0B5 S-tronic adaptation error/jerky start - 2010 Audi S4
Grigor
C?ID=118822
Hello, currently I'm trying to adapt an S-tronic with the following story. The car (2010 Audi S4 S-tronic) was towed in with very jerky starting in 1st/R gears. Scanning it then gave me:
Tuesday,16,July,2019,17:18:01:35753
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUKGAFL2AA069194   License Plate: INITIAL 2019.07.16
Mileage: 157330km-97760mi   Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 47 52 53 55 56 5F 62
          72
VIN: WAUKGAFL2AA069194   Mileage: 157330km-97760miles
09-Cent. Elect. -- Status: Malfunction 1010
Address 01: Engine (J623-CCBA)       Labels:. 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
   Component: 3.0T SIMOS84  H06 0003
   Revision: --H06---
   Coding: 0104000A240F0128
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
   ROD: EV_ECM30TFS0218K0907551D.rod
   VCID: 3228E95765A4C8DF5F-8066
7810 - Intake Air Regulating Flap
          P10A4 00 [096] - Mechanical Malfunction
                    Mileage: 157319 km
                    Date: 2019.05.03
                    Time: 14:13:24
                    Engine speed: 0.00 /min
                    Coolant temperature: 93 °C
                    Intake air temperature: 51 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 12.898 V
                    Unlearning counter according OBD: 37
                    Engine speed: actual: 0 /min
                    PDT_ENVD: 875.59570 hPa
                    RFP_AD_STOP_SAVE_LOW_ENVD: 2
                    RFP_AD_STOP_SAVE_HIGH_ENVD: 0
                    VP_RFP_AD_LIH_1_ENVD: 4.39453 V
                    VP_RFP_BOL_MTC_1_ENVD: 0.52734 V
6506 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [104] - -
                    Mileage: 157308 km
                    Date: 2019.05.03
                    Time: 13:42:47
                    Engine speed: 516.00 /min
                    Normed load value: 34.5 %
                    Coolant temperature: 98 °C
                    Intake air temperature: 60 °C
                    Voltage terminal 30: 12.288 V
                    Engine speed: actual: 1152 /min
                    MAF_ENVD: 245.11764 mg/stroke
                    Coolant temperature (unfiltered): 20.3 °C
                    Engine: operating status: IS
                    Engine load: 17.968750 %
                    Vehicle speed: actual: 0 km/h
Readiness: 0000 0001
   Part No SW: 8K0 927 156 M    HW: 0B5 927 156 E
   Component: 0B5 30TFSINAR H03 0008
   Revision: --H03---    Serial number: 0000001362
   ASAM Dataset: EV_TCMDL501 A02044
   ROD: EV_TCMDL501.rod
   VCID: 3E30CD67A1FC1CBFAB-806A
8021 - Clutch
          P2789 00 [100] - Adaptive Learning at Limit
                    Mileage: 157308 km
                    Date: 2019.05.03
                    Time: 13:30:58
                    Engine speed: 666 /min
                    Transmission input speed: 666 /min
                    Engine torque: 4 Nm
                    Transmission fluid temperature: 61 °C
                    Accelerator position: 0.0 %
                    Clutch status: Beide Kupplungen offen
8957 - Clutch 1
          P17D6 00 [104] - Pressure too High
                    Reset counter: 37
                    Mileage: 157308 km
                    Date: 2019.05.03
                    Time: 13:41:06
                    Engine speed: 596 /min
                    Transmission input speed: 596 /min
                    Transmission output speed: 15 /min
                    Engine torque: 20 Nm
                    Transmission fluid temperature: 85 °C
                    Clutch status: Kupplung 1 kann Moment übertragen
8962 - Clutch 2
          P17D7 00 [104] - Pressure too High
                    Reset counter: 37
                    Mileage: 157308 km
                    Date: 2019.05.03
                    Time: 13:39:57
                    Engine speed: 519 /min
                    Transmission input speed: 519 /min
                    Transmission output speed: 18 /min
                    Engine torque: 16 Nm
                    Transmission fluid temperature: 83 °C
                    Clutch status: Kupplung 2 kann Moment übertragen
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0010
   Coding: 290D18
   VCID: 7AB80177F554F09FD7-802E
                    Fault Status: 00101101
                    Reset counter: 54
                    Mileage: 157308 km
                    Date: 2019.05.03
                    Time: 13:39:57
                    Hex Value: 0x00C0
                    Hex Value: 0x4082
                    Hex Value: 0x0027
                    Hex Value: 0x23A1
                    Hex Value: 0x00FF
02214 - Tire Pressure Warning
                    Reset counter: 17
                    Mileage: 157328 km
                    Date: 2019.06.25
                    Time: 15:13:07
                    Hex Value: 0x4300
                    Hex Value: 0x4006
                    Hex Value: 0x1237
                    Hex Value: 0x19B0
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0326
   Coding: 0D0100
   VCID: 78BC1B7FCB58E28FA1-802C
   Subsystem 1 - Part No SW: 8T0 959 754 AJ    HW: 8T0 959 754 AJ
   Component: FBSAUDIB8 IDG  H38 0060
   Serial number: 0509000050783016
   Serial number: 0209000073092009
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Fault Status: 00101011
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.07
                    Time: 17:07:15
03285 - Sensor for Contact with Door Handle; Front Left
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.10
                    Time: 08:31:09
                    Fault Status: 00100001
                    Fault Frequency: 12
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:08:43
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 14:58:08
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01061020091259
   Coding: 66102000
   VCID: 004C739F9388AA4F99-8054
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000359769
   Coding: 26001811003CAF010000080300003D0D0F1C520800010161000000
   Shop #: WSC 06325 123 12345
   VCID: 3C34C76FBFE00EAF85-8068
   Component: WWS 021009  H06 0070
   Serial number: SWF09100020282
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10621974
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002809090578
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 13:37:00
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EGD051ZFG
   Coding: 303836354230303030304A55304C384B3053
   VCID: 42C8B997D504785FCF-8016
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Serial number: 5810000R0900004EMV
   Serial number: 6334MSME4B2239127
   Serial number: 6344MSME4B605A32F
   Serial number: 6352QSME273D0D0AP
   Serial number: 6362QSME0B3B3F28V
   Serial number: 63732SME353D5426/
   Serial number: 63832SME1D3C4A1CD
   Revision: --------    Serial number: 90319IJ2000BI
   Coding: 000036
   VCID: 3D32CA6BA4FA07A7B2-8068
                    Fault Frequency: 8
   Part No SW: 8K0 920 980 Q    HW: 8K0 920 980 Q
   Component: KOMBIINSTR.   H05 0255
   Revision: 00000000    Serial number: CJ23185A9
   Coding: 839F09000300D705020000
   VCID: 40CCB39FD3086A4FD9-8014
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E099298053
   Coding: 00C303
   VCID: 52E889D70D64E8DF7F-8006
   Component: J367-BDM  H06 0170
   Serial number: 19090299100909
                    Fault Frequency: 25
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.05.31
                    Time: 13:51:53
                    Bin. Bits:    10000
                    Voltage: 11.50 V
                    Count: 10
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 08:09:27
                    Bin. Bits:    00011
                    Voltage: 10.80 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.90 s
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:17:30
                    Bin. Bits:    10000
                    Voltage: 15.80 V
                    Count: 19
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00001010006691
   Coding: 00581B00000000000000
   VCID: 3B36C473BAEE09978C-806E
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:16:17
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 13:38:26
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009405935
   Coding: 011C13204E00410001
   VCID: 45C2A28BCC2A4F67EA-8010
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.05.28
                    Time: 12:08:19
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 14:44:32
   Revision: 00002001    Serial number: 0122016630
   Coding: 01060E3A007E440500B0010000000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000171415
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS037  H06 0041
9 Faults Found:
02771 - Bulb for Left Brake / Turn Signal / Tail Lamp (M69)
                    Reset counter: 54
                    Mileage: 157308 km
                    Date: 2019.04.30
                    Time: 20:11:06
02901 - Lamp for Brake / Blink / Parking 2; Left (M72)
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 15:27:31
02902 - Lamp for Brake / Blink / Parking 2; Right (M73)
                    Reset counter: 54
                    Mileage: 157308 km
                    Date: 2019.05.03
                    Time: 11:57:48
02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
                    Reset counter: 54
                    Mileage: 157319 km
                    Date: 2019.05.07
                    Time: 16:53:50
02742 - Bulb for Brake/Turn Signal Light; Left
                    Reset counter: 54
                    Mileage: 157319 km
                    Date: 2019.05.07
                    Time: 16:53:50
02743 - Bulb for Brake/Turn Signal Light; Right
                    Reset counter: 54
                    Mileage: 157319 km
                    Date: 2019.05.07
                    Time: 16:53:50
                    Reset counter: 54
                    Mileage: 157319 km
                    Date: 2019.05.07
                    Time: 16:53:51
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 08:09:27
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:09:25
   Part No SW: 8T0 035 223 AK    HW: 8T0 035 223 AK
   Component: DSP Prem      H08 0170
   Revision: 00008001    Serial number: 34881005584803
   VCID: 77BE1843C646EDF7A8-8022
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009449734
   VCID: 44C4BF8FC710766FFD-8010
                    Fault Frequency: 11
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:05:36
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:56:56
   Revision: 00000003    Serial number: 00000000464604
   VCID: 3424EF4F97B0C6EF4D-8060
                    Reset counter: 14
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 13:38:15
                    Voltage: 16.20 V
                    Count: 45
                    Hex Value: 0x0860
                    Hex Value: 0x0088
                    Hex Value: 0x0101
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06324 000 00000
   VCID: 77BE18430646EDF7A8-8022
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335J-097532545
   Coding: 020000010000000001
   VCID: 1D722AEB043A67A792-8048
   Part No SW: 8T1 035 664 A    HW: 8T1 035 664 A
   Component: H-BN-NA       H41 0042
   Revision: --------    Serial number: 490JZ097519411
   Coding: 010200000206A1EC41000F0C000000030000
   VCID: 3620D54781CCD4FF73-8062
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Serial number: 9356JL091080031
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000373517
   Component: CD-Database  1293
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000102027796
   Coding: 010C13204000210001
   VCID: 42C8B997DD04785FCF-8016
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 14:44:32
   Revision:             Serial number: 0000102027777
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:05:38
End----------(Elapsed Time: 01:50, VBatt start/end: 12.3V/12.3V)-----------
Checking the ATF level (per factory specs) showed that it was 0.5L low on ATF and it looked slightly brown with no burnt smell. Filled it up with OE fluid, cleared engine and transmission fault codes, here's the scan.
Wednesday,17,July,2019,13:18:07:35753
VIN: WAUKGAFL2AA069194   License Plate: AFTER CLEAR
          72
   Revision: --H06---
Readiness: 1110 0001
   Coding: 290D18
                    Reset counter: 54
                    Mileage: 157308 km
                    Date: 2019.05.03
                    Time: 13:39:57
                    Hex Value: 0x00C0
                    Hex Value: 0x4082
                    Hex Value: 0x0027
                    Hex Value: 0x23A1
                    Hex Value: 0x00FF
                    Fault Frequency: 16
                    Reset counter: 19
                    Mileage: 157328 km
                    Date: 2019.06.25
                    Time: 15:13:07
                    Hex Value: 0x4300
                    Hex Value: 0x4006
                    Hex Value: 0x1237
                    Hex Value: 0x19B0
                    Hex Value: 0x00FF
   Coding: 0D0100
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.07
                    Time: 17:07:15
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.10
                    Time: 08:31:09
                    Fault Frequency: 12
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:08:43
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 14:58:08
   Coding: 66102000
   Coding: 00FD11
   Coding: 025028
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 13:37:00
   Coding: 000036
                    Fault Frequency: 8
   Coding: 00C303
                    Fault Frequency: 25
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.05.31
                    Time: 13:51:53
                    Bin. Bits:    10000
                    Voltage: 11.50 V
                    Count: 10
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 08:09:27
                    Bin. Bits:    00011
                    Voltage: 10.80 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.90 s
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:17:30
                    Bin. Bits:    10000
                    Voltage: 15.80 V
                    Count: 19
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:16:17
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 13:38:26
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.05.28
                    Time: 12:08:19
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 14:44:32
9 Faults Found:
                    Reset counter: 54
                    Mileage: 157308 km
                    Date: 2019.04.30
                    Time: 20:11:06
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 15:27:31
                    Reset counter: 54
                    Mileage: 157308 km
                    Date: 2019.05.03
                    Time: 11:57:48
                    Reset counter: 54
                    Mileage: 157319 km
                    Date: 2019.05.07
                    Time: 16:53:50
                    Reset counter: 54
                    Mileage: 157319 km
                    Date: 2019.05.07
                    Time: 16:53:50
                    Reset counter: 54
                    Mileage: 157319 km
                    Date: 2019.05.07
                    Time: 16:53:50
                    Reset counter: 54
                    Mileage: 157319 km
                    Date: 2019.05.07
                    Time: 16:53:51
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 08:09:27
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:09:25
                    Fault Frequency: 11
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:05:36
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:56:56
                    Reset counter: 14
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 13:38:15
                    Voltage: 16.20 V
                    Count: 45
                    Hex Value: 0x0860
                    Hex Value: 0x0088
                    Hex Value: 0x0101
   Coding: 0000004
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 14:44:32
                    Reset counter: 54
                    Mileage: 157321 km
                    Date: 2019.06.21
                    Time: 10:05:38
Then went on to do the basic settings as per:
http://wiki.ross-tech.com/wiki/index.php/7-Speed_S-Tronic_Direct-Shift_Gearbox_(DSG/0B5)
After this step:
Select Erase counter for start and stop processes
[Go!] to activate the Basic Setting.
I immediately get an error:
ERROR: Request out of range
If I try to continue and do:
Select Clutch valve calibration [Go!] to activate the Basic Setting.
It runs for a few seconds and the I get an error:
Aborted for safety reasons (or something similar)
If I try to drive the car, it still jerks when in D trying to pull off sometimes pretty violently and sometimes a bit smooth. The car jerks forward, then it feels like the clutch disengages and the engine revs rise to 1000 - 1300 rpm.
It is very random. It feels very similar to a manual clutch (from back in the day) when you misjudge the engagement point of the clutch and car jerks violently and sometimes the engine stalls (here it doesn't stall as the clutch seems to disengage and engine revs rise).
There are no codes whatsoever after the only 1 clear all I have done after the fluid correction.
I tried to check all kinds of TPIs for the codes above and nothing comes up.
Of course a new transmission, clutch and mechatronic will fix it. I would like to first find out what exactly is the problem for the jerky start and for the basic settings errors (probably they are related).
Anyone has seen this or has any ideas? Thanks in advance!
DrPeter
16.4905° S, 151.7375° W
Yes, there does appear to be several Technical Service Bulletins from Audi factory service information/repair manuals that detail flash updates for the Transmission Controller, VAG# [8K0 927 156 M].
Here is one of the latest one I have found:
Technical product information Transaction No.: 2027286
Jerk when changing from 2nd to 1st gear, S-tronic
SW version 0008 has been updated to (at least) 0012
Hope this helps,
drpeter
NostraJackAss
Yeah and isn't this under useful life warranty too?
Nice post Peter!
OP you better read the whole JPPSG
MIL + clutch smell + call up = FREE Repair?
Grigor
C?ID=118822
drpeter
Thanks Peter! Indeed this is what I found a few minutes after posting, updated to 0012 and clutch engagement was a lot better, but still every now and then super jerky. I assume that there is a problem with either the clutch, mechatronic or something between them. Is there any way to test which one exactly is the problem?
Nice post Peter!
I read it. There is no clutch smell, but in any case do you mean that Audi has extended warranty on this? If so, how do you know besides obviously calling the dealer? Thanks!
NostraJackAss
Ask yourself this question okay?
Isn't the fact that the car is covered under useful life warranty & software was considered incorrect & from the beginning, further needed change so many times a reason & to request it be covered under warranty for defect or even recalled?
DrPeter
There is a document on erWin Audi called "Servicing-7-Speed Dual Clutch Transmission 0B5 (S tronic)", I suggest having a look at that.
There does not appear to be any specific tests, however there is a lot of information on the "Disassembling and Assembling" of the transmission and this may help with the inspection of specific components.
Check the basics! Starting with fluid level and quality....
You really have only two choices, call any NAR Audi dealership or contact Audi North America - Warranty, the source of the information is from the manufacture, they will be able to use your VIN number and verify if there is any open recalls, campaigns or extended warranties that may exist.
drpeter
Donibcsi
Hungary
C?ID=28126
I got same fault code after I changed clutch. The clutch was slide before I changed, there was not any other issue. After I finished change the K2 clutch can not finished adaptation and I got this fault code P2789. I did it with ODIS and when I finished adaptation, ODIS said I must to change the whole transmission!!! Before I started to fix the slippery issue there was not this problem.
I changed to the another new clutch I thought the new clutch has a problem but the issue is came again with the second clutch again. I do not have more idea.
ATF level and quality is ok.
I ready changed the clutch on another car in same time and there is no problem its working fine.
Thanks fort any idea.
