into Coding II with code 30605. Best regards Robert from sweden
Tuesday,16,July,2019,11:47:29:02028
VCDS Version: 19.6.1.0 (x64)
VIN: WAUZZZ4F6BN062375 License Plate:
Chassis Type: 4F-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 18 19 34 42 46 4F 52 53 55 56
5F 62 69 6D 72 76
VIN: WAUZZZ4F6BN062375 Mileage: 179500km-111536miles
Address 01: Engine (CDY) Labels: Redir Fail!
Part No SW: 4F9 910 402 A HW: 4F0 907 401 E
Component: 3.0TDI EDC17G004AG 0080
Revision: 16H14--- Serial number:
Coding: 0125002C191F0928
Shop #: WSC 40970 222 95490
VCID: 247E7C85E7DC136FDD-8070
001139 - Exhaust Pressure Sensor 1
P0473 - 001 - Signal too High - MIL ON
Fault Status: 11100001
Mileage: 178502 km
Date: 2019.07.15
Time: 13:47:56
RPM: 1680 /min
Speed: 30.2 km/h
Pressure: 94 mbar
Temperature: 28.8°C
Temperature: -5.9°C
Pressure: 6 mbar
(no units): 211.5
001152 - Coolant Fan Control Circuit 1
P0480 - 000 - Electrical Malfunction
Mileage: 178502 km
Date: 2019.07.15
Time: 13:47:56
RPM: 1680 /min
Speed: 30.2 km/h
Temperature: 28.8°C
Mass Air / Rev.: 487.6 mg/str
Duty Cycle: 19.7 %
Temperature: -5.9°C
001683 - Fan 2 Control Circuit
P0693 - 000 - Short to GND
Mileage: 178502 km
Date: 2019.07.15
Time: 13:48:06
RPM: 1281 /min
Speed: 23.5 km/h
Temperature: 27.9°C
Mass Air / Rev.: 376.0 mg/str
Duty Cycle: 19.7 %
Temperature: -5.9°C
001153 - Coolant Fan Control Circuit 2
P0481 - 000 - Electrical Malfunction
Mileage: 178502 km
Date: 2019.07.15
Time: 13:48:06
RPM: 1260 /min
Speed: 24.6 km/h
Temperature: 27.9°C
Mass Air / Rev.: 340.8 mg/str
Duty Cycle: 19.7 %
Temperature: -5.9°C
Readiness: 1 1 0 0 0
Part No SW: 4F2 910 156 R HW: 09L 927 156 C
Component: AG6 09L 3,0 TDI RdW 0050
Revision: --H05--- Serial number: 4608058
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 345E8CC5573C83EF4D-8060
006241 - Throttle Position Sensor (G79)
P1861 - 000 - Error Message from ECU - Intermittent
Mileage: 178418 km
Date: 2019.07.14
Time: 11:40:17
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AM HW: 4F0 614 517 BK
Component: ESP8 quattro H03 0100
Coding: 0000396
VCID: 6FD443A97E9AE03770-803A
Fault Status: 00101101
Reset counter: 4
Mileage: 178418 km
Date: 2019.07.14
Time: 11:40:16
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x0029
Hex Value: 0x0192
Hex Value: 0x00FF
Viking
C?ID=151455
If you've had the dpf removed then I'm curious as to why the ECU is reading the pressure sensor. I'd probably be back to the tuner (or workshop) who supposedly removed them from the ECU.
