Hello
Neil73
I have a Mk7 golf and have been trying to get footwell lights fitted. I have followed a guide for this using vcds. Now I have no lights on the interior or the puddle lights on the mirrors. Is it possible that I have turned these off accidentally?? I have checked all fuses and seem ok.
Any help would be appreciated.
Neil
South Molton, UK
What coding/adaptations have you changed with VCDS?
A full Auto-Scan would be a starting point for us to help you.
Neil73
Will post one up. Thanks
Neil73
Hello, Please see scan below. Hope you can see it.
Sunday,14,July,2019,14:35:03:24573
VIN: WVWZZZAUZFP598083   License Plate: N666HWL
Mileage: 112863km-70129mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFP598083   Mileage: 112863km-70129miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 7635
   Revision: 84H22---
   Coding: 01110012034505092000
   Shop #: WSC 00028 028 00074
   ASAM Dataset: EV_ECM16TDI01104L906021M 002012
   ROD: EV_ECM16TDI01104L906021P.rod
   VCID: 2F3B10CC1798B3AF633-807A
17158 - Databus
          U1123 00 [040] - Received Error Message
                    Mileage: 112806 km
                    Date: 2019.07.13
                    Time: 00:05:22
                    Engine speed: 0.00 /min
                    Coolant temperature: 44 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 12.160 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Acceleration: 0.000 m/s²
          U0428 00 [040] - -
                    Mileage: 112806 km
                    Date: 2019.07.13
                    Time: 00:05:21
                    Voltage terminal 30: 12.220 V
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 60345000001046
   Coding: 04FA8AA1242909740777060841C62520512490E06082A4F31440F078C002
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7EA5FD8880728A27B85-802A
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 20
                    Mileage: 112806 km
                    Date: 2019.07.13
                    Time: 00:05:22
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 139
                    Mileage: 109030 km
                    Date: 2019.02.23
                    Time: 12:09:11
16412 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 21
                    Mileage: 112806 km
                    Date: 2019.07.13
                    Time: 00:05:32
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 21
                    Mileage: 112806 km
                    Date: 2019.07.13
                    Time: 00:05:32
   Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
   Component: AC Manuell    H02 1001
   Revision: 00001K06
   Coding: 02120104202100001000000000000000
   Shop #: WSC 00028 028 00067
   VCID: 3C213780D6EE5837D61-8068
   Part No SW: 5Q0 937 086 AC    HW: 5Q0 937 086 AC
   Revision: --------    Serial number: 86581901150701
   Coding: 07000842C2C1027B0BA44080B10403281008000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7BA3F49C93609F0F9FB-802E
   Component: WWS    150115  042 0551
   Serial number:         150122023223
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y15M01D26H06M19S58
   Coding: 00A8DD
   Serial number: 000000000ZY150140ENQ
   Serial number: 00000000000061534146
8 Faults Found:
919560 - Light Switch
          B126A 29 [136] - Signal Implausible
                    Reset counter: 21
                    Mileage: 112840 km
                    Date: 2019.07.13
                    Time: 06:00:30
460041 - Heated Rear Window
          B1265 14 [008] - Open or Short to Ground
                    Reset counter: 21
                    Mileage: 112840 km
                    Date: 2019.07.13
                    Time: 06:00:30
132619 - Voltage Supply; Terminal 30; Right
          B140E 13 [008] - Open Circuit
                    Reset counter: 21
                    Mileage: 112840 km
                    Date: 2019.07.13
                    Time: 06:34:55
132363 - Voltage Supply; Terminal 30; Left
          B140D 13 [008] - Open Circuit
                    Reset counter: 21
                    Mileage: 112840 km
                    Date: 2019.07.13
                    Time: 06:00:30
133131 - Voltage Supply Terminal 30
          B1423 13 [008] - Open Circuit
                    Reset counter: 21
                    Mileage: 112840 km
                    Date: 2019.07.13
                    Time: 06:00:30
525056 - Production Mode Active
          U1103 00 [009] - -
                    Reset counter: 0
                    Mileage: 112840 km
                    Date: 2019.07.13
                    Time: 06:00:30
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [009] - Alert Emergency Activation Stage 1
                    Reset counter: 236
                    Mileage: 112840 km
                    Date: 2019.07.13
                    Time: 06:36:51
565764 - LED Light Bar
          B1664 31 [009] - No Signal
                    Reset counter: 236
                    Mileage: 112840 km
                    Date: 2019.07.13
                    Time: 05:27:56
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391502007979
   Coding: 0071051001
   VCID: 3D273A84CDF4513FE1F-8068
13637426 - Databus
                    Reset counter: 21
                    Mileage: 112806 km
                    Date: 2019.07.13
                    Time: 00:05:22
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 04011503212077
   Coding: 00000300FE0739
   VCID: 38292B90E2D67417329-806C
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 21
                    Mileage: 112806 km
                    Date: 2019.07.13
                    Time: 00:05:22
                    Control Module temperature: 21 °C
                    Voltage terminal 15: 12.2 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 21
                    Mileage: 112806 km
                    Date: 2019.07.13
                    Time: 00:05:22
                    Voltage terminal 15: 12.1 V
1078 - Databus
          [FAULT_CIS_SAS_INIT]
                    Reset counter: 21
                    Mileage: 112806 km
                    Date: 2019.07.13
                    Time: 00:05:23
1043 - Automatic Distance Control
          B10E7 F0 [008] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 22
                    Mileage: 112806 km
                    Date: 2019.07.13
                    Time: 00:05:22
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR0BSC83
   Shop #: WSC 00028 028 00064
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F5B008C8778832FB33-802A
   Belt Pretensioner left:
   Serial number: 34169677B29011541565
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676B30011571383
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 901 15
   Serial number: 3576700000053575F21S
   Subsystem 4 - Part No SW: -----------    HW: 480 002 901 15
   Serial number: 358670000001D375F21X
   Subsystem 5 - Part No SW: -----------    HW: 480 402 801 15
   Serial number: 3516502B51901D92C1DD
   Subsystem 6 - Part No SW: -----------    HW: 480 402 801 15
   Serial number: 3526502C9192BC70226A
   Subsystem 7 - Part No SW: -----------    HW: 480 402 801 15
   Serial number: 3556502A71901D9140D8
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 21
                    Mileage: 112806 km
                    Date: 2019.07.13
                    Time: 00:05:23
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150125400158
   Coding: 0C00
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 41DF4674B10C35DF857-8014
   Part No SW: 5G1 920 941     HW: 5G1 920 941
   Component: KOMBI         204 4270
   Coding: 27A512002780260001886A011400000000000000
   VCID: 6695B5E8F8E232E7505-8032
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Reset counter: 125
                    Mileage: 107323 km
                    Date: 2018.12.08
                    Time: 13:13:15
   Revision: --------    Serial number: 31011510800175
   Coding: 030100040F087300EF00005C080F00010001050000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72BDD9B8C42ADE47CCD-8026
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150000154740065051
   Coding: 2CFFFF
   Serial number: 8758365303
131659 - Door Control Module - Passenger's Door
          U0200 00 [008] - No Communications
          [Timeout Knoten 0x4B / 52 - Türsteuergerät Beifahrerseite]
                    Reset counter: 21
                    Mileage: 112840 km
                    Date: 2019.07.13
                    Time: 06:34:59
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: OFF
   Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
   Component: TSG FS        009 0015
   Serial number: 0000133918880
   Coding: 00310220D001028000001000
   VCID: 45D75264A52419FFB9F-8010
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000007894654
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 8102
   VCID: 43D34C7CAB1027CF97B-8016
12289 - Supply voltage
          [Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung (<5.5V für 3ms: KL50=0]
                    Mileage: 112840 km
                    Date: 2019.07.13
                    Time: 00:00:01
                    Motor status: 00
                    Supply voltage: 7.25 V
                    Temperature: 17.0 °C
                    KFC: 30
                    KFA: 00 01
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 5.11 V
                    uAdSensI_SwitchedKl30_xdu16: 5.11 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0015
   Serial number: 0000135176896
   Coding: 00310020DE01028000801000
   VCID: 44D14F60AE1E20F7AE1-8010
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000007792626
   Coding: 050000
   Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
   Component: MU-S-D-ER     041 0421
   Serial number: V5C02901151851
   Coding: 02730200FF00000021111201000800001F0100060100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 1F1BE00C6738232FD33-804A
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H60 0030
   Serial number: VWZ8Z9RS206ZXA
End----------(Elapsed Time: 01:36, VBatt start/end: 12.3V/12.3V)-----------
grant@gendan
You seem to have a number of Supply voltage (terminal 30) issues showing in the (09) Central Electric module.
These need to be investigated and fixed.
Was the guide you followed definitely for your model and year of car?
You need to have a good look at the new wiring to see what has caused these faults.
Neil73
Ok will have look. The guide I followed did say it was suitable for my car. Thanks
Neil: To add to the responses that you have already received from Grant - and for the simpler matter (I suspect) of the puddle lights- here's a more readable version of the code string on the Passenger door module @hex52:
Byte	Hex	Binary
0	00	00000000
1	31	00110[b]0[/b]01
2	00	00000000
3	20	00100000
4	DE	11011110
5	01	00000001
6	02	00000010
7	80	10000000
8	00	00000000
9	80	10000000
10	10	00010000
11	00	00000000
I've highlighted Byte1, Bit2 -which should be set for puddle light operation. (it's obtusely called "exit light" in the Long Coding Helper screen).
So- Byte1 should be hex35 and the same for the Driver door module @ address hex42)
Neil73
Thanks Don, I have had a guy look at with a different dealer level software and the interior lights now work, but not the puddle lights. I will look at your information and see if I can see why. Many thanks.
Neil
Neil73
Puddle lights now working. Thanks to everyone who has given advice. Now cam someone point in the correct direction for a guide on trying again to get the footwell lights working.
Thanks Neil
Neil - good to read about your success with the puddle-lights!!
Please help me with my confusion: what part of the seemingly diametrically-opposite positions in your 2 x posts below have I failed to understand (the blue bold bits)?
Neil
Thanks Neil
Neil73
Hi Don. The issue started by try to code in the the footwell lights. I have reversed what I did initially and the chap who looked at it has then got me back to where I started, with just the original lights working. Now I would like to try and get the footwell lights working.
Hope this makes sense.
Neil
Neil73
Don, just to add I followed a guide for a Skoda that I was told would be ok for my golf. I have looked for a guide for the golf and can't see one. In hindsight I should have asked on here first but you live and learn.
Neil: OK - I'm not sure that I can help, but further facts about your retrofit (I assume that this was a retrofit) might illicit more suggestions from others here.
First, can you confirm that the footwell lighting kit that you purchased included a wire that you connected to pin#72, socket C on the BCM?
Also, and as I understand, stuff changed on BCM s post about MY16: on previous control modules, the software switch for the footwell lights was Byte 17, Bit 3 (this was enabled on your previous auto-scan) - and there is also a second software switch on Byte 5, Bit 7 but on many auto-scans that I've seen (like my early model mk7 which had factory footwell lights) this is not set. On the newer BCM s the software switch was "adaptation-ised" in the channel IDE09732-ENG114629-Interior light: light configuration-Foot well lighting - this happened regardless of whether the BCM has a zero-code string, or not.
And finally - irrespective of BCM type, the Leuchte-set for pin72C on the BCM (which of course was deactivated at the factory) needs to be enabled like this - assuming that the retrofitted lamps are LED type):
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	100
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	46 - LED Kleinleistung
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active
So, perhaps if you clear the current DTC s from your car - and re-post a new unedited auto-scan so we can see what changes were made by "the chap who looked at it" and also post an adaptation map of the BCM.
