Polo 1.2 tdi 2014 year delphi dcm 3.7
emin
Turkey
C?ID=341393
sometime lose 1 and 3 injector signal and car not working
I see same problem 2 times in my history in different cars..but not fixed..
vcds not any dtc..in engine ecu,also I make .frf update to last version but still this error..
may be anyone found solution..thanks
btw: car came from diesel shop..its not inj error,also seem not dpf or egr error too ,because we remove exhaust too
emin
Turkey
C?ID=341393
Please post an Auto-Scan for context, even if the are no DTCs.
Hello Boss
here autoscan...no dtc..I was tried remove egr pipes,connectors,dpf pipes exhaust too...but car same...
problem may be mechanic too..But I dont have any expeirence before on it..Help please
Saturday,20,July,2019,18:08:45:11570
VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
Dealer/Shop Name: beyinci.com
Workshop Code: 389 04501 103077
VIN: WVWZZZ6RZBY262994   License Plate:
Mileage: 140370km-87221mi   Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 15 17 19 25 44 56 61
VIN: WVWZZZ6RZBY262994   Mileage: 140370km-87221miles
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9980
   Revision: 12005001    Serial number:
   Coding: 00114014032401080000
   ASAM Dataset: EV_ECM12TDI03103P906021B 001043
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 271E02265EC02677F8-8072
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210224E3417300B4842E24EB82D500521300
   Shop #: WSC 00788 648 00255
   VCID: 075E62A6B2000677D8-8052
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 3228E3726D0253DF5F-8066
   Part No SW: 6R0 937 088 D    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H46 0322
   Revision: BU046001    Serial number: 0379 062110025
   Coding: 24B02BBF08A10000003009B03C2B0CD0CF80610F7E860441A00000000000
   VCID: 3FCEBA46AE508EB7A0-806A
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  007 1611
   Serial number: KU0KU024021100012698
   Coding: 58BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  007 1611
   Serial number: KU0KU002031100010124
   Coding: 48BC30
   Subsystem 3 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Serial number: KU0KU028021100010036
   Coding: 48BC32
   Subsystem 4 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  007 1611
   Serial number: KU0KU001031100011989
   Coding: 48BC32
   Part No SW: 6R0 959 655 J    HW: 6R0 959 655 J
   Component: VW10Airbag00E H09 0020
   Revision: --------    Serial number: 003GW00412V3
   Coding: 003045
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 49DAA49EE89430070E-801C
   Part No SW: 6R0 920 861 F    HW: 6R0 920 861 F
   Component: KOMBI         H05 0304
   Coding: 140800
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
   VCID: 383CD15A837EB98F61-806C
Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H38 0025
   Revision:   H38       Serial number: 110211F1002309
   Coding: 2500C2
   VCID: 3326E67692185AD754-8066
01304 - Radio
                    Reset counter: 204
                    Mileage: 140376 km
                    Date: 2013.12.10
                    Time: 17:49:09
   Component: IMMO          H05 0304
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A983B128D52DB1F27-803E
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F2EEA06EA307E3730-807A
Address 56: Radio
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0025
   Coding: 03031A5A
   VCID: 74A4256AD7961DEF8D-8020
   Subsystem 1 - Part No SW: 6R0 915 181 B    HW: 6R0 915 181
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370594572
End----------(Elapsed Time: 00:58, VBatt start/end: 12.4V/12.4V)-----------
emin
Turkey
C?ID=341393
solved myself,special thanks to me :)
iichel
Eindhoven, NB, NL
C?ID=284912
Interesting to see it didn't show as a DTC. Good you fixed it
