Hello, currently I'm trying to adapt an S-tronic with the following story. The car (2010 Audi S4 S-tronic) was towed in with very jerky starting in 1st/R gears. Scanning it then gave me:
Checking the ATF level (per factory specs) showed that it was 0.5L low on ATF and it looked slightly brown with no burnt smell. Filled it up with OE fluid, cleared engine and transmission fault codes, here's the scan.
Then went on to do the basic settings as per:
http://wiki.ross-tech.com/wiki/index.php/7-Speed_S-Tronic_Direct-Shift_Gearbox_(DSG/0B5)
After this step:
Select Erase counter for start and stop processes
[Go!] to activate the Basic Setting.
I immediately get an error:
ERROR: Request out of range
If I try to continue and do:
Select Clutch valve calibration [Go!] to activate the Basic Setting.
It runs for a few seconds and the I get an error:
Aborted for safety reasons (or something similar)
If I try to drive the car, it still jerks when in D trying to pull off sometimes pretty violently and sometimes a bit smooth. The car jerks forward, then it feels like the clutch disengages and the engine revs rise to 1000 - 1300 rpm.
It is very random. It feels very similar to a manual clutch (from back in the day) when you misjudge the engagement point of the clutch and car jerks violently and sometimes the engine stalls (here it doesn't stall as the clutch seems to disengage and engine revs rise).
There are no codes whatsoever after the only 1 clear all I have done after the fluid correction.
I tried to check all kinds of TPIs for the codes above and nothing comes up.
Of course a new transmission, clutch and mechatronic will fix it. I would like to first find out what exactly is the problem for the jerky start and for the basic settings errors (probably they are related).
Anyone has seen this or has any ideas? Thanks in advance!
Tuesday,16,July,2019,17:18:01:35753
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUKGAFL2AA069194 License Plate: INITIAL 2019.07.16
Mileage: 157330km-97760mi Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 47 52 53 55 56 5F 62
72
VIN: WAUKGAFL2AA069194 Mileage: 157330km-97760miles
09-Cent. Elect. -- Status: Malfunction 1010
Address 01: Engine (J623-CCBA) Labels:. 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H06 0003
Revision: --H06---
Coding: 0104000A240F0128
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
ROD: EV_ECM30TFS0218K0907551D.rod
VCID: 3228E95765A4C8DF5F-8066
7810 - Intake Air Regulating Flap
P10A4 00 [096] - Mechanical Malfunction
Mileage: 157319 km
Date: 2019.05.03
Time: 14:13:24
Engine speed: 0.00 /min
Coolant temperature: 93 °C
Intake air temperature: 51 °C
Ambient air pressure: 950 mbar
Voltage terminal 30: 12.898 V
Unlearning counter according OBD: 37
Engine speed: actual: 0 /min
PDT_ENVD: 875.59570 hPa
RFP_AD_STOP_SAVE_LOW_ENVD: 2
RFP_AD_STOP_SAVE_HIGH_ENVD: 0
VP_RFP_AD_LIH_1_ENVD: 4.39453 V
VP_RFP_BOL_MTC_1_ENVD: 0.52734 V
6506 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [104] - -
Mileage: 157308 km
Date: 2019.05.03
Time: 13:42:47
Engine speed: 516.00 /min
Normed load value: 34.5 %
Coolant temperature: 98 °C
Intake air temperature: 60 °C
Voltage terminal 30: 12.288 V
Engine speed: actual: 1152 /min
MAF_ENVD: 245.11764 mg/stroke
Coolant temperature (unfiltered): 20.3 °C
Engine: operating status: IS
Engine load: 17.968750 %
Vehicle speed: actual: 0 km/h
Readiness: 0000 0001
Part No SW: 8K0 927 156 M HW: 0B5 927 156 E
Component: 0B5 30TFSINAR H03 0008
Revision: --H03--- Serial number: 0000001362
ASAM Dataset: EV_TCMDL501 A02044
ROD: EV_TCMDL501.rod
VCID: 3E30CD67A1FC1CBFAB-806A
8021 - Clutch
P2789 00 [100] - Adaptive Learning at Limit
Mileage: 157308 km
Date: 2019.05.03
Time: 13:30:58
Engine speed: 666 /min
Transmission input speed: 666 /min
Engine torque: 4 Nm
Transmission fluid temperature: 61 °C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen offen
8957 - Clutch 1
P17D6 00 [104] - Pressure too High
Reset counter: 37
Mileage: 157308 km
Date: 2019.05.03
Time: 13:41:06
Engine speed: 596 /min
Transmission input speed: 596 /min
Transmission output speed: 15 /min
Engine torque: 20 Nm
Transmission fluid temperature: 85 °C
Clutch status: Kupplung 1 kann Moment übertragen
8962 - Clutch 2
P17D7 00 [104] - Pressure too High
Reset counter: 37
Mileage: 157308 km
Date: 2019.05.03
Time: 13:39:57
Engine speed: 519 /min
Transmission input speed: 519 /min
Transmission output speed: 18 /min
Engine torque: 16 Nm
Transmission fluid temperature: 83 °C
Clutch status: Kupplung 2 kann Moment übertragen
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0010
Coding: 290D18
VCID: 7AB80177F554F09FD7-802E
Fault Status: 00101101
Reset counter: 54
Mileage: 157308 km
Date: 2019.05.03
Time: 13:39:57
Hex Value: 0x00C0
Hex Value: 0x4082
Hex Value: 0x0027
Hex Value: 0x23A1
Hex Value: 0x00FF
02214 - Tire Pressure Warning
Reset counter: 17
Mileage: 157328 km
Date: 2019.06.25
Time: 15:13:07
Hex Value: 0x4300
Hex Value: 0x4006
Hex Value: 0x1237
Hex Value: 0x19B0
Hex Value: 0x00FF
Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
Component: BCM2 1.1 H02 0326
Coding: 0D0100
VCID: 78BC1B7FCB58E28FA1-802C
Subsystem 1 - Part No SW: 8T0 959 754 AJ HW: 8T0 959 754 AJ
Component: FBSAUDIB8 IDG H38 0060
Serial number: 0509000050783016
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000073092009
00192 - Rear Left Door Handle Touch Sensor (G417)
Fault Status: 00101011
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.07
Time: 17:07:15
03285 - Sensor for Contact with Door Handle; Front Left
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.10
Time: 08:31:09
Fault Status: 00100001
Fault Frequency: 12
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:08:43
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 14:58:08
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01061020091259
Coding: 66102000
VCID: 004C739F9388AA4F99-8054
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000359769
Coding: 26001811003CAF010000080300003D0D0F1C520800010161000000
Shop #: WSC 06325 123 12345
VCID: 3C34C76FBFE00EAF85-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 021009 H06 0070
Serial number: SWF09100020282
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10621974
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000002809090578
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 13:37:00
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H39 0560
Serial number: 003EGD051ZFG
Coding: 303836354230303030304A55304C384B3053
VCID: 42C8B997D504785FCF-8016
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900004EMV
Serial number: 6334MSME4B2239127
Serial number: 6344MSME4B605A32F
Serial number: 6352QSME273D0D0AP
Serial number: 6362QSME0B3B3F28V
Serial number: 63732SME353D5426/
Serial number: 63832SME1D3C4A1CD
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319IJ2000BI
Coding: 000036
VCID: 3D32CA6BA4FA07A7B2-8068
Component: E221 - MFL H02 0003
Fault Frequency: 8
Part No SW: 8K0 920 980 Q HW: 8K0 920 980 Q
Component: KOMBIINSTR. H05 0255
Revision: 00000000 Serial number: CJ23185A9
Coding: 839F09000300D705020000
VCID: 40CCB39FD3086A4FD9-8014
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E099298053
Coding: 00C303
VCID: 52E889D70D64E8DF7F-8006
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
Serial number: 19090299100909
Fault Frequency: 25
Reset counter: 54
Mileage: 157321 km
Date: 2019.05.31
Time: 13:51:53
Bin. Bits: 10000
Voltage: 11.50 V
Count: 10
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 08:09:27
Bin. Bits: 00011
Voltage: 10.80 V
Count: 6
Bin. Bits: 10000
Time: 0.90 s
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:17:30
Bin. Bits: 10000
Voltage: 15.80 V
Count: 19
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00001010006691
Coding: 00581B00000000000000
VCID: 3B36C473BAEE09978C-806E
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:16:17
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 13:38:26
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009405935
Coding: 011C13204E00410001
VCID: 45C2A28BCC2A4F67EA-8010
02123 - Door Warning Light / Entry Light
Fault Status: 00101100
Reset counter: 54
Mileage: 157321 km
Date: 2019.05.28
Time: 12:08:19
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 14:44:32
Revision: 00002001 Serial number: 0122016630
Coding: 01060E3A007E440500B0010000000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000171415
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS037 H06 0041
9 Faults Found:
02771 - Bulb for Left Brake / Turn Signal / Tail Lamp (M69)
Reset counter: 54
Mileage: 157308 km
Date: 2019.04.30
Time: 20:11:06
02901 - Lamp for Brake / Blink / Parking 2; Left (M72)
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 15:27:31
02902 - Lamp for Brake / Blink / Parking 2; Right (M73)
Reset counter: 54
Mileage: 157308 km
Date: 2019.05.03
Time: 11:57:48
02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
Reset counter: 54
Mileage: 157319 km
Date: 2019.05.07
Time: 16:53:50
02742 - Bulb for Brake/Turn Signal Light; Left
Reset counter: 54
Mileage: 157319 km
Date: 2019.05.07
Time: 16:53:50
02743 - Bulb for Brake/Turn Signal Light; Right
Reset counter: 54
Mileage: 157319 km
Date: 2019.05.07
Time: 16:53:50
Reset counter: 54
Mileage: 157319 km
Date: 2019.05.07
Time: 16:53:51
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 08:09:27
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:09:25
Part No SW: 8T0 035 223 AK HW: 8T0 035 223 AK
Component: DSP Prem H08 0170
Revision: 00008001 Serial number: 34881005584803
VCID: 77BE1843C646EDF7A8-8022
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009449734
VCID: 44C4BF8FC710766FFD-8010
Fault Frequency: 11
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:05:36
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:56:56
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000464604
VCID: 3424EF4F97B0C6EF4D-8060
Reset counter: 14
Mileage: 157321 km
Date: 2019.06.21
Time: 13:38:15
Voltage: 16.20 V
Count: 45
Hex Value: 0x0860
Hex Value: 0x0088
Hex Value: 0x0101
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 77BE18430646EDF7A8-8022
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335J-097532545
Coding: 020000010000000001
VCID: 1D722AEB043A67A792-8048
Part No SW: 8T1 035 664 A HW: 8T1 035 664 A
Component: H-BN-NA H41 0042
Revision: -------- Serial number: 490JZ097519411
Coding: 010200000206A1EC41000F0C000000030000
VCID: 3620D54781CCD4FF73-8062
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356JL091080031
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000373517
Component: CD-Database 1293
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102027796
Coding: 010C13204000210001
VCID: 42C8B997DD04785FCF-8016
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 14:44:32
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102027777
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:05:38
End----------(Elapsed Time: 01:50, VBatt start/end: 12.3V/12.3V)-----------
Wednesday,17,July,2019,13:18:07:35753
VIN: WAUKGAFL2AA069194 License Plate: AFTER CLEAR
72
Revision: --H06---
Readiness: 1110 0001
Coding: 290D18
Reset counter: 54
Mileage: 157308 km
Date: 2019.05.03
Time: 13:39:57
Hex Value: 0x00C0
Hex Value: 0x4082
Hex Value: 0x0027
Hex Value: 0x23A1
Hex Value: 0x00FF
Fault Frequency: 16
Reset counter: 19
Mileage: 157328 km
Date: 2019.06.25
Time: 15:13:07
Hex Value: 0x4300
Hex Value: 0x4006
Hex Value: 0x1237
Hex Value: 0x19B0
Hex Value: 0x00FF
Coding: 0D0100
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.07
Time: 17:07:15
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.10
Time: 08:31:09
Fault Frequency: 12
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:08:43
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 14:58:08
Coding: 66102000
Coding: 00FD11
Coding: 025028
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 13:37:00
Coding: 000036
Fault Frequency: 8
Coding: 00C303
Fault Frequency: 25
Reset counter: 54
Mileage: 157321 km
Date: 2019.05.31
Time: 13:51:53
Bin. Bits: 10000
Voltage: 11.50 V
Count: 10
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 08:09:27
Bin. Bits: 00011
Voltage: 10.80 V
Count: 6
Bin. Bits: 10000
Time: 0.90 s
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:17:30
Bin. Bits: 10000
Voltage: 15.80 V
Count: 19
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:16:17
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 13:38:26
Reset counter: 54
Mileage: 157321 km
Date: 2019.05.28
Time: 12:08:19
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 14:44:32
9 Faults Found:
Reset counter: 54
Mileage: 157308 km
Date: 2019.04.30
Time: 20:11:06
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 15:27:31
Reset counter: 54
Mileage: 157308 km
Date: 2019.05.03
Time: 11:57:48
Reset counter: 54
Mileage: 157319 km
Date: 2019.05.07
Time: 16:53:50
Reset counter: 54
Mileage: 157319 km
Date: 2019.05.07
Time: 16:53:50
Reset counter: 54
Mileage: 157319 km
Date: 2019.05.07
Time: 16:53:50
Reset counter: 54
Mileage: 157319 km
Date: 2019.05.07
Time: 16:53:51
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 08:09:27
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:09:25
Fault Frequency: 11
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:05:36
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:56:56
Reset counter: 14
Mileage: 157321 km
Date: 2019.06.21
Time: 13:38:15
Voltage: 16.20 V
Count: 45
Hex Value: 0x0860
Hex Value: 0x0088
Hex Value: 0x0101
Coding: 0000004
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 14:44:32
Reset counter: 54
Mileage: 157321 km
Date: 2019.06.21
Time: 10:05:38
After this step:
